HC3 & HC3L - 5.081.18 - BETA - 14/10/2021
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Important Notices:
This version focuses on system performance optimisation and fixes for existing features.
Main features:
1. Performance Improvements
Enhanced speed and responsiveness of the interface for better user experience.
Removed storage of unnecessary data to save more system resources.
2. Bug Fixing
Critical fixes for gateway connection feature.
Resolved heating-related issues.
What's new:
    Alarm
        Unlocked creating alarm zones for all types of binary sensors.
        Possibility of changing and setting custom icons for Satel outputs and zones.
    Dashboard
        Reduced time of loading device tiles.
        Loading subsequent items with scrolling.
    Devices
        Reduced time of loading device rows.
        Loading subsequent items with scrolling the list.
        More available icons based on device hierarchy.
        Possibility to disable saving of device energy to the database.
    Elero*
        Correct handling of the ongoing device pairing process.
        Regionalization of available features based on gateway frequency.
    Energy
        Comparing the same time periods on the Savings tab.
        Chart of savings since the date of installation.
        Interval for storing virtual energy measurement reduced to five minutes.
        More user-friendly installation cost removal.
    Gateway Connection
        Information that the gateway is ready to use as a slave.
        Information on incompatibility due to a different version of the Z-Wave engine.
    General
        Possibility of choosing more than one main energy meter.
    Nice*
    Other
        Four new language versions of the recovery interface (DA, HU, LT, RU).
        Added missing translations for several language versions.
    Performance
        Removed storing the charts-related data into RAM.
        Reduced redundant requests to api.
Bug fixes:
    Dashboard
        Unresponsive interface and long loading times for large systems.
    Devices
        Device after reconfiguration changes its name, ID, and room assignment (ZW3).
        Possibility of starting a few reconfiguration processes for one device (ZW3).
        Removing queued action of setting parameter if the device entered sleep mode (ZW3).
        Overriding the temperature set in heating schedule is not possible for FGT-001 (ZW3).
        No support for FIBARO Heat Controller error notifications (ZW3).
        No support for com.fibaro.hvacSystem device type (ZW3).
        Incorrect support for MCO MH10, MH-S31x, MH-S41x devices (ZW3).
        Thermostat in Auto mode added as linked device does not operate the switch correctly.
        Some endpoints belonging to multifunctional devices (e.g. thermostats) are missing.
        Virtual power metering value does not change after its editing.
        Configuration parameter value is not refreshed after resetting.
        No units for sensors connected to FIBARO Smart Implant.
    Energy
        Sum of energy consumed by all devices is not calculated properly.
    Gateway Connection
        No possibility to restore backup with previous software version.
        State of devices added to slave gateway does not update and gateway needs rebooting.
        Incorrect mapping of devices connected to FIBARO Smart Implant added to slave gateway.
        No possibility to configure virtual power metering for devices added to slave gateway.
        Incorrect support of FIBARO RGBW Controller added to slave gateway.
        No possibility to select category for devices added to slave gateway.
    Notifications
        Devices that are discharged or unavailable still trigger notifications.
    Other
        VoIP feature does not work.
    Profiles
        Action assigned to the Quick App button does not start after switching the profile.
    Scenes
        Creating new global variable does not allow to use it in scenes.
Known issues:
    Z-Wave Engine 3.0
        Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
        Gateway connection is not available in the new Z-Wave engine version.
*  - does not apply to HC3L (Home Center 3 Lite
Version installée sur mes 3 machines, il n'y a pas dire c'est plus fluide partout, sauf sur le dashboard principale où je trouve le nouvel effet(?) un peu perturbant. A vrai dire je ne sais pas si c'est réellement un effet ou une contournement technique pour soulager l'écran/ram/proc ? a vous d'apprécier, peut être une question d'habitude...
Pour le reste c'est vraiment mais alors là vraiment très rapide et fluide.
Pour ceux qui ont du satel integra les icones sont enfin de retour !
A voir maintenant sur la durée.
@Dragoniacs Je ne suis pas un afficionados de l'appli, je viens d'y jeter un coup d'oeil et ça rame toujours autant. Ce ci dit, j'ai un iphone qui date de la dernière guerre et qui ne doit plus supporter totalement certain composants, sur mon ipad je ne vois pas de différence.
Installé sur ma box de dev, effectivement c'est plus rapide, même si la différence n'est pas flagrante car je n'ai pas beaucoup de modules dessus (essentiellement des QA)
Niveau occupation RAM il y a eu une belle optimisation, ça a bien baissé :)
Regardez le "used" en gris :
Soit 28% utilisé sur ma box de dev :
  • Like 3
Il y a 1 heure, Lazer a dit :
oui 100% d'accord avec toi , voilà pour moi : (61 modules Zwave)
Modifié par ericl78
Je vais tester alors.
Ça sera la première fois que j'installerai une bêta.
Mais avec moult sauvegardes avant bien sûr ...
Ma HC3 est en prod depuis le début, et je n'ai rien (enfin pas grand-chose) à redire.
Juste une scene d'info météo qui "pushe" un bulletin toutes les heures. Le problème c'est qu'elle ne démarre pas automatiquement dès le passage au jour suivant (je dois la lancer manuellement - ensuite ca rooouuule pour le reste de la journée !).
Mais je verra cela quand les travaux seront finis (si, si, ça vient ..!).
Modifié par Sowliny
Mise à jour faite avec succès !
Quoique j'ai eu un blocage (encore oui..., mais cela n'est pas dû cette version beta) au reboot après la m.à.j., qui a été résolu par un débranchement barbare de la prise d'alimentation (même le bouton arrière n'avait plus aucun effet).
Ensuite redémarrage gentil...
