HC3 & HC3L - 5.080.9 - Stable - 29/07/2021
Stable
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Important Notices:
The following software update removes energy data collected during the use of versions lower than 5.072 beta due to a changed strategy for handling reports.
For all Z-Wave devices which feature meter capabilities (power, energy, gas, water, etc.) soft-reconfiguration procedure is required due to improvements in support of those device types (not applicable to updates from version 5.072 beta).
Update 5.080 includes a new version of the Z-Wave software (called Z-Wave 3.0). This version features expanded default device support, the ability to add products using Smart Start technology and many other changes. Please note that this is a beta version engine and its compatibility will be developed with further updates - not all Z-Wave devices are fully supported.
ATTENTION - installing version 5.080 does not automatically change the existing Z-Wave 2.0 software to 3.0. In order to run version 3.0, it is necessary to restore the gateway to factory settings, requiring the system to be configured from scratch. In future updates we will work on extended device support and provide a mechanism to migrate your current system configuration to the new Z-Wave engine.
Main features:
1. Z-Wave Software 3.0
New Z-Wave engine version 3.0 - in order to use it is necessary to configure the system from scratch. Currently it is not possible to migrate the system in version 2.0 (current) to version 3.0 (new).
Version 3.0 includes the following changes:
Simplified mechanism for adding devices (Smart Start).
Support for improved encryption mechanisms (Security S2).
Streamlined process of advanced device parameters configuration.
Possibility to update device software from a file.
Extended compatibility of Z-Wave devices (more devices, additional features).
2. Yubii Ecosystem (Home Center 3 & Yubii Home)*
Changes to the Yubii Ecosystem device support:
New features related to operating speed for selected devices
(also available from block scenes and notifications).
Support for further Nice devices.
Support for configuring device parameters.
Redesigned configuration wizard.
3. Energy Panel
The first part of functionalities we are providing in the brand-new Energy Panel:
Eye-catching energy data visualisation interface.
Preview of energy data generated by devices using renewable energy sources.
Preview of individual and aggregated data related to energy consumption at home.
New Savings tab and Panel Settings window.
Caution: the data presented in the Energy Panel is only an estimate due to the measuring accuracy of the devices involved in the calculations.
4. Gateway Connection
We have introduced a mechanism for linking HC3L and Yubii Home gateways. It is possible to connect a master HC3 with HC3L or Yubii Home, which operate in slave mode. This allows to create a smart home system based on HC3, HC3L and YH products. Please note that the master panel can only be HC3. Note - linking of control panels only works within the Z-Wave 2.0 engine.
What's new:
Access
Tooltip with description on user synchronization button.
Alarm
Brand new alarm control dashboard, available to any user.
Possibility of arming and disarming individual zones and the entire house.
Information on the zone tile how much time has elapsed since arming/disarming/alarm.
Backup
Column with backup size information.
Information in api about the Z-Wave engine version on which the backup was created.
Warning before restoring a backup contains the Z-Wave engine version when it differs.
Space for cloud backups is increased by 25MB on master HC3 for each connected gateway.
Climate
Wider range of temperature to be used in schedules.
Dashboard
Icon in the header indicating that there is no internet connection.
Device limit on YH/HC3L replaced with a recommendation of their maximum number.
Correct scrollbar in the main menu.
Live refreshing the value on the right device control panel.
Devices
Notification of required device reconfiguration after its updating.
Possibility of interrupting a queued device update process.
Possibility to set a favourite position for grouped roller blinds.
Refreshed Z-Wave configuration parameters support if selected the new Z-Wave engine.
Info on the Advanced tab about the security level the device was added with.
Marking devices added in security mode with a lock icon.
Increased the limit of 20 characters for the device name to 60 characters.
Improved operation and support of power and energy meters.
Added support for upcoming firmware updates of FIBARO Heat Controller (FGT-001).
Support for FIBARO Smart Implant (FGBS-222) version 5.2.
Changed the default icon, role and category of the Rehau RE.GUARD device.
Possibility to upload the parameters template to Z-Wave device from .json file (ZW 3.0).
Possibility to delete parameters template which overrides the official template (ZW 3.0).
Extended list of official templates for Z-Wave devices (ZW 3.0).
Support of scale and unit for Z-Wave devices in parameters templates (ZW 3.0).
Console log of detecting the Z-Wave device and starting the adding process (ZW 3.0).
New mechanism of devices calibration (ZW 3.0).
Restoring the default device icon if uploaded icon no longer exists.
Changes in energy data component on device advanced tab.
Availability of configuration parameters based on device interfaces.
Possibility of setting the virtual power metering and using it in energy panel.
Support for Heatit Z-Smoke Battery version 4.1/4.2.
Support for Qubino 3-Phase Smart Meter.
Elero*
New category of devices in adding process.
Pairing of Elero devices possible with the new adding wizard.
Dedicated section in the main settings menu for Elero and Nice.
Energy
Brand new energy panel, available to any user.
Support of devices that consume and produce electricity.
Display of production, consumption, and energy balance for selected time period.
Comparison of the energy balance for the last three time periods.
Top three devices that consumed the most energy during the current time period.
Detailed energy consumption data displayed by room or device category.
Filtering of detailed energy consumption data by room or device category.
Panel Settings window which allows to configure more options related to costs.
Possibility to choose the billing period by setting its length and start date.
Possibility to set up the tariff by choosing the currency, main rate and additional rates.
Possibility to set up the installation cost and installation date.
New Savings tab including summary of consumption and energy balance in time.
Toggle switch on General and Savings tabs to display data in kWh or using set currency.
The interval for storing historical energy data changed from one hour to 15 minutes.
Displaying the energy balance from the main energy meter if configured.
Gateway Connection
Possibility to use Yubii Home and Home Center 3 Lite as slave gateways.
Adding and removing devices on connected YH or HC3L from the master gateway.
Possibility to add slave gateway connected to subnet used by master in Wi-Fi connection.
Blocked connecting of gateways with new version or different versions of Z-Wave engine.
General
Possibility of setting m/s as a wind speed unit.
Accepting global variable values longer than 20 characters.
Setting the main energy meter available for devices with specified interface and rate type.
History
Enlarged clickable area on the button with information about new events.
Nice*
Support in scenes for actions with specified roller blind movement speed.
Notifications available as scene triggers.
Possibility of setting the configuration parameters.
Redesigned wizard of adding new devices.
Dedicated section in the main settings menu for Nice and Elero.
Notifications
System notification for possible scene update when wind speed unit has changed.
Other
Saving the name of device or scene after pressing the enter key.
New, Danish language version.
Current Z-Wave engine (version 2.0) selected by default on engine selection window.
Plugins
Added Husqvarna Automower plugin with support in scenes.
Quick Apps
New variable type - secret variable, designed for passwords.
Scenes
Capability of creating multi-line messages for e-mail and push notifications.
Z-Wave
Possibility to select the Z-Wave engine version after resetting to factory settings.
Bug fixes:
Access
Mobile devices assigned to removed users are not deleted or reassigned.
Backup
Unexpected new line character in backup description.
Incorrect Z-Wave engine version in uploaded local backup (ZW 3.0).
Cameras
Image from a camera using digest authentication does not arrive via e-mail.
Preview tab is not active after saving the paths and address of IP camera.
Dashboard
Negative values greater than -1 are displayed as positive.
Rebooting the gateway results in resetting the counter of used devices.
Incorrect rounding of values with at least 2 decimal places.
Devices
Changing the temperature sensor belonging to linked device does not activate the heating.
Door lock may be in wrong state right after being added.
Inverted state logic for door lock custom icons.
No possibility to configure endpoint as output when configured as input before.
FIBARO Walli Controller (FGWCEU-201) does not work in security mode.
Incorrect value of parameter 14 for Heatit Z-TRM2fx.
No possibility to add custom icons after factory reset of the gateway.
In some cases, removing the device from the Z-Wave network fails (ZW 3.0).
For some devices setting the association fails (ZW 3.0).
Incorrect multichannel reports handlings (ZW 3.0).
Incorrect descriptions of parameters in Heatit Z-TRM3 device template.
No possibility to switch off indications from the device for the energy panel.
Elero*
Device after binding is always assigned to default room.
After adding and performing one action, the device is unavailable and does not respond.
Energy
Some data is not displayed when using the remote access connection.
Energy consumed by a device with virtual power measurement is not saved each 15 minutes.
Gateway Connection
Master gateway does not update the device states after rebooting slave gateway.
History
No icons and labels for some events and actions.
No units for values reported by multilevel sensors.
Network
Access Points of the same network are displayed as separate Wi-Fi networks.
Wi-Fi network unexpectedly disconnects, and gateway retries to obtain an IP address.
Wi-Fi module is always switched on after reboot of the gateway.
In some cases, connecting to Wi-Fi network fails.
Nice*
The stop action for grouped roller shutters does not work.
No possibility to add a device for which the adding process was interrupted earlier.
Error when trying to control several shutters simultaneously.
No translations for notifications in block scenes.
No possibility to create and edit scene with Nice device.
Notifications
E-mail notifications for addresses containing a plus character are not sent.
Other
Tooltips do not disappear automatically and cannot be closed by clicking on them.
Swagger is available via remote access but is useless.
Z-Wave service status in Installer App is displayed incorrectly.
Translations on Yubii Home are not generic and refer to FIBARO Home Center.
Performance
Problems with gateway start-up on large systems (ZW 3.0).
Plugins
No display of data stored in the Dahua plugin.
Unable to trigger a scene via Satel alarm outputs.
Some Sonos devices are not discovered by the plugin.
Blocked UDP ports prevent the detection of some devices on the network.
Fibaro Heat Activator plugin does not work (ZW 3.0).
The plugin view is not available in the mobile app.
Profiles
Buttons of Quick Apps which are available in scenes are not available in profiles.
No actions available for devices (ZW 3.0).
Quick Apps
UI elements do not refresh when changing properties.
Action setColor does not update the colour property of colorController device type.
Error after updating the Quick App file containing a hyphen in its name.
Save button is active even though there are no changes.
The Quick App view is not available in the mobile app.
Scenes
No possibility of creating scene with action for group of devices.
Incorrect interpretation of home arming status based on the status of the partition.
No possibility to set scene with push notification if user with mobile device was removed.
Incorrect property set when selected the disarmed condition block.
Incorrect actions in block scenes for FIBARO Intercom.
Update
Insufficient timeout for requesting gateway update status.
Never ending loader on devices update page when no devices to be updated (ZW 3.0).
Known issues:
Energy
No energy data collected during the use of versions lower than 5.072 beta.
The ROI calculation functionality does not include a quantity factor.
New Z-Wave engine 3.0
Overriding the temperature set in heating schedule is not possible for FGT-001.
The schedule overwrite functionality of Z-Wave thermostats does not work properly.
Not all Z-Wave devices are fully compatible with the new version of Z-Wave engine.
In some cases, device adding/removing fails - gateway needs rebooting to retry.
Gateway connection is not available in the new Z-Wave engine version.
No support for FIBARO Heat Controller error notifications.
* - does not apply to HC3L (Home Center 3 Lite)
  • Thanks 3
Woaw! Et ben, ,il assure en ce moment avec des sorties aussi rapide de différentes version!
Depuis le 17 juin, on a eu 3 béta et maintenant une stable!
Ils ne sont partis en vacances chez Fibaro?:2:
oui, mise à jour effectuée, ras.
Il semble qu'ils ont corrigé le prb de lenteur d'ouverture de la page des appareils.
Installée depuis hier soir 18h00 RAS OK
Version installée. Pas de souci.
Par contre, c'est quoi ce binz où il faut être en clavier ENG pour pouvoir avoir un tarif en décimal car le '.' français n'est pas pris en compte ?
Voilà ... :D
Je vais attendre un ou deux jours avant de procéder.
Il faut que je stabilise d'abord mon développement actuel.
Ce qui me titillait était l'impact de la mise à jour du moteur z-wave sur, par exemple, le paramétrage des modules...
Mais au vu des posts précédents, ça se passe de façon parfaitement transparente... personne ne relate d'incident.
Quoi qu'il en soit, ça fait une sacrée liste à étudier très attentivement.
Vraiment, y faut... mais ça prend (beaucoup) de temps (j'ai juste commencé !).
Surtout je pense à la section relative au moteur Z-wave 3.
C'est une mise à jour indépendante semble t'il de cette version 5.080. Avec une procédure particulière.
Et le "reste" mérite aussi une attention très soutenue. Impressionnant comme nouveaux apports...
On pressent maintenant ce que pourra devenir la HC3, très loin de notre ancien "monde HC2", et de son intégration (non, j'ai pas dit "noyade"...) au sein de l'écosystème Nice.
J'ai eu aussi ce problème avec les une ou deux premieres versions, mais depuis la 5.nnn, plus rien...
As-tu effectué un reboot "à froid" ?
Je m'explique : éteindre la box avec son bouton, puis débrancher l'alim quelques dizaines de secondes.
Rebrancher, et la box redémarre.
Je procède comme cela, car il arrive (souvent) que le reboot, et même l'extinction/redémarrage ne suffisent pas lors d'un comportement "erratique".
Cela dit, je n'ai pas encore installé la 5.080...
Modifié par Sowliny
J’avoue que moi aussi la mise à jour du moteur Z-wave ne me rassure pas… A priori ce n’est qu’une mise à jour en tâche de fond, le moteur n’est pas actif, sauf à faire un full reset de la box… Donc pas trop de danger (enfin… pas plus que d’habitude ^^).
Mais comme la box est hyper stable depuis la dernière MAJ, j’hésite…
Euh, dès fois que le journal des nouveautés ne soit pas clair :
Le nouveau moteur Z-Wave v3 n'est pas une mise à jour.
Le nouveau moteur Z-Wave v3 n'est accessible qu'après une réinitialisation complète de la box, et après avoir spécifiquement choisi le moteur Z-Wave v3 lors de l'assistant de démarrage (sachant que le moteur v2 reste celui sélectionné par défaut)
Quoi qu'il en soit, même pour ceux qui font le choix de faire une nouvelle installation avec ce nouveau moteur Z-Wave v3, cela reste une première version qui n'est pas exempte de bugs... à réserver aux plateformes de tests, et éviter la production.
Pour les systèmes existants, la migration du moteur v2 vers le moteur v3 sera proposé ultérieurement par Fibaro.... d'ici l'automne environ (plus ou moins un certain retard)
Bref, vous pouvez faire cette mise à jour 5.080.9 sans crainte (mais on n'est jamais à l'abri d'un bug quelconque).
  • Like 3
Bonsoir @Lazer,
Le journal des nouveautés est très clair, et je n'avais que vaguement étudié ce passage (d'accord, très important).
Je vais donc faire la mise à jour vers la 5.080... dans quelques jours.
Je suis également ton conseil en ce qui concerne le nouveau moteur Z-wave, car ma HC3 est en prod depuis le début (oui, un peu fou).
J'avais complètement adapté mes scripts HC2, et fait la bascule en quelques jours. Compte-tenu de la faible complexité des scènes (éclairages), cela n'a pas posé de gros problèmes.
Mais j'en ai bavé avec les premières versions !!!
Mise à jour effectuée en 5.080.9
Seul problème, j'ai pour l'instant perdu la possibilité de gérer mon portail Nice Robus 600 depuis la HC3. Les commandes ne répondent plus même après un réinstallation.
J'ai ouvert un ticket Fibaro.
Nouveau sur le forum et HC3, j'ai tenté la mise à jour (je sais, c'est fou...).
Jusque là, tout va bien, mais faut-il vraiment tout re-paramétrer à zéro pour avoir le Z-Wave 3.0 ou dois-je simplement attendre la prochaine mise à jour qui devrait le faire tout seul ???
Par contre, je suis passé sur chaque device et j'ai fait un "soft reconfigure device" car je croyais que c'est ce qui était recommandé, mais peut-être n'était-ce tout simplement pas nécessaire ??
Fly
Je te conseille d'attendre avant de passer en Z-Wave v3.
La prochaine version, pas sûr, ça sera surement bien plus tard.
Là c'est du beta, y'a plein de modules qui ne sont pas reconnus sur le nouveau moteur, il leur faudra encore plusieurs mois de travail, comme déjà précisé.
La reconfiguration douce des périphériques, c'est pour ceux qui mesurent une puissance électrique, à cause du nouveau mode de calcul de l'énergie électrique de modules.
à l’instant, Lazer a dit :
La reconfiguration douce des périphériques, c'est pour ceux qui mesure une puissance électrique, à cause du nouveau mode de calcul de l'énergie électrique de modules.
OK, je crois que c'est bien le cas des "Roller Shutter 3" et des "MultiLevel Switch", et si j'ai bien compris, j'ai juste maintenant l'interface "Energy" qui me renvoie des valeurs. Mais c'est pas très pratique, j'ai par exemple l'item "63" et il faut savoir que c'est le module volet roulant, idem sur le 53 (*):
(*) mais je pense qu'on est hors sujet, c'est juste que mon roller shutter, il dispose de plusieurs items, je n'ai pas trop compris pourquoi, peut-être n'ai je pas choisi le bon item à masquer ???)
En Z-Wave , chaque module physique peut avoir plusieurs fonctions (endpoint). Et chaque fonction correspond à un module dans l'interface Fibaro : un parent (qui désigne le module physique), et des enfants (qui désignent les différentes fonctions)
Normalement la plupart sont cachés dans l'interface car on ne s'en sert pas, de sorte à ne rendre visible que celui est est utile, c'est à dire la commande du volet roulant dans ton exemple.
Tu peux renommer tes modules pour qu'ils apparaissent joliment dans le panneau d'énergie : les 53.0, 63.0, etc
il y a 7 minutes, Lazer a dit :
C'est moi qui ai caché et renommé les modules que je pensais mais visiblement je ne l'ai pas fait correctement...
Pour ne pas polluer ce topic, je crois qu'il est préférable que je reparte à zéro... (--> voir ici si tu peux m'aider SVP...)
Fly
Quelques news sur les futures nouveautés à venir chez Fibaro :
  • Finalement, retour du Zigbee tant attendu, voilà qui va faire plaisir à certains ! => version beta au 2nd trimètre 2022, donc dans 1 an quoi
  • Plus proche, d'ici la fin de cette année 2021:
    • Améliorations du panneau d'énergie, et utilisation de scènes en relation avec ce panneau (j'imagine des scénarios du style déclenchement sur consommation, par exemple pour du délestage... simple supposition de ma part)
    • Améliorations du support des modules Nice et Elero
    • Gros travail sur l'application mobile depuis laquelle il sera possible de partiellement configurer la box (bon... certes... pourquoi pas... mais je pense qu'on est nombreux à préférer des améliorations sur l'ergonomie de l'appli....)
    • Amélioration du nouveau moteur Z-Wave v3 (qui est toujours en beta pour rappel) et possibilité de migrer depuis une installation existante
    • Améliorations générales de stabilité et de performance
    • Fibaro va aussi chercher à cibler de nouveaux marchés avec ses modules....
Source : forum officiel https://forum.fibaro.com/topic/50641-features-postponed-after-2020/page/6/#comment-234983
  • Like 3
