HC3 & HC3L - 5.063.30 - BETA - 11/03/2021
Important Notice:
In some cases (on large systems) update with automatic backup may fail due to the size of the database.
Please create local backup manually and then perform the update with "No backup before update (not recommended)" option selected.
What's new:
Backup
Storing historical data during backup creation deactivated by default.
Auto-trimming to 500000*/1000000** events during backup procedure for reducing backup size.
Warning about not storing historical data in auto-backups created during update.
Warning about possible loss of historical data before restoring backup.
Devices
Support for Steinel IS 140-2 version 1.0.
Support for Steinel L810 LED iHF version 1.1.
Network
Wireless network interfaces data included in system report.
Added test button for networks with unknown status.
Performance
Added memory usage limit for power and temperature events to reduce overall memory load.
Plugins
Added plugin for Dahua camera.
Update
Automatic backup during update procedure does not contain historical events data anymore.
Bug fixes:
Devices
Issues with configuring parameters in devices without templates or with disabled template.
Gateway Connection
Master gateway crashes when using Climate Panels with thermostats from Slave gateway.
Network
Error 500 in some cases during connection with Wi-Fi network.
Disconnected emergency network displayed as unknown after reboot.
Performance
Rare system crash on boot when system contains a large number of plugins/Quick Apps.
Plugins
Fibaro Heat Activator plugin turned off after adding by default.
No data from YR Weather plugin.
Scenes
Scene created from device settings is not filled automatically with Scene Activation Event.
Update
Possibility to start update before displaying auto-backup options.
* - applies to Home Center 3 Lite
** - applies to Home Center 3
  • Like 2
Mise à jour effectuée,
J'ai perdu la poubelle pour les devices Zwave (cache vidé)
vous aussi ?
Pensez aux Ctrl+F5 après la mise à jour
Fibaro enchaine les Betas.... bon au moins on a le correctif pour la météo YR Weather :)
houlà pas que! ça boot sans se planter, depuis la version précédente, je devais la débrancher du secteur pour qu'elle arrive à booter c'est le correctif :"Rare system crash on boot when system contains a large number of plugins/Quick Apps." et ça c'est cool !
les cameras dahua enfin reconnues après 8 ans de HC ça se fête également, je vais pouvoir déconnecter mon proxy de cams !
et je la trouve super réactive mais ça, ça doit être l'effet placebo.
parole de peul !
Tu veux dire que ce plugin permet d'afficher les flux h264 ?
ça fonctionne avec toutes les caméras ? (Hikvision ici)
J'ai envie de cliquer....
Oui du h264 mais un refresh toutes les 3 secondes par contre le plugin est donné pour du dahua. J'ai pensé à vous qui avez du hikivion, à essayer et je croise les doigts pour que ça fonctionne.
click ! click ! :)
EDIT:
Je viens de jeter un oeil sur l'App et le plugin ne semble pas encore être pris en charge. Faudra donc attendre un peu pour savoir si le flux y sera continu ou avec un refresh toutes les 3 secondes comme dans l'interface de la HC3.
Modifié par TonyC
  Le 11/03/2021 à 16:35, Lazer a dit :
Développer
Toujours pas de clique :) ? A.Socha sur le fofo disait que s'il n'y avait pas de souci majeur la stable devrait sortir la semaine prochaine. Donc plus trop à attendre :6:
là je me détent en codant quelques lignes de LUA :D, mais si ça ne me prend pas trop de temps, je cliquerai tout à l'heure
bon moi j'ai un eu un crash de mon QA qui analyse le refreshState à cause d'un événement "NotificationCreatedEvent ".
Suite à l'interception de cet événement, j'interroge l'API "notificationCenter", et c'est à ce moment que ça plante.
j'ai pas réussi à récupérer le libellé de la notification dans le "data.text", valeur null, donc plantage.
j'ai contourné le problème, en attendant d'en savoir plus, en ajoutant un pcall() (merci @Lazer...)
Y aurait-il eu des modifications de cette API ? :15:
  • Sad 1
@jjacques68 hum... faut que je me méfie avec GEA du coup...
@Nico Non... et oui !!
En fait ma prod est encore sur la HC2, mais la HC3 est AUSSI en prod, car depuis 6 mois, tous les nouvelles domotisations sont faites directement sur la HC3 (ça fera ça de moins à migrer). Et des trucs un peu lourds en énergie : le compteur Linky (via l'EDRT2), le chauffe-eau (c'est critique ça), le chargeur de la voiture, mais aussi tout ce qui se trouve au garage via l'IPX800.
Et il y a aussi tout ce qui est en doublon entre les 2 box, grâce à l'API : Unifi présence, Netatmo, onduleur Eaton, Network Monitor, etc, donc des trucs qui n'auront pas besoin d'être migrés non plus du coup :)
Bon Unifi présence, je me demande encore à quoi il sert, il y a 2 ans j'avais toutes les cartes de fidélité des hôtels, SNCF, Air France, etc... aujourd'hui, je dois dormir à peu près 365 jours par an chez moi (bon, faut enlever les vacances quand même... quoi que même là, ça a été réduit depuis 1 an... va comprendre -_-). Les temps changent.
Le bon coté des choses, j'ai fait un test d’empreinte carbone, je suis passé de très mauvais élève, à très largement en dessous de la moyenne française. Greta approuve :D
Ma conso d'électricité a augmenté, mais comme je me chauffe au nucléaire, ça reste écologique (oui on est le 11 mars..... une malheureuse date anniversaire)
  • Haha 1
Pffff... je ne comprend pas qu'ils n'ajoutent pas de l'espace sur le cloud... dire qu'avec la HC2 on a le droit à 10x plus !!!
Nous sommes d’accord cela devient légèrement agaçant...
Bon en tout cas la mise à jour est passée :)
Et le plugin Météo qui refonctionne, c'est donc bien comme je me soupçonnais, Fibaro, qui une fois de plus, n'a pas anticipé et mis à jour le plugin avant le changement d'API par le fournisseur. Espérons qu'ils proposent rapidement une mise à jour pour HC2.
  Le 11/03/2021 à 21:49, Lazer a dit :
Développer
tien en parlant de taille de backup,
Juste avant cette ise à jour, j'ai fais un backup SANS l'historique, résultat : 3.2 Mo
Les backup réalisés la nuit par le backup auto : 45 Mo !!!
Plus de 40 Mo d'historique !!! je comprends pas l'intérêt de sauvegarder l'historique ??
ouai ben je confirme qu'il y a un loup caché au démarrage avec le notificationCenter...
Le resfreshState me dit qu'il y a une notification, mais au moment où l'erreur tombe, je ne vois rien dans le swagger.
Erreur retournée par le PCALL()  :
./include/mainFunc.lua:86: attempt to concatenate a nil value (field 'text')
Ben logique, y a rien !!
et quelques minutes plus tard, elle apparait
    "id": 1,
    "type": "FirmwareUpdateNotification",
    "created": 1615501766,
    "canBeDeleted": true,
    "priority": "info",
    "wasRead": false,
    "data": {
      "deviceId": 522,
      "progress": 0,
      "status": "Available",
      "info": ""
A suivre...
Modifié par jjacques68
Mortelle cette optimisation, regardez l'utilisation CPU avant/après :D
(le pic c'est quand j'ai fait les backups et la mise à jour, normal)
Et pour la RAM, pas de changement significatif.
  • Like 2
je ne sais pas si je suis le seul, mais il semble que l'icône de suppression de modules "dispositifs" disparaisse, donc impossible de supprimer un module.
Mais pas tous de suite, après quelques manipulations
Modifié par flacon030
