Kukulkan Posté(e) le 12 février 2021 Signaler Posté(e) le 12 février 2021 Hi! Sorry for the English, but I don't know where to ask. I have several HCLs and they are connected to the switches as shown in the picture. And my system crashes. The Fibaro Finder shows a lot of HCL duplicates. What could be the problem? The switches are unmanaged, the DHCP distributes just a Tenda modem. But HCL has a static IP address. Thank you for any advice!
Lazer Posté(e) le 12 février 2021 Signaler Posté(e) le 12 février 2021 How many HCL to you have ? In HCL network configuration panel, do they use DHCP or static IP address ? I case they all use DHCP, then the issue comes from your DHCP Server (modem/router). In case they all use Static IP address, you must check that they all use different address. It may help to temporary disconnect the HCL and keep only one connected at a time, to be sure to connect to this particular one (in case another HCL has the same address)
Kukulkan Posté(e) le 12 février 2021 Auteur Signaler Posté(e) le 12 février 2021 @Lazer I have 4 HCL. And they all use a different, static IP address
Lazer Posté(e) le 12 février 2021 Signaler Posté(e) le 12 février 2021 And you can access all of them ? So there is no problem
