Cuz!
Désolé pour la mauvaise langue, c'est un traducteur. Ma question est la suivante: est-il possible d'envoyer directement les données du capteur à la base de données? J'ai HC2 et HCL.
Merci pour tout conseil!
Je ne suis pas certain de comprendre la question..... que veux-tu dire par envoyer "directement" les données du capteur à la base de données ?
Car en l'état, les données provenant des capteurs sont bien stockées dans la base de données.
You can write in english if you prefer.
My French is terrible, sorry :( I am looking for solution to send data from HC2 and HCL to external SQL server. I Need a way to directly get data to SQL server. Thanks for the help!
OK :)
So you can look at the DomoCharts project :
Or @jjacques68 has done something like this on the forum, he pushes all data (not only sensors) to an external database.
Il y a 11 heures, Kukulkan a dit :
Directly, I don't think it's possible.
but through a bridge, yes ! (with HC3)
I'm sure it's possible with HC2, but HCL... not sure
I use this diagram :
One QA that get all informations I need   --->   Bridge   --->   SGBD   <---   Web application to retrieve informations
The EDI I use to create the bridge is Windev. This EDI has his own SGBD (HFSQL).
This SGBD can be use with SQL server with a "connector" (I don't use that)
The communication support between HC3 and the Bridge is a socket TCP.
I have an another QA to manage this socket.
I save in database all informations about :
  • events of devices (value, state, ...)
  • debug messages (debug, warning, trace, error)
  • NotificationCreatedEvent
These informations are recovered from the API refreshStates of HC3.
The web application is created with Webdev.
it's a simply table with some filters.
Modifié par jjacques68
