jjacques68 Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 What's new: Alarm Added column with alarm scene ID. Backup Disabling backup creation button when reached the backups limit. Optional saving of the history content when creating backup manually. Dashboard Serial number displayed as a tooltip after hovering on FIBARO logo. Exact value from the api displayed as a tooltip on device tile and on the right sidebar. Possibility to control com.fibaro.player devices from the right sidebar. Possibility to open video gate from the right sidebar. Thermostat preview available from the FIBARO Home Center app. Icons for opening and closing states of roller shutters. Devices Power consumption charts in device Advanced tab. Three new icon sets for valves. Support for Heatit Z-Smoke Detector 230V version 4.1. Support for Heatit Z-Temp2 version 1.1. Support for Heatit Z-TRM3 version 4.0. Support for Sensative Strip Guard in any version. Support for U-Fairy Valve Shut-Off Controller. Gateway Connection Unlocked early access feature of connecting two or more gateways: FIBARO Home Centers 3 may be connected only to other Home Centers 3. Slave gateway must be empty or will be restored to factory settings. All gateways must have the same version installed. Backing up connected gateways together using the master gateway. Updating connected gateways one after another starting from slave gateways. Possibility to update all gateways or master gateway only. Possibility to restore backup for all gateways or master gateway only. Possibility to access slave gateways via generated password. History Displaying events related to power consumption of devices. Improved displaying events from FIBARO RGBW Controllers. Notifications Critical push notifications available as a new channel in device notifications. Other Beta version status displayed on the login screen and in General Settings. Optimized services performance and events handling. Optimized database write and read times. Plugins Tedee lock plugin. Quick Apps Buttons and sliders available as actions in block scenes. Update Notice of the necessary local connection to perform the update. Redirection to current system status after starting the update. Bug fixes: Alarm Possibility to add Z-Wave devices to Satel alarm zones. Cannot add alarm zones during the First Time Installation. Backup Cannot migrate cloud backups from one Home Center 3 to another. Incorrect states when creating backups. Cancellation of downloading an update stops creating/restoring the backup. Cameras No pause button on camera image preview. Complex stream paths are improperly translated. Devices Temperature setpoint chart is displayed incorrectly. Energy data on device Advanced tab is not cleared. No possibility to add FIBARO RGBW 2 (FGRGBW-442) in security mode. History Incorrect units for events from multilevel sensors. Filtering events by rooms does not work properly. Network Services do not start if there is a network connection without the Internet. Notifications Critical push notifications are not sent. No notifications from BiDi Z-Wave device after rebooting the gateway. Other Chinese language version choice is not saved. Services do not start after leaving the stand-by mode. Power diode is not lit after leaving the stand-by mode. Plugins Planika fireplace plugin status is refreshed too often and results in mobile app crash. Profiles Scene in which the active profile is a condition does not start after rebooting. Quick Apps Non-admin users get the login screen when opening the quick app on the mobile app. Non-admin users get only the custom part of quick app on the mobile app. The first letter in labels is automatically changed to a capital letter. No button for removing the device after leaving the edit mode. No family section in general device settings. Recovery Large systems in some cases start up in recovery mode. Scenes Scene Activation IDs are not displayed when creating block scene. Deactivation of a running scene does not stop the scene. Soft reconfiguration of the device is required to run scenes with Access Control Events. No protection against running the same scene at short time intervals. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Première chose à vérifier après mise à jour : voir si vos scènes sont correctement déclenchées (hors cron) 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 clic clic clic © Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nono007 Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Bonjour, oula ça faisait longtemps que je n'étais pas venu, mais je viens de recevoir ma HC3 et j'ai halluciné par le travail que vous avez déjà. Sinon, je viens d'installer la Beta, pour le moment rien a signaler, j'ai A Quick App perso, avec enfants, ça semble OK, j'ai une scène simple qui allume le frigo si la prise est OFF ==> OK Bref on verra avec le temps. J'ai pas tester les bug/nouvelle fonctionnalité, sauf la plus simple ... "Serial number displayed as a tooltip after hovering on FIBARO logo." et oui ça fonctionne Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 22 décembre 2020 Auteur Signaler Partager Posté(e) le 22 décembre 2020 (modifié) nan perso moi j'attends les retour... enfin si tout le monde fait comme ça ... y aura pas de retour Modifié le 22 décembre 2020 par jjacques68 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dgille Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 MAJ réalisée, RAS , avec 15 mn de recul.... principale modification visible, sur la gestion de l énergie... a suivre. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Il y a 2 heures, jjacques68 a dit : Dashboard Possibility to control com.fibaro.player devices from the right sidebar. Possibility to open video gate from the right sidebar. Hum… Etrange comme idée non ? Du coup sur un QA comme le Sonos ZC Player, duplication des fonctions de transport + volume Pour l'intercom Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 (modifié) Mouais moyen cool cette maj, après quelques checks, adieu /api/panels/event?, le réglage de température ne répond plus aux consignes manuelles et quelques sueurs froides durant l'update mais qui se sont bien soldées, heureusement. Je me tâte à faire un gros rollback, je me laisse quelques heures de réflexion il y a 9 minutes, Krikroff a dit : Hum… Etrange comme idée non ? Curieux en effet, pas certain de toujours bien capter ce qu'il leur passe par la tête Modifié le 22 décembre 2020 par TonyC Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 il y a 5 minutes, TonyC a dit : adieu /api/panels/event? En effet, il faut passer par Je n'ai pas testé encore mais un de mes doigts me remonte que la structure retournée à évolué avec la 5.061... il y a 8 minutes, TonyC a dit : Curieux en effet, pas certain de toujours bien capter ce qu'il leur passe par la tête Je ne pige pas l'intérêt du truc. Un ticket est ouvert depuis l'introduction en 5.061.33 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Bah moi... Je trouve ça pertinent Non sérieux, c'est logique que la vue par défaut propose les contrôles associées aux actions (fonction) obligatoire de chaque type de QuickApp. Par exemple pour un BinarySwitch, par défaut on a la possibilité de faire ON/OFF. Pour un Multilevel (lumière, volet), par défaut on a la possibilité de faire varier la valeur avec un slider. Il est donc tout à fait logique que Fibaro affiche automatiquement les boutons play pause stop volume etc sur un Player. Sur mon QA pour Kodi, j'avais justement ajouté manuellement les boutons manquants... dans la prochaine version je les supprimerai pour ne pas faire double emploi. Seul regret, on va perdre les jolis emojis en couleur que j'avais mis pour chaque bouton.... bon c'est pas forcément une grosse perte. Je trouve dommage qu'on ne puisse toujours pas travailler l'aspect des QuickApps en revanche @TonyC tu vas pouvoir tester le master/slave que tu attendais tant ! 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Ok pourquoi pas j’entends ce que tu dis pas faux... mais il n’y a plus de cohérence dans la vue QA... et dans la preview du QA les commandes tu fais comment ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Oui la cohérence est un problème, mais tant qu'on ne pourra pas travailler le design des QA, ça restera moche dans tous les cas (désolé, mais je trouve encore que les VD étaient plus jolis, même si très basiques) La Preview, je n'avais pas pensé à cela.... et Fibaro non plus apparemment Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Je suis d’accord côté design VD vs QA y’a pas photo... c’est dire j’espère que nous aurons de bonnes surprises pour 2021 Sinon l'espace disponible pour le backup cloud est toujours limite, en gros c’est un backup point. Bof . Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 Ouais j'ai pas compris le truc du backup cloud là, j'ai cru qu'ils allaient faire lever la limitation, mais en fait non. Juste l'option pour pas sauvegarder les logs.... fausse joie Du coup mon script de backup local reste plus que jamais utile 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 22 décembre 2020 Auteur Signaler Partager Posté(e) le 22 décembre 2020 ah ben oui ! et maintenant il prendra moins de place ! enfin normalement... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 22 décembre 2020 Signaler Partager Posté(e) le 22 décembre 2020 ouais mais si tu perds aussi les historiques de température et consommation lors du restore, c'est dommage. Enfin je sais pas, je n'ai pas testé Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 22 décembre 2020 Auteur Signaler Partager Posté(e) le 22 décembre 2020 perso... ces historique là... moi je m'en fiche un peu. la seule chose qui m'intéresse c'est les événements. Et je les stocke en base, donc... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) le 23 décembre 2020 Signaler Partager Posté(e) le 23 décembre 2020 Je n'ai pas l'impression qu'ils aient corrigé mon bug d'import des QA type thermostat....Envoyé de mon RMX1993 en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
speedoxx007 Posté(e) le 24 décembre 2020 Signaler Partager Posté(e) le 24 décembre 2020 Le 22/12/2020 à 16:35, jjacques68 a dit : Gateway Connection Unlocked early access feature of connecting two or more gateways: FIBARO Home Centers 3 may be connected only to other Home Centers 3. Slave gateway must be empty or will be restored to factory settings. All gateways must have the same version installed. Backing up connected gateways together using the master gateway. Updating connected gateways one after another starting from slave gateways. Possibility to update all gateways or master gateway only. Possibility to restore backup for all gateways or master gateway only. Possibility to access slave gateways via generated password. Euh donc on ne pourra jamais utiliser une HC2 ou HCL comme Slave? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) le 24 décembre 2020 Signaler Partager Posté(e) le 24 décembre 2020 Ça sera pour la prochaine update Envoyé de mon RMX1993 en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 24 décembre 2020 Signaler Partager Posté(e) le 24 décembre 2020 @Dragoniacs tu as testé le réimport de ton QA thermostat du coup ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) le 24 décembre 2020 Signaler Partager Posté(e) le 24 décembre 2020 Non, pas encore eu le temps de faire ça... Envoyé de mon RMX1993 en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 24 décembre 2020 Signaler Partager Posté(e) le 24 décembre 2020 Ca m'inquiète un peu, pas de HC2 en slave pour le moment. Mais surtout, cela dump la box slave, du coup je ne comprends pas l'intérêt là... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dgille Posté(e) le 24 décembre 2020 Signaler Partager Posté(e) le 24 décembre 2020 Ils essayent peut-être de faire un vrai cluster de HC3 avec des devices qui pourraient passer d une box a l autre. S ils y arrivent, cela pourrait en faire une vraie solution en HA, c est Noël, on peut rêver 5 mn... 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 24 décembre 2020 Auteur Signaler Partager Posté(e) le 24 décembre 2020 Je viens de faire cette mise à jour, bon mon vieux !! c'était LA-BO-RIEUX !!!!! Mise à jour, assez rapide. Après don redémarrage, panique complet. Tous mes QA qui utilisent les socket ehternet = tentative de connexions en boucle, sans respecter le timeout de 3s que j'ai mis en place. Reboot de la HC3. ça a mis trois plomb. Socket OK. Moteur Z-wave a mis plus de 10 minutes à se mettre en route !! CPU à 100 % un core après l'autre pendant ces 10 minutes. et tout d'un coup c'est ok. On dirait qu'elle est plus réactive ? ou c'est une impression ? Je le constate à l'usage du CPU... Lien vers le commentaire Partager sur d’autres sites More sharing options...
