Heating Manager - PID and more
ok, merci pour ton support. :13:
Voici les logs pour la 5.15b
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: onInit - Heating Manager (QA 846) - Cave Vins
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: HEATING & COOLING MANAGER v. 5.15 Beta
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: Chargement de la configuration ...
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'lbSetpoint' updated => Chargement de la configuration ...
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'lbMode' updated =>
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'lbInfo' updated =>
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [-PID-] Loading PID data from variable 'HM_Data'
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'Manuel' updated => Manuel (12.0°)
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'Confort' updated => Confort (13.0°)
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'Eco' updated => Eco (14.0°)
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'Vacation' updated => Vacances (13.0°)
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [UI] label 'lbEdit' updated => Réglage du mode Manuel : 12.0° [10°-21°]
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: Initialize OK
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [BOOT] Configuring heaters/coolers
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: (addHeater) Retrieving PID data for [Cave_AirCo]
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: (addHeater) Turning off [Cave_AirCo]
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => turnOff [turnOff]
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: addHeater OK
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [BOOT] Configuring regulation modes
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: (setmodes) Mode Auto : Resolving alias '13'
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: (setmodes) Mode Auto : '13' = 13°
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: [BOOT] Validating heaters/coolers configuration
[14.01.2023] [19:46:18] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Testing On / Off commands : Please wait ...
[14.01.2023] [19:46:26] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => On [turnOn]
[14.01.2023] [19:46:27] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Turn On => true
[14.01.2023] [19:46:27] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => Off [turnOff]
[14.01.2023] [19:46:28] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Turn Off => false
[14.01.2023] [19:46:28] [DEBUG] [QUICKAPP846]: getTempSensor : heater Cave_AirCo
[14.01.2023] [19:46:28] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Using room Cave Vins default sensor as temperature sensor
[14.01.2023] [19:46:29] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Sensor = 'Cave_Tmp'
[14.01.2023] [19:46:29] [DEBUG] [QUICKAPP846]: (Cave_AirCo) PID Cycle = 5m
[14.01.2023] [19:46:29] [DEBUG] [QUICKAPP846]: checkHeatersConfig OK
[14.01.2023] [19:46:29] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
et ceux de la 5.16b qui reste bloqué
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: onInit - Heating & Cooling Manager (846) - Cave Vins
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: HEATING & COOLING MANAGER v. 5.16
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: Chargement de la configuration ...
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbSetpoint' updated => Chargement de la configuration ...
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbMode' updated =>
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbInfo' updated =>
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [-PID-] Loading PID data from variable 'HM_Data'
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'Manuel' updated => Manuel (12.0°)
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'Confort' updated => Confort (13.0°)
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'Eco' updated => Eco (14.0°)
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'Vacation' updated => Vacances (13.0°)
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbEdit' updated => Réglage du mode Manuel : 12.0° [10°-21°]
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: Initialize OK
[14.01.2023] [20:02:34] [DEBUG] [QUICKAPP846]: [BOOT] Configuring heaters/coolers
je pense (oui; ça m'arrive ...) à un truc.
Entre la 5.15b et la 5.16b n'aurais-tu pas rajouté un paramètre  (qu'il ne trouve pas => bug) .
Voici le fichier config (qui fonctionne en 5.15b) :
e, fait non , il ne passe pas, toujours à cuase des emoji
finalement, il a bien voulu repartir en 5,15b. Pourquoi ?????
Voici le log de démarrage
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: onInit - Heating Manager (QA 846) - Cave Vins
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: HEATING & COOLING MANAGER v. 5.15 Beta
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: Chargement de la configuration ...
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'lbSetpoint' updated => Chargement de la configuration ...
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'lbMode' updated =>
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'lbInfo' updated =>
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [-PID-] Loading PID data from variable 'HM_Data'
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'Manuel' updated => Manuel (12.0°)
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'Confort' updated => Confort (13.0°)
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'Eco' updated => Eco (14.0°)
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'Vacation' updated => Vacances (13.0°)
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [UI] label 'lbEdit' updated => Réglage du mode Manuel : 12.0° [10°-21°]
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: Initialize OK
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [BOOT] Configuring heaters/coolers
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: (addHeater) Retrieving PID data for [Cave_AirCo]
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: (addHeater) Turning off [Cave_AirCo]
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => turnOff [turnOff]
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: addHeater OK
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [BOOT] Configuring regulation modes
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: (setmodes) Mode Auto : Resolving alias '13'
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: (setmodes) Mode Auto : '13' = 13°
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: [BOOT] Validating heaters/coolers configuration
[14.01.2023] [22:42:59] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Testing On / Off commands : Please wait ...
[14.01.2023] [22:43:07] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => On [turnOn]
[14.01.2023] [22:43:09] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Turn On => true
[14.01.2023] [22:43:09] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => Off [turnOff]
[14.01.2023] [22:43:10] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Turn Off => false
[14.01.2023] [22:43:10] [DEBUG] [QUICKAPP846]: getTempSensor : heater Cave_AirCo
[14.01.2023] [22:43:10] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Using room Cave Vins default sensor as temperature sensor
[14.01.2023] [22:43:10] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Sensor = 'Cave_Tmp'
[14.01.2023] [22:43:10] [DEBUG] [QUICKAPP846]: (Cave_AirCo) PID Cycle = 5m
[14.01.2023] [22:43:10] [DEBUG] [QUICKAPP846]: checkHeatersConfig OK
[14.01.2023] [22:43:10] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
excuse-moi d'encore t'ennuyer ... ,
mais comme tu m'as dit de lire les logs, surtout au démarrage, j'obéis ...
Dans le log je vois Kd:1
[14.01.2023] [22:53:37] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 23.8
alors que dans ma config, j'ai mis Kd=0
 HM:addHeater({id=327, Kp=20, Ki=3, Kd=0})
ne me tue pas SVP ....
salut,
Je confirme qu'il y a bien un problème au redémarrage des services de la box.
Toutes les semaines, dans la nuit du samedi au dimanche, à 3h00, il y a un backup auto, suivi d'un redémarrage des services de la box.
Et ce matin, j'ai retrouvé le thermostat PID sur OFF et la température de la cave à 15,3°C (consigne = 13°C)
Malheureusement, je n'ai pas les logs de 3h...
Mais je suis presque sûr de la cause, quand je regarde le graphique de température.
Voici le log de niveau 4 lors du redémarrage (toujours en5.15b)
Tag :
Type :
RÉINITIALISER
[15.01.2023] [11:06:38] [TRACE] [QUICKAPP846]: UIEvent: {"values":[],"eventType":"onReleased","deviceId":846,"elementName":"Confort"}
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: onInit - Heating Manager (QA 846) - Cave Vins
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: HEATING & COOLING MANAGER v. 5.15 Beta
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: Chargement de la configuration ...
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbSetpoint' updated => Chargement de la configuration ...
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbMode' updated =>
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbInfo' updated =>
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [-PID-] Loading PID data from variable 'HM_Data'
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'Manuel' updated => Manuel (13.0°)
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'Confort' updated => Confort (13.0°)
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'Eco' updated => Eco (14.0°)
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'Vacation' updated => Vacances (13.0°)
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [UI] label 'lbEdit' updated => Réglage du mode Manuel : 13.0° [10°-21°]
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: Initialize OK
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: [BOOT] Configuring heaters/coolers
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: (addHeater) Retrieving PID data for [Cave_AirCo]
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: (addHeater) Turning off [Cave_AirCo]
[15.01.2023] [11:10:34] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => turnOff [turnOff]
[15.01.2023] [11:10:35] [DEBUG] [QUICKAPP846]: addHeater OK
[15.01.2023] [11:10:35] [DEBUG] [QUICKAPP846]: [BOOT] Configuring regulation modes
[15.01.2023] [11:10:35] [DEBUG] [QUICKAPP846]: (setmodes) Mode Auto : Resolving alias '13'
[15.01.2023] [11:10:35] [DEBUG] [QUICKAPP846]: (setmodes) Mode Auto : '13' = 13°
[15.01.2023] [11:10:35] [DEBUG] [QUICKAPP846]: [BOOT] Validating heaters/coolers configuration
[15.01.2023] [11:10:35] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Testing On / Off commands : Please wait ...
[15.01.2023] [11:10:43] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => On [turnOn]
[15.01.2023] [11:10:44] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Turn On => true
[15.01.2023] [11:10:44] [DEBUG] [QUICKAPP846]: Cave Vins : Cave_AirCo => Off [turnOff]
[15.01.2023] [11:10:45] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Turn Off => false
[15.01.2023] [11:10:45] [DEBUG] [QUICKAPP846]: getTempSensor : heater Cave_AirCo
[15.01.2023] [11:10:45] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Using room Cave Vins default sensor as temperature sensor
[15.01.2023] [11:10:45] [DEBUG] [QUICKAPP846]: (Cave_AirCo) Sensor = 'Cave_Tmp'
[15.01.2023] [11:10:45] [DEBUG] [QUICKAPP846]: (Cave_AirCo) PID Cycle = 5m
[15.01.2023] [11:10:45] [DEBUG] [QUICKAPP846]: checkHeatersConfig OK
[15.01.2023] [11:10:45] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
Le 13/01/2023 à 22:12, Felig a dit :
Franchement ces oscillations c'est pas normal. Chez moi les variations de température sont de 0.2° dans un sens ou l'autre max.
les oscillations n'ont malheureusement rien à voir avec le warning sur la probable interraction avec un autre régulateur.
Voici le graphe de température
ert le log demandé
15.01.2023] [23:07:52] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
[15.01.2023] [23:07:52] [DEBUG] [QUICKAPP846]: onInit - Heating Manager (QA 846) - Cave Vins
[15.01.2023] [23:07:52] [DEBUG] [QUICKAPP846]: ------------------------------------------------------------------------------
[15.01.2023] [23:07:52] [DEBUG] [QUICKAPP846]: HEATING & COOLING MANAGER v. 5.15 Beta
[15.01.2023] [23:07:52] [DEBUG] [QUICKAPP846]: Chargement de la configuration ...
[15.01.2023] [23:07:52] [DEBUG] [QUICKAPP846]: [-PID-] Loading PID data from variable 'HM_Data'
[15.01.2023] [23:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave Vins : Consigne = 13.0°C (Source: Confort)
[15.01.2023] [23:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (boot)
[15.01.2023] [23:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.1°C | Extérieur 4.0°C
[15.01.2023] [23:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":21.9,"lastError":0.1,"Ki":3}
[15.01.2023] [23:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 21.9
[15.01.2023] [23:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 2.0% | I = 65.7% | D = 0.6% | 68.0%
[15.01.2023] [23:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.1°C | Début clim. 3m 23s
[15.01.2023] [23:11:26] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[15.01.2023] [23:11:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.5°C
[15.01.2023] [23:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[15.01.2023] [23:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.5°C | Extérieur 4.0°C
[15.01.2023] [23:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":21.4,"lastError":-0.5,"Ki":3}
[15.01.2023] [23:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 21.4
[15.01.2023] [23:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -10.0% | I = 64.2% | D = -0.6% | 54.0%
[15.01.2023] [23:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.5°C | Début clim. 2m 39s
[15.01.2023] [23:14:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 13.1°C
[15.01.2023] [23:15:42] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[15.01.2023] [23:18:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[15.01.2023] [23:18:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.1°C | Extérieur 4.0°C
[15.01.2023] [23:18:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":21.5,"lastError":0.1,"Ki":3}
[15.01.2023] [23:18:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 21.5
[15.01.2023] [23:18:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 2.0% | I = 64.5% | D = 0.6% | 67.0%
[15.01.2023] [23:18:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.1°C | Début clim. 3m 19s
[15.01.2023] [23:20:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.5°C
[15.01.2023] [23:21:23] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [01:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 13.0°C
[16.01.2023] [01:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [01:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.1°C
[16.01.2023] [01:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":15.9,"lastError":-0.0,"Ki":3}
[16.01.2023] [01:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 15.9
[16.01.2023] [01:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 47.7% | D = -0.1% | 48.0%
[16.01.2023] [01:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 2m 21s
[16.01.2023] [01:15:24] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [01:15:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.3°C
[16.01.2023] [01:17:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.9°C
[16.01.2023] [01:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [01:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 4.1°C
[16.01.2023] [01:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":15.8,"lastError":-0.1,"Ki":3}
[16.01.2023] [01:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 15.8
[16.01.2023] [01:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 47.4% | D = -0.1% | 45.0%
[16.01.2023] [01:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 2m 14s
[16.01.2023] [01:20:17] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [01:20:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.3°C
[16.01.2023] [01:22:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 13.0°C
[16.01.2023] [01:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [01:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.1°C
[16.01.2023] [01:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":15.8,"lastError":-0.0,"Ki":3}
[16.01.2023] [01:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 15.8
[16.01.2023] [01:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 47.4% | D = 0.1% | 48.0%
[16.01.2023] [01:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 2m 21s
[16.01.2023] [03:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [03:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 4.1°C
[16.01.2023] [03:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.5,"lastError":-0.1,"Ki":3}
[16.01.2023] [03:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.5
[16.01.2023] [03:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 43.5% | D = 0.0% | 42.0%
[16.01.2023] [03:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 2m 03s
[16.01.2023] [03:15:05] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [03:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [03:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 4.1°C
[16.01.2023] [03:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.4,"lastError":-0.1,"Ki":3}
[16.01.2023] [03:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.4
[16.01.2023] [03:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 43.2% | D = 0.0% | 41.0%
[16.01.2023] [03:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 2m 02s
[16.01.2023] [03:20:05] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [03:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [03:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 4.1°C
[16.01.2023] [03:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.3,"lastError":-0.1,"Ki":3}
[16.01.2023] [03:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.3
[16.01.2023] [03:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 42.9% | D = 0.0% | 41.0%
[16.01.2023] [03:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 2m 01s
[16.01.2023] [03:23:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.5°C
[16.01.2023] [05:13:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 13.2°C
[16.01.2023] [05:14:47] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [05:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [05:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 4.3°C
[16.01.2023] [05:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.9,"lastError":0.2,"Ki":3}
[16.01.2023] [05:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.9
[16.01.2023] [05:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 44.7% | D = 0.6% | 49.0%
[16.01.2023] [05:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 26s
[16.01.2023] [05:20:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.6°C
[16.01.2023] [05:20:29] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [05:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [05:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.6°C | Extérieur 4.3°C
[16.01.2023] [05:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.5,"lastError":-0.4,"Ki":3}
[16.01.2023] [05:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.5
[16.01.2023] [05:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -8.0% | I = 43.5% | D = -0.6% | 35.0%
[16.01.2023] [05:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.6°C | Début clim. 1m 44s
[16.01.2023] [05:23:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 13.2°C
[16.01.2023] [05:24:46] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [07:14:58] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [07:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [07:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 3.3°C
[16.01.2023] [07:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.6,"lastError":-0.1,"Ki":3}
[16.01.2023] [07:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.6
[16.01.2023] [07:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 40.8% | D = 0.0% | 39.0%
[16.01.2023] [07:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 55s
[16.01.2023] [07:19:58] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [07:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [07:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 3.3°C
[16.01.2023] [07:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.5,"lastError":-0.1,"Ki":3}
[16.01.2023] [07:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.5
[16.01.2023] [07:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 40.5% | D = 0.0% | 39.0%
[16.01.2023] [07:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 54s
[16.01.2023] [07:23:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.5°C
[16.01.2023] [07:24:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 12.9°C
[16.01.2023] [07:24:57] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [09:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [09:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.1°C | Extérieur 4.8°C
[16.01.2023] [09:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.1,"lastError":0.1,"Ki":3}
[16.01.2023] [09:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.1
[16.01.2023] [09:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 2.0% | I = 42.3% | D = 0.6% | 45.0%
[16.01.2023] [09:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.1°C | Début clim. 2m 13s
[16.01.2023] [09:19:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.7°C
[16.01.2023] [09:20:15] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [09:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [09:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.7°C | Extérieur 4.8°C
[16.01.2023] [09:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.8,"lastError":0.7,"Ki":3}
[16.01.2023] [09:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.8
[16.01.2023] [09:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 14.0% | I = 44.4% | D = 0.6% | 59.0%
[16.01.2023] [09:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.7°C | Début clim. 2m 55s
[16.01.2023] [09:24:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.7°C => 13.0°C
[16.01.2023] [09:25:53] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.3°C
[16.01.2023] [09:25:58] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [09:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [09:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.8°C
[16.01.2023] [09:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.7,"lastError":-0.0,"Ki":3}
[16.01.2023] [09:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.7
[16.01.2023] [09:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 44.1% | D = 0.0% | 44.0%
[16.01.2023] [09:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 2m 11s
[16.01.2023] [09:50:14] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [09:50:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.5°C
[16.01.2023] [09:52:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 13.1°C
[16.01.2023] [09:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [09:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.1°C | Extérieur 4.8°C
[16.01.2023] [09:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.8,"lastError":0.1,"Ki":3}
[16.01.2023] [09:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.8
[16.01.2023] [09:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 2.0% | I = 44.4% | D = 0.1% | 47.0%
[16.01.2023] [09:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.1°C | Début clim. 2m 18s
[16.01.2023] [09:55:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.5°C
[16.01.2023] [09:55:20] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [09:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [09:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.5°C | Extérieur 4.8°C
[16.01.2023] [09:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.3,"lastError":-0.5,"Ki":3}
[16.01.2023] [09:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.3
[16.01.2023] [09:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -10.0% | I = 42.9% | D = -0.6% | 32.0%
[16.01.2023] [09:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.5°C | Début clim. 1m 36s
[16.01.2023] [09:58:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 13.1°C
[16.01.2023] [09:59:39] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[16.01.2023] [10:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[16.01.2023] [10:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.1°C | Extérieur 4.8°C
[16.01.2023] [10:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":14.4,"lastError":0.1,"Ki":3}
[16.01.2023] [10:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 14.4
[16.01.2023] [10:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 2.0% | I = 43.2% | D = 0.6% | 46.0%
[16.01.2023] [10:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.1°C | Début clim. 2m 16s
[16.01.2023] [10:04:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.7°C
[16.01.2023] [10:05:19] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
P.S. : as-tu trouvé/pu reproduire chez toi le régulateur qui se mait sur OFF aorès un redémarrage de la box ?
P.S.2 : je suis toujours en 5,15b
Merci Jojo, plein d'infos super utiles. Je fais des tests de mon côté et je reviens.
En ce qui concerner les oscillations j'ai l'impression qu'il y a un pb avec ton thermomètre:
Dans les 3 dernières lignes de ton log (mais ça se reproduit avant), il y a des choses bizarres:
1) A 10:03 la température est de 13.1°, et la clim se met en marche
2) 1 minute 30 secondes après, alors que la clim est en marche, la température augmente de 0.6° ??
3) Au-delà du fait que la température devrait baisser et non monter, des variations de température aussi fortes (0.6° en 1m30) c'est bizarre non ?
Ta cave à vins c'est une pièce ou un meuble dans un environnement chaud ? Tu as une explication ? Tu as moyen d'utiliser un autre thermomètre plus précis pour comparer (genre un SRT321) ?
En ce qui concerne Kd, bien vu c'est ma faute. J'avais bloqué la valeur zéro pour Kp, Ki et Kd suite à ton expérience avec Ki=0, alors qu'il n'y a pas de raison de la bloquer pour Kd.
EDIT: En regardant de plus près les logs, TOUTES les modifications de température sont de 0.6° ou 0.7° minimum. Comme si c'était le pas minimum pour ton thermomètre. Je pense qu'il n'est pas assez précis pour une régulation optimisée. Chez moi j'utilise un SRT321 comme thermomètre (ce qui me permet d'afficher la consigne sur l'écran LCD) et il est capable de mesurer des variations de température de 0.1°.
Modifié par Felig
Il y a 14 heures, Felig a dit :
content de te lire, je craignais t'avoir dégoutté sous le flot d'info que j'avais envoyé.
Bien vu. En fait j'utilise une PT100 raccordée à un FGBS222 dont le paramètre 67 définit l'écart de température minimal pour qu'elle soit remontée à la box. Et je l'avais laissé à sa valeur par défaut qui était de ... 0,5 °C. Je change donc de ce pas le paramètre.
ça ne me surprend que partiellement : il y a (je crois) une protection interne à l'airco (Daikin) qui l'empèche de redémarrer immédiatement après un arrêt.
Mais je vai d'abord voir ce que dit le changelent du paramètre 67
Ok, de mon côté je vois 2 choses qui restent à régler:
1) le reboot de la HC3: si tu as le temps est-ce que tu peux faire un reboot manuel et vérifier si tu as aussi le pb du thermostat qui se met sur off ?
    - Si ça bloque est-ce que tu vois un log au démarrage ?
    - Si ça ne bloque pas ça veut dire qu'un reboot automatique est plus violent qu'un reboot manuel, c'est pas intuitif, mais je testerai chez moi
2) la version 5.16 qui refuse de démarrer: est-ce que c'est réglé ?
  D'après les logs il y a un problème dans la fonction addheater. Est-ce que tu peux poster ton fichier config en format file (pour éviter le pb des emoji) (ou carrément le fqa si plus simple) et j'essaierai de reproduire le bug chez moi.
Merci!
Merci!
non, c'est moi qui te remercie ...
Je commencerai par la fonctionnalité régul.
Malgré que j'ai modifié le paramètre de mon module pour remonter les changements de température dès 0,1 °C, j'au toujours de fortes oscillations :
et pas centrée sur la consigne de 13°C
et je trouve étrange que l'AirCo soit désactivé alors que la tempér
j'avais fait une réponse super complète pour tes autres questions, mais tout a été perdu ...
Je dois partir maintenant, mais recommencerai ce pm ...
Entre-temps j'ai trouvé le bug de la version 5.16, donc ça tu peux laisser tomber. C'est corrigé dans la version ci-jointe.
Pour les oscillations ça ne m'étonne pas, le problème n'est pas seulement que le thermomètre ne reporte que les changements de 0.5°, c'est que la température change très vite, ce qui dans une configuration de chauffage normale n'est pas le cas. Mais ça serait intéressant d'avoir des logs sur quelques heures (avec showDebug=1 pour éviter le spam) pour voir comment la régul travaille.
HM HC3 Cool.lua
Merci,
Le log faisait partie des éléments perdus.
Le re-voici donc :
Trouver :
Entrer la phrase
Tag :
Type :
RÉINITIALISER
[20.01.2023] [10:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [10:28:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur -1.0°C
[20.01.2023] [10:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.3,"Ki":3}
[20.01.2023] [10:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [10:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 37.5% | D = -0.3% | 31.0%
[20.01.2023] [10:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 32s
[20.01.2023] [10:28:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [10:29:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [10:29:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [10:29:35] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [10:30:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.2°C
[20.01.2023] [10:30:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [10:31:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [10:32:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [10:32:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [10:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [10:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur -1.0°C
[20.01.2023] [10:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [10:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [10:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.3% | 38.0%
[20.01.2023] [10:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 52s
[20.01.2023] [10:34:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [10:34:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [10:35:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [10:35:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [10:36:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [10:37:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [10:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [10:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur -1.0°C
[20.01.2023] [10:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":0.2,"Ki":3}
[20.01.2023] [10:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [10:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 38.1% | D = 0.2% | 42.0%
[20.01.2023] [10:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 06s
[20.01.2023] [10:39:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [10:39:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[20.01.2023] [10:40:08] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [10:40:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [10:41:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [10:42:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [10:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [10:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur -1.0°C
[20.01.2023] [10:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":-0.3,"Ki":3}
[20.01.2023] [10:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[20.01.2023] [10:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 37.2% | D = -0.5% | 31.0%
[20.01.2023] [10:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 31s
[20.01.2023] [10:43:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [10:44:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.7°C
[20.01.2023] [10:44:34] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [10:44:53] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.3°C
[20.01.2023] [10:45:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [10:46:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [10:47:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.8°C
[20.01.2023] [10:47:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [10:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [10:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur -1.0°C
[20.01.2023] [10:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":-0.0,"Ki":3}
[20.01.2023] [10:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[20.01.2023] [10:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.2% | D = 0.3% | 38.0%
[20.01.2023] [10:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 51s
[20.01.2023] [10:48:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [10:49:54] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [10:50:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.8°C
[20.01.2023] [10:51:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [10:52:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [10:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [10:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur -1.0°C
[20.01.2023] [10:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":0.2,"Ki":3}
[20.01.2023] [10:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [10:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 37.8% | D = 0.2% | 42.0%
[20.01.2023] [10:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 05s
[20.01.2023] [10:54:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.8°C
[20.01.2023] [10:55:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [10:55:08] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [10:55:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.1°C
[20.01.2023] [10:56:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [10:56:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [10:57:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [10:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [10:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [10:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur -1.0°C
[20.01.2023] [10:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.1,"Ki":3}
[20.01.2023] [10:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [10:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 37.5% | D = -0.3% | 35.0%
[20.01.2023] [10:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 44s
[20.01.2023] [10:59:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [10:59:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [10:59:47] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [11:00:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.1°C
[20.01.2023] [11:00:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [11:01:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [11:02:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [11:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [11:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur -1.0°C
[20.01.2023] [11:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.3,"lastError":-0.2,"Ki":3}
[20.01.2023] [11:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.3
[20.01.2023] [11:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 36.9% | D = -0.1% | 33.0%
[20.01.2023] [11:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 37s
[20.01.2023] [11:03:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [11:04:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [11:04:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [11:04:39] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [11:05:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [11:05:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [11:06:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [11:33:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [11:34:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.7°C
[20.01.2023] [11:34:34] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [11:34:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [11:36:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [11:37:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [11:38:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [11:38:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.9°C
[20.01.2023] [11:38:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [11:38:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [11:38:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.3% | 38.0%
[20.01.2023] [11:38:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 52s
[20.01.2023] [11:38:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [11:39:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [11:40:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.8°C
[20.01.2023] [11:41:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [11:42:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [11:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [11:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 1.9°C
[20.01.2023] [11:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":0.2,"Ki":3}
[20.01.2023] [11:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [11:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 38.1% | D = 0.2% | 42.0%
[20.01.2023] [11:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 06s
[20.01.2023] [11:44:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.8°C
[20.01.2023] [11:44:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [11:45:08] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [11:45:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.1°C
[20.01.2023] [11:46:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [11:46:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [11:47:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [11:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [11:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [11:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 1.9°C
[20.01.2023] [11:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.1,"Ki":3}
[20.01.2023] [11:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [11:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 37.8% | D = -0.3% | 36.0%
[20.01.2023] [11:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 45s
[20.01.2023] [11:49:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [11:49:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [11:49:48] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [11:50:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.2°C
[20.01.2023] [11:50:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [11:51:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [11:52:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [11:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.9°C
[20.01.2023] [11:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [11:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 1.9°C
[20.01.2023] [11:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.1,"Ki":3}
[20.01.2023] [11:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [11:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 37.5% | D = 0.0% | 36.0%
[20.01.2023] [11:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 45s
[20.01.2023] [11:53:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [11:54:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.9°C
[20.01.2023] [11:54:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [11:54:48] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [11:55:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [11:56:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [11:57:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [11:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [11:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [11:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.9°C
[20.01.2023] [11:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [11:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [11:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.1% | 38.0%
[20.01.2023] [11:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 52s
[20.01.2023] [11:59:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [11:59:54] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:00:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [12:00:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.2°C
[20.01.2023] [12:01:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [12:02:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [12:03:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [12:03:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:03:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.9°C
[20.01.2023] [12:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [12:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [12:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.0% | 38.0%
[20.01.2023] [12:03:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 51s
[20.01.2023] [12:04:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.5°C
[20.01.2023] [12:04:54] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:05:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [12:06:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [12:07:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [12:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [12:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 1.9°C
[20.01.2023] [12:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":-0.1,"Ki":3}
[20.01.2023] [12:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[20.01.2023] [12:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 37.2% | D = -0.1% | 35.0%
[20.01.2023] [12:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 44s
[20.01.2023] [12:09:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [12:09:47] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:10:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [12:11:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [12:12:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [12:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [12:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.9°C
[20.01.2023] [12:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":-0.0,"Ki":3}
[20.01.2023] [12:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[20.01.2023] [12:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.2% | D = 0.1% | 37.0%
[20.01.2023] [12:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 51s
[20.01.2023] [12:14:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [12:14:53] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:15:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [12:17:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [12:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 1.9°C
[20.01.2023] [12:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":0.2,"Ki":3}
[20.01.2023] [12:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [12:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 37.8% | D = 0.2% | 42.0%
[20.01.2023] [12:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 05s
[20.01.2023] [12:18:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [12:19:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [12:19:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [12:20:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[20.01.2023] [12:20:08] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:20:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [12:21:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [12:21:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [12:22:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [12:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 1.9°C
[20.01.2023] [12:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":-0.2,"Ki":3}
[20.01.2023] [12:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[20.01.2023] [12:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.2% | D = -0.4% | 33.0%
[20.01.2023] [12:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 37s
[20.01.2023] [12:23:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [12:24:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [12:24:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [12:24:40] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:25:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [12:25:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [12:26:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [12:27:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [12:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:28:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.9°C
[20.01.2023] [12:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":-0.0,"Ki":3}
[20.01.2023] [12:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[20.01.2023] [12:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.2% | D = 0.2% | 37.0%
[20.01.2023] [12:28:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 51s
[20.01.2023] [12:28:43] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [12:29:54] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:30:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [12:31:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [12:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [12:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 1.9°C
[20.01.2023] [12:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":0.4,"Ki":3}
[20.01.2023] [12:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [12:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 38.4% | D = 0.4% | 47.0%
[20.01.2023] [12:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 19s
[20.01.2023] [12:34:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [12:34:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [12:35:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [12:35:22] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:35:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [12:36:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.2°C
[20.01.2023] [12:36:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [12:37:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [12:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 1.9°C
[20.01.2023] [12:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.3,"Ki":3}
[20.01.2023] [12:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [12:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 37.5% | D = -0.7% | 31.0%
[20.01.2023] [12:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 31s
[20.01.2023] [12:38:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [12:39:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.9°C
[20.01.2023] [12:39:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [12:39:33] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:40:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.4°C
[20.01.2023] [12:40:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [12:41:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [12:42:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [12:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.9°C
[20.01.2023] [12:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [12:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [12:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.3% | 38.0%
[20.01.2023] [12:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 52s
[20.01.2023] [12:43:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [12:44:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:45:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [12:46:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [12:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 1.9°C
[20.01.2023] [12:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":0.2,"Ki":3}
[20.01.2023] [12:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [12:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 38.1% | D = 0.2% | 42.0%
[20.01.2023] [12:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 06s
[20.01.2023] [12:48:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [12:49:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [12:49:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [12:50:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [12:50:08] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:50:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [12:51:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [12:52:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [12:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 1.9°C
[20.01.2023] [12:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.2,"Ki":3}
[20.01.2023] [12:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [12:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.5% | D = -0.4% | 33.0%
[20.01.2023] [12:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 38s
[20.01.2023] [12:53:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [12:54:13] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [12:54:41] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [12:54:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [12:55:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.4°C
[20.01.2023] [12:55:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [12:57:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [12:57:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [12:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [12:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.9°C
[20.01.2023] [12:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [12:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [12:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.2% | 38.0%
[20.01.2023] [12:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 52s
[20.01.2023] [12:58:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.3°C
[20.01.2023] [12:59:54] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:00:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.2°C
[20.01.2023] [13:02:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [13:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 1.9°C
[20.01.2023] [13:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":0.4,"Ki":3}
[20.01.2023] [13:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [13:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 38.7% | D = 0.4% | 47.0%
[20.01.2023] [13:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 20s
[20.01.2023] [13:04:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.0°C
[20.01.2023] [13:05:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [13:05:22] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:05:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [13:20:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [13:20:25] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:20:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.2°C
[20.01.2023] [13:21:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [13:22:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [13:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 3.0°C
[20.01.2023] [13:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.3,"Ki":3}
[20.01.2023] [13:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [13:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 38.4% | D = -0.7% | 32.0%
[20.01.2023] [13:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 34s
[20.01.2023] [13:23:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [13:24:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [13:24:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [13:24:36] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:25:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.4°C
[20.01.2023] [13:25:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [13:26:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [13:27:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [13:28:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:28:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 3.0°C
[20.01.2023] [13:28:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.0,"Ki":3}
[20.01.2023] [13:28:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [13:28:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.4% | D = 0.3% | 39.0%
[20.01.2023] [13:28:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 55s
[20.01.2023] [13:28:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.1°C
[20.01.2023] [13:28:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [13:29:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.1°C
[20.01.2023] [13:29:58] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:30:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.0°C
[20.01.2023] [13:32:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [13:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [13:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 3.0°C
[20.01.2023] [13:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":0.4,"Ki":3}
[20.01.2023] [13:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [13:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 39.6% | D = 0.4% | 48.0%
[20.01.2023] [13:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 23s
[20.01.2023] [13:34:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.1°C
[20.01.2023] [13:34:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.8°C
[20.01.2023] [13:35:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [13:35:25] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:35:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.1°C
[20.01.2023] [13:36:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [13:37:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.6°C
[20.01.2023] [13:37:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [13:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 3.0°C
[20.01.2023] [13:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.0,"lastError":-0.2,"Ki":3}
[20.01.2023] [13:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.0
[20.01.2023] [13:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.0% | D = -0.6% | 34.0%
[20.01.2023] [13:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 42s
[20.01.2023] [13:38:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [13:39:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [13:39:44] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:40:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [13:40:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [13:41:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [13:42:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [13:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 3.0°C
[20.01.2023] [13:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":-0.1,"Ki":3}
[20.01.2023] [13:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [13:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 38.7% | D = 0.1% | 37.0%
[20.01.2023] [13:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 49s
[20.01.2023] [13:43:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [13:44:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [13:44:52] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:45:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.1°C
[20.01.2023] [13:46:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [13:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.5°C
[20.01.2023] [13:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.5°C | Extérieur 3.0°C
[20.01.2023] [13:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.4,"lastError":0.5,"Ki":3}
[20.01.2023] [13:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.4
[20.01.2023] [13:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 10.0% | I = 40.2% | D = 0.6% | 51.0%
[20.01.2023] [13:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.5°C | Début clim. 2m 31s
[20.01.2023] [13:49:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.2°C
[20.01.2023] [13:49:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [13:50:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[20.01.2023] [13:50:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [13:50:33] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:51:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.1°C
[20.01.2023] [13:51:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [13:52:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [13:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [13:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 3.0°C
[20.01.2023] [13:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.2,"Ki":3}
[20.01.2023] [13:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [13:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.6% | D = -0.7% | 35.0%
[20.01.2023] [13:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 44s
[20.01.2023] [13:54:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.9°C
[20.01.2023] [13:54:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [13:54:46] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [13:55:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.4°C
[20.01.2023] [13:56:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [13:56:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [13:57:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [13:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [13:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 3.0°C
[20.01.2023] [13:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.0,"Ki":3}
[20.01.2023] [13:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [13:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.6% | D = 0.2% | 40.0%
[20.01.2023] [13:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 58s
[20.01.2023] [13:59:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [14:00:01] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:00:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [14:01:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [14:02:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [14:03:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:03:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 3.0°C
[20.01.2023] [14:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.0,"lastError":-0.2,"Ki":3}
[20.01.2023] [14:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.0
[20.01.2023] [14:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.0% | D = -0.2% | 35.0%
[20.01.2023] [14:03:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 43s
[20.01.2023] [14:03:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [14:04:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [14:04:46] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:04:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [14:05:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [14:05:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [14:06:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [14:07:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [14:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 3.0°C
[20.01.2023] [14:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.0,"lastError":-0.0,"Ki":3}
[20.01.2023] [14:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.0
[20.01.2023] [14:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.0% | D = 0.2% | 39.0%
[20.01.2023] [14:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 56s
[20.01.2023] [14:09:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.5°C
[20.01.2023] [14:09:59] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:10:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [14:11:13] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [14:12:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [14:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 3.0°C
[20.01.2023] [14:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.2,"Ki":3}
[20.01.2023] [14:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [14:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 38.4% | D = -0.2% | 34.0%
[20.01.2023] [14:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 41s
[20.01.2023] [14:13:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [14:14:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [14:14:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [14:14:44] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:15:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [14:15:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [14:16:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [14:17:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [14:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 3.0°C
[20.01.2023] [14:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.0,"Ki":3}
[20.01.2023] [14:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [14:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.4% | D = 0.2% | 39.0%
[20.01.2023] [14:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 55s
[20.01.2023] [14:19:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [14:19:57] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:20:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [14:21:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [14:22:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [14:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 3.0°C
[20.01.2023] [14:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.2,"Ki":3}
[20.01.2023] [14:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [14:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.8% | D = -0.2% | 34.0%
[20.01.2023] [14:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 40s
[20.01.2023] [14:23:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [14:24:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [14:24:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [14:24:42] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:25:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [14:25:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [14:26:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [14:27:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [14:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:28:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 3.0°C
[20.01.2023] [14:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.0,"Ki":3}
[20.01.2023] [14:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [14:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.8% | D = 0.2% | 38.0%
[20.01.2023] [14:28:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 53s
[20.01.2023] [14:28:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [14:29:56] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:30:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [14:32:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [14:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 3.0°C
[20.01.2023] [14:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":0.2,"Ki":3}
[20.01.2023] [14:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [14:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 38.4% | D = 0.2% | 43.0%
[20.01.2023] [14:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 06s
[20.01.2023] [14:33:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [14:34:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [14:34:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [14:35:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [14:35:09] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:35:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [14:36:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [14:37:13] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [14:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 3.0°C
[20.01.2023] [14:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.2,"Ki":3}
[20.01.2023] [14:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [14:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.8% | D = -0.4% | 33.0%
[20.01.2023] [14:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 39s
[20.01.2023] [14:38:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [14:39:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [14:39:41] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:39:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [14:41:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [14:42:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [14:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 3.0°C
[20.01.2023] [14:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.0,"Ki":3}
[20.01.2023] [14:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [14:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.8% | D = 0.2% | 38.0%
[20.01.2023] [14:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 53s
[20.01.2023] [14:43:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [14:44:56] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:45:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [14:46:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [14:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [14:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 3.0°C
[20.01.2023] [14:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.0,"lastError":0.4,"Ki":3}
[20.01.2023] [14:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.0
[20.01.2023] [14:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 39.0% | D = 0.4% | 47.0%
[20.01.2023] [14:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 21s
[20.01.2023] [14:49:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [14:49:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [14:50:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [14:50:23] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:50:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.2°C
[20.01.2023] [14:51:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [14:52:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [14:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 3.0°C
[20.01.2023] [14:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":-0.3,"Ki":3}
[20.01.2023] [14:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [14:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 38.1% | D = -0.7% | 31.0%
[20.01.2023] [14:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 33s
[20.01.2023] [14:53:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [14:54:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [14:54:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [14:54:36] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [14:55:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.4°C
[20.01.2023] [14:55:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [14:56:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [14:57:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [14:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [14:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 3.0°C
[20.01.2023] [14:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":-0.0,"Ki":3}
[20.01.2023] [14:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [14:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.1% | D = 0.3% | 38.0%
[20.01.2023] [14:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 54s
[20.01.2023] [14:58:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [14:58:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.3°C
[20.01.2023] [14:59:56] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:00:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.1°C
[20.01.2023] [15:01:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [15:03:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:03:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 3.0°C
[20.01.2023] [15:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.0,"lastError":0.3,"Ki":3}
[20.01.2023] [15:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.0
[20.01.2023] [15:03:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 39.0% | D = 0.3% | 45.0%
[20.01.2023] [15:03:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 14s
[20.01.2023] [15:03:13] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.5°C
[20.01.2023] [15:03:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.3°C
[20.01.2023] [15:04:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.0°C
[20.01.2023] [15:04:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.7°C
[20.01.2023] [15:05:18] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:05:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [15:06:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [15:07:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [15:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 4.2°C
[20.01.2023] [15:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.2,"Ki":3}
[20.01.2023] [15:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [15:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 38.4% | D = -0.5% | 34.0%
[20.01.2023] [15:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 41s
[20.01.2023] [15:08:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [15:09:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [15:09:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [15:09:43] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:10:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [15:10:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [15:11:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [15:12:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [15:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [15:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.0,"Ki":3}
[20.01.2023] [15:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [15:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.4% | D = 0.2% | 39.0%
[20.01.2023] [15:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 55s
[20.01.2023] [15:13:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [15:14:57] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:15:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [15:16:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [15:17:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [15:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 4.2°C
[20.01.2023] [15:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":0.4,"Ki":3}
[20.01.2023] [15:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [15:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 39.6% | D = 0.4% | 48.0%
[20.01.2023] [15:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 23s
[20.01.2023] [15:19:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [15:19:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [15:20:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [15:20:25] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:20:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [15:21:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [15:22:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [15:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [15:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 4.2°C
[20.01.2023] [15:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":-0.1,"Ki":3}
[20.01.2023] [15:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [15:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 39.3% | D = -0.5% | 37.0%
[20.01.2023] [15:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 49s
[20.01.2023] [15:24:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [15:31:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [15:32:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [15:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [15:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [15:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":-0.0,"Ki":3}
[20.01.2023] [15:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [15:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.3% | D = 0.0% | 39.0%
[20.01.2023] [15:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 57s
[20.01.2023] [15:34:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [15:34:59] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:35:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [15:36:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [15:37:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [15:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [15:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [15:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":-0.0,"Ki":3}
[20.01.2023] [15:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [15:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.3% | D = 0.0% | 39.0%
[20.01.2023] [15:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 57s
[20.01.2023] [15:39:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [15:39:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [15:39:59] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:40:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [15:41:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [15:42:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [15:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 4.2°C
[20.01.2023] [15:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.3,"Ki":3}
[20.01.2023] [15:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [15:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 38.4% | D = -0.3% | 32.0%
[20.01.2023] [15:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 35s
[20.01.2023] [15:43:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [15:44:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [15:44:38] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:44:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [15:46:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [15:47:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [15:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [15:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.0,"Ki":3}
[20.01.2023] [15:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [15:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.4% | D = 0.3% | 39.0%
[20.01.2023] [15:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 55s
[20.01.2023] [15:48:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [15:49:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [15:49:57] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:50:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.1°C
[20.01.2023] [15:52:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [15:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 4.2°C
[20.01.2023] [15:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":0.3,"Ki":3}
[20.01.2023] [15:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [15:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 39.3% | D = 0.3% | 46.0%
[20.01.2023] [15:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 15s
[20.01.2023] [15:53:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.5°C
[20.01.2023] [15:53:53] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.3°C
[20.01.2023] [15:54:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.0°C
[20.01.2023] [15:54:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [15:55:18] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [15:55:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [15:56:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [15:57:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [15:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [15:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 4.2°C
[20.01.2023] [15:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":-0.2,"Ki":3}
[20.01.2023] [15:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [15:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 38.7% | D = -0.5% | 34.0%
[20.01.2023] [15:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 41s
[20.01.2023] [15:58:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [15:59:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [15:59:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [15:59:44] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:00:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [16:00:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [16:01:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [16:02:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [16:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [16:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":-0.0,"Ki":3}
[20.01.2023] [16:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [16:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.7% | D = 0.2% | 39.0%
[20.01.2023] [16:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 55s
[20.01.2023] [16:03:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [16:04:58] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:05:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [16:06:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [16:07:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.3°C
[20.01.2023] [16:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 4.2°C
[20.01.2023] [16:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":0.3,"Ki":3}
[20.01.2023] [16:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [16:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 39.6% | D = 0.3% | 46.0%
[20.01.2023] [16:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 16s
[20.01.2023] [16:08:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.5°C
[20.01.2023] [16:09:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.2°C
[20.01.2023] [16:09:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [16:10:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [16:10:19] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:10:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [16:11:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [16:12:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [16:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 4.2°C
[20.01.2023] [16:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.0,"lastError":-0.2,"Ki":3}
[20.01.2023] [16:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.0
[20.01.2023] [16:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.0% | D = -0.5% | 35.0%
[20.01.2023] [16:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 42s
[20.01.2023] [16:13:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [16:14:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [16:14:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [16:14:45] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:15:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [16:15:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [16:16:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [16:17:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [16:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [16:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.0,"lastError":-0.0,"Ki":3}
[20.01.2023] [16:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.0
[20.01.2023] [16:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.0% | D = 0.2% | 39.0%
[20.01.2023] [16:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 56s
[20.01.2023] [16:18:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [16:19:59] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:20:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [16:21:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [16:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [16:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 4.2°C
[20.01.2023] [16:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.4,"lastError":0.4,"Ki":3}
[20.01.2023] [16:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.4
[20.01.2023] [16:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 40.2% | D = 0.4% | 49.0%
[20.01.2023] [16:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 24s
[20.01.2023] [16:24:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [16:24:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [16:25:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [16:25:27] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:25:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [16:26:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.2°C
[20.01.2023] [16:26:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [16:27:13] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [16:27:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [16:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:28:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 4.2°C
[20.01.2023] [16:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.2,"Ki":3}
[20.01.2023] [16:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [16:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.6% | D = -0.6% | 35.0%
[20.01.2023] [16:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 44s
[20.01.2023] [16:28:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [16:29:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [16:29:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [16:29:46] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:30:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [16:30:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [16:32:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [16:32:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [16:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [16:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.0,"Ki":3}
[20.01.2023] [16:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [16:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.6% | D = 0.2% | 40.0%
[20.01.2023] [16:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 58s
[20.01.2023] [16:33:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [16:35:01] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:35:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [16:37:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [16:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 4.2°C
[20.01.2023] [16:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.4,"lastError":0.2,"Ki":3}
[20.01.2023] [16:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.4
[20.01.2023] [16:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 40.2% | D = 0.2% | 44.0%
[20.01.2023] [16:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 12s
[20.01.2023] [16:38:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [16:39:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.1°C
[20.01.2023] [16:39:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.8°C
[20.01.2023] [16:40:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [16:40:14] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:40:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.1°C
[20.01.2023] [16:41:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [16:41:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [16:42:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [16:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [16:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 4.2°C
[20.01.2023] [16:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.3,"lastError":-0.1,"Ki":3}
[20.01.2023] [16:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.3
[20.01.2023] [16:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 39.9% | D = -0.3% | 38.0%
[20.01.2023] [16:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 52s
[20.01.2023] [16:44:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[20.01.2023] [16:44:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:45:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.1°C
[20.01.2023] [16:45:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [16:46:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.6°C
[20.01.2023] [16:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [16:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 4.2°C
[20.01.2023] [16:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":-0.2,"Ki":3}
[20.01.2023] [16:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [16:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.3% | D = -0.1% | 35.0%
[20.01.2023] [16:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 44s
[20.01.2023] [16:48:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [16:49:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [16:49:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [16:49:47] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:50:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [16:50:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [16:51:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [16:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [16:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 4.2°C
[20.01.2023] [16:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":-0.0,"Ki":3}
[20.01.2023] [16:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [16:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.3% | D = 0.2% | 40.0%
[20.01.2023] [16:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 57s
[20.01.2023] [16:54:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [16:54:59] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [16:55:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [16:56:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [16:57:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [16:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [16:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 4.2°C
[20.01.2023] [16:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.4,"lastError":0.3,"Ki":3}
[20.01.2023] [16:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.4
[20.01.2023] [16:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 40.2% | D = 0.3% | 47.0%
[20.01.2023] [16:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 18s
[20.01.2023] [16:59:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 12.8°C
[20.01.2023] [16:59:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [17:00:21] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:00:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.1°C
[20.01.2023] [17:01:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [17:01:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [17:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [17:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 4.2°C
[20.01.2023] [17:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.2,"Ki":3}
[20.01.2023] [17:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [17:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.6% | D = -0.5% | 35.0%
[20.01.2023] [17:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 44s
[20.01.2023] [17:04:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [17:04:47] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:05:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [17:05:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [17:06:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [17:07:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [17:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 2.9°C
[20.01.2023] [17:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.0,"Ki":3}
[20.01.2023] [17:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [17:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.6% | D = 0.2% | 40.0%
[20.01.2023] [17:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 58s
[20.01.2023] [17:09:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [17:10:01] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:10:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [17:10:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.9°C
[20.01.2023] [17:11:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [17:12:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [17:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 2.9°C
[20.01.2023] [17:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.5,"lastError":0.3,"Ki":3}
[20.01.2023] [17:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.5
[20.01.2023] [17:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 40.5% | D = 0.3% | 47.0%
[20.01.2023] [17:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 19s
[20.01.2023] [17:14:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 12.9°C
[20.01.2023] [17:14:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[20.01.2023] [17:15:22] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:15:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [17:16:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [17:17:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [17:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 2.9°C
[20.01.2023] [17:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.3,"Ki":3}
[20.01.2023] [17:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [17:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 39.6% | D = -0.6% | 33.0%
[20.01.2023] [17:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 38s
[20.01.2023] [17:18:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [17:19:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.7°C
[20.01.2023] [17:19:40] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:19:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [17:20:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.3°C
[20.01.2023] [17:20:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [17:22:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [17:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [17:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 2.9°C
[20.01.2023] [17:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.2,"lastError":-0.0,"Ki":3}
[20.01.2023] [17:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.2
[20.01.2023] [17:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.6% | D = 0.3% | 40.0%
[20.01.2023] [17:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 58s
[20.01.2023] [17:24:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [17:24:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [17:25:01] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:25:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [17:26:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [17:27:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [17:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:28:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 2.9°C
[20.01.2023] [17:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.4,"lastError":0.2,"Ki":3}
[20.01.2023] [17:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.4
[20.01.2023] [17:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 40.2% | D = 0.2% | 44.0%
[20.01.2023] [17:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 12s
[20.01.2023] [17:29:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [17:29:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [17:30:14] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:30:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [17:31:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [17:32:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [17:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [17:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:33:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 2.9°C
[20.01.2023] [17:33:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.3,"lastError":-0.1,"Ki":3}
[20.01.2023] [17:33:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.3
[20.01.2023] [17:33:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 39.9% | D = -0.3% | 38.0%
[20.01.2023] [17:33:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 52s
[20.01.2023] [17:34:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [17:34:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [17:34:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:35:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.1°C
[20.01.2023] [17:35:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [17:36:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.6°C
[20.01.2023] [17:37:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [17:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 2.9°C
[20.01.2023] [17:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":-0.2,"Ki":3}
[20.01.2023] [17:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [17:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 39.3% | D = -0.1% | 35.0%
[20.01.2023] [17:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 44s
[20.01.2023] [17:38:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [17:38:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [17:39:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [17:39:47] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:39:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [17:40:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.2°C
[20.01.2023] [17:40:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [17:42:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [17:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [17:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 2.9°C
[20.01.2023] [17:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.1,"lastError":-0.0,"Ki":3}
[20.01.2023] [17:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.1
[20.01.2023] [17:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 39.3% | D = 0.2% | 40.0%
[20.01.2023] [17:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 57s
[20.01.2023] [17:44:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [17:45:00] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:45:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [17:45:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.1°C
[20.01.2023] [17:46:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [17:46:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [17:47:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [17:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 2.9°C
[20.01.2023] [17:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":-0.2,"Ki":3}
[20.01.2023] [17:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [17:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 38.7% | D = -0.2% | 35.0%
[20.01.2023] [17:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 42s
[20.01.2023] [17:48:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [17:49:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [17:49:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [17:49:45] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:50:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [17:50:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [17:51:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [17:52:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [17:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 2.9°C
[20.01.2023] [17:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.8,"lastError":-0.1,"Ki":3}
[20.01.2023] [17:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.8
[20.01.2023] [17:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 38.4% | D = 0.1% | 37.0%
[20.01.2023] [17:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 48s
[20.01.2023] [17:53:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.0°C
[20.01.2023] [17:54:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [17:54:51] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [17:54:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [17:55:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.1°C
[20.01.2023] [17:55:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [17:56:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [17:57:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [17:58:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [17:58:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 2.9°C
[20.01.2023] [17:58:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.2,"Ki":3}
[20.01.2023] [17:58:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [17:58:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.8% | D = -0.1% | 34.0%
[20.01.2023] [17:58:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 40s
[20.01.2023] [17:58:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [17:59:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [17:59:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [17:59:43] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:00:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [18:01:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [18:02:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [18:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [18:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 2.9°C
[20.01.2023] [18:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.0,"Ki":3}
[20.01.2023] [18:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [18:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.8% | D = 0.2% | 38.0%
[20.01.2023] [18:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 53s
[20.01.2023] [18:04:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [18:04:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [18:04:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:05:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.1°C
[20.01.2023] [18:05:02] [WARNING] [QUICKAPP846]: Cave Vins : Cave_AirCo a été modifié - vérifiez que seul HCM le contrôle
[20.01.2023] [18:05:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.0°C
[20.01.2023] [18:06:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.0°C => 12.2°C
[20.01.2023] [18:06:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [18:07:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [18:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 2.9°C
[20.01.2023] [18:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.3,"lastError":-0.3,"Ki":3}
[20.01.2023] [18:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.3
[20.01.2023] [18:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 36.9% | D = -0.3% | 31.0%
[20.01.2023] [18:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 31s
[20.01.2023] [18:08:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [18:09:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [18:09:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [18:09:33] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:11:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [18:12:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [18:12:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.9°C
[20.01.2023] [18:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 2.9°C
[20.01.2023] [18:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.2,"lastError":-0.1,"Ki":3}
[20.01.2023] [18:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.2
[20.01.2023] [18:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 36.6% | D = 0.2% | 35.0%
[20.01.2023] [18:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 43s
[20.01.2023] [18:13:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [18:14:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [18:14:46] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:14:53] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.1°C
[20.01.2023] [18:15:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.9°C
[20.01.2023] [18:16:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [18:17:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [18:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 2.9°C
[20.01.2023] [18:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":0.3,"Ki":3}
[20.01.2023] [18:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [18:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 37.5% | D = 0.4% | 44.0%
[20.01.2023] [18:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 10s
[20.01.2023] [18:19:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 12.9°C
[20.01.2023] [18:19:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [18:20:13] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:20:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.2°C
[20.01.2023] [18:21:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [18:22:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [18:22:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [18:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:23:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 2.9°C
[20.01.2023] [18:23:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.3,"lastError":-0.2,"Ki":3}
[20.01.2023] [18:23:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.3
[20.01.2023] [18:23:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 36.9% | D = -0.5% | 32.0%
[20.01.2023] [18:23:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 36s
[20.01.2023] [18:23:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.9°C
[20.01.2023] [18:24:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [18:24:39] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:24:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [18:25:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.3°C
[20.01.2023] [18:25:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [18:26:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [18:27:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [18:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:28:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 2.9°C
[20.01.2023] [18:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.3,"lastError":-0.0,"Ki":3}
[20.01.2023] [18:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.3
[20.01.2023] [18:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 36.9% | D = 0.2% | 37.0%
[20.01.2023] [18:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 50s
[20.01.2023] [18:28:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [18:29:53] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:30:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [18:31:53] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [18:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 2.9°C
[20.01.2023] [18:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":0.2,"Ki":3}
[20.01.2023] [18:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [18:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 37.5% | D = 0.2% | 42.0%
[20.01.2023] [18:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 04s
[20.01.2023] [18:33:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [18:33:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [18:34:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [18:34:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [18:35:06] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:35:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [18:36:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [18:37:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [18:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:38:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 2.9°C
[20.01.2023] [18:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.3,"lastError":-0.2,"Ki":3}
[20.01.2023] [18:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.3
[20.01.2023] [18:38:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 36.9% | D = -0.4% | 33.0%
[20.01.2023] [18:38:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 36s
[20.01.2023] [18:38:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [18:39:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [18:39:39] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:39:43] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [18:40:13] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [18:40:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [18:41:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [18:42:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [18:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 2.9°C
[20.01.2023] [18:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.2,"lastError":-0.1,"Ki":3}
[20.01.2023] [18:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.2
[20.01.2023] [18:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 36.6% | D = 0.1% | 35.0%
[20.01.2023] [18:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 43s
[20.01.2023] [18:43:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [18:44:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [18:44:45] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:45:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.1°C
[20.01.2023] [18:46:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [18:47:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.5°C
[20.01.2023] [18:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:48:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.5°C | Extérieur 2.9°C
[20.01.2023] [18:48:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":0.5,"Ki":3}
[20.01.2023] [18:48:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [18:48:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 10.0% | I = 38.1% | D = 0.6% | 49.0%
[20.01.2023] [18:48:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.5°C | Début clim. 2m 25s
[20.01.2023] [18:49:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.3°C
[20.01.2023] [18:49:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.0°C
[20.01.2023] [18:50:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [18:50:28] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:50:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.2°C
[20.01.2023] [18:51:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.0°C
[20.01.2023] [18:51:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.0°C => 12.2°C
[20.01.2023] [18:52:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [18:52:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [18:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [18:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 2.9°C
[20.01.2023] [18:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.2,"Ki":3}
[20.01.2023] [18:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [18:53:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.5% | D = -0.7% | 33.0%
[20.01.2023] [18:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 37s
[20.01.2023] [18:54:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.9°C
[20.01.2023] [18:54:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.6°C
[20.01.2023] [18:54:40] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [18:54:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [18:55:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [18:56:33] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [18:57:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [18:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [18:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 2.9°C
[20.01.2023] [18:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":-0.1,"Ki":3}
[20.01.2023] [18:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[20.01.2023] [18:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 37.2% | D = 0.1% | 35.0%
[20.01.2023] [18:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 45s
[20.01.2023] [18:58:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [18:59:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [18:59:47] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:00:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.1°C
[20.01.2023] [19:01:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[20.01.2023] [19:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 2.9°C
[20.01.2023] [19:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":0.3,"Ki":3}
[20.01.2023] [19:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [19:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 38.1% | D = 0.4% | 45.0%
[20.01.2023] [19:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 12s
[20.01.2023] [19:03:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.5°C
[20.01.2023] [19:03:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.3°C
[20.01.2023] [19:04:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.0°C
[20.01.2023] [19:04:53] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [19:05:15] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:05:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [19:05:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.2°C
[20.01.2023] [19:06:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [19:07:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [19:07:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [19:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 1.5°C
[20.01.2023] [19:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.2,"Ki":3}
[20.01.2023] [19:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [19:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.5% | D = -0.5% | 33.0%
[20.01.2023] [19:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 38s
[20.01.2023] [19:08:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.9°C
[20.01.2023] [19:09:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.7°C
[20.01.2023] [19:09:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.4°C
[20.01.2023] [19:09:40] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:10:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.1°C
[20.01.2023] [19:10:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [19:11:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [19:12:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [19:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [19:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:13:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.5°C
[20.01.2023] [19:13:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [19:13:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [19:13:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.2% | 38.0%
[20.01.2023] [19:13:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 52s
[20.01.2023] [19:14:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [19:14:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:15:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [19:17:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [19:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 1.5°C
[20.01.2023] [19:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":0.2,"Ki":3}
[20.01.2023] [19:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [19:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 38.1% | D = 0.2% | 42.0%
[20.01.2023] [19:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 06s
[20.01.2023] [19:18:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [19:19:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.1°C
[20.01.2023] [19:19:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.7°C
[20.01.2023] [19:20:08] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:20:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.5°C
[20.01.2023] [19:20:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [19:21:13] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [19:22:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [19:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:23:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 1.5°C
[20.01.2023] [19:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.2,"Ki":3}
[20.01.2023] [19:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [19:23:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 37.5% | D = -0.4% | 33.0%
[20.01.2023] [19:23:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 38s
[20.01.2023] [19:23:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [19:24:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [19:24:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[20.01.2023] [19:24:40] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:25:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.4°C
[20.01.2023] [19:25:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[20.01.2023] [19:26:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[20.01.2023] [19:27:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [19:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:28:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.5°C
[20.01.2023] [19:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.5,"lastError":-0.0,"Ki":3}
[20.01.2023] [19:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.5
[20.01.2023] [19:28:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.5% | D = 0.2% | 38.0%
[20.01.2023] [19:28:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 52s
[20.01.2023] [19:28:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [19:29:55] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:30:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [19:31:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [19:32:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [19:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:33:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 1.5°C
[20.01.2023] [19:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":0.4,"Ki":3}
[20.01.2023] [19:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [19:33:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 38.7% | D = 0.4% | 47.0%
[20.01.2023] [19:33:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 20s
[20.01.2023] [19:34:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [19:34:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [19:35:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[20.01.2023] [19:35:22] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:35:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [19:36:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [19:37:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[20.01.2023] [19:38:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:38:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 1.5°C
[20.01.2023] [19:38:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.3,"Ki":3}
[20.01.2023] [19:38:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [19:38:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 37.8% | D = -0.7% | 31.0%
[20.01.2023] [19:38:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 32s
[20.01.2023] [19:38:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [19:39:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [19:39:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [19:39:35] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:40:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [19:40:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [19:41:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [19:42:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [19:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:43:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.5°C
[20.01.2023] [19:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.0,"Ki":3}
[20.01.2023] [19:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[20.01.2023] [19:43:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 37.8% | D = 0.3% | 38.0%
[20.01.2023] [19:43:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 53s
[20.01.2023] [19:43:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [19:44:56] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:45:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[20.01.2023] [19:47:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.3°C
[20.01.2023] [19:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:48:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur 1.5°C
[20.01.2023] [19:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":0.3,"Ki":3}
[20.01.2023] [19:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [19:48:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 38.7% | D = 0.3% | 45.0%
[20.01.2023] [19:48:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 14s
[20.01.2023] [19:49:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.0°C
[20.01.2023] [19:49:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.6°C
[20.01.2023] [19:50:16] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:50:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[20.01.2023] [19:51:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [19:52:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [19:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [19:53:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:53:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.5°C
[20.01.2023] [19:53:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":-0.0,"Ki":3}
[20.01.2023] [19:53:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [19:53:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.7% | D = -0.3% | 38.0%
[20.01.2023] [19:53:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 54s
[20.01.2023] [19:54:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [19:54:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [19:54:57] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [19:55:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [19:56:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [19:57:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.8°C
[20.01.2023] [19:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [19:58:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur 1.5°C
[20.01.2023] [19:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":-0.2,"Ki":3}
[20.01.2023] [19:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [19:58:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 38.1% | D = -0.2% | 34.0%
[20.01.2023] [19:58:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 41s
[20.01.2023] [19:58:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [19:59:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [19:59:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[20.01.2023] [19:59:43] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [20:00:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[20.01.2023] [20:00:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [20:01:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [20:02:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[20.01.2023] [20:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [20:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur 1.5°C
[20.01.2023] [20:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":-0.0,"Ki":3}
[20.01.2023] [20:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [20:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 38.1% | D = 0.2% | 38.0%
[20.01.2023] [20:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 54s
[20.01.2023] [20:03:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.3°C
[20.01.2023] [20:04:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.5°C
[20.01.2023] [20:04:56] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [20:06:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.7°C
[20.01.2023] [20:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [20:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.7°C | Extérieur 1.5°C
[20.01.2023] [20:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":13.4,"lastError":0.7,"Ki":3}
[20.01.2023] [20:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 13.4
[20.01.2023] [20:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 14.0% | I = 40.2% | D = 0.7% | 55.0%
[20.01.2023] [20:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.7°C | Début clim. 2m 43s
[20.01.2023] [20:10:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.7°C => 13.3°C
[20.01.2023] [20:10:46] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [20:10:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 13.0°C
[20.01.2023] [20:11:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[20.01.2023] [20:11:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [22:00:43] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.1°C => 12.3°C
[20.01.2023] [22:01:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[20.01.2023] [22:02:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[20.01.2023] [22:02:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[20.01.2023] [22:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [22:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur 1.0°C
[20.01.2023] [22:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":-0.1,"Ki":3}
[20.01.2023] [22:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[20.01.2023] [22:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 38.1% | D = 0.2% | 36.0%
[20.01.2023] [22:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 48s
[20.01.2023] [22:03:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[20.01.2023] [22:04:50] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [22:05:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 12.8°C
[20.01.2023] [22:06:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[20.01.2023] [22:07:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[20.01.2023] [22:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[20.01.2023] [22:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 1.0°C
[20.01.2023] [22:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":0.2,"Ki":3}
[20.01.2023] [22:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[20.01.2023] [22:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 38.7% | D = 0.3% | 43.0%
[20.01.2023] [22:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 08s
[20.01.2023] [22:08:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[20.01.2023] [22:08:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[20.01.2023] [22:09:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[20.01.2023] [22:09:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[20.01.2023] [22:10:11] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[20.01.2023] [22:10:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[20.01.2023] [22:11:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[20.01.2023] [22:12:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[21.01.2023] [00:01:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[21.01.2023] [00:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [00:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur 0.5°C
[21.01.2023] [00:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.7,"lastError":0.4,"Ki":3}
[21.01.2023] [00:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.7
[21.01.2023] [00:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 38.1% | D = 0.7% | 47.0%
[21.01.2023] [00:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 19s
[21.01.2023] [00:03:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.5°C
[21.01.2023] [00:05:21] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [00:05:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.5°C => 13.0°C
[21.01.2023] [00:07:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [00:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [00:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur 0.5°C
[21.01.2023] [00:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.9,"lastError":0.2,"Ki":3}
[21.01.2023] [00:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.9
[21.01.2023] [00:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 38.7% | D = -0.2% | 42.0%
[21.01.2023] [00:08:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 06s
[21.01.2023] [00:08:23] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[21.01.2023] [00:09:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[21.01.2023] [00:09:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.8°C
[21.01.2023] [00:10:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[21.01.2023] [00:10:09] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [00:10:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[21.01.2023] [00:11:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[21.01.2023] [00:12:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.7°C
[21.01.2023] [00:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [00:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur 0.5°C
[21.01.2023] [00:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.6,"lastError":-0.3,"Ki":3}
[21.01.2023] [00:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.6
[21.01.2023] [00:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 37.8% | D = -0.5% | 31.0%
[21.01.2023] [00:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 33s
[21.01.2023] [00:13:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[21.01.2023] [02:01:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[21.01.2023] [02:02:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[21.01.2023] [02:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [02:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.8°C | Extérieur -0.6°C
[21.01.2023] [02:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.1,"lastError":-0.2,"Ki":3}
[21.01.2023] [02:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.1
[21.01.2023] [02:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -4.0% | I = 36.3% | D = -0.4% | 32.0%
[21.01.2023] [02:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.8°C | Début clim. 1m 35s
[21.01.2023] [02:03:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[21.01.2023] [02:04:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[21.01.2023] [02:04:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.5°C
[21.01.2023] [02:04:37] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [02:05:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[21.01.2023] [02:05:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[21.01.2023] [02:06:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[21.01.2023] [02:07:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[21.01.2023] [02:08:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [02:08:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.9°C | Extérieur -0.6°C
[21.01.2023] [02:08:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.0,"lastError":-0.1,"Ki":3}
[21.01.2023] [02:08:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.0
[21.01.2023] [02:08:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -2.0% | I = 36.0% | D = 0.1% | 34.0%
[21.01.2023] [02:08:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.9°C | Début clim. 1m 41s
[21.01.2023] [02:08:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[21.01.2023] [02:09:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.2°C
[21.01.2023] [02:09:44] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [02:10:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[21.01.2023] [02:11:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [02:12:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[21.01.2023] [02:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [02:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur -0.6°C
[21.01.2023] [02:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":0.4,"Ki":3}
[21.01.2023] [02:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[21.01.2023] [02:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 37.2% | D = 0.5% | 46.0%
[21.01.2023] [02:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 16s
[21.01.2023] [02:14:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.6°C
[21.01.2023] [04:02:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[21.01.2023] [04:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [04:03:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur -2.4°C
[21.01.2023] [04:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.1,"lastError":-0.3,"Ki":3}
[21.01.2023] [04:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.1
[21.01.2023] [04:03:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 36.3% | D = -0.5% | 30.0%
[21.01.2023] [04:03:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 28s
[21.01.2023] [04:03:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[21.01.2023] [04:04:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[21.01.2023] [04:04:31] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [04:04:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.2°C
[21.01.2023] [04:05:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[21.01.2023] [04:06:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[21.01.2023] [04:07:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[21.01.2023] [04:07:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[21.01.2023] [04:08:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [04:08:03] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur -2.4°C
[21.01.2023] [04:08:03] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.1,"lastError":-0.0,"Ki":3}
[21.01.2023] [04:08:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.1
[21.01.2023] [04:08:03] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 36.3% | D = 0.3% | 37.0%
[21.01.2023] [04:08:03] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 49s
[21.01.2023] [04:08:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [04:09:52] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [04:10:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 12.9°C
[21.01.2023] [04:11:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[21.01.2023] [04:12:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[21.01.2023] [04:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [04:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur -2.4°C
[21.01.2023] [04:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.4,"lastError":0.3,"Ki":3}
[21.01.2023] [04:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.4
[21.01.2023] [04:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 37.2% | D = 0.3% | 44.0%
[21.01.2023] [04:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 09s
[21.01.2023] [04:14:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 12.8°C
[21.01.2023] [04:14:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.4°C
[21.01.2023] [04:15:12] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [04:15:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.0°C
[21.01.2023] [06:04:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [06:04:46] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [06:04:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[21.01.2023] [06:05:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.9°C
[21.01.2023] [06:06:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 13.1°C
[21.01.2023] [06:07:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.1°C => 13.3°C
[21.01.2023] [06:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [06:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.3°C | Extérieur -2.9°C
[21.01.2023] [06:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":11.9,"lastError":0.3,"Ki":3}
[21.01.2023] [06:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 11.9
[21.01.2023] [06:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 6.0% | I = 35.7% | D = 0.3% | 42.0%
[21.01.2023] [06:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.3°C | Début clim. 2m 05s
[21.01.2023] [06:09:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.3°C => 12.8°C
[21.01.2023] [06:09:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.4°C
[21.01.2023] [06:10:07] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [06:10:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.0°C
[21.01.2023] [06:11:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.0°C => 12.2°C
[21.01.2023] [06:12:12] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.5°C
[21.01.2023] [06:12:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[21.01.2023] [06:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [06:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.7°C | Extérieur -2.9°C
[21.01.2023] [06:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":11.6,"lastError":-0.3,"Ki":3}
[21.01.2023] [06:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 11.6
[21.01.2023] [06:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -6.0% | I = 34.8% | D = -0.6% | 28.0%
[21.01.2023] [06:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.7°C | Début clim. 1m 24s
[21.01.2023] [06:13:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 12.9°C
[21.01.2023] [06:14:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.9°C => 12.5°C
[21.01.2023] [06:14:26] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [06:14:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.3°C
[21.01.2023] [06:15:43] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[21.01.2023] [08:05:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[21.01.2023] [08:06:43] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
[21.01.2023] [08:07:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.7°C => 13.0°C
[21.01.2023] [08:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [08:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.0°C | Extérieur -3.1°C
[21.01.2023] [08:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.0,"lastError":-0.0,"Ki":3}
[21.01.2023] [08:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.0
[21.01.2023] [08:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -0.0% | I = 36.0% | D = 0.4% | 36.0%
[21.01.2023] [08:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.0°C | Début clim. 1m 48s
[21.01.2023] [08:08:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [08:09:50] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [08:09:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[21.01.2023] [08:10:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 12.8°C
[21.01.2023] [08:11:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 13.0°C
[21.01.2023] [08:12:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [08:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [08:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur -3.1°C
[21.01.2023] [08:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":12.2,"lastError":0.2,"Ki":3}
[21.01.2023] [08:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 12.2
[21.01.2023] [08:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 36.6% | D = 0.2% | 41.0%
[21.01.2023] [08:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 2m 01s
[21.01.2023] [08:14:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[21.01.2023] [08:15:04] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [08:15:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.0°C
[21.01.2023] [08:17:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [10:07:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [10:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [10:08:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.2°C | Extérieur -2.6°C
[21.01.2023] [10:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":11.5,"lastError":0.2,"Ki":3}
[21.01.2023] [10:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 11.5
[21.01.2023] [10:08:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 4.0% | I = 34.5% | D = 0.2% | 39.0%
[21.01.2023] [10:08:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.2°C | Début clim. 1m 55s
[21.01.2023] [10:08:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[21.01.2023] [10:09:57] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [10:10:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 13.2°C
[21.01.2023] [10:10:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.0°C
[21.01.2023] [10:11:42] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.0°C => 13.2°C
[21.01.2023] [10:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.2°C => 13.4°C
[21.01.2023] [10:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [10:13:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 13.4°C | Extérieur -2.6°C
[21.01.2023] [10:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":11.9,"lastError":0.4,"Ki":3}
[21.01.2023] [10:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 11.9
[21.01.2023] [10:13:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = 8.0% | I = 35.7% | D = 0.2% | 44.0%
[21.01.2023] [10:13:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 13.4°C | Début clim. 2m 10s
[21.01.2023] [10:14:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 13.4°C => 12.8°C
[21.01.2023] [10:15:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.3°C
[21.01.2023] [10:15:13] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [10:15:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.0°C
[21.01.2023] [10:16:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.0°C => 12.2°C
[21.01.2023] [10:16:52] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.2°C => 12.4°C
[21.01.2023] [10:17:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.4°C => 12.6°C
[21.01.2023] [10:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave_AirCo : Démarrage cycle PID (Cycle) (5m)
[21.01.2023] [10:18:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Consigne 13.0°C | Temp. 12.6°C | Extérieur -2.6°C
[21.01.2023] [10:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Storing: {"cumError":11.5,"lastError":-0.4,"Ki":3}
[21.01.2023] [10:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : Kp = 20 | Ki = 3 | Kd = 1 | EC = 11.5
[21.01.2023] [10:18:02] [DEBUG] [QUICKAPP846]: [-PID-] Cave_AirCo : P = -8.0% | I = 34.5% | D = -0.8% | 26.0%
[21.01.2023] [10:18:02] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : C 13.0°C | T 12.6°C | Début clim. 1m 16s
[21.01.2023] [10:18:22] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.8°C
[21.01.2023] [10:19:02] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.8°C => 12.6°C
[21.01.2023] [10:19:19] [DEBUG] [QUICKAPP846]: [REGUL] Cave Vins (Cave_AirCo) : Arrêt climatisation
[21.01.2023] [10:19:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.6°C => 12.3°C
[21.01.2023] [10:20:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.3°C => 12.5°C
[21.01.2023] [10:21:32] [DEBUG] [QUICKAPP846]: [INFO ] Cave_AirCo : Modif. Température 12.5°C => 12.7°C
il y a 42 minutes, Felig a dit :
le problème n'est pas seulement que le thermomètre ne reporte que les changements de 0.5°
j'ai donc corrigé ce problème, maintenant c'est 0,1°C
il y a 45 minutes, Felig a dit :
c'est que la température change très vite,
je confirme. Maintenant, dans la réalité, ça ne pose pas de problème, c'était pour de la geekerie (comme tu m'avais dit ne pas aimer le fluctuations > 0,2°C)
il y a 50 minutes, Felig a dit :
Entre-temps j'ai trouvé le bug de la version 5.16, donc ça tu peux laisser tomber. C'est corrigé dans la version ci-jointe.
super ! je la met en place !
voici le fqa avec ma config :
HM_PID_v5.15b.fqa
Pour répondre à ta question sur pourquoi la clim est arrêtée quand le thermomètre est au-dessus de la consigne, c'est normal. Dans les logs tu vois aussi l'inverse: la clim se déclenche même quand la température est inférieure à 13°. C'est pour tenir compte de l'inertie: quand tu déclenches la clim ça met du temps à faire effet, donc il ne faut pas attendre que la temp. remonte trop. Et inversement, quand tu arêtes, il y a un peu d'inertie normalement. Mais en l’occurrence l'inertie est super faible chez toi: quand on arrête la clim, la température continue à baisser pendant même pas une minute et ensuite remonte vite.
Essaie d'augmenter Kp à 100 et Ki à 6 stp, ça rendra la régulation plus agressive, voyons si c'est mieux. Et si les changements ne sont pas flagrants essaie Kp=150 ou 200. On est dans une configuration avec quasiment pas d'inertie.
L'autre solution c'est d'avoir des cycles plus courts. J'ai mis une durée minimum de 5 minutes, pour éviter d'allumer et d'éteindre les appareils tout le temps, mais pour de la clim ça semble trop long.
Ajoute la ligne suivante dans ton fichier config pour passer à 3 minutes:
    HMCF.minCycle = 3*60      -- min. duration (sec) of PID cycle  (Default: 5*60)
Il y a 18 heures, Felig a dit :
1) le reboot de la HC3: si tu as le temps est-ce que tu peux faire un reboot manuel et vérifier si tu as aussi le pb du thermostat qui se met sur off ?
j'ai mis le niveau de log à 4 avant de faire un reboot via l'interface web.
Il s'est bien passé, c'est-à-dire que le thermostat n'est pas passé sur OFF.
Le reboot automatique se passe 1/sem dans la nuit du sam au dim à 3h. Il provient du script de backup automatique
de  @Lazer qui n'est pas quelqu'un de violent
Je te dirai quoi demain
log_Reboot.txt
il y a 8 minutes, Felig a dit :
c'était justement une question que je me posait : comment défini la durée d'un cycle ?
Ne mettrait-on pas la valeur (5*60) par défaut dans le fichier config ?.
En tout cas, je met la 5,17b en route en modifiant Kp et Ki comme tu me le recommands.
Oui je vais ajouter ce paramètre par défaut dans config. Le cycle détermine la fréquence à laquelle la clim. est démarrée. A la fin de chaque cycle le programme regarde la température, analyse l'erreur par rapport à la consigne, et en déduit la durée de chauffage/climatisation sur le prochain cycle. Le cycle doit être supérieur ou égal au temps de réveil du thermomètre (le programme le vérifie au démarrage). Tu as un thermomètre sans temps de réveil, donc on peut faire des cycles courts, la seule contrainte c'est les appareils qui n'apprécient pas d'être allumés ou éteints trop souvent (comme ta Daikin qui refuse de s'allumer tout de suite après avoir été éteinte). Dans le QA, par défaut la durée d'allumage minimum d'un radiateur est de 30 secondes. Avec un cycle de 3 minutes, tu devrais avoir une période de clim de 1 minute environ toutes les 3 minutes environ d'après les logs, donc ça devrait être bon.
Il y a 3 heures, Felig a dit :
J'avais remis Kp à 100, et ce n'est vraiment pas top :
Voici le log (en piece jointe, car il contiendrait encore des emoji ...)
je passe le cycle à 3 min pour voir  ce que ça donne
log_Regul.txt
Modifié par jojo
il y a une heure, jojo a dit :
serait-ce avec la 5.17b ? (car autres logs ok avec 5.15b)
Il y a 23 heures, jojo a dit :
le reboot auto a bien fonctionné, mais promis juré, le régulateur passait sur OFF avant. Ce bug a peut-être été corrigé "par hasard" en 5,17b
en tout cas le fait d'avoir diminué la durée du cycle semble avoir réduit l'amplitude des oscillations.
Donc pour moi, cette version est fonctionnement stable.
On peut, si tu le désires, regarder pour encore améliorer l'UI.
