TonyC Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Nouvelle cuvée ! What's new: Access Added column with user ID. Block Scenes Renamed Alert to Notification category. Splitted Simple Message block into two blocks: E-mail and Push. Added new block in Notification category - Interactive Push that can be sent to any user. Added actions for Sonos Speaker plugin in Device/Single block. Climate Optimized time needed to change setpoint of zone with multiple FIBARO Heat Controllers. Added column with zone ID. Devices Temperature charts for FIBARO Heat Controller version 4.5 or higher in device Advanced tab. Carbon monoxide history charts for FIBARO CO sensors in device Advanced tab. Scale in hours for device history charts (temperature, smoke, carbon monoxide etc.). USB port icons for com.fibaro.usbPort device type. More icons available for FIBARO Wall Plugs. New linked device - Binary Sensor. Support for MCOHome A8-9 version 6.4. Support for MCOHome A8-7 version 3.7. Support for MCOHome MH-C321 version 3.3. Support for MCOHome MH-C421 version 3.3. Support for MCOHome MH-F500 version 2.1. Support for MCOHome MH-S311 version 5.5. Support for MCOHome MH-S312 version 5.5. Support for MCOHome MH-S314 version 5.5. Support for MCOHome MH-S411 version 5.5. Support for MCOHome MH-S412 version 5.2. Support for MCOHome MH-DT311 version 3.3. Support for MCOHome MH-DT411 version 3.2. History Brand new, optimized, and redesigned panel including more events! Displaying events related to devices, scenes, and users. Displaying system configuration events like adding/removing the device, scene, or user. Displaying actions performed to trigger devices from the interface or mobile app. Displaying source of each event - system or specified user. Filtering events by object type, event type and source type. Loading items while scrolling the list of events. Info badge indicating new events at the top of the list. Lua Scenes Possibility to set and get a specific variable from scene. Added fibaro.setSkin function to change active theme for specified users. Default operators for scene triggers. AccessControlEvent trigger support. Nice New procedure of adding mono-directional devices*. User-friendly configuration wizard. Displaying and editing existing device configuration. Actions triggering Nice devices visible in History. *Nice Smilo series is not supported Other Improved filtering in full-screen console view. Improvements and minor fixes for dark theme. Quick Apps Dividing the code editor into several files in separate tabs. Added com.fibaro.remoteController device type. Added com.fibaro.player device type. Added UDP client support. Recovery Mode Reloading list of network interfaces after resetting. Slovak language version. Scenes Sorting scenes by ID. Added Climate category. Bug fixes: Access No mobile devices displayed for non-admin user. Block Scenes Inactive save button after dragging and dropping previously added block. Climate Schedule is not synchronized if FIBARO Heat Controller was forced to synchronize. Control of other devices during synchronization of schedules is not possible or delayed. Dashboard Duplicated camera image on the right sidebar for FIBARO Intercom. Camera image full screen view does not close the right sidebar. Devices No possibility to set negative values in FIBARO Smart Implant inputs configuration. Incorrect values on data charts after changing time zone in general settings. System error when set incorrect address of IP camera. Lua Scenes Non-admin user cannot run the scene. Notifications E-mail and push notifications from removed devices remain active. Too many notifications from FIBARO Intercom. Profiles Active profile is not updated when switched. Remote Access No IP camera image if mjpg stream was selected. ***OTHER MINOR BUG FIXES***** Ce dernier ne fait pas partie de la liste officielle mais il me manquait depuis que je n'ai plus de HC2 à mettre à jour !! 1
jjacques68 Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 ah zut, toujours pas : - icône pour QA - bug de l'IHM pour le gardenPanel - multiinstance des scènes - les objets des QA dans la mobile APP et je veux pas de câlins 1
mprinfo Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 @jjacques68 @lazer UDP fini le chômage technique au boulot plus d'excuse pour le QA Eaton Envoyé de mon BLA-L29 en utilisant Tapatalk 1
jjacques68 Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 il y a 10 minutes, mprinfo a dit : UDP ah punaise je l'avais pas vu lui ! interessant !
jjacques68 Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 hé ben c'était du rapide ce coup là
TonyC Posté(e) le 23 juillet 2020 Auteur Signaler Posté(e) le 23 juillet 2020 (modifié) Bon pour l'instant pas très concluant de mon coté, la HC3 met des plombes à me rendre la main après un reboot et là elle vient de rebooter sans que je ne luis demande rien. Ils y a eut des modifs coté synchro des FGT qui étaient déjà longues à synchro mais là ça devient mortel. A suivre. EDIT: Je corrige ce que je dit plus haut, il est vrai qu'elle est plus longue à rendre la main, mais dès qu'on l'a prise elle réagit immédiatement. Avant cette update et c'est vrai avec la hc2 la synchro des FGT faisait qu'on avait bien accès à l'IHM mais les ordres zwave étaient en standby jusqu'en fin de synchro. Là des que la main est donnée la HC3 répond immédiatement aux ordres. Donc plus longue a rendre la main après un boot, mais au final réactive plus rapidement. Je vais vérifier tout ça dans les jours à venir. Pour le reboot brutal par cotre j'espère que ce n'était juste qu'un incident isolé. A voir également dans la durée. Et pour le panel HISTORY là c'est carrément cool enfin une vision synthétique, rapide et à porté de tous sur ce qu'il se passe dans la box ! Modifié le 23 juillet 2020 par TonyC 1
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 (modifié) Mise à jour effectuée aussi... sans souci technique. Par contre, nette propension à se déconnecter du lan. Egalement, elle ne me donnait accès qu'à une section de la zone "engrenage" (Sauvegarde... et... Sauvegarde !) Pour "Dispositifs" et d'autres -> oualou !!! J'ai malgré tout pu faire une inclusion en profitant d'un instant de lucidité (de la HC3...), mais qui au final s'est révélé complètement vérolé. Je l'ai changé de port sur le switch, puis arrêt avec son bouton, et pour finir déconnection du jack d'alim. Na ! Quand même ! Redémarrage en remettant l'alimentation -> et j'ai repris la main Modifié le 23 juillet 2020 par Sowliny
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 (modifié) Ha ben voilà, plus de connection à nouveau... Pourtant le Finder la trouve bien (ethernet et wifi) Juste avant, je n'avais plus accès aux variables, ni à l'onglet "Général"... moulinage, moulinage, et petits pois qui font la ronde... Modifié le 23 juillet 2020 par Sowliny
TonyC Posté(e) le 23 juillet 2020 Auteur Signaler Posté(e) le 23 juillet 2020 (modifié) @Sowliny essaye de basculer sur le wifi, je ne sais pas pourquoi mon tit doigt me dit que ça sera plus stable. Autre chose, n'hésite pas à loguer un ticket au support fibaro. Modifié le 23 juillet 2020 par TonyC
mprinfo Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Mon pouce me dit que je fais bien de rester sur hc2Envoyé de mon BLA-L29 en utilisant Tapatalk 1
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Le pouce de @mprinfo est de bon conseil. La situation générale sur HC3 ne va pas en s'améliorant de mon point de vue (de petits bugs (emmerdes) quasi sans arrêt...). Je vais réactiver ma HC2 comme j'ai fini ma transhumance d'été... A @TonyC : Je vais tenter comme tu le dis, uniquement en wifi. D'autant plus que pendant les rares moments ou j'avais la main, l'éthernet était déclaré comme déconnecté (!!!)- Râââhhhh !!!
mprinfo Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Pouce gauche en plus il est passé dans la fendeuse il y a 2 mois et demiSi il est pas sage même punitionJ'ai eu de la chance la fendeuse n'a rien Envoyé de mon BLA-L29 en utilisant Tapatalk 2 1
mprinfo Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Rester sur hc2 est la sagesse de l'âgePrendre une HC3 pour préparer gentillement la migration est une très bonne solutionAvantageLa hc2 est très stable donc aucune urgenceLa HC3 en test permet de voir comment ça evolu. Ça permet de faire pleins d'essai sans tendre le dosSi on la plante aucune urgence pour dépannerLa découverte de QA est un vrai plaisirJe ne pense pas migrer cette année. Envoyé de mon BLA-L29 en utilisant Tapatalk
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 (modifié) + 30 minutes... Après menace de la remplacer par la HC2 (et moult reboots... !) la situation semble s'être stabilisée. J'ai la main, et j'ai pu refaire l'inclusion sans engendrer un Quasimodo... Les scènes sont relancées, les push sont bien reçus (et pas heure plus tard...) Je vais quand même signaler ce crise de D.T. (délirium tremens) comme il se doit D'autant plus que rien ne me dit que cela ne recommencera pas ! + 15 minutes... A nouveau erreur 504 ! Reboot... Inaccessible en wifi, en ethernet... Dead sur Fibaro ID Connect. Modifié le 23 juillet 2020 par Sowliny 1
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 il y a 15 minutes, mprinfo a dit : Rester sur hc2 est la sagesse de l'âge C'est absolument vrai. Mais, malgré mes 66 ans à l'automne, je ne suis pas (encore / suffisamment ?) sage. Cependant, je vais réinstaller ma HC2 et ma HC3 (qui pilotera la grange) et qui pourront fonctionner en mode pont.
mprinfo Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Donc tu vois que tu es.sage tu garde la hc2J'espère que@jjacques68 n'a pas tout ces soucis car il va vouloir être réconforter Je vois mal passer mon mois d'août en Alsace Envoyé de mon BLA-L29 en utilisant Tapatalk 1
TonyC Posté(e) le 23 juillet 2020 Auteur Signaler Posté(e) le 23 juillet 2020 @Sowliny un peu de lecture sur le pblm que tu dois avoir : https://forum.fibaro.com/topic/51141-hc3-new-firmware-5040037/?do=findComment&comment=211491 Donc mets toi en wifi, une fois que c'est ok, tu refais la config de ton ip lan en forcent en statique. Ca devrait corriger ton souci.
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 + un certain temps... Reboot, reboot, reboot, et dix de der... Bon j'ai repris la main. Je vais lui ficher la paix pour la nuit. J'ai comme l'impression qu'il lui faut (encore) plus de temps pour... quoi faire ??? Je me le demande. Compter ses modules et ses scènes ? Vraiment incompréhensible... d'autant plus qu'il semble y avoir un lien entre une activité via l'IHM et son état de connectivité (et de "conscience"). 1
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 (modifié) il y a 20 minutes, mprinfo a dit : Donc tu vois que tu es.sage tu garde la hc2 J'espère que@jjacques68 n'a pas tout ces soucis car il va vouloir être réconforter Je vois mal passer mon mois d'août en Alsace Envoyé de mon BLA-L29 en utilisant Tapatalk Bien sûr que je la garde ! D'autant plus que la HC3 ne permet pas encore le mode pont - et ça me désole. Bonsoir @jjacques68 si tu nous lit ! Modifié le 23 juillet 2020 par Sowliny
Sowliny Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 il y a 17 minutes, TonyC a dit : @Sowliny un peu de lecture sur le pblm que tu dois avoir : https://forum.fibaro.com/topic/51141-hc3-new-firmware-5040037/?do=findComment&comment=211491 Donc mets toi en wifi, une fois que c'est ok, tu refais la config de ton ip lan en forcent en statique. Ca devrait corriger ton souci. Merci pour cette info ! Par contre je suis en IP fixe (lan et wifi) dès le début... Je vais bien sûr potasser le lien !
jjacques68 Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Pas de chance les gars, chez j'ai aucun soucis !! Ça roule tout seul, en tout cas j'ai rien remarqué d'anormal...Envoyé de mon iPhone en utilisant Tapatalk Pro 1
mprinfo Posté(e) le 23 juillet 2020 Signaler Posté(e) le 23 juillet 2020 Moi je garde les traditionsClignotement led mise à jourJe prépare l aperoJe clic sur mise à jourJe bois gentillement l'apéritifÉtant plus en état pour utiliser la boxJe vais dodoEt le lendemain tout va bienC'est la seul procédure qui fonctionne à 100 pour 100 pour mettre à jour les box Fibaro Envoyé de mon BLA-L29 en utilisant Tapatalk 2
