HC2 & HCL - 4.582 - BETA - 07/05/2020
Version 4.582 Beta
New improvements:
- Added target and measured temperature chart in General tab of FIBARO Heat Controller (FGT-001) version 4.5 or higher.
- Possibility to disable sending system notifications as push messages.
- Added Warming Prioritizer plugin to bind FIBARO Heat Controller version 4.7 or higher and switch that controls the boiler.
- Added support for MCOHome MH9-CO2-WA and MH9-CO2-WD version 2.4.
- Added support for MCOHome MH10-PM2.5-WA and MH10-PM2.5-WD version 2.3.
- Added support for MCOHome MH7-WB version 4.2.
- Added support for MCOHome A8-9 version 6.2.
- Added support for Aeotec Heavy Duty Switch version 3.28.
- Added support for Sensative Strips Drip.
- Added support for Eurotronics Spirit TRV.
- Added support for Dome Siren (DMS01).
- Added support for Dome Water Main Shut-Off (DMWV1).
Resolved issues:
- Block scene changing the LED ring illumination of FIBARO Walli series devices ignores set delay.
- Brightness set in FIBARO RGBW 2 (FGRGBW-442) changes automatically after refreshing the page.
- Colour set in FIBARO RGBW 2 (FGRGBW-442) is not the same in different parts of the interface.
- Favourite colour cannot be added for FIBARO RGBW (FGRGBWM-441)
- Restoring backup fails in some cases.
- Incorrect status of FIBARO CO Sensor (FGCD-001) in event panel.
- Scene controller endpoint is hidden for FIBARO Single Switch (FGS-213).
- Redundant updating of schedule during its synchronization in FIBARO Heat Controller (FGT-001).
- Z-Wave devices do not display available firmware updates.
- Energy data is not removed from all endpoints of the device.
- Plugin view is not loaded in the mobile app.
- Incorrect support for Fakro ZWS12 with rain sensor.
- Incorrect support for Forest Shuttle.
- Missing translations in Italian.
- Other minor fixes.
@mprinfo, croisement ;)
non après ;) et moi il y avait les détails :D
Oui mais moi je fais une jolie mise page
Pas un simple copier coller :D
En plus c'est peut être la dernière mise à jour pour HC2 pour moi :20:
Et puis je voulais être le premier a annoncer ce que nous attendons tous:
:98:
  • Like 4
  • Thanks 1
  • Haha 1
à l’instant, mprinfo a dit :
Tu as craqué ? C'est moi qui vais :20:
Deux à la suite, c’est grave docteur
C'est la première mise à jour de la hc2 que je ne ferai pas en... 7 ans :20: RIP HC2 03-2013  03-2021
Modifié par TonyC
Sacré liste, cela veut dire en tout cas qu'ils bossent encore sacrément sur la HC2 malgré la HC3, une partie de l'équipe HC2 existe donc encore. Excellente nouvelle !
Plante sur le backup ici, longtemps que j’avais pas eu ça...
Nouvelle tentative
Mdr regarde bien les numéros de version ça ce suit donc ça avance pas fort. faut pas s'attendre à des nouveautés. Peut-être la hc2 en slave d'une hc3..
C'est clair, y'a pas de nouveauté là, juste des correctifs, et des templates de modules.... et comme par hasard beaucoup de MCO Home, puisqu'ils viennent d'annoncer leur partenariat.
Modules qui fonctionnaient très bien sans template, il suffisait d'injecter les paramètres à la main, qu'on trouve dans la documentation de chaque module.
Clairement, la HC2 n'aura plus de nouveauté, on peut s'estimer heureux qu'ils continuent un suivi minimal comme ça...
Si déjà ils pouvaient faire un transfert HC2 > HC3 qui fonctionne sans tout réinstaller ça m'ira bien.
Ça fonctionne mais le risque 0 n'existe pas
Le problème si tu traînes un mer.. Dans ton réseau tu la transmets au nouveau réseau
Même un confinement n'y fera rien
  • Haha 1
il y a 10 minutes, ericl78 a dit :
Hi
Je viens de lancer la maj :=)
Parfait, 5 minutes
A+
@nico on est d'accord
Par contre ton post ne dit pas vraiment cela
'la hc2 est en fin de vie il faut accepter
