HC3 - 5.021.38 - 28/02/2020
Désolé pour la présentation c'est un copier coller du change log sur la hc3, j'essaierai de le mettre en forme ce soir !
On ne voit plus (en tout cas je ne vois pas) de notion de beta ou stable d'ou le titre qui ne le précise pas...
EDIT:
Un peu de rework sur la présentation que je viens de pompé sur le fofo officiel et qui apporte plus de lisibilité au changelog.
Thank you for using the FIBARO Home Center 3! Our constant improvements are to better your experience. Be sure to update to the latest version to enjoy new features.
What's new:
    Block Scenes
        Actions on the LED ring for FIBARO Walli series devices.
        Actions for Z-Wave thermostats.
    Cameras
        Redirect to camera configuration after adding.
        Setting up a custom icon.
    Climate
        Indicating the active mode of climate schedule.
    Dashboard
        Controlling the binarySwitch, multilevelSwitch and rollerShutter devices from the right sidebar.
        Displaying the currently set temperature on the thermostat icon.
        Collapsing/expanding the rooms side menu.
    Devices
        Z-Wave removal mode available from the list of all devices.
        Displaying the battery level under the battery icon on the device list.
        Default humidity range changed to 40-50%.
        Unified configuration of various types of linked devices.
        Support for pending and failed associations.
        Support for the black box of FIBARO Heat Controller (FGT-001).
        Support for FIBARO RGBW Controller 2 (FGRGBW-442).
        Support for Z-Wave locks.
        Support for Z-Wave thermostats.
        Support for wind and rain sensors.
    General
        Downloading the current location of the gateway in https connection mode.
    Lua Scenes
        Possibility to download a scene trigger using the sourceTrigger object that triggered the scene.
        Values retrieved from the api are typed.
        Os.time, os.date and fibaro.sleep functions.
    Migration from HC2/HCL
        "Finish migration" button on the welcome screen to restore backup transferred from HC2/HCL.
    Network
        Disabled switching off Wi-Fi during the first configuration.
    Other
        Shorter loading time of device and room lists.
        Added loaders for loading lists in settings.
        Unified display of entries in the debugger (Lua, Quick Apps) and the Z-Wave console.
        Collapsing/expanding the settings side menu.
        Added Czech language.
    Plugins
        Satel plugin fixes and improvements..
        Integration of Satel alarm partitions with the FIBARO alarm.
    Profiles
        Display and control of climate zones.
        Display and control of alarm zones.
        New icons related to weather and temperature.
    Quick Apps
        New device types: com.fibaro.genericDevice and com.fibaro.weather.
    Recovery Mode
        Displaying inactive system version.
        Progress bar when uploading a local file.
        Displaying the time remaining to automatic reboot of the gateway.
    Rooms
        Indicating the default room on the list of rooms.
    VoIP
        Added the functionality description.
Bug fixes:
    Access
        No refresh after synchronizing users.
        Remote support cannot be enabled via remote access.
    Backup
        The "restore with version" feature does not download the correct software version.
        Instead of restoring the selected local backup, the latest local backup is always restored.
        Number of scenes in backup is always equal 0.
    Block Scenes
        Unable to enter the time in the delay block.
        Lists of rooms and sections do not load.
        Active "run scene" button despite unsaved changes.
        Selected triggers disappear after reloading page.
        No suitable options for the type com.fibaro.barrier.
        Redundant fields in blocks for RGBW devices.
        No condition values displayed for Central Scene controllers.
        Forcing the watering from the scene causes a system error.
        Missing translations.
    Cameras
        Cannot display the advanced tab.
        Incorrect image path causing no camera image.
        Invalid default image refresh time.
    Climate
        Incorrect limits of minimum and maximum temperature.
        Zone temperature is not displayed in manual mode.
        Restarting the gateway when any partition is in Hold mode causes a system error.
    Dashboard
        Search does not work properly if entered a dot in the search box.
    Devices
        No device polling button if polling is globally enabled.
        Double message about unsaved changes in device parameters.
        Errors in displaying the energy consumption of the device.
        No advanced settings section for Z-Wave locks supporting pin codes.
        Changing the role of RGBW device requires reloading the page to display properly.
        No icons for several types of sensors connected to the FIBARO Smart Implant.
        Cannot set the minimum and maximum RGBW slider value.
        Cannot reset advanced parameters to the default values.
        Invalid redirection to associated device.
        The Advanced tab is not displayed when added a scene with Central Scene event.
        USB powered device is marked as a battery device.
        The user added icon has an invalid path.
        Changing the device name is not applied in the notifications.
        Lack of support for the FIBARO Smart Implant device.
        Incorrect support of the Danfoss RS device.
    Diagnostics
        Unable to download the device template.
    Garden
        Setting is not displayed correctly on the days that the schedule does not apply to.
        Incorrect operation of sprinklers in a sequence.
    Lua Scenes
        Incorrect loading of the scene editor view.
        Errors in displaying the debugger.
    Network
        Changing the IP address or addressing mode does not work properly.
        Access Point is inactive after the recovery procedure.
    Notifications
        Lack of filtering by type and priority.
        Notifications for linked devices do not work.
    Other
        Displaying incorrect checkboxes when using a tablet.
        Inconsistent icons and buttons on warning popups.
    Plugins
        Philips Hue devices are set to default light values after switching off and on.
        No weather data displayed on the YR Weather plugin preview tab.
    Quick Apps
        New device is always assigned to the default room.
        The ID of an existing item changes when adding a new item.
        The device view is not updating.
        Lack of code scrolling.
        Importing an unassigned device results in an error.
        Visual fixes.
    Recovery Mode
        The restore, repair and switch actions do not display statuses.
        Visual fixes.
    Rooms
        The section name does not change when closing the window.
    Update
        Retrying to download the update returns an error.
    Z-Wave
        Unable to close the adding controller window.
        The mesh reconfiguration for the Z-Wave devices does not work.
Modifié par TonyC
Il n'y a plus que des stables :13:
Fibaro reprend ses bonnes vieilles habitude de firmware la veille d'un week-end.... :rolleyes:
Mais est-elle vraiment disponible cette fois-ci ?
PS : sujet déplacé dans la section Firmwares.
il y a 8 minutes, Lazer a dit :
Désolé @Lazer, je pensais y être lorsque j'ai ouvert le topic. Sorry ! et oui que des stables on dirait :)
Et migration réussi sans aucun souci des 90 modules, et à priori c'est pas le seul...
Donc GG Fibaro !
Je viens de recevoir ma HC3 et de la mettre à jour, donc RAS :=)
Question: si je migre ma HC2 avec mes 65 modules, il me restera à réécrire mes 100 scripts!
Lors de la migration, la HC2 est effacée au niveau conf Zwave, vrai ?
Si je réinstalle sur la hc2 une configuration qui a été sauvegardée sur mon pc, ma HC2 refonctionne t'elle ?
Merci à vous
Non Pascal, on en a déjà parlé sur 2 autres topics.
Ils utilisent le bascule de controleur principal
Donc GG Fibaro !
Oui très très bonne surprise vu de mes yeux et pas que des modules Fibaro ayant poussé le vice sur le HC2 avec du Qubino SmartMeter, Fil Pilote et de l’Aeotec également. Tout est parfaitement fonctionnel et configuré à l’identique !
Après il y a du Taff pour refaire scènes et Cie .
Pour les impatients avec 1 semaine de vacances c’est parfait, personnellement le jour où je bascule je le ferai progressivement.
Dans tous les cas un grand bravo à Fibaro
Beau changelog et beaucoup d'évolutions !!!
Moi, tant qu'il n'y a pas GEA, je peux pas passer a la HC3...
Envoyé de mon SM-A530F en utilisant Tapatalk
il y a une heure, Dragoniacs a dit :
Tu ne verras jamais GEA intégré par FIBARO ;-)
Les poignets bougent encore bien mais ils font du surplace sur scène
  • Haha 2
Hi
Pour les personnes que cela intéresse, il y a un site qui possède des HC3 en stock, livrée en 72h
Je ne désire pas faire de pub pour ce site sur le forum, mais recherche sur google de "achat fibaro home center 3"  et vous trouverez le site sur la première page affichée
Voilà, juste pour info
