salut a tous
j'ai une DAHUA  IPC-HDBW2431R-ZS et impossible de l’intégré a la HC2
avez-vous une idée ?
/cgi-bin/snapshot.cgi
/cgi-bin/mjpg/video.cgi
ne fonctionne pas :(
This time in English :-)
Check by this internal tool of ONVIF Assocation (it's old but last public accessed, test all function of Onvif cameras and give links to snaps or live streams)
On discovery tab enter IP, user and pass of camera, select network card in NIC box (by default the loopback is selected) and press PROBE. After connected go to diagnostic tab and select <media configuration/media streaming> and <realtime streaming> (or more if you need) after this press RUN SELECTED. After test (with many black window or with image from camera) on right window you will see many interesting info and link to stream or jpg snap.
I discovered snapshot link and lowres streams of my new and old Dahua and Novus cameras without problems
https://drive.google.com/open?id=1vtl0ajm9oygxdPj4JykXmMrpo5RNYY-L
Modifié par drboss
BTW If you things use this camera via api ex. via REST HTTP it use digest authorisation.
If you have problem with snapshot image taken by link with onvif in address (ex below) turn off onvif authorisation in camera setup. But test first with turned on
   STEP 8 - Check that MediaUri field contains valid URL
      URI: http://192.168.1.109/onvifsnapshot/media_service/snapshot?channel=1&subtype=0
ex for other Dahua with PTZ.
# go to garden gate if opened
curl --digest --user admin:pass -v  'http://admin:pass@192.168.1.109/cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=1&arg3=0'
# return to track
sleep 15
curl --digest --user admin:pass -v  'http://192.168.1.109/cgi-bin/ptz.cgi?action=start&channel=0&code=StartTour&arg1=1&arg2=0&arg3=0'
Modifié par drboss
