HC2 & HCL - 4.550 - Stable - 22/07/2019
Liste des modifications logicielles 4.550:
Version 4.550
New improvements:
- Implemented security fixes for backups.
- Optimized and reduced amount of data processed when adding Z-Wave devices.
- Optimized and reduced amount of data processed when booting the system.
- Optimized communication between services to speed up the operation of the gateway.
- Added geofencing events to be used in scenes.
- Added possibility of setting radius around the point in localisation panel.
- Added notification recommending users to edit scenes based on location to ensure their proper operation in the next version of FIBARO Home Center app.
- Optimized response time of scenes setting brightness and colour of the LED ring for FIBARO Walli series.
- Optimized Z-Wave locks synchronization process by reducing maximum number of pin codes.
- Added possibility of assigning virtual devices to categories to be used in FIBARO Home Center app.
- Added possibility of hiding the virtual device.
- Added possibility of creating global variables with predefined values.
- Changed the time zones display format into more user-friendly.
- Added the button in General Configuration for resetting energy data.
- Home Center name is automatically set to serial number if empty and may be selected in block scenes.
- Added possibility of updating firmware of FIBARO Roller Shutter 2 (requires reconfiguration).
- Added support for FIBARO Roller Shutter 2 v26.26.
- Added support for FIBARO RGBW Controller v27.27.
- Added support for overriding the heating schedule for Danfoss Link Room Sensor.
- Added support for Heatit Z-TRM2fx.
- Added support for Qubino Smart Meter.
- Added support for Qubino 3-Phase Smart Meter.
Resolved issues:
- The map in location configuration is not displayed correctly and the location cannot be set by entering coordinates.
- Gateway in DHCP mode does not automatically establish a connection in case of temporary network shortage.
- Parameters cannot be changed for devices without templates.
- Setting the decimal separator affects values after the decimal point for temperature sensors.
- List of backups does not load correctly.
- Specific configuration of sprinklers panel results in no connection with the gateway.
- Remote support does not work after losing and restoring the connection to remote access.
- FIBARO Walli devices do not properly support all actions available in scenes.
- Actions set in the configuration of FIBARO Walli devices are not hidden after changing the value of responsible parameter.
- The outputs state of the FIBARO Smart Implant changes automatically after rebooting the gateway.
- The inputs state of the FIBARO Smart Implant is always safe after rebooting the gateway.
- Leviton devices do not report the status correctly.
- CoolMasterNet Universal HVAC Bridge loses configuration after rebooting the gateway.
- Remote support is always enabled and does not turn off automatically after 7 days.
- Connected gateways lose the connection.
- Failed login attempts are counted incorrectly.
- Location is not updated when setting in the wizard.
- Scene code is not generated properly when setting two or more geofence events.
- Devices related to the CoolAutomation plugin are not added to the device list.
- Time of overriding the heating schedule for Danfoss thermostats is always set to 2 hours.
- Widgets are not available in mobile app.
- Users from China cannot set their location.
- Other minor fixes.
Idem Ok pour moi, par contre je n'ai plus la mesure instantané sur mon smartmeter qubino :( je vais fouiller dans les paramètres ;)
Je t'avoue que je ne regarde jamais puisque j'utilise uniquement Domocharts (qui permet de logguer bien plus de métriques)
La dernière beta n'ayant rien donné de mieux de ce coté là, ça m'étonnerait que cette nouvelle stable change quelque chose, car elle reprend les modifs des dernières bétas.
@schwinny je viens d'aller regarder du coup, j'ai 6 jours d'historique pour les températures et consommations électriques.... je suis en 4.543 Beta sur ma box de prod.
N'oublie pas que l'historique conservé est limité en espace, plus tu as de modules et de remonté fréquences des infos, plus la HC2 les purge rapidement.... ceci pour éviter d'exploser la base de données.
C'est ok pour mon qubino smart meter ;) un intervalle d'interrogation à paramétrer :)
pour les fils pilote je ne sais pas, les miens étaient déjà inclus ...
ok pour moi.
Mais le typage des VD c’est pas encore ça.
j’essaye de mettre «light » sur les VD qui actionne des lumière via un ipx, mais la HC2 ne le vois toujours pas comme une lumière.
Il n'a jamais été question que le typage des VD permette de les transformer en lumière.
On en a parlé il y a quelques temps, sur un topic, je ne sais plus où (surement sur le topic d'une beta)
Le typage des VD et modules ne sert que pour la nouvelle application, afin de permettre le regroupement des modules. En dehors de ça, que ça soit pour la HC2 ou l'ancienne application, cela ne sert à rien.
Pas mal du tout, ils ont bossé dit donc.
Par contre mise à jour dans 10 jours, car je pars en congés fin de semaine :)
Je me connecte a ma box pour faire la MAJ et je vois ceci...
a votre avis, le support l'a lancé suite a ma demande de support  ? :)
le soucis cest que ca reste a cette étape....
Bon maj effectuée.
je pense que le support l'avait lancé et a du planté la box... et que du coup ils l'ont remise en prod a distance :)
je suis VIP MOI cest fibaro qui me fait les MAJ maintenant ^^
  • Like 3
