HC2 & HCL - 4.542 - BETA - 20/05/2019
Version 4.542 BETA
New improvements:
  • Optimized and reduced amount of data processed when adding Z-Wave devices.
  • Optimized and reduced amount of data processed when booting the system.
  • Optimized communication between services to speed up the operation of the gateway.
  • Added geofencing events to be used in scenes.
  • Added possibility of setting radius around the point in localization panel.
  • Added notification recommending users to edit scenes based on location to ensure their proper operation in the next version of FIBARO Home Center app.
  • Optimized response time of scenes setting brightness and color of the LED ring for FIBARO Walli series.
  • Optimized the pin codes synchronization process for Z-Wave locks by reducing their maximum limit.
  • Added possibility of assigning virtual devices to categories to be used in FIBARO Home Center app.
  • Added possibility of hiding the virtual device.
  • Added possibility of creating global variables with predefined values.
Resolved issues:
  • The map in location configuration is not displayed correctly and the location cannot be set by entering coordinates.
  • Gateway in DHCP mode does not automatically establish a connection in case of temporary network shortage.
  • Parameters cannot be changed for devices without templates.
  • Setting the decimal separator affects values after the decimal point for temperature sensors.
  • List of backups does not load correctly.
  • Specific configuration of sprinklers panel results in no connection with the gateway.
  • Remote support does not work after losing and restoring the connection to remote access.
  • FIBARO Walli devices do not properly support all actions available in scenes.
  • Actions set in the configuration of FIBARO Walli devices are not hidden after changing the value of responsible parameter.
  • The output status of the FIBARO Smart Implant changes automatically after rebooting the gateway.
  • Leviton devices do not report the status correctly.
  • CoolMasterNet Universal HVAC Bridge loses configuration after rebooting the gateway.
  • Other minor fixes.
  Le 20/05/2019 à 10:58, BenjyNet a dit :
geofancing, c'est à la mode.... Mais est-ce que ça marche ? Depuis le temps qu'ils le prometent
Développer
ça dépend des jours :/
j'ai fait la mise à jour sur ma box de test, on peut enfin cacher les VD :)
Par contre, je ne vois pas les templates Qubino :98:
@Massalia Édite une scène bloque et vas dans GPS, tu vas vite trouver :)
EDIT:
Petit complément d'info dans le panel LOCALISATION on peut directement paramétrer le radius de localisation.
Modifié par TonyC
  Le 20/05/2019 à 11:31, Massalia a dit :
Ok, trouver !
Il n'y as pas grand chose.
Développer
Si si quand même, je n'ai pas encore trop jouer avec, mais on peu définir n'importe où des points avec un radius et les tester en tant que zones d'entrées/sorties. Si c'est précis et sans tuer les batteries du téléphone alors ça peut être pas mal pour certaines fonctions.
  Le 20/05/2019 à 11:38, TonyC a dit :
Développer
On en avait discuté il y a pas mal de temps, pour ça l'astuce consiste à écrire une scène, qui peut modifier la fréquence de raffraichissement via l'API.
Ainsi, fréquence élevée quand tu es à proximité pour fiabiliser (pas nécessaire d'ouvrir automatiquement le portail si tu passe la soirée/apéro chez le voisin)
Et fréquence faible quand tu es au boulot/vacances/chez la maitresse (à supposer que ça ne soit pas la voisine, justement)
  • Haha 2
Merci pour l'info @Lazer, j'avoue que quant à la fiabilité/utilisabilité du geoloc avant cette version, je n'y prêtais pas trop attention. Mais je vais rechercher le topic car si ça s'est amélioré alors je compte l'utiliser.
  Le 20/05/2019 à 10:45, TonyC a dit :
Développer
tout arrive !!
Allez on clique ;-)
PS : Tenez nous au courant pour la geolocalisation ;-)
et voilà, maj effectuée !
A vous tous, regardez votre conso cpu, diminution importante
autrement, RAS
AIE... Chez moi depuis la maj, je n'arrive plus à activer des scènes depuis Alexa.
Avez-vous le même problème?
