HC2 & HCL - 4.531 - BETA - 05/02/2019
hc2update-beta.pngHC2 et HCL - 4.531 Beta du 05/02/2019
Liste des modifications de la version beta 4.531:
Version 4.531 Beta
New improvements:
- Added possibility of grouping the FIBARO Roller Shutters.
- Added possibility of assigning each room to one of the categories.
- Added notification about existing two users with the same login.
- Optimized handling of FLiRS devices (eg. FIBARO Heat Controller) to improve communication with the gateway.
- Added support for Oomi by Fantem MultiSensor.
- Added support for Jasco ZW6302B Portable Smart Multi Sensor.
- Added support for Remotec ZXT-600AU.
Resolved issues:
- Weather is not updating.
- Unwanted IP address blocking by the external integrations.
- Possibility to change the e-mail address owned by the admin to the one already used by a regular user.
- Possibility to enter in the wizard the e-mail address containing uppercase letters.
- Login to the user account if the admin and user logins are identical.
- User receives notifications recommending a change of the PIN code owned by the admin.
- Notification recommending to change the default PIN code does not contain the user login.
- FIBARO RGBW Controller device category cannot be edited.
- Possibility to set the action for holding the button when the FIBARO Roller Shutter 3 works with a bistable button.
- No status after editing the location settings when restarting the gateway.
- No possibility to update the FIBARO Heat Controller without the external temperature sensor.
- External temperature sensor status is not displayed when the sensor is not paired.
- Unwanted notifications about devices status change.
- Incorrect time after performing the Recovery procedure.
- Other minor fixes.
Modifié par Lazer
  • Thanks 1
Bonjour bonjour,
Voila on clique on clique, uisque "Other Minor fixes" ;-) C'est la que tout est.
sympa de pouvoir grouper les Roller-shutters ;-)
RAS tout qui tourne comme une horloge. Sur une des boxes le redémarrage après MAJ c'est crouté, mais nickel après reboot.
Modifié par TonyC
Bon alors la météo, enfin OK ?
Ca semble OK sur ma box de test, voici enfin une Beta qui pourrait me faire faire le grand pas
Rahh,! Je viens juste de terminer mon module Météo openWeather et ils réparent enfin(!) la météo interne! Ils sont drôle chez Fibaro, ils font des blagues tout le temps!... :)
C'est bien la première fois que j'essaye une bêta, mais j'en avais marre de ne pas avoir le plugin météo
Pas de soucis pour le moment...
Envoyé de mon SM-A530F en utilisant Tapatalk
  • Haha 1
plus de push sur l’iPhone et plus possible d’utiliser la nouvelle app, erreur au login. Suis-je le seul ??
Modifié par ikillou
  Le 08/02/2019 à 05:34, ikillou a dit :
Développer
Bonjour
de mon coté, cela fonctionne sans problème
Bon courage
Juste un petit problème
Si vous modifiez un scène lua et que vous la sauvegardé, vous ne retombez pas sur la page du script lua !
Nous avions déjà rencontré ce problème il doit y avoir deux ans environ.
Cela devrait être modifié dans la prochaine version
A plus
Installation ok pour moi, j'avais pas réussi à mettre la 4.530 (Enfin tenté qu'une fois et j'avais le souci de scène non modifiable). Ici migration faite, nickel désormais.
