HC2 & HCL - 4.530 - Stable - 07/01/2019
Et celle là ? personne n'a encore vu ?
Liste des modifications logicielles 4.530:
Version 4.530
New improvements:
- Added functionality of sharing gateways to other Fibaro ID users via id.cloud.fibaro.com.
- Added manual user synchronization with the button in Access Control.
- Added support for FIBARO Roller Shutter 3.
- Added temperature displaying from the built-in sensor for FIBARO Heat Controller for version 4.5 or higher.
- Added temperature sensor status displaying in the advanced configuration of FIBARO Heat Controller.
- Added possibility of changing the name of your Home Center in the configuration settings.
- Added assigning devices to categories for easier control in the new FIBARO Home Center mobile app.
- Added assigning scenes to categories for easier control in the new FIBARO Home Center mobile app.
- Added Thermostat & Heating Zone plugin, which allows to control the heating zone temperature using a physical thermostat.
Resolved issues:
- No notifications set in the advanced configuration of devices.
- Incorrect state reporting of a blind/gate in the interface.
- Mesh network reconfiguration causes delays in system operation.
- Unable to add more than one empty button in a virtual device.
- YR Weather plugin generates too many requests.
- Empty fields in the LAN settings after switching from Static IP to DHCP.
- Changing DNS and enabling remote support results in an interface error.
- Notification about no compatible backups is displayed despite having them.
- No auto-reboot after editing the location settings.
- Incorrect redirection from the PIN code change notification.
- IP camera settings tab hangs the interface.
- Security fixes for remote access scripts.
- Other minor fixes.
" for easier control in the new FIBARO Home Center mobile app."
Ça a le mérite d'être clair. Voilà ce qu'on attends maintenant.
Ah par contre dans l'appli mobile (Android), la consommation électrique ne remonte pas. Elle reste à 0. (pas très utilile dans mon cas mais bon)
  Le 07/01/2019 à 15:38, cromoto a dit :
Développer
Oui, regarde ce lien, on voit un screenshot de la nouvelle appli
https://www.google.fr/amp/s/blog.domadoo.fr/75388-fibaro-recoit-2-ces-2019-innovation-awards/amp/
  Le 07/01/2019 à 17:11, Bloug a dit :
c'est osé de sortir une MAJ " Stable " la veille des CES :lol:
Développer
Il sont coutumiers du fait :D
Bon la dernière fois ça leur a fait la plus mauvaise pub de leur existence je pense.... gageons que celle-ci soit une vraie stable :)
Ahh j'avais du raison, le nouveau typage sert bien pour le tri dans la nouvelle appli.
Bon, je clique ou pas...
Oui mais bon, toujours pas pour les VD :(
pourtant c'est ce que j'utilise le plus, donc si on ne peut pas y accéder facilement en page d'accueil c'est dommage.
à suivre quand Fibaro nous éblouira avec la nouvelle appli.
