Version 4.510
This update introduces new and optimized operating system, modified file structure and the following brand new features:
- Update package downloaded in the background, without locking the interface.
- Creating encrypted local backup that can be downloaded to your hard drive and later restored.
- Creating encrypted backups, stored in Fibaro cloud that can be later restored.
- Customized icons included to backup.
- Restoring backup with full rollback (restores also software version) or with current software version (up from 4.503). Backups created so far become incompatible.
- System configuration transfer between gateways linked to the same Fibaro ID account via id.cloud.fibaro.com.
Changes related to GDPR:
- Displaying the number of remaining attempts to log in.
- Blocking the possiblity to log in for 30 minutes after 5 unsuccessful attempts from a given IP address.
- Displaying the value of time remaining to unlock the ability to log in.
- E-mail notification sent to admin after 5 unsuccessful attempts to log in.
- E-mail message sent every 90 days that recommends changing your password.
Other improvements:
- New, more reliable file structure.
- No need to use the recovery pendrive.
- Optimized software update process minimizing the risk of potential errors during system update.
- Easier and more intuitive setting of advanced parameters.
- New user interface of recovery system.
- Information about scenes used by a given device available in its configuration.
- Notification after successful update recommending to create a backup if there is no compatible backup.
- Possibility to disable creating auto-backup in Fibaro cloud before performing update.
- Indication of exceeding 90% of cloud backup storage.
- Compatibility with cameras connecting through https protocol.
- Caching icons in the browser cache for faster loading.
- Adjustable brightness of device LEDs in Configuration - General.
- Added new plugins: Samsung Smart Appliances, Philips TV, Cool Master, Power View (Hunter Douglas), Initial State.
- Added support for FIBARO Wall Plug UK - type G.
- Added Kuwait time zone.
Resolved issues:
- Losing the synchronization of the set time.
- No variables list while creating a virtual device.
- No icon change lock via the remote access.
- Switching a number of grouped devices results in 503 error.
- Non-admin users cannot modify their own e-mail address and password.
- Number of devices counted in a particular backup contains all endpoints, active plugins and users instead of devices only.
- Notification suggesting replacing the battery of FIBARO The Heat Controller instead of charging.
- Scene based on time condition results in 'timer handler failed with error' message.
- No possibility to set time manually.
- No power consumption bars in 'Top 5' section.
- No content for notification recommending to create a backup.
- Error while changing configuration from DHCP to Static IP.
- No possibility to disable the remote access in LAN configuration.
- LEDs do not indicate the available update.
- System hangs on starting services after update or backup procedure.
- Notification about disabled remote support does not link to LAN configuration.
- Possibility to disable scene by the user with no sufficient rights.
- Incorrect Z-Wave region set in some cases after performing update for chip versions other than EU.
- Unable to activate remote support.
- 'Invalid access token' error while trying to connect with Samsung Smart Appliances plugin.
- Unable to add device with Philips TV plugin.
- Onkyo plugin uses a lot of resources.
- Other minor fixes.
Ce soir apéro la màj attendra le week-end sur la prod... RAS en environnement de test ;)
  • Like 2
Je crois que les icônes restent sur la partition de backup du disque, c'est ce que j'avais cru comprendre lors de la beta 503
Pour la HCL il n y pas de 4.510? Car j'ai la Hc2 en 4.180 et la HCL en passerelle en 4.170. Je pense attendre encore...
Non, il a été dit plusieurs fois qu'elle est devenue totalement inutile (plus de backup, de sécurité, de recovery)
Tout se fait avec le seul "disque" interne.
Ce "disque" est une clé USB Flash de 2 Go à cellules SLC, donc pour simplifier c'est une sorte de SSD.
Depuis la 4.503, le système est totalement reformaté, et partitionné. Plus de détails sur le topic de la 503.
je rentre demain,
je lancerais la maj ce weekend
n'étant qu'en 4.180 cela promet quelques changements vu tout ce que j'ai lu sur les bêta
Envoyé de mon ONEPLUS A5000 en utilisant Tapatalk
J’ai suivi vos avis positifs et maintenant je pleure... erreur 404 et led « recovery » allumée (un peu avant c’etait la seule allumée et elle clignotait lentement)
merci Fibaro, je viens de perdre des années de LUA codés dans la douleur...
Modifié par Kantarno
Rassurez-vous, en étant patient j’ai fini par avoir la page de revovery. En faisant « exit » ça a rebooté et finalement tout semble ok... je revis
  • Like 2
