si je rajoute ca àla fin du bouton red
fibaro:debug(response3);
fibaro:debug(status3);
fibaro:debug(errorCode3);
cela donne ca dans le debug
[DEBUG] 23:45:13: "id":62,"lastSetValue":8,"size":1,"value":8
[DEBUG] 23:45:13: ---------------
[DEBUG] 23:45:13: {"id":8,"name":"Prise multimedia","roomID":9,"type":"com.fibaro.FGWP101","baseType":"com.fibaro.binarySwitch","enabled":true,"visible":true,"isPlugin":false,"parentId":105,"remoteGatewayId":0,"interfaces":["energy","power","zwave","zwaveAlarm"],"properties":{"parameters":[{"id":1,"lastSetValue":1,"size":1,"value":1},{"id":16,"lastSetValue":1,"size":1,"value":1},{"id":34,"lastSetValue":63,"size":1,"value":63},{"id":35,"lastSetValue":0,"size":1,"value":0},{"id":39,"lastSetValue":600,"size":2,"value":600},{"id":40,"lastSetValue":80,"size":1,"value":80},{"id":42,"lastSetValue":15,"size":1,"value":15},{"id":43,"lastSetValue":30,"size":1,"value":30},{"id":45,"lastSetValue":10,"size":1,"value":10},{"id":47,"lastSetValue":3600,"size":2,"value":3600},{"id":49,"lastSetValue":0,"size":1,"value":0},{"id":50,"lastSetValue":300,"size":2,"value":300},{"id":51,"lastSetValue":500,"size":2,"value":500},{"id":52,"lastSetValue":6,"size":1,"value":6},{"id":60,"lastSetValue":25000,"size":2,"value":25000},{"id":61,"lastSetValue":9,"size":1,"value":9},{"id":62,"lastSetValue":2,"size":1,"value":2},{"id":63,"lastSetValue":1,"size":1,"value":1},{"id":70,"lastSetValue":65535,"size":2,"value":65535}],"associationSet":[{"devices":[1],"groupID":1},{"devices":[1],"groupID":2},{"devices":[1],"groupID":3}],"associationView":[{"devices":[1],"groupID":1},{"devices":[1],"groupID":2},{"devices":[1],"groupID":3}],"zwaveCompany":"Fibar Group","zwaveInfo":"3,3,52","zwaveVersion":"","pollingTimeSec":0,"alarmLevel":"0","alarmType":"0","color":"off","configured":"true","dead":"false","deviceControlType":"12","deviceIcon":"2","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","energy":"7.07","liliOffCommand":"éteindre prise","liliOnCommand":"allumer prise","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"3","parametersTemplate":"225","power":"0.00","productInfo":"","pushNotificationID":"1","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","showEnergy":"true","smsNotificationID":"0","smsNotificationType":"0","useTemplate":"true","userDescription":"Le module est relié àla prise murale de la chambre 2.","value":"false"},"actions":{"reconfigure":0,"reset":0,"turnOff":0,"turnOn":0},"created":1427698595,"modified":1427698595,"sortOrder":10}
[DEBUG] 23:45:13: {"type":"ERROR","reason":"id","message":"no id"}
[DEBUG] 23:45:13: 400
[DEBUG] 23:45:13: 0
J'ai fait quelques modifications au VD: Plus besoin de créer des variables globales ni de faire un setting. Pour l'ID du module a commander, il faut le mettre dans le champs Port TCP l'ID du module (exemple pour moi: 195)
Ca fonctionne chez moi en v4.040 mais pas sure que ca soit compatible v3. Est-ce que ca fonctionne pour vous aussi ?
Zozotte
Colors_Wallplug (1).vfib
Alors la, incroyable, ca marche du tonnerre, il n y a même plus de latence de 5 secondes, c est instantané  :60:
Mais ne pas oublier de remercier Rems au passage  :13:
en V3.6 ça ne semblerait pas marcher
Avec ou sans l'adresse IP et en mettant l'ID du module en port TCP, j'obtiens l'erreur suivante :
[DEBUG] 22:41:49: err ID: 84 status: 501
