Domodial Posté(e) le 2 février 2018 Signaler Posté(e) le 2 février 2018 (modifié) Hello, Toujours en recherche active de faire une UI qui soit à mon gout, après Iridium je suis tombé sur celui çi ! Il s'agit d'un builder + applications mobiles/Tablettes tout ça. C'est abordable, il n'y a pas de serveur et ça comprends pas mal de requête et bidirectionnels. iViewer supporte : TCP Client/Server, UDP Unicast/Multicast/Broadcast, HTTP/HTTPS. MIAM ! Le Builder lui ne fonctionne que sous windoz. Portrait & Landscape Support for independant portrait and landscape orientations to show different controls when rotating the mobile device. The interface can also be easily locked to a single orientation if required. Supported Objects Build your interface with a variety of GUI Objects, such as buttons, gauges, sliders, dynamic or static images, video streams, embedded web pages, dynamic scrolling lists, text labels and input fields. Transitions & Sounds Easily apply transitions to your page flips or subpages such as fades, reveals, etc. All with customisable timing and easing. Support for audio file playback triggered via events. Gestures Gesture engine to take full advantage of mobile device multi-touch capabilities. Including multiple finger touches, swipes, pinch/zoom and rotation gestures with customisable actions. Simultaneous Control Simultaneously control unlimited Ethernet devices directly from your mobile device, no other hardware required. Expand your control to other transports such as IR (infrared), RS232 (serial) and relay (contact closure) by using control system hardware such as our own products, or any third party hardware. Open Platform iViewer works with any Ethernet-controllable hardware on the market. Directly control network addressable AV gear such as AV Receivers and TVs, or integrate with any control system hardware available today to provide a fully customisable control interface. iViewer can be used in a whole range of scenarios - not just automation systems. Remote control vehicles, digital signage, media player control - these are just some of the uses our customers have created. Highly Configurable Granular control over communication socket properties including heartbeats, startup events and queuing means that you can be sure iViewer is capable of integrating with your systems. Macros & Actions Easily create macros of multiple commands with customisable per-command delays, great for activity startup and shutdown events. Assign advanced actions at the button level, including cycling action groups, press and hold delays, separate press and release events, and more. Even the most unique actions are covered in iViewer. Remote Debugging iViewer includes a built-in remote debugger tool to show status of system connections, incoming data logs, GUI object states, etc. All done via a web browser (Chrome or Safari) connected to the mobile device running iViewer. Modifié le 2 février 2018 par Domodial
pepite Posté(e) le 2 février 2018 Signaler Posté(e) le 2 février 2018 ah ben voila tu as trouve ton bonheur..je sens qu'on va bientot changé d'interface ;-)
Domodial Posté(e) le 2 février 2018 Auteur Signaler Posté(e) le 2 février 2018 (modifié) Meme pas, tout est un peut galère, trop blindé, trop de "il faut prendre ce truc en plus sinon vous avez droit a Kedale" Bref ça me désole que les constructeurs (hors mis Lifedomus) ne propose pas de builder !!!! C'est juste dingue, si vous ne gérez pas les gars proposez un truc bien ou les clients se casserons les noix mais arriverons à un truc de bien. Franchement, ils gagnerait du temps pour le devellopment de fonctionnalités, et basta le Design serait laissé aux bons quoi. Fibaro ce n'est pas le plus moche (heureusement) mais je ne parle pas des autres... Avec Fibaro c'est que ce n'est pas malléable à souhait, la vue dashboard qui devrait censé être le point d'entrée, qui l'utilise ? Ben personne lol (sauf je ne dirais pas le nom) Du coup nous allons tous dans la vue programmation, mais qui n'est pas non plus malléable et surtout pas de différentiation entre Pepite et Domodial (d'un point de vue graphique). Truc de malade qui m'énerve depuis pas mal de temps. Bon je me calme je vais cuisiner ! EDIT : Et imperihome je me bat pour que les caméras soient reconnues en authentification en RTSP. Alors déjà que c'est compliqué pour eux à comprendre, l'interface c'est des gros boutons relou et voilà. Le RTSP est reconnu par TinyCam Pro (android) sur mes 17 caméras, et Impérihome dit que l'authentification sur Android n'est pas possible dû à une limitation d'android lol Et personne ne comprends ce que je dit. EDIT 2 : En plus il y a des gens qui sont dans la même mouise et ils ne répondent pas sur le ticket. Bref. HS car c'est des caméras mais bon...les gros boutons faites quelque chose quoi ! La bidouille photoshop c'est vraiment de la démerde de contournement, rien de viable. Modifié le 2 février 2018 par Domodial
