Krikroff Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 Cela donne quoi avec un "vdf -h" Output
mprinfo Posté(e) le 13 novembre 2017 Auteur Signaler Posté(e) le 13 novembre 2017 [root@localhost:~] vdf -h Tardisk Space Used sb.v00 172M 172M s.v00 311M 311M scsi_mpt.v00 464K 461K bnxtnet.v00 520K 517K elx_esx_.v00 5M 5M brcmfcoe.v00 2M 2M elxiscsi.v00 512K 510K elxnet.v00 632K 629K lpfc.v00 2M 2M amsd.v00 8M 8M bootcfg.v00 80K 77K conrep.v00 5M 5M cru.v00 44K 40K fc_enabl.v00 2M 2M hponcfg.v00 348K 346K ilo.v00 36K 32K oem_buil.v00 8K 4K scsi_hpd.v00 3M 3M scsi_hpv.v00 2M 2M smx_prov.v00 26M 26M ssacli.v00 19M 19M testeven.v00 68K 67K net_ixgb.v00 564K 561K intelcim.v00 268K 265K nmlx4_co.v00 652K 651K nmlx4_en.v00 676K 673K nmlx4_rd.v00 232K 229K nmlx5_co.v00 1M 1M smartpqi.v00 424K 421K nhpsa.v00 552K 549K qedentv.v00 2M 2M qlnative.v00 2M 2M ata_liba.v00 296K 294K ata_pata.v00 44K 40K ata_pata.v01 28K 27K ata_pata.v02 36K 32K ata_pata.v03 36K 33K ata_pata.v04 40K 37K ata_pata.v05 36K 34K ata_pata.v06 28K 27K ata_pata.v07 32K 31K block_cc.v00 84K 80K char_ran.v00 48K 47K ehci_ehc.v00 92K 91K hid_hid.v00 60K 56K i40en.v00 532K 529K igbn.v00 328K 325K ima_qla4.v00 1M 1M ipmi_ipm.v00 40K 36K ipmi_ipm.v01 80K 78K ipmi_ipm.v02 100K 98K lsi_mr3.v00 324K 321K lsi_msgp.v00 492K 491K misc_cni.v00 24K 22K misc_dri.v00 1M 1M mtip32xx.v00 252K 250K ne1000.v00 632K 630K nenic.v00 208K 204K net_bnx2.v00 284K 282K net_bnx2.v01 2M 2M net_cdc_.v00 28K 25K net_cnic.v00 148K 145K net_e100.v00 312K 311K net_e100.v01 352K 349K net_enic.v00 168K 167K net_fcoe.v00 80K 79K net_forc.v00 124K 121K net_libf.v00 76K 75K net_nx_n.v00 1M 1M net_tg3.v00 316K 312K net_usbn.v00 56K 53K net_vmxn.v00 104K 100K ntg3.v00 112K 110K nvme.v00 264K 261K nvmxnet3.v00 156K 153K ohci_usb.v00 60K 59K pvscsi.v00 68K 65K qfle3.v00 1M 1M qflge.v00 496K 494K sata_ahc.v00 84K 83K sata_ata.v00 56K 52K sata_sat.v00 64K 62K sata_sat.v01 44K 42K sata_sat.v02 48K 44K sata_sat.v03 36K 35K sata_sat.v04 32K 30K scsi_aac.v00 176K 174K scsi_adp.v00 444K 442K scsi_aic.v00 292K 288K scsi_bnx.v00 284K 280K scsi_bnx.v01 204K 203K scsi_fni.v00 236K 234K scsi_ips.v00 104K 102K scsi_isc.v00 44K 42K scsi_lib.v00 212K 211K scsi_meg.v00 96K 95K scsi_meg.v01 176K 173K scsi_meg.v02 92K 89K scsi_mpt.v01 500K 497K scsi_mpt.v02 428K 425K scsi_qla.v00 284K 281K shim_isc.v00 16K 15K shim_isc.v01 16K 15K shim_lib.v00 44K 43K shim_lib.v01 44K 43K shim_lib.v02 24K 20K shim_lib.v03 24K 20K shim_lib.v04 12K 9K shim_lib.v05 12K 9K shim_vmk.v00 220K 217K shim_vmk.v01 232K 228K shim_vmk.v02 236K 232K uhci_usb.v00 60K 59K usb_stor.v00 160K 158K usbcore_.v00 316K 312K vmkata.v00 776K 773K vmkplexe.v00 48K 46K vmkusb.v00 1M 1M vmw_ahci.v00 268K 267K xhci_xhc.v00 232K 231K emulex_e.v00 28K 25K btldr.t00 508K 506K weaselin.t00 4M 4M esx_dvfi.v00 456K 452K esx_ui.v00 13M 13M lsu_hp_h.v00 140K 136K lsu_lsi_.v00 268K 265K lsu_lsi_.v01 480K 477K lsu_lsi_.v02 264K 261K lsu_lsi_.v03 560K 556K native_m.v00 748K 744K rste.v00 824K 822K vmware_e.v00 120K 117K vsan.v00 38M 38M vsanheal.v00 7M 7M vsanmgmt.v00 12M 12M nmst.v00 68K 66K xorg.v00 3M 3M imgdb.tgz 1M 1M state.tgz 20K 18K ----- Ramdisk Size Used Available Use% Mounted on root 32M 2M 29M 6% -- etc 28M 184K 27M 0% -- opt 32M 48K 31M 0% -- var 48M 364K 47M 0% -- tmp 256M 172K 255M 0% -- iofilters 32M 0B 32M 0% -- hostdstats 67M 1M 65M 2% --
Krikroff Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 Lol, oui effectivement il y a un problème tu as de la marge dans tmp/ Peut-être une piste ici https://kb.vmware.com/s/article/1007638 1
pepite Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 (modifié) Il y a 18 heures, jojo a dit : esxcli system module set --enabled=false --module=vmw_ahci mais il faut avoir un HPGen8, sinon ça marche moins bien Ah oui, ca balance cache ;-) C'est sur que c'est mieux avec un GEn8 lol ..encore appele pix ce matin, je ne les lache pas ;-) Il y a 1 heure, mprinfo a dit : Error in copying from /bootbank/sb.v00 to /tmp/stagebootbank/sb.v00: [Errno 28] No space left on device Ah bon, un souci ? ;-) @mprinfo tu as adopté les chats de @jojo ;-) Modifié le 13 novembre 2017 par pepite
mprinfo Posté(e) le 13 novembre 2017 Auteur Signaler Posté(e) le 13 novembre 2017 je vais regarder cela ce soirj'ai pas mal bidouiller dans ilo je me demande si j'ai pas fait une connerie ? Envoyé de mon SM-G901F en utilisant Tapatalk
pepite Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 il y a 51 minutes, mprinfo a dit : Tardisk Space Used sb.v00 172M 172M hihi
jojo Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 je viens de re-installer Esxi 6.5U1sur ma clé de secours et bizarre vous avez dit bizarre ?
jojo Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 j'ai remis l'ancienne clé (l'originale) et Il semblerait donc qu'il ne lise pas les infos depuis le serveur mais depuis une DB qu'il mais à jour ? y a-t-il un moyen (autre que via Esxi) pour vérifier la version réelle du driver installé ?
jojo Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 en allant dans ILO, je vois que je suis bien en 088. Je suppose que cette source est fiable ?
jojo Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 et bien non ! J'ai fait le test "de la mort qui tue". J'ai (re)-booté le serveur sir la clé de backup et j'ai la version 102. Et ILO ne voulait me donner les versions des software que quand un service AMS était démarré. C'est comme si ce fameux driver était sur la clé ?` Je raconte des bêtises ou pas ?
jojo Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 (modifié) je confirme, ce salopard de driver est stocker sur cette foutue clé USB. En effet j'ai refait la manip du downgrade, et je vois bien dans Esxi que je suis en 088. On en apprend tous les jours ... Modifié le 13 novembre 2017 par jojo
Krikroff Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 Heu il y un truc que je ne pige pas là, cela me semble logique que le driver soit installé sur le support ou est installé ESXi. Si tu fais 10 clés tu auras 10 ESXi ou j’ai pas suivi quelque chose ?Envoyé de mon iPhone en utilisant Tapatalk
mprinfo Posté(e) le 13 novembre 2017 Auteur Signaler Posté(e) le 13 novembre 2017 Idem je crois aussi que c'est normal que le pilote soit sur la microSD
jojo Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 je pensait que le driver serait installé sur la carte même (EPROM)
Krikroff Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 C’est un driver ESXi Et pas un micro logiciel . En gros c’est comme installer un driver sous Windows...Envoyé de mon iPhone en utilisant Tapatalk 1
mprinfo Posté(e) le 13 novembre 2017 Auteur Signaler Posté(e) le 13 novembre 2017 documentation HP Gen8 :http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03796560-5.pdf 1
jojo Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 il y a 37 minutes, Krikroff a dit : C’est un driver ESXi Et pas un micro logiciel . En gros c’est comme installer un driver sous Windows... Envoyé de mon iPhone en utilisant Tapatalk voyons le côté positif des chose, si ça vait merdé, je n'aurait pas foutu mon serveur en l'air, juste à refaire la clé. Donc dans ce cas-ci, c'est HPE qui a fait un petit bug dans sa custom image alors
mprinfo Posté(e) le 13 novembre 2017 Auteur Signaler Posté(e) le 13 novembre 2017 vdf -h Sous ESXI 6.5U1 Ramdisk Size Used Available Use% Mounted on root 32M 2M 29M 6% -- etc 28M 184K 27M 0% -- opt 32M 48K 31M 0% -- var 48M 364K 47M 0% -- tmp 256M 172K 255M 0% -- iofilters 32M 0B 32M 0% -- hostdstats 67M 1M 65M 2% -- Sous ESXI 6.5 Ramdisk Size Used Available Use% Mounted on root 32M 24K 31M 0% -- etc 28M 144K 27M 0% -- opt 32M 68K 31M 0% -- var 48M 420K 47M 0% -- tmp 256M 1M 254M 0% -- iofilters 32M 0B 32M 0% -- hostdstats 67M 1M 65M 2% -- c'est fou cela tout ce passe très bien sous esxi 6.5 [root@localhost:~] esxcli system maintenanceMode set --enable true [root@localhost:~] esxcli network firewall ruleset set -e true -r httpClient [root@localhost:~] cd /tmp [root@localhost:/tmp] wget http://downloads.hpe.com/pub/softlib2/software1/pubsw -linux/p1749737361/v98767/hpvsa-5.5.0-88.zip Connecting to downloads.hpe.com (15.233.128.58:80) hpvsa-5.5.0-88.zip 100% |*******************************| 701k 0:00:00 ETA [root@localhost:/tmp] unzip hpvsa-5.5.0-88.zip Archive: hpvsa-5.5.0-88.zip inflating: index.xml inflating: vendor-index.xml inflating: metadata.zip inflating: scsi-hpvsa-5.5.0-88OEM.550.0.0.1331820.x86_64.vib [root@localhost:/tmp] cp scsi-hpvsa-5.5.0-88OEM.550.0.0.1331820.x86_64.vib /var/ log/vmware/ [root@localhost:/tmp] esxcli software vib remove -n scsi-hpvsa -f Removal Result Message: The update completed successfully, but the system needs to be rebooted for the changes to be effective. Reboot Required: true VIBs Installed: VIBs Removed: HPE_bootbank_scsi-hpvsa_5.5.0.102-1OEM.550.0.0.1331820 VIBs Skipped: [root@localhost:/tmp] esxcli software vib install -v file:scsi-hpvsa-5.5.0-88OEM.550.0.0.1331820.x86_64.vib --force --no-sig-check --maintenance-mode Installation Result Message: The update completed successfully, but the system needs to be rebooted for the changes to be effective. Reboot Required: true VIBs Installed: Hewlett-Packard_bootbank_scsi-hpvsa_5.5.0-88OEM.550.0.0.1331820 VIBs Removed: VIBs Skipped: [root@localhost:/tmp] esxcli system module set --enabled=false --module=vmw_ahci [root@localhost:/tmp] reboot
mprinfo Posté(e) le 13 novembre 2017 Auteur Signaler Posté(e) le 13 novembre 2017 Pour ceux qui install dsm dans une VM une solution simple sans besoin de convertir le fichier image ouvrir notepad++ et coller ce code # Disk DescriptorFile version=1 CID=37f446cf parentCID=ffffffff createType="vmfs" # Extent description RW 102400 VMFS "synoboot.img" 0 # The Disk Data Base #DDB ddb.adapterType = "lsilogic" ddb.deletable = "true" ddb.encoding = "UTF-8" ddb.longContentID = "9ba4bf6fac655fab2bfeefae37f446cf" ddb.thinProvisioned = "1" ddb.uuid = "60 00 C2 9a ee da ca 33-df 5e 04 3f 80 55 f9 62" ddb.virtualHWVersion = "10" enregistrer le fichier avec le nom synoboot.vmdk renommer le fichier xpeno en synoboot.img
Lazer Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 Jojo je ne vois pas ce qui te choque, le driver hpvsa est installé sur le disque système, donc le support qui a permis de booter ESXi (carte SD, clé USB etc), c'est tout à fait normal, rien à voir avec le datastore. Donc si tu te fais plusieurs clé USB, il te faut downgrader autant de fois; Le 12/11/2017 à 14:02, sebcbien a dit : D'un autre côté, HP/ESXi vont sortir un correctif pour ce problème non ? Franchement, je ne pense pas, ce bug est présent depuis 2 ans, et le MicroServer n'est pas franchement la priorité de HPE et VMware. De plus en entreprise, il n'y a généralement aucun disque dans les serveurs, le stockage se fiat en mode SAN, c'est à dire sur des baies de disques partagées externes, donc pas besoin du driver hpvsa (carte RAID interne) Le 12/11/2017 à 15:11, Krikroff a dit : Sinon, rien à voir mais l’avantage aussi du SSD c’est d’avoir la partition de swap de l’ESXi sur un disque avec des accès et un débit à la hauteur. Bon j’imagine que cette partition doit pouvoir être déplacée mais par défaut il me semble que c’est sur le disque d’installation : USB faible performance, MicroSD fragilité... Au final j’aime mon SSD. Je ne suis pas du tout spécialiste donc je raconte peut-être des bêtises, j’ai pris des raccourcis pour arriver ces conclusions Je pense que tu te fourvoies Par défaut, le swap de chaque VM est stocké dans le répertoire de la VM, donc sur le datastore. D'ailleurs regarde l'espace libre de ton datastore quand toutes les VM sont arrêtées, puis lorsqu'elles seront toutes allumées, tu verras la différence ! Donc le swap n'est pas sur USB/SD, car on ne peut créer de datastore sur ces supports (et heureusement) C'est forcément disque dur, SSD, stockage externe (SAN, iSCSI, NFS) 1
Krikroff Posté(e) le 13 novembre 2017 Signaler Posté(e) le 13 novembre 2017 Merci pour cette rectification, je me coucherai moins bête ce soir Pffff c'est tellement logique pourtant, quel boulet 1
mprinfo Posté(e) le 15 novembre 2017 Auteur Signaler Posté(e) le 15 novembre 2017 [mention=3]Krikroff[/mention] je viens d'installer 16go sur mon gen8 je peux installer ESXI 6.55U1 et downgrader le pilote HP Mon probléme venait bien du fait que je n'avais que 4GO Je te remercie pour ton aide 3
Krikroff Posté(e) le 15 novembre 2017 Signaler Posté(e) le 15 novembre 2017 Génial, un bon investissement les 16Go Envoyé de mon iPhone en utilisant Tapatalk 2
Nico Posté(e) le 15 novembre 2017 Signaler Posté(e) le 15 novembre 2017 Par contre les messages d'erreurs sont aussi hyper explicite:) 1
