marpas01 Posté(e) le 8 juillet 2017 Signaler Posté(e) le 8 juillet 2017 (modifié) bonjour j ai domotisé la filtration de ma piscine et fait ce scenario pour filtrer pendant 3 plages dans la journée mais ça ne fonctionne pas pouvez-vous m'aider merci d'avance --[[ %% autostart %% properties %% weather %% events %% globals --]] local sourceTrigger = fibaro:getSourceTrigger(); function tempFunc() local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); if ( ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "0") ) ) then fibaro:call(260, "turnOn"); setTimeout(function() fibaro:call(260, "turnOff"); end, 14400000) end setTimeout(tempFunc, 60*1000) end else local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); if ( ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "08:00") ) ) then fibaro:call(260, "turnOn"); setTimeout(function() fibaro:call(260, "turnOff"); end, 14400000) end setTimeout(tempFunc, 60*1000) end else local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); if ( ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "14:00") ) ) then fibaro:call(260, "turnOn"); setTimeout(function() fibaro:call(260, "turnOff"); end, 21600000) end setTimeout(tempFunc, 60*1000) "end" local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); Modifié le 8 juillet 2017 par marpas01
speedoxx007 Posté(e) le 11 juillet 2017 Signaler Posté(e) le 11 juillet 2017 (modifié) Hello Il existe une bonne solution avec un VD: Je l'utilise depuis env. 1 année et ça fonctionne très bien. Modifié le 11 juillet 2017 par speedoxx007
