HC2 - 4.133 - BETA - 26/06/2017
Bonjour à tous,
Même style que la 4.132 beta
Citation
Version 4.133 Beta
Resolved issues:
-Error during sending string with hexadecimal data from virtual device
Bonsoir
Je suis passé en 4.31
- Prb VD qui ne fonctionnent plus
- plus d'envoi d'email
Je suis passé en 4.32
- idem
Je suis repassé en 4.30
- tout fonctionne sans prb
J'attends de vos nouvelles, tout est corrigé en 4.33 ?
Merci à vous
#!/bin/ash
# add this script to crontab of your router or any linux machine
# i use openwrt router with sendmail, curl packages
# */15 * * * * /scripts/hc2watchdog
set -e
# IP of HC2
HCIP="192.168.1.n"
# login string for HC2
HCLOG="admin@domain.pl:password"
# email from
mserver="mail.mail.pl"
muser="hc2@domain.pl"
mpass="password"
# email to
memail="user@domain.pl"
status_www=`curl -N -I --user $HCLOG $HCIP/api/settings/info 2>/dev/null | head -n 1`
echo $status_www
status_server=`curl -N --user $HCLOG $HCIP/api/refreshStates 2>/dev/null | head -n 1 | cut -d',' -f1 | cut -d "{" -f2`
status_time=`curl -N --user $HCLOG $HCIP/api/refreshStates 2>/dev/null | head -n 1 | cut -d',' -f3`
echo "HC2 response:"
echo "==============================="
echo $status_server
echo $status_time
case "$status_server" in
  *status*)
    echo "HC2 working"
    echo $status_time
    exit
esac
echo "Problem..."
# send syslog message to my syslog server, put hash begin of next line if you not use
logger "HC2 - restart $status_server" -p authpriv.alert -t HC2
echo "HC2 restart..."
curl --user $HCLOG http://$HCIP/services/finishUpgradeAfterError.php
# send email to you after restart, put hash begin of next line if you not use
mailsend -smtp $mserver -port 587 -auth -user $muser -pass $mpass -starttls -f dom@durbajlo.email -name "HC2 watchdog" -t $memai
echo "HC2 status " $status_server > /tmp/hc2.status
echo "HC2 - oczekiwanie na restart"
sleep 60s
echo "HC2 - check after restart"
echo "================================"
echo $status_www
echo $status_server
echo $status_time
Parce que, dans la version 4133 sont les mêmes erreurs que dans la version précédente, j'ai écrit un script pour redémarrer  automatiquement de l'extérieur ma HC2  en cas d'erreur 503 ou d'un serveur interne de HC2.
Tout en anglais à https://forum.fibaro.com/index.php?/topic/26127-external-watchdog-for-hc2/
Modifié par drboss
@ericl78 no... en version 9.9999 :13:
code secret de HC2
version = version + 0.001
if version < 9.999 then
call funcion(minimum_1_error_creation)
if version >= 9.999 then
call funcion(randomly_1_error_remove)
Le 26/06/2017 à 21:01, drboss a dit :
code secret de HC2
Peux tu stp me donner plus d'info, je n'arrive pas à te comprendre
merci à toi
Le 27/06/2017 à 21:08, ericl78 a dit :
merci à toi
C est pour rire^^
Je te traduis en langage de terrien :
Code secret de HC2
version = version + 0.001 (on ajoute à la version actuelle 0.001 soit si en 4.132 arrive en 4.133)
if version < 9.999 then (si la version est inférieur à ...)
call funcion(minimum_1_error_creation) (faire une erreur au moins)
call funcion(randomly_1_error_remove) (si la version est supérieure ou égale à 9,99 enlever aléatoirement une erreur).
Le 26/06/2017 à 15:25, pepite a dit :
Bonjour à tous,
Fibaro fait de gros efforts pour être de plus en plus sexi :2:
Salut à tous
Moi tout est OK par contre j ai un problème avec les notifications les accents sont remplacé par des signes ;)
Envoyé de mon MHA-L09 en utilisant Tapatalk
ce problème d'accent a toujours existé.
Si tu as le courage, cherche sur le forum, j'ai posté la solution, il faut mettre un caractère très particulier avant le '.
(n'ayant plus de HC2, il me sera difficile de le retrouver)
Il y a 11 heures, jojo a dit :
J'ai retrouvé dans mes notes la solution :
Notification Panel
Z-Apostrophe
Test : l`apostrophe
1"
2'
3 ’ <- la solution
Merci jojo
je vais tester
ps comment c est edomus j ai vu que tu as changé :huh:
Modifié par flechg
Ah oui tiens j'avais pas fait gaffe mais moi aussi j'ai tous les caractères accentués qui passent pas ! Et donc faut rajouter quoi devant alors ? J'ai pas suivi :)
il y a 45 minutes, flechg a dit :
Merci jojo
je vais tester
Non, ce n'est pas Edomus, mais Lifedomus, je mets à jour ma signature ..
@BenjyNet,
J'ai raconté des bêtises (comme d'hab), la seule solution que j'avais, c'était pour les apostrophe. Pour les caractères accentués, je le mettais sans les accents ...
Oui moi aussi j'ai viré les accents, et donc vu le sujet j'ai essayé avec et effectivement ça déconne !! :D Mais il me semble que c'est comme ça depuis le début non ?
Oui moi aussi je vais virer les accents par contre ça fonctionnait avec la version stable chez moi
allez @Lazer, un peu de positivisme ...
Fibaro sans des bugs à la con qui apparaissent sans raison, ce ne serait plus Fibaro.
  • Upvote 2
  • 3 semaines après...
