Mise à jour 1.140.0 du 06/06/2017.
- Added new heating panel functionalities that allows you to easily control your heating zones. Simply access it from Climate section.
- Added ability to use a Touch ID for disarming Fibaro alarm.
- Simplified adding and first door lock configuration.
- Added auto-reconnecting functionality - when an application cannot connect to the Home Center, the connection is reestablished.
- Added possibility to update Home Center from application settings.
- Updated Finnish, Portuguese and Czech translations.
- Added minor application improvements.
