HC2 nodon octan remote sans template
Marcolopo76
j'ai réussi a paramétrer cette télécommande
mais dans le panneau de diagnostique de la HC2
ça me dit module sans template et me l'affice dans le centre de notification ...
au secours
merci
Some devices in your Z-Wave network do not have Z-Wave templates.
If they do not work properly or miss some functionalities, download the device's template and send it to support@fibaro.com.
We will prepare the appropriate Z-Wave template to fix the problem and provide full support of the device.
The lack of parameters template does not mean that device is not supported. You can still add configuration parameters manually according to device's manual using the Advanced Configuration page.
This notification will disappear when all devices will have Z-Wave templates.
