drboss
    100
    5
drboss a gagné pour la dernière fois le 4 janvier 2020
drboss a eu le contenu le plus aimé !
À propos de drboss
  • Date de naissance 01/01/1970
    Varsovie
    Home Center Lite
    Autre
    4.140
2929 visualisations du profil
drboss's Achievements
38
  1. drboss
    Mon problème est résolu, j'ai oublié que pour le temps (-1) une nouvelle instance de la scène est démarrée à chaque fois.
  2. drboss
    I return to my problem with: I can't find where is the problem, it's occurs with this code (paste partially): --[[ %% properties 344 sceneActivation ../.. GEA.add ({"SceneActivation", 344, 10}, -1, "Ogród - alarm uzbrojony", {{"geatelegram", "Ogród - alarm uzbrojony"}}) GEA.add ({"SceneActivation", 344, 11}, -1, "Ogród - alarm rozbrojony", {{"geatelegram", "Ogród - alarm rozbrojony"}}) if the line is triggered by changed sceneActivation value the command is start (message, scene running) ok, but after this GEA call section for "CentralSceneEvent": centralsceneevent = {name="CentralSceneEvent", optimize = true, control=function(id, key, attribute) if (GEA.currentEntry.duration > -1) then return false, GEA.trad.central_instant end return GEA.options.number.control(id) and type(key)~="nil" and type(attribute)~="nil", GEA.trad.central_missing end, getValue=function(id, key, attribute) return (GEA.source.event.data.deviceId==tonumber(id) and tostring(GEA.source.event.data.keyId)==tostring(key) and tostring(GEA.source.event.data.keyAttribute)==tostring(attribute)) end --LINE 1309 }, And generate error because event table (GEA.source.event) is null. It's clear because it's sceneActivation not CentralSceneEvent from %% events section. The device is UBS with enabled scene functionality. Why this happen, Why???
  3. drboss
    Mon code: --[[ %% autostart %% properties 312 value 311 sceneActivation 312 sceneActivation %% events %% globals --]] --pour info -- ID.Domogolne.dom_czuwanie = 311 -- ID.Domogolne.ogrod_czuwanie = 312 -- ID.techniczne.sterowanie_alarm = 313 GEA.add ({{"SceneActivation", ID.Domogolne.dom_czuwanie, 20},{"Value", ID.Domogolne.ogrod_czuwanie, 0},{"Time!", "22:00", "06:00"}}, -1, "Ogrod uzbrojony razem z nocnym", {"turnOn", ID.techniczne.sterowanie_alarm}) --wlaczenie ogrodu z noca -- dom_rozb i ( ogr_uzb lub org_alm ) GEA.add ({{"SceneActivation", ID.Domogolne.dom_czuwanie, 21},{"Or",{"SceneActivation", ID.Domogolne.ogrod_czuwanie, 10}, {"SceneActivation", ID.Domogolne.ogrod_czuwanie, 20}},{"Time", "6:00", "23:00"}}, -1, "Ogrod rozbrojony razem z nocnym", {"turnOn", ID.techniczne.sterowanie_alarm}) --wylaczenie ogrodu po nocy GEA exécute correctement les commandes mais... [DEBUG] 13:11:21: 2020-05-01 13:11:21.375676 [ fatal] Unknown exception: /opt/fibaro/scenes/211.lua:1309: attempt to index field 'event' (a nil value) centralsceneevent = {name="CentralSceneEvent", optimize = true, control=function(id, key, attribute) if (GEA.currentEntry.duration > -1) then return false, GEA.trad.central_instant end return GEA.options.number.control(id) and type(key)~="nil" and type(attribute)~="nil", GEA.trad.central_missing end, [1309] getValue=function(id, key, attribute) return (GEA.source.event.data.deviceId==tonumber(id) and tostring(GEA.source.event.data.keyId)==tostring(key) and tostring(GEA.source.event.data.keyAttribute)==tostring(attribute)) end pourquoi???
  4. drboss
    DAHUA  IPC-HDBW2431R-ZS et HC2
    BTW If you things use this camera via api ex. via REST HTTP it use digest authorisation. If you have problem with snapshot image taken by link with onvif in address (ex below) turn off onvif authorisation in camera setup. But test first with turned on STEP 8 - Check that MediaUri field contains valid URL URI: http://192.168.1.109/onvifsnapshot/media_service/snapshot?channel=1&subtype=0 ex for other Dahua with PTZ. # go to garden gate if opened curl --digest --user admin:pass -v 'http://admin:pass@192.168.1.109/cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=1&arg3=0' # return to track sleep 15 curl --digest --user admin:pass -v 'http://192.168.1.109/cgi-bin/ptz.cgi?action=start&channel=0&code=StartTour&arg1=1&arg2=0&arg3=0'
  5. drboss
    This time in English :-) Check by this internal tool of ONVIF Assocation (it's old but last public accessed, test all function of Onvif cameras and give links to snaps or live streams) On discovery tab enter IP, user and pass of camera, select network card in NIC box (by default the loopback is selected) and press PROBE. After connected go to diagnostic tab and select <media configuration/media streaming> and <realtime streaming> (or more if you need) after this press RUN SELECTED. After test (with many black window or with image from camera) on right window you will see many interesting info and link to stream or jpg snap. I discovered snapshot link and lowres streams of my new and old Dahua and Novus cameras without problems https://drive.google.com/open?id=1vtl0ajm9oygxdPj4JykXmMrpo5RNYY-L
  6. Et encore mon ancienne modification, une petite pour indique quel VD ou scene vérifié par watchdog n'existe pas: Message("red", "Error : status=" .. tostring(response.status)..", when check: "..watchdog[i].type ..watchdog[i].id) en place du code: Message("red", "Error : status=" .. tostring(response.status))
  7. @tcheri Si vous en avez vraiment besoin at si toujours à jour, petite modification pour redémarrage du bouton avec error: 1. si vous devez vérifier un bouton spécifique, la ligne de VD a l'option ajoutée: vd_button avec le numéro du bouton pour vérifier {type = "VD", id =1151, match = {text="", interval=0}, no_match = {text="", type="ERROR"}, restart=true, notification = {"email", "SQLLOG"}, vd_button ="23"}, 2. modification de code: À la place de la lignes (position env. line 236): if watchdog[i].type:lower() == "scene" then getURL = "http://127.0.0.1:11111/api/scenes/"..watchdog[i].id.."/debugMessages" elseif watchdog[i].type:lower() == "vd" then if watchdog[i].vd_button == nil then watchdog[i].vd_button="0" end getURL = "http://127.0.0.1:11111/api/virtualDevices/"..watchdog[i].id.."/debugMessages/0" else Message("red", "Error : unknown type value") end insérer le code: if watchdog[i].type:lower() == "scene" then getURL = "http://127.0.0.1:11111/api/scenes/"..watchdog[i].id.."/debugMessages" elseif watchdog[i].type:lower() == "vd" then if watchdog[i].vd_button == nil then watchdog[i].vd_button="0" end getURL = "http://127.0.0.1:11111/api/virtualDevices/"..watchdog[i].id.."/debugMessages/"..watchdog[i].vd_button else Message("red", "Error : unknown type value") end
  8. J'ai aussi ce problème avec NodOn
  9. Erreur dans: http://192.168.1.x/services/system/servicesStatus.php - compte incorrectement les DEVICES avec piles vides. Le script compte lorsque la valeur est 0 au lieu de 255
  10. drboss
    @Steven, @pepite jusqu'à que vous créée la nouvelle édition de GEA , je corrige chez moi comme suit: local num1 = tonumber(string.match(value4, "-?[0-9.]+")) local num2 = tonumber(string.match(result, "-?[0-9.]+")) et je vais tester...
  11. drboss
    En résumé, la fonction "Value+/-" ne fonctionne pas lorsque la valeur du périphrique est négative et GEA est moins aléatoire qu'une femme...
  12. drboss
    @pepite C'est comme ça que ça se passe chez moi (GEA6.10): values is taken from 3 thermometers devices value=-23.8 GEA.add({"Value+", 335, -40}, 30, "sukces1 #value#") not work (every time) value=-23.8 GEA.add({"Value-", 335, -10}, 30, "sukces1 #value#") not work (every time) value= 18.2 GEA.add({"Value+", 262, -9}, 30, "sukces2 #value#") work (every time) value= 11.5 GEA.add({"Value+", 1281, 0}, 30, "sukces3 #value#") work (every time) value= 11.5 GEA.add({"Value+", 1281, 0}, 30, "sukces3 #value#") work (every time) value= 11.5 GEA.add({"Value+", 1281,-11}, 30, "sukces3 #value#") work (every time) value= 11.5 GEA.add({"Value+", 1281,-9}, 30, "sukces3 #value#") not work (3 times), work after change condiction to fist position (to verify) value= -6.5 GEA.add({"Value+", 1126, -40}, 30, "sukces1 #value#") not work (every time) value= -6.5 GEA.add({"Value-", 1126, -9}, 30, "sukces2 #value#") not work (every time) ps. C'est comme demander à une femme quelque chose et son cœur répondra. Nous ne savons pas non plus quoi et pour quoi
  13. drboss
    @pepite , tu es le plus actif alors je te demande, pourquoi {"Value+", 1281, 0} ou {"Value+", 1281, 9} fonctionne mais {"Value+", 1281, -9} ne fonctionne pas?
  14. Nouvelle version: http://192.168.1.x/services/system/servicesStatus.php Des résultats plus détaillés qu'auparavant: {"HCServer":{"running":true,"status":"Ok","devicesStatus":{"disconnected":10,"directRoute":41,"indirectRoute":24,"unknownRoute":26,"batteryEmpty":0,"batteryLow":0,"batteryMedium":17,"batteryHigh":13}},"Zwave":{"running":true,"status":"Ok"},"FibaroServices":{"running":true,"status":"Ok"},"RemoteAccess":{"running":true,"status":"Ok"}}
  15. drboss
    Bon anniversaire jojo
