Sankotronic
    62
    17
Sankotronic a gagné pour la dernière fois le 2 octobre 2025
Sankotronic a eu le contenu le plus aimé !
À propos de Sankotronic
  • Date de naissance 04/18/1968
    Rijeka
  • Intéret :
    HA
    Home Center 3
    HC2 4.630 HC3 5.183
6092 visualisations du profil
Sankotronic's Achievements
Contributor
Contributor (5/14)
  • Reacting Well Rare
  • Dedicated Rare
  • Collaborator Rare
  • Conversation Starter Rare
  • First Post Rare
Recent Badges
62
  1. Hi @fel-x, Ntfy solution you are referring to and provided link is solution from @jgab. My solution is not yet published but includes more messaging services. You can check it here: https://forum.fibaro.com/topic/80437-sankotronic-lab-yubii-uhas™-universal-home-automation-system-for-hc3/ BTW - my favorite service is Pushover since it has the best priority levels and alarm messages repeats sound until is really opened and seen by the user so can't be missed
  2. Hello to all, I do not quite understand what is the problem on your side. It is true that my quick app is encrypted, but I already posted a hint how to write code to get token automatically without needing to generate it manually here: and I'm willing to share complete code if anyone is interested.
  3. Hello again, Today token was renewed without any errors: Normally token should be valid for 1 year, but to be on the safe side my quick app renew token every 180 days. BTW - I guess you noticed that quick app is in French on above picture. Normally it is in Croatian. I can translate quick app on the go since it is now part of the new Yubii UHAS (Universal Home Automation System) that I'm working on. I can also stop, and restart any quick app that is part of the Yubii UHAS with Yubii Home mobile application.
  4. Hello, my Quick app Enphase Envoy Monitor token will expire in 1 day: Will let you know if it managed to renew token automatically as expected
  5. Hi @TitiXsi, To refresh token you need to store serial ID of the Envoy and login credentials to refresh token. With that you first request session ID: local url="https://enlighten.enphaseenergy.com/login/login.json" local payload='{"user":{"email":"'..self.userName..'","password": "'..self.userPassword..'"}}' self.http:request(url,{options={checkCertificate=false,method='POST',headers={['Accept']='application/json',['Content-Type']='application/json',},data=payload,timeout=10000}, to get new session ID. After you get session ID then you call: local url="https://entrez.enphaseenergy.com/tokens" local payload='{"session_id":"'..self.sessionID..'","serial_num":"'..self.serialNO..'","username":"'..self.userName..'"}' self.http:request(url,{options={checkCertificate=false,method='POST',headers={['Accept']='application/json',['Content-Type']='application/json',},data=payload,timeout=10000}, to get token. As you can see from my code you do need session ID, serial NO and user name to get new token. NOTE that if if any of the above request fails then there must be delay of at least 5 minutes before you can try to get new session ID and the token again. Not to wait for long time I reduced lifespan of the token to few hours for testing purposes. I can do that because I store time when token was generated and then I add time until when it must be refreshed.
  6. Hello, this morning at around 07:50h CET all my virtual devices and quick apps for Netatmo weather station and Air Quality monitors reported problem with Netatmo servers. HC2 Virtual devices reported 30 minutes no response. Scene for Netatmo weather get stuck in negotiations and I had to stop it manually by flipping the switch auto/manual. Quick app just reported connection error: Operation canceled and continue working properly. At about 08:25h CET everything come back to normal operation and none of my VD and QA reported invalid tokens. If you notice any problems please check first in debug if it is interruption of the service or your token is invalidated. In case that you have problems with token then you will have to generate new ones and paste them to either Netatmo scenes or Quick apps. BTW - I noticed also that their mobile apps had problem with connection with servers including Netatmo, Energy and Home coach. I'm talking about these solutions: https://marketplace.fibaro.com/items/netatmo-weather-station-qa-v1-1 https://marketplace.fibaro.com/items/netatmo-indoor-air-quality-monitor-qa-v1-1 both on version 2.1
  7. Hi @Nico, Sorry for late replay. To renew tokens for Netatmo Weather station standalone version follow this steps: Get new tokens at Netatmo my apps Open Netatmo weather scene and paste new tokens to code Delete global variable NetatmoW_scene_[scene_ID] Save scene and run it at least once manually so that global variable is generated with new tokens Instead of deleting global variable you can just change local variable scVersion from "3.2" to "3.3" and then save scene and run manually at least once. Hope this helps.
  8. Interesting. Please, can you provide me a link to mentioned Influx db QA? Where I can find it? Thank you
  9. Hi @flacon030, You are completely right about needing to reinstall encrypted QA each time when there is an update released. I guess with encrypted QA that will be always the case, needing to replace QA, because I do not believe that Fibaro will change anything related to encrypted QA and security in the future. On the other hand I do not find that as a big problem. Most of my work does not need much of the upgrades except in case like with Netatmo decided to again change their API or server domain. Since that is something that does not happen very often... In case of my work, there is always possibility to get unencrypted version that can be then easily upgraded by changing code, but that has a price.
  10. Hello @Verdure, either you are doing something wrong or there is a problem with your station. Cant say since you didn't provide any debug info. Even I know that QA is working I just installed Netatmo QA on my Yubii Home box, added app on Netatmo developer site and copy/pasted client ID, client secret and refresh token to QA and it started working immediately as expected: And debug from importing QA until it is configured and use my second station (has wind and rain) as weather provider:
  11. Hello @Verdure, For this QA to work you need to go to https://dev.netatmo.com/ and if you do not have one then create your account to login. After you login, in the top right corner click on your account name and select My apps option. Best option is to create new app for this QA. You can give name to this app so you know it is used with this QA on HC3. You also need to provide data protection officer name and e-mail. As soon as app is added, its client ID and client secret will be generated. Copy those since you will need to paste them in QA variables. Last step is to generate tokens. Just choose scope read_station and click on generate tokens button. You will be redirected to web page to confirm token generation and then returned to app. Copy/paste refresh token to QA variable and save QA. Note that access token is not needed since QA will generate one on the first run. There is a detailed instructions how to install QA in provided user manual, see chapter 3. Thank you for choosing my work!
  12. Hello, You can try this one on Fibaro marketplace: https://marketplace.fibaro.com/items/netatmo-weather-station-qa-v1-1 I just update it to version 2.1 Latest update is to use Netatmo servers endpoint that will not be removed. To install QA just follow instructions in provided User manual. If you need any further assistance I'm available on Fibaro forum. There is also QA for Netatmo Smart indoor air quality monitor on Fibaro marketplace: https://marketplace.fibaro.com/items/netatmo-indoor-air-quality-monitor-qa-v1-1 It is also updated to version 2.1 for the latest Netatmo API changes.
  13. Hello, I was right about daylight savings (winter/summer time) and discrepancy of the consumption reported by API and Enlighten app. There are users already reacted on this problem: https://support.enphase.com/s/question/0D5Ps00000pxRwbKAE/productionjson-consumption-less-than-shown-on-enlighten-app I have also sent e-mail to api@enphaseenergy.com if they can check.
  14. Hello, I noticed that there is a problem with today consumption calculation after we changed from winter to summer time (+1h). Today consumption is not calculated by my QA, but it is received from Envoy local API. Since I do calculate today imported energy, which is more or less correct, but today consumption is reported less than it should be, there is problem with grid dependence calculation which is then before production starts more than 100%. I'm curious if there is other users that noticed this discrepancy. Actually there is also discrepancy between today consumption reported by local API and today consumption reported by their mobile app and their cloud at https://enlighten.enphaseenergy.com I guess that Enphase Envoy actually does not take into account that seasonal time change. What do you think?
  15. Hi @Nico, HC2 version has a bit different code and if Netatmo cloud is not properly updated (every 10 minutes) then VD+scene requests data every 1 minute until cloud is properly updated and that is enough time between requests not to fail with token updates.
