276 -
Tout ce qui a été posté par speedoxx007
HC2 & HCL - 4.151 - BETA - 07/12/2017
speedoxx007 a répondu à un(e) sujet de speedoxx007 dans Firmware
j'attend avant de cliquer sur mes deux boxes :-) -
HC2 & HCL - 4.151 - BETA - 07/12/2017 Beta software changes list 4.151: Version 4.151 Beta New improvements: - Improved Fibaro Heat Controller support - Improved secure communication - Improved PIN synchronization stability for Z- Wave locks - Added default temperature sets to heating panel - Update of devices' states after Home Center start - Protection against incorrect Power and Energy values for Fibaro devices - Improved notification center for users without admin privilege - Improved installed plugins view - Possibility to change size of edit window in LUA scenes - Updated Wall Plug US icons - Frequency information when adding new devices to Home Center Resolved issues: - Problem with generating Magic scenes for alarm conditions - Problem with saving Blocks scenes - Problem with refreshing interactive push scenes - Inability to set association in Home Center added as Secondary controller - Problem with displaying devices' parameters - Problem with controlling temperature sets in heat schedules after time passes 00:00 - Problem with displaying rooms when Hikvision camera plugin was added to system in Edge browser - Problem with displaying grouped devices - Problem with refreshing Slider value for Sonos plugin - Wrong notification about incorrect mesh network reconfiguration - Problem with low battery level notification - Problem with not disappearing notification about energy measurement in dashboard - Deleted wrong resources from Fibaro Docs - Minor graphic fixes
Ok merci je vais tester.
J'ai un petit souci avec ce Code pour envoi d'un message quand le lave linge a fini de laver: -- Lave Linge GEA.add({"Global", "Lave_Linge", "En Attente"}, 5*60, "La machine est terminée depuis #duration#",{{"Portable", 323},{"Portable", 393}}) GEA.add({"Sensor-", id["WP_LAVE_LINGE"], 0.1}, 30*60, "", {{"Global", "Lave_Linge", "Arret"}}) GEA.add({"Sensor+", id["WP_LAVE_LINGE"], 1}, 2*60, "", {{"Global", "Lave_Linge", "Lavage"}}) GEA.add({{"Sensor+", id["WP_LAVE_LINGE"], 1},{"Sensor-", id["WP_LAVE_LINGE"], 2.8}, {"Global", "Lave_Linge", "Lavage"}}, 1*60, "", {{"Global", "Lave_Linge", "En Attente"}}) Est-ce que je dois mettre les valeurs de Sensor- et + en Kilowatt ou en Watt? En sachant que mon lave linge consomme au lavage entre 36 Watt et 2250 Watt et en Standby 0.55 Watt Merci pour vos aides.
Mise à jour faite. RAS
HC2 & HCL - 4.143 - BETA - 16/11/2017
Alors pour moi depuis la V4.142 c'est nettement plus stable, voir très stable -
Pour le moment ça tourne bien Envoyé de mon SM-A520F en utilisant Tapatalk -
Moi aussi c'est en cours -
Version 4.143 Beta Resolved issues: Problem with block scenes for devices that use centralSceneEvent Problem with generating block and magic scenes for CO Sensor
Question bête, ou es-ce que on trouve GEA 6.00 ? :-)
HC2 & HCL - 4.142 - BETA - 09/11/2017
Chez moi tres stable tout fonctionne. Disons plus stable que la v4.140... Envoyé de mon SM-A520F en utilisant Tapatalk -
Pour le moment ça tourne bien. -
en cours... -
Beta software changes list 4.142: Version 4.142 Beta New improvements: - Support for Fibaro Wall Plug UK - Indicator for a device added in security mode - Improved security communication handing - Improved Fibaro Heat Controller support Resolved issues: - Problem with RGBW controller imported from a secondary Home Center - Problem with deleting devices in version 4.140 - Problem with Zwave.me Wallc-S modules support - Problem with recurrent scenes - Devices with disabled "Show energy consumption measurements" still used in summary consumption on dashboard bar - Problem with controlling devices added in security mode - Problem with block scenes using Fahrenheit temperature scale - Minor graphic fixes
HC2 & HCL - 4.140 - STABLE - 14/09/2017
speedoxx007 a répondu à un(e) sujet de mprinfo dans Firmware
Moi c'est pareil. Voici la réponse du Tech Support: Hello,We know about this problem.It is related with Our servers provider – dHosting.They are working on restoring services.Sorry for inconvenience. -
HC2 & HCL - 4.141 - BETA - 26/10/2017
Moi pour le moment pas, car la V4.140 tourne stable chez moi. -
Version 4.141 Beta New improvements: Support for Fibaro The Heat Controller. Support for Fibaro Wall Plug US. System stability improvements. Resolved issues: In some cases no value field displayed in block scenes. Application rejected Z-Wave request notification shows wrong device ID. Weather condition does not trigger the scene. Minor graphic fixes.
J'ai eu le même souci depuis la version 4.140 scene bloc avec "au coucher du soleil" ne fonctionnait plus. J'ai fait ave GEA: -- Gestion éclairage piscine -- Weekdays entre Dates 15.05 et le 15.10 et Turnon au coucher du soleil à 40% de puissance et éteindre "sunset +60" GEA.add(true, 1*30, "",{{"Days", "Weekday"}, {"Time", "sunset", "sunset+2"}, {"Dates", "15/05", "15/10"}, {"turnOn",id["SPOT_PISCINE"]}, {"Value",id["SPOT_PISCINE"],40}, {"turnOn",id["LIGNE_SPOTS_PISCINE"]}, {"Value",id["LIGNE_SPOTS_PISCINE"],40}}) GEA.add(true, 1*30, "",{{"Days", "Weekday"}, {"Time", "sunset+60", "sunset+62"}, {"Dates", "15/05", "15/10"}, {"turnOff",id["SPOT_PISCINE"]}, {"turnOff",id["LIGNE_SPOTS_PISCINE"]}}) -- Weekend entre15.05 et le 15.10 et Turnon au coucher du soleil à 40% de puissance et éteindre "sunset +120" GEA.add(true, 1*30, "",{{"Days", "Weekend"}, {"Time", "sunset", "sunset+2"}, {"Dates", "15/05", "15/10"}, {"turnOn",id["SPOT_PISCINE"]}, {"Value",id["SPOT_PISCINE"],40}, {"turnOn",id["LIGNE_SPOTS_PISCINE"]}, {"Value",id["LIGNE_SPOTS_PISCINE"],40}}) GEA.add(true, 1*30, "",{{"Days", "Weekend"}, {"Time", "sunset+120", "sunset+122"}, {"Dates", "15/05", "15/10"}, {"turnOff",id["SPOT_PISCINE"]}, {"turnOff",id["LIGNE_SPOTS_PISCINE"]}}) Pour le moment ça fonctionne. Je vais encore essayer de inclure la météo... :-)
Moi j'ai fait. Rien a signaler pour le moment -
HC2 & HCL - 4.136 - BETA - 05/09/2017
J'ai re-tenter de avoir un Debug du VD Clock Sync. Il n y a rien et ensuite un Reboot après quelques secondes. Je vais supprimer ce VD du coup... -
Tuto HC2 Clock Sync - Synchronisation De L'horloge Avec Ntp
speedoxx007 a répondu à un(e) sujet de Krikroff dans Tutoriels
Depuis la version Beta 4.136 le VD Clock Sync fait rebooter la HC2. Dans le Debug on ne voit rien. Donc dans mon cas Clock Sync fait une synchro à 2h du matin et ensuite quelque seceondes après la HC2 fait un redémarrage complet. En rafraichisant manuellement dans le VD Clock Sync la HC2 fait un Reboot droit après. Que est la cause?- 93 réponses
- Périphérique virtuel
- NTP
Ou trouver la cause du reboot avec Clock sync Envoyé de mon SM-A520F en utilisant Tapatalk -
Le Reboot de ma Hc2 est à cause du VD Clock Sync qui ce lance à 2h du matin. J'ai rafraîchi manuellement dans clock sync deux fois ce matin et hop deux reboot. Envoyé de mon SM-A520F en utilisant Tapatalk -
Ma HCL n'a pas redémarrer, mais la HC2 à redémarrer cette nuit à 2h du matin. -
Maj aussi fait. Tout semble ok, pour le moment
