276 -
Tout ce qui a été posté par speedoxx007
HC2 & HCL - 4.160 - Stable - 22/01/2018
speedoxx007 a répondu à un(e) sujet de speedoxx007 dans Firmware
R. A. S. Pour le moment Envoyé de mon SM-A520F en utilisant Tapatalk -
Software Changes List 4.160: Version 4.160 New improvements: - Improved Fibaro Heat Controller support - Improved secure communication - Improved PIN synchronization stability for Z-Wave locks - Added default temperature sets to heating panel - Update of devices' states after Home Center start - Protection against incorrect Power and Energy values for Fibaro devices - Improved notification center for users without admin privilege - Improved installed plugins view - Possibility to change size of edit window in LUA scenes - Updated Wall Plug US icons - Frequency information when adding new devices to Home Center - Improved control of third party devices included in heating panel zone - manual setting on any thermostat will exclude it from a heating panel schedule for two hours Resolved issues: - Problem with generating Magic scenes for alarm conditions - Problem with saving Blocks scenes - Problem with refreshing interactive push scenes - Inability to set association in Home Center added as Secondary controller - Problem with displaying devices' parameters - Problem with controlling temperature sets in heat schedules after time passes 00:00 - Problem with displaying rooms when Hikvision camera plugin was added to system in Edge browser - Problem with displaying grouped devices - Problem with refreshing Slider value for Sonos plugin - Wrong notification about incorrect mesh network reconfiguration - Problem with low battery level notification - Problem with not disappearing notification about energy measurement in dashboard - Deleted wrong resources from Fibaro Docs - Problem with sending multi-line interactive push messages - Problem with undefined parameters of Aeotec Siren Gen5 - Problem with incorrect translations for Fibaro Intercom - Problem with 503 error after system startup - Problem with operating some devices from the heating panel - Problem with displaying LUA and Block scenes when using devices included in security mode - Problem with displaying devices' parameters - Problem with "Arming delay" and "Disarming delay" functions in Fibaro Alarm - Problem with Zipato RFID Reader reports handling - Problem with block scenes using delay - Problem with a delay function used as a condition in block scenes - No device grouping section for Fibaro RGBW Controller - Minor graphic fixes - Minor system fixe
R.A.S tout fonctionne Envoyé de mon SM-A520F en utilisant Tapatalk
Mise à jour en cours....
Est-ce que le zipato key pad refonctionne? Envoyé de mon SM-A520F en utilisant Tapatalk
HC2 & HCL - 4.152 - BETA - 21/12/2017
Probablement le problème avec le ZIPATO Keypad qui existent dans la V4.151 ne sont pas résolu... Je reste sur 4.150 -
Beta software changes list 4.152: Version 4.152 Beta New improvements: - Improved Fibaro Heat Controller support - Improved control of third party devices included in heating panel zone - manual setting on any thermostat will exclude it from a heating panel schedule for two hours Resolved issues: - Problem with sending multi-line interactive push messages - Problem with undefined parameters of Aeotec Siren Gen5 - Problem with incorrect translations for Fibaro Intercom - Problem with 503 error after system startup - Problem with operating some devices from the heating panel - Problem with displaying LUA and Block scenes when using devices included in security mode - Minor graphic fixes
Ou es-ce que je trouve le VD GEA Alarm?
HC2 & HCL - 4.151 - BETA - 07/12/2017
J'ai vu sur les serveurs que il y a une V4.152 qui traine, mais pas encore libéré... http://updatehc2.fibaro.com/4.152/ -
Recovery vers 4.150 fait ainsi tous les icônes refait. Mon zipato key pad fonctionne a nouveau :-) Envoyé de mon SM-A520F en utilisant Tapatalk -
Deja exclu et reinclu mon zipato key pad. Synchronisation des badges fonctionne. Il y a deja des msg dans le fofo officiel... Envoyé de mon SM-A520F en utilisant Tapatalk -
ZIPATO Keypad ne communique plus avec la HC2... Je serai obliger de faire un Recovery vers 4.150 -
Tuto HC2 Watchdog Pour Scènes Et Modules Virtuels
speedoxx007 a répondu à un(e) sujet de Lazer dans Tutoriels
J'avais ma HC2 in English alors "GEA run since" et ça fonctionne. -
Merci @pepite. Je vais tester. -
Ok mais le texte n'ai jamais le même. Envoyé de mon SM-A520F en utilisant Tapatalk -
Comment je peu surveiller GEA V6.00 avec Watchdog ? -
@pepite Maintenant je suis
Ok pardon, je vais tester. Merci @Steven c'est parfait, ça fonctionne maintenant.
Hello @Steven Non je n'ai pas créé manuellement la variable globale "GEA_Plugins". GEA_Plugins n'existe pas. Oui mon GEA il tourne bien.
VD GEA Status ne fonctionne pas V6.00 Le Debug du Bouton "ON" il ce Retour: [ERROR] 14:59:34: line 3: Assertion failed Le Debug du Bouton "Rafraichir" donne ceci: [ERROR] 14:56:59: line 208: attempt to concatenate local 'sceneID' (a nil value) Que dois je faire pour que ça fonctionne?
Merci @Steven. Maintenant j'ai compris.
J'ai un souci avec les Conditions "Weather" avec GEA V6.00 -- Gestion éclairage piscine simplifié GEA.add(true, 1*120, "",{{"Global", "PresentState", "Home"}, {"Weather", "clear|cloudy"}, {"Days", "Weekday"}, {"Time", "sunset+15", "sunset+18"}, {"Dates", "15/05", "15/10"}, {"turnOn",id["SPOT_PISCINE"]}, {"Value",id["SPOT_PISCINE"],40}, {"turnOn",id["LIGNE_SPOTS_PISCINE"]}, {"Value",id["LIGNE_SPOTS_PISCINE"],40}}) GEA.add(true, 1*120, "",{{"Global", "PresentState", "Home"}, {"Weather", "clear|cloudy"}, {"Days", "Weekday"}, {"Time", "sunset+90", "sunset+93"}, {"Dates", "15/05", "15/10"}, {"turnOff",id["SPOT_PISCINE"]}, {"turnOff",id["LIGNE_SPOTS_PISCINE"]}}) GEA.add(true, 1*120, "",{{"Global", "PresentState", "Home"}, {"Weather", "clear|cloudy"}, {"Days", "Weekend"}, {"Time", "sunset+15", "sunset+18"}, {"Dates", "15/05", "15/10"}, {"turnOn",id["SPOT_PISCINE"]}, {"Value",id["SPOT_PISCINE"],40}, {"turnOn",id["LIGNE_SPOTS_PISCINE"]}, {"Value",id["LIGNE_SPOTS_PISCINE"],40}}) GEA.add(true, 1*120, "",{{"Global", "PresentState", "Home"}, {"Weather", "clear|cloudy"}, {"Days", "Weekend"}, {"Time", "sunset+120", "sunset+123"}, {"Dates", "15/05", "15/10"}, {"turnOff",id["SPOT_PISCINE"]}, {"turnOff",id["LIGNE_SPOTS_PISCINE"]}}) Je sais que dans GEA V6.00 c'est GEA.add( {"Weather", "Cloudy"}, 0, "#value#", {ACTIONS} ) Donc pour la 1er ligne: GEA.add(true, 1*120, "",{{"Global", "PresentState", "Home"}, {"Weather", "clear|cloudy", 0}, {"Days", "Weekday"}, {"Time", "sunset+15", "sunset+18"}, {"Dates", "15/05", "15/10"}, {"turnOn",id["SPOT_PISCINE"]}, {"Value",id["SPOT_PISCINE"],40}, {"turnOn",id["LIGNE_SPOTS_PISCINE"]}, {"Value",id["LIGNE_SPOTS_PISCINE"],40}}) Mais le Debug me sort: [DEBUG] 11:31:20: Add auto : #25 [true][Days, ["Weekday"]][Time, ["sunset+15","sunset+18"]][Dates, ["15\/05","15\/10"]] | 120 | | [Global, ["PresentState","Home"]][Weather, ["clear|cloudy",0]][TurnOn, [276]][Value, [276,40]][TurnOn, [417]][Value, [417,40]] [DEBUG] 11:31:20: Option : [Weather, ["clear|cloudy",0]] can't be used as an action [DEBUG] 11:31:20: GEA ... STOPPED Je suis peut être bête ou je ne vois rien devant mes lunettes Merci d'avance pour vos aides
j'ai fait sur mes 2 prod et ça joue pour le moment -
HCL mise à joure faite... HC2 en cours -
Autrement ça l'air stable ?
