Borgs
17 -
Tout ce qui a été posté par Borgs
@pepite Tried to implement your sugestion but cant find the row below anywhere in my GEA code fibaro:wakeUpDeadDevice(entry[GEA.keys["PARAMS"]][i][2]) I can find this: fibaro:wakeUpDeadDevice(paramsIterator[2]) But I commented out (--) the row that I did find "fibaro:wakeUpDeadDevice(paramsIterator[2])" and replaced with your suggestion "fibaro:call(1, 'wakeUpAllDevices', (entry[GEA.keys["PARAMS"]][2]))" And BAAM!! it worked!! The door sensor that was "Dead" was awaken by GEA..
Oui qui fait le travail et rend mon capteur de porte éveillé à nouveau. Mais encore ne fonctionne pas dans GEA
Below is my new GEA scen, old is removed --[[ %% autostart %% properties 697 value %% globals --]] -- GEA configuration function config() GEA.isVersionFour = true -- On est en version 4.017 Beta ou supérieure / GEA.language = "EN" -- Votre langue : FR (default) / Your language : EN GEA.checkEvery = 30 -- Check every X seconds (default : 30) GEA.portables = {496, 550} -- Smartphones you want to be notified {70, 71} GEA.debug = false -- Show trace in the debug window (default : false) -- GEA.getGlobalForActivation = {"SuspendreGEA", "non"} -- Active or deactive GEA execution with a global variable -- GEA.catchError = false GEA.optimize = GEA.typeOptimize["IMMEDIATE_ONLY"] -- option : GEA.typeOptimize["NONE"], GEA.typeOptimize["IMMEDIATE_ONLY"], GEA.typeOptimize["ALL"] -- optimizes the worry of the getName and getRoom fibaro but no longer displays the name of the affected modules. end function setEvents() GEA.add(true, 1*60, "wake-dead", {{"Wakeup", 696}}) GEA.add(true, 1*60, "wake-dead", {{"Wakeup", 697}}) end -- ================================================== -- -- DON'T TOUCH UNDER THIS POINT -- -- ================================================== This is the output in the Debug [DEBUG] 15:23:32: [ Always ] Add Autostart : task added for 60 seconds (ID: 1) [Wakeup,696] [DEBUG] 15:23:32: [ Always ] Add Autostart : task added for 60 seconds (ID: 2) [Wakeup,697] [DEBUG] 15:23:32: GEA Version 5.40 : Running... [DEBUG] 15:24:32: [ Always ] sendActions : doing actions (ID: 1) [Wakeup,696] [DEBUG] 15:24:32: [ Always ] sendActions : !ACTION! : WakeUp 696 (ID: 1) [Wakeup,696] [DEBUG] 15:24:32: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 1) [Wakeup,696] [DEBUG] 15:24:32: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 1) [Wakeup,696] [DEBUG] 15:24:32: [ Always ] Done : task done and suspended (ID: 1) [Wakeup,696] [DEBUG] 15:24:32: [ Always ] sendActions : doing actions (ID: 2) [Wakeup,697] [DEBUG] 15:24:32: [ Always ] sendActions : !ACTION! : WakeUp 697 (ID: 2) [Wakeup,697] [DEBUG] 15:24:32: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 2) [Wakeup,697] [DEBUG] 15:24:32: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 2) [Wakeup,697] [DEBUG] 15:24:32: [ Always ] Done : task done and suspended (ID: 2) [Wakeup,697] I get two push notifications to my phone But Door sensor is still dead in the WEB interface
Will try with a CLEAN GEA scene and at the same time remove the existing GEA. Battery reports 80% for the door scensor Mesh network reconfigure = Yes Feels like we have different approaches to this :-) I want to find why the wakeup command in GEA doesn´t wake up the device. For now I am not tytring to solve why the door sensor dies... If I press the big "X" on the device in the webinterface it works just fine for a few hours and then dies again. This is positive while trying to sort out why GEA have problems to wake up the device. Once I solve the GEA problem I will focus on the device to ensure that it does not die again.
Running 4.082 in my HC2. That issue you found is due to cut/paste error from my side. But I have now disabled that line and still same issue with your to do a more "clean" wakeup method: GEA.add(true, 1*60, "wake-dead", {{"Wakeup", 696}}) GEA.add(true, 1*60, "wake-dead", {{"Wakeup", 697}}) This still gives the same output in the Debug: [DEBUG] 13:58:33: [ Always ] sendActions : doing actions (ID: 1) [Wakeup,696] [DEBUG] 13:58:33: [ Always ] sendActions : !ACTION! : WakeUp 696 (ID: 1) [Wakeup,696] [DEBUG] 13:58:33: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 1) [Wakeup,696] [DEBUG] 13:58:33: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 1) [Wakeup,696] [DEBUG] 13:58:33: [ Always ] Done : task done and suspended (ID: 1) [Wakeup,696] [DEBUG] 13:58:33: [ Always ] sendActions : doing actions (ID: 2) [Wakeup,697] [DEBUG] 13:58:33: [ Always ] sendActions : !ACTION! : WakeUp 697 (ID: 2) [Wakeup,697] [DEBUG] 13:58:33: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 2) [Wakeup,697] [DEBUG] 13:58:33: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 2) [Wakeup,697] [DEBUG] 13:58:33: [ Always ] Done : task done and suspended (ID: 2) [Wakeup,697] But door sensor is still dead but I can "wake it" by pressing the big X on it in the web interface.
Ok, maintenant je dois une unité qui meurt à nouveau. l'unité est un capteur de porte 'Fibaro' Ont mis en Å“uvre votre suggestion, mais il ne fait pas de différance. Je reçois le message push qui indique qu'il a exécuté la commande de réveil. Mais les unités reste morte. Code au top: --[[ %% autostart %% properties 94 value 113 value 141 value 153 value 160 value 162 value 164 value 189 value 194 value 207 value 239 value 296 value 298 value 300 value 302 value 309 value 314 value 338 value 354 value 357 value 383 value 392 value 418 value 443 value 452 value 456 value 476 armed 481 value 498 value 514 value 525 value 573 value 600 value 602 value 697 value %% globals --]] -- GEA configuration function config() GEA.isVersionFour = true -- On est en version 4.017 Beta ou supérieure / GEA.language = "EN" -- Votre langue : FR (default) / Your language : EN GEA.checkEvery = 30 -- Check every X seconds (default : 30) GEA.portables = {496, 550} -- Smartphones you want to be notified {70, 71} GEA.debug = false -- Show trace in the debug window (default : false) -- GEA.getGlobalForActivation = {"SuspendreGEA", "non"} -- Active or deactive GEA execution with a global variable -- GEA.catchError = false GEA.optimize = GEA.typeOptimize["IMMEDIATE_ONLY"] -- option : GEA.typeOptimize["NONE"], GEA.typeOptimize["IMMEDIATE_ONLY"], GEA.typeOptimize["ALL"] -- optimizes the worry of the getName and getRoom fibaro but no longer displays the name of the affected modules. end local VinKallare = {Tak = 262, Dorr = 697, DorrMaster = 696, Rorelse = 309, RorelseMaster = 308} Mes nouvelles règles function setEvents() GEA.add(true, 1*60, "wake-dead", {{"Wakeup", 696}}) GEA.add(true, 1*60, "wake-dead", {{"Wakeup", 697}}) Ma vieille règle: GEA.add({"Dead", VinKallare["Dorr"]}, 1*60, "Vinkà¤llar dà¶rr sensorn har problem, har fà¶rsà¶kt att và¤cka den igen.", {{"WakeUp", VinKallare["Dorr"]}}) Sortie dans les fenêtres de débogage [DEBUG] 06:46:58: GEA Version 5.40 : Running... [DEBUG] 06:47:18: [ Always ] sendActions : doing actions (ID: 1) [Wakeup,696] [DEBUG] 06:47:18: [ Always ] sendActions : !ACTION! : WakeUp 696 (ID: 1) [Wakeup,696] [DEBUG] 06:47:18: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 1) [Wakeup,696] [DEBUG] 06:47:18: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 1) [Wakeup,696] [DEBUG] 06:47:18: [ Always ] Done : task done and suspended (ID: 1) [Wakeup,696] [DEBUG] 06:47:18: [ Always ] sendActions : doing actions (ID: 2) [Wakeup,697] [DEBUG] 06:47:18: [ Always ] sendActions : !ACTION! : WakeUp 697 (ID: 2) [Wakeup,697] [DEBUG] 06:47:18: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 2) [Wakeup,697] [DEBUG] 06:47:18: [ Always ] sendActions : !ACTION! : sendPush wake-dead (ID: 2) [Wakeup,697] [DEBUG] 06:47:18: [ Always ] Done : task done and suspended (ID: 2) [Wakeup,697] [DEBUG] 06:47:19: [ Dead [696|DS-Vinkà¤llare] ] sendActions : doing actions (ID: 76) [WakeUp,697] [DEBUG] 06:47:19: [ Dead [696|DS-Vinkà¤llare] ] sendActions : !ACTION! : WakeUp 697 (ID: 76) [WakeUp,697] [DEBUG] 06:47:19: [ Dead [696|DS-Vinkà¤llare] ] sendActions : !ACTION! : sendPush Vinkà¤llar dà¶rr sensorn har problem, har fà¶rsà¶kt att và¤cka den igen. (ID: 76) [WakeUp,697] [DEBUG] 06:47:19: [ Dead [696|DS-Vinkà¤llare] ] sendActions : !ACTION! : sendPush Vinkà¤llar dà¶rr sensorn har problem, har fà¶rsà¶kt att và¤cka den igen. (ID: 76) [WakeUp,697] [DEBUG] 06:47:19: [ Dead [696|DS-Vinkà¤llare] ] Done : task done and suspended (ID: 76) [WakeUp,697] si je regarde dans l'interface web, il est encore un «X» sur l'unité. Si j'appuie sur le «X» sur l'unité, il se réveille directement.
J'ai plus de 100 lignes GEA.add dans ma scène GEA. Serait-ce une bonne chose de diviser ce dans les scènes GEA supplémentaires? Vous songez à faire comme ceci: - Avoir alarme "règles" dans GEA scène 1 - Avoir le contrôle de la lumière dans GEA scène 2 - Avoir le «contrôle du système" dans GEA scène 3 (Wakeup et batterie de contrôle) Ou est-il préférable juste pour garder toutes les 100+ lignes dans une seule scène GEA?
@pepite Après mise à jour 4.082 mon appareil refuse de «mourir» plus donc je ne peux tester votre suggestion. Je vais essayer votre suggestion si un périphérique commence à "mourir"
Bonjour Pepite, Oui, je reçois le message Push chaque fois.
Je rencontre des problèmes pour se réveiller un dispositif GEA. Voici mon code: Tout d'abord la définition de l'Id locale: local VinKallare = {Tak = 262, Dorr = 294, DorrMaster = 293, Rorelse = 309, RorelseMaster = 308} Ensuite, la ligne de code qui se réveille à la fois le capteur de porte et l'unité principale du capteur de porte: GEA.add({"Dead", VinKallare["Dorr"]}, 1*60, "Vinkà¤llar dà¶rr sensorn har problem, har fà¶rsà¶kt att và¤cka den igen.", {{"WakeUp", VinKallare["Dorr"]}, {"WakeUp", VinKallare["DorrMaster"]}}) Et la sortie dans le journal [DEBUG] 15:11:51: [ Dead [294|Dà¶rr] ] sendActions : doing actions (ID: 51) [WakeUp,294] [WakeUp,293] [DEBUG] 15:11:51: [ Dead [294|Dà¶rr] ] sendActions : !ACTION! : WakeUp 294 (ID: 51) [WakeUp,294] [WakeUp,293] [DEBUG] 15:11:51: [ Dead [294|Dà¶rr] ] sendActions : !ACTION! : WakeUp 293 (ID: 51) [WakeUp,294] [WakeUp,293] [DEBUG] 15:11:51: [ Dead [294|Dà¶rr] ] sendActions : !ACTION! : sendPush Vinkà¤llar dà¶rr sensorn har problem, har fà¶rsà¶kt att và¤cka den igen. (ID: 51) [WakeUp,294] [WakeUp,293] [DEBUG] 15:11:52: [ Dead [294|Dà¶rr] ] sendActions : !ACTION! : sendPush Vinkà¤llar dà¶rr sensorn har problem, har fà¶rsà¶kt att và¤cka den igen. (ID: 51) [WakeUp,294] [WakeUp,293] [DEBUG] 15:11:52: [ Dead [294|Dà¶rr] ] Done : task done and suspended (ID: 51) [WakeUp,294] [WakeUp,293] Tout semble bon, mais l'unité ne se réveille pas. Si je vais à l'interface Web et pousse le grand X sur l'appareil, il se réveille directement et fonctions ok Pourquoi le "réveiller" commande dans GEA n'a pas d'effet?
Comment faites-vous cela dans le GEA? J'ai essayé plusieurs façons différentes, mais je ne peux pas le faire fonctionner comme je veux. Équipement: capteur de mouvement Fibaro (id = 120), Siren (id = 99) Fonction: Lorsque le capteur de mouvement est "armed" et il est un mouvement en face du capteur de mouvement, la sirène sera activée. Que dois-je spécifier sous %% properties? 120 value ou 120 armed
Bonjour, Je pensais que je voudrais présenter un rapport sur mes tests. Il y avait trois choses que je voulais faire: 1. Utilisez la valeur Lux pour déterminer si les feux doivent être allumés en un certain temps. Cela a été résolu avec la participation de la «pépite»: GEA.add ({"value-", Ute["Lux"], 200}, 30, "", {{"Time", "5:40", "5:41"}, {"Days","Weekday"}, {"turnOn", FonsterUppe["Kok"]}, {"turnOn", FonsterUppe["MatRum"]}}) 2. Utilisez un paramètre global pour déterminer si les feux doivent être activés ou non, a également été résolu par l'entrée de la «pépite» GEA.add({"Global", "GuestsInHouse", 0}, 30, "", {{"Time", "21:45", "21:46"}, {"turnOff", FonsterUppe["MittenRum"]}, {"turnOff", FonsterUppe["SoJ"]}, {"turnOff", FonsterUppe["ArbetsRumSkap"]}}) 3. Réglementer si les lumières doivent être tournées au coucher du soleil en fonction de l'heure du coucher du soleil se produit. A été résolu en utilisant l'entrée de différents utilisateurs. GEA.add(true, 30, "", {{"Time", "21:30", "21:31"}, {"Global","GEA_EarlySun", 0}}) GEA.add(true, 30, "", {{"Time", "Sunrise", "Sunrise+1"}, {"Global","GEA_EarlySun", 1}}) GEA.add({"Global", "GEA_EarlySun", 1}, 30, "", {{"Time", "Sunset-9", "Sunset-8"}, {"turnOn", FonsterUppe["MittenRum"]}, {"turnOn", FonsterUppe["SoJ"]}, {"turnOn", FonsterUppe["ArbetsRumSkap"]}}) Cela allumer la lumière au coucher du soleil, mais ne sera pas allumer si le coucher du soleil est après 21h30 Merci à vous tous de me aider à résoudre mes besoins!
@seriksson Je suis en mode de test maintenant, saura demain si cela fonctionne ou non.
@jojo va essayer, mais veulent les lumières ~ 9 minutes avant le coucher du soleil, mais pas si le coucher du soleil est après 21h40. Est-ce que ça marche? GEA.add(true, 30, "", {{"Time", "Sunset-9<21:40", "Sunset-8<21:40"}, {"turnOn", FonsterUppe["MittenRum"]}, {"turnOn", FonsterUppe["SoJ"]}, {"turnOn", FonsterUppe["ArbetsRumSkap"]}})
@pepite : Je vais essayer votre suggestion Probablement une tâche simple, mais comment puis-je limiter la règle ci-dessous pour allumer les lumières au coucher du soleil, mais seulement si le coucher du soleil est avant 21h45?? GEA.add(true, 30, "", {{"Time", "Sunset-9", "Sunset-8"}, {"turnOn", FonsterUppe["MittenRum"]}, {"turnOn", FonsterUppe["SoJ"]}, {"turnOn", FonsterUppe["Kok"]}, {"turnOn", FonsterUppe["MatRum"]}, {"turnOn", FonsterUppe["ArbetsRumSkap"]}, {"Value", FonsterUppe["VRum"], 23}})
Bonjour, (Avertissement traduit avec Google Translate) Débutant ici et besoin d'aide simples ... J'ai une règle qui tourne sur quelques lumières dans la matinée. Mais je voudrais ajouter un chèque que si mon compteur Lux montre des valeurs supérieures, puis 500 lux puis les lumières ne doivent pas être allumés. Ou seulement allumer les lumières lorsque posemètre montré en dessous de 500 lux. Lux mètre a id 162 et je lui ai donné le nom 'Ute ["Lux"] GEA.add(true, 30, "", {{"Time", "5:40", "5:41"}, {"Days","Weekday"}, {"turnOn", FonsterUppe["Kok"]}, {"turnOn", FonsterUppe["MatRum"]}}) J'ai une autre règle qui éteint quelques lumières. Je voudrais ajouter un contrôle que les lumières doivent être éteintes si une valeur globale est 0. nom global de paramètre est "GuestsInHouse" GEA.add(true, 30, "", {{"Time", "21:45", "21:46"}, {"turnOff", FonsterUppe["MittenRum"]}, {"turnOff", FonsterUppe["SoJ"]}, {"turnOff", FonsterUppe["ArbetsRumSkap"]}}) Quelqu'un pourrait-il me guider comment activer cette fonction?
Toutes mes inscriptions seront traduits avec «Google Translate» puisque je ne parle le français. Un débutant avec Z-Wave et ont un Fibaro HC2 avec 4080 code. Ont mis en place un script GEA et déplacé un grand nombre de scènes régulières dans GEA. Mais pour prendre un peu l'avenir, je vais avoir besoin de votre aide. Cordialement Borg
