Allan2b
    276
Tout ce qui a été posté par Allan2b
  1. Il me semble que quand tu ouvre ton appli les icônes reviennent en position, ça ne garde pas en mémoire les changements . sur iPhone en tout cas c'est comme ça
  2. Bonjour je viens de lire un article sur http://fibarolife.com sur les widgets, je savais que c'était possible depuis la dernier version sur Android mais je l'ignorais sur IOS. mois qui suis sur IOS ça marche très bien. Source : http://fibarolife.com/fibaro-mobile-app-install-widgets/# How to create a widgets Android OS Follow the instructions below to create a new widget for an Android device: 1) Launch the FIBARO mobile application. 2) Login to the FIBARO Home Center. 3) Open the home screen of your smartphone. 4) Press and hold on the home screen that you want to place the scene widget on. Depending on your device, you may need to tap Apps and Widgets, or a similarly-named menu option. 5) Press and hold on the Fibaro widget, then drag it to the home screen. There will need to be space on the home screen to successfully add a new widget. 6) Select one of the listed scenes.* 7) In case of an error message, go back to step 1. 8) Run the scene’s widget by tapping its icon (successful triggering of the scene will be confirmed with a message). * – You can add as many scene’s widgets as you want to your home screen, as you like, but only it must be done one widget after at a time.another. Remarks: – Each widget may be resized to meet the user’s needs. – You can add the widgets on as many different home screens as you wishwant. – The current version of the FIBARO application app allows to run only widgets to only run from the connected gateway. – There is no possibility to add the widget for a Magic scene or for scene protected by the a PIN code. iOS Follow the instructions below to create a new widget for an Apple device: 1) Swipe down from the top of the screen of your iPhone to open the Notification Center.* 2) Tap on “Today†if it isn’t already selected. 3) Scroll down to the bottom of the screen. 4) Tap on the “Edit†button. 5) Under the “Do Not Include†section, tap on the green plus sign next to the Fibaro FIBARO widget to include it in your Today view. 6) Tap “Done†in the top right corner. The Fibaro FIBARO widget will appear in the Notification Center with other Today widgetsin the Today section. 7) Tap “Configure†to adjust the widget -– the Fibaro FIBARO app will be opened. 8) Select the scenes you would like to add from the list shown.** 9) Click the “Save†button to confirm your selection. Saving without any no scenes selected will results in removing of previously added scenes.*** 10) Correct A successful addition of the widget will results in the screen looking like the below screenshot. setting the widget like on the attached screenshot. ClickTo launch the scene, tap the icon. the icon of the scene to launch it. * – iPhone running iOS 8 or higher is required. ** – iOS app allows for adding max. 4 different scenes to the ‘Today’ tab. *** – In such case the appropriate message will be displayed. Remarks: – Scenes must be run one at a time and cannot happen all at once. During the startup of the scene, possibility to run another scene is locked. – Widgets may be also configured through the FIBARO applicationapp. To do so, launch the app, go to Settings and click Configure to select scenes for the widget. – The current version of the FIBARO app allows widgets to only run from the connected gateway.The current version of the application allows to run only widgets from the connected gateway. – There is no possibility to add the widget for a Magic scene or for scene protected by a PIN code.There is no possibility to add the widget for Magic scene or for scene protected by the PIN code.
  3. C'est claire il fait vraiment froid, nous on a du arrêter de se baigner
  4. Bonjour j'ai tester l'app sur un samsung S6, et sur les derniers version y compris la 1.80 j' ai un problème de réactivité tactile sur l'app. le telephone fonctionne très bien mais quand j'ouvre fibaro ca devient dur de naviguer dans l'application , on clic sur une icône sans change de page je veux rentrer sur un device il faut s'y prendre a plusieurs reprise pour y arriver .... est ce que quelqu'un rencontre ou a rencontrer se problème?
  5. En faite je ne pense pas que soit la peine d'installer Astérisk sur un NAS , le serveur SIP et deja installer dans le Raspberry Pi http://www.oyoma.net/wp-content/uploads/2013/10/NovoSIP-Manuel-de-mise-en-service-scrolling1.pdf
  6. app android et iOS
  7. J'ai commandé le Novosip, je ferais un petit retour après l'avoir tester. Pour environ 400€ ça me parait un très très bon portier . novosip.com
  8. Pour ma part je vais me laisser tenter par le portier novosip Portier vidéo SIP sur Raspberry Pi A peux Pred 450€ . Je ferais un retour dès réception
  9. Bonjour j'essaye d'utilser ce MV mais rien a faire j'ai le meme problème que "Petermoto" ma variable reste 0 je essayer le MV 1.2 pareil . je sèche la
  10. Allan2b
    Help Hc2 Bloquer
    je suis entrain de télécharger, merci pour votre aide .j'ai mon backup mais je pense me lancer dans une reconfiguration a zeros, j'avais sauvegardé mes VM et mes scenes. Le Forum est le meilleur le support
  11. Allan2b
    Help Hc2 Bloquer
    Merci pour ton aide Lazer
  12. Allan2b
    Help Hc2 Bloquer
    merci time capsule j'aime fait une sauvegarde du fichiers backups que j'avais effacer. maintenant manque l'image
  13. Allan2b
    Help Hc2 Bloquer
    Merci Lazer le fichier backups a disparu je vais essayer de retrouver l'image non elle n'est plus garantie
  14. Bonjour je me tourne vers le forum vu que le suport fibaro semble être débordé vu que je n'ai pas de réponse . après avoir avoir rebooter ma box, impossible de me connecter, que se soit en local ou distance (erreur 503). J'ai pourtant les 3 voyants allumés, elle est bien détectée quand je fait un ping, mais rien a faire je l'ai laisser tourner toute la nuit rien du tout redouter plusieurs fois pareil. Et bien sur je peux meme pa faire de recovery elle reste bloquer avec toutes les les allumées . en mode normal j'obtient ca et en mode recovery Si quelqu'un peux m'aider ou pas
  15. Quelqu'un a une idée sur le nouveau plugin portier ip bell fibaro? je possède justement un portier ip fonctionnant avec ip bell mais ça ne fonctionne pas
  16. Allan2b
    Pop Up Customisé
    super!!!! par contre ca fonctionne uniquement si on est connecter en admin
  17. super merci "sebsbien" on va tester.
  18. Bonjour et merci pour cet excellent VD en espèrent que les prévisions se rapprochent de la réalité . je voudrait stoker la valeur de la prévision pluie du jour même dans une variable pour l'utiliser dans ma gestion de l'arrosage . comment faire? je sèche là
  19. je n'arrive pas a faire fonctionner le sceneId chez moi
  20. il suffi de faire un slide vers le haut depuis l'icone alarme de l'interface figaro pour armer tout les modules et un slide vers le base pour désarmer
  21. Super Top!!!! sceneId ne fonctionne pas chez moi
  22. Box Planter plus accès a l'interfce . Recovery Vérification des fichiers de restauration bloquer a 40% depuis 30 min Merci Fibaro
  23. j'au rebuter ma HC2 car le menu configuration n'était plus accessible, les voyants son bon mais impossible de me connecter erreur 503 meme le finder ne la trouve pas alors qu'elle est bien sur le réseau. Figaro vous êtes les meilleur
  24. idem pour moi AEON LABS (HEM2) ne remonte pas les info, il n'y a d'ailleurs aucun réglage pour le polling. des qu'on appuis sur le module pour faire remonter les infos(mise jour de la table de routage ) le zwave se bloque
  25. test du HEM2 nouveau icons mais toujours le meme problème des l'inclusion du module le zwave crache et aucune mise a jour des conso . Aucun problème résolu
