parip69
    15
    Ingolstadt
    40.7
486 visualisations du profil
parip69's Achievements
  1. parip69
    %%killOtherInstances
    Hallo So that's for testing. If you press Start and comment out the "%% killOtherInstances", the sequential number is always displayed. If you have "%% killOtherInstances" in it, it will continue. --[[ %% properties %% events %% globals %% killOtherInstances --]] -- %% killOtherInstances local num = fibaro:countScenes(57) local count = 1 local function run() print("Instance n°" .. tostring(num) .. " & Loop n°" .. tostring(count)) count = count +1 setTimeout(run, 3000) end run() if (fibaro:countScenes()>1) then fibaro:abort(); fibaro:sleep(1000) end Test ist ok Pres Start
  2. parip69
    VU+ Scene
    Hello Unfortunately, I can not find a solution for my problem. I've read weeks ago. Is there a "get" or "request" option as below for scene only, but without fonction as below for only one scene. Hello Lazer I can think that you have no time, but others many. Thank you local selfId = fibaro:getSelfId(); local ip = fibaro:get(selfId, "IPAddress") local url = "/web/powerstate" local ws = Net.FHttp(ip, 80) local resp = ws:GET(url) --fibaro:debug(resp) if (string.find(resp, "true") == NIL) then fibaro:debug('AN') else fibaro:debug('AUS') end
  3. parip69
    VU+ Scene
    Hi Where I have to enter the return so my function returns true. I need help. My print (statusVU ()) is always nill i need the return or vareanle with response.status. function statusVU() local vuStatusAus getURL = 'http://192.168.11.33:80/web/powerstate' putURL = 'http://192.168.11.33:80/web/powerstate' local httpClient = net.HTTPClient() httpClient:request(getURL, { success = function(response) if response.status == 200 then httpClient:request(putURL, { success = function(response) if response.status == 200 then return true end end, error = function(err) end, options = { method = 'PUT', data = response.data } }) else end end, error = function(err) end, options = { method = 'GET' } }) end print(statusVU())
  4. parip69
    VU+ Scene
    Hello I need a tip ... please
  5. parip69
    VU+ Scene
    Hi I need it in a script not in VD. Please help with the scrip. My response is always nil. thank you function statusVU(); local http = net.HTTPClient(); http:request('http://192.168.11.11:80/web/powerstate', {success = function(resp) local vuStatusAus = (string.match (resp.data, "true")); if vuStatusAus == "true" then; return true; else; VuEinAus = "aus"; return false; end; end}) end print(statusVU())
  6. Bonjour Malheureusement, il ne fonctionne plus avec Firmware 4.081. Y at-il une solution? Mersi
  7. With a script that the ONECLICK html on the Click??? ??????????????????????????????????????????????????? local url = 'http://127.0.0.1:11111' response = url:call("mainData.scenes[44].clear()") ?????????????????????????????????????????????????? From: http://192.168.11.111/fibaro/de/scenes/edit.html?id=44#bookmark-advanced <a id="clearDebugButton" href="#" onclick="mainData.scenes[44].clear(); return false;">
  8. How can I debug empty from a scene.
  9. dans une scène. debug l Une fois par jour, le debug vide.
  10. Einmal pro Tag, die Leere zu debuggen. dans une scène. debug vide.
  11. Bonjour il est possible que la fenêtre de mise au point pour vider les scènes ???? Vidange De La Fenêtre De Débogage.
  12. parip69
    Plugin Pour Styles Crhome
    Hallo Ich Haben Sie eine Frage. Kend jemand das Plugin fà¼r Styles Crhome? Ich habe es Geschaft das Programierer Szene Lua Script-Fenster zu vergrà¶sern mit einem ccs teil. Leider kann iech das Syle von HC2 nicht weiter beeinflussen. Vileicht interesiert jemand. Leider kann ich nicht programmieren. Kann oder gibt es ein css file das man die hc2 von der Optik beeinflust? Ihr seit ohnehin die Besten.
  13. Bonjour Ve Vous avez une question. Est-ce que quelqu'un sait ce plugin pour Styles Crhome? I Geschaft pour agrandir l'image est la fenêtre de script Lua scène. vileicht interesiert quelqu'un. Malheureusement, je ne peux pas programmer, mais l'image pour agrandir la fenêtre déjà . Maintenant, les scripts homme d'écrire. L'homme peut personnaliser le css de hc2 après propre choix. Votre depuis toute façon le meilleur.
  14. Bonjour Je suis parvenu àtout écrire dans une variable. Exemple avec les paramètres pour le début de changement, changement tardif et de nuit. Comment faire le script pour reconstruire tous de prendre de la variable et writeback. S'il vous plaît aidez-moi avec ce ou est-il une solution pour le travail posté? Merci beaucoup
  15. Bonjour Je suis de l'Allemagne et s'il vous plaît Hertzlich la possibilité de la prise - pour tester 0.2.2.zip de commutateur virtuel et le capteur. Je vous remercie à l'avance.
