39 -
Sexe :
Ville :
geer
Box
660 visualisations du profil
melinm's Achievements
Merci à vous, Il me reste donc soit à me souvenir, soit à ouvrir mes interrupteurs/lampes.
Merci, Mais je ne trouve pas l'info. Ni dans les params du module ni dans le json: { "id": 310, "name": "Studio", "roomID": 300, "type": "com.fibaro.binarySwitch", "baseType": "com.fibaro.actor", "enabled": true, "visible": true, "isPlugin": false, "parentId": 309, "remoteGatewayId": 0, "interfaces": [ "deviceGrouping", "fibaroFirmwareUpdate", "light", "power", "zwave" ], "properties": { "parameters": [ { "id": 1, "lastReportedValue": 255, "lastSetValue": 255, "size": 1, "value": 255 }, { "id": 3, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 4, "lastReportedValue": 0, "lastSetValue": 0, "size": 2, "value": 0 }, { "id": 6, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 13, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 14, "lastReportedValue": 1, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 15, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 16, "lastReportedValue": 1, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 30, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 31, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 32, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 33, "lastReportedValue": 1, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 39, "lastReportedValue": 600, "lastSetValue": 600, "size": 2, "value": 600 } ], "pollingTimeSec": 0, "zwaveCompany": "Fibargroup", "zwaveInfo": "3,3,52", "zwaveVersion": "2.2", "configured": "true", "dead": "false", "deviceControlType": "2", "deviceGroup": "[]", "deviceGroupMaster": "0", "deviceIcon": "1", "emailNotificationID": "0", "emailNotificationType": "0", "endPointId": "0", "firmwareUpdate": "{\"info\":\"\",\"progress\":0,\"status\":\"UpToDate\",\"updateVersion\":\"2.2\"}", "isLight": "true", "liliOffCommand": "", "liliOnCommand": "", "log": "", "logTemp": "", "manufacturer": "", "markAsDead": "true", "model": "", "nodeId": "51", "parametersTemplate": "363", "power": "0.00", "powerConsumption": "66", "productInfo": "1,15,4,2,16,2,2,2", "pushNotificationID": "0", "pushNotificationType": "0", "remoteGatewayId": "0", "saveLogs": "true", "serialNumber": "", "showEnergy": "true", "smsNotificationID": "0", "smsNotificationType": "0", "updateVersion": "", "useTemplate": "true", "userDescription": "", "value": "false" }, "actions": { "reconfigure": 0, "turnOff": 0, "turnOn": 0, "updateFirmware": 1 }, "created": 1498337740, "modified": 1498337740, "sortOrder": 183 }
Bonjour, Y'a t'il un moyen de savoir quel est le modele d'un module via la console web? Je ne sais plus si j'ai des FGS223 , FGS222 ou encore des FGS221 installé à certains endroits. Merci
Mise à jour Béta Hc2 & Hc Lite 4.092 Beta - 20/09/2016
melinm a répondu à un(e) sujet de speedoxx007 dans Firmware
Voilà , problème résolu. C'est bien une erreur de javascript. Si un virtualdevice affiche un numerique, dans mon cas 0.4856, ca plante dans cette fonction: function getAllowedHtml(a) { return a = a.replace(/\<(\/)?(font|a)([\s]?[a-z|\s|\=|\'|\"]*)?\>/g, "[%3C]$1$2$3[%3E]"), a = a.replace(/\<\/?([\w|\s|\=|\'|\"]{1,})\>/g, "%3C$1%3E"), a = a.replace(/\[%3C\]/g, "<"), a = a.replace(/\[%3E\]/g, ">") } Avec l'ajout d'un string dans l'étiquette ça corrige le problème: avant: fibaro:call(selfId, "setProperty", "ui.LabelJour.value", emoncmsFeed(90)); aprés: fibaro:call(selfId, "setProperty", "ui.LabelJour.value", emoncmsFeed(90)..' L'); Je vais aller mettre l'info sur le forum officiel: http://forum.fibaro.com/index.php?/topic/22317-devices-not-shown-in-ui/ Ca à même corrigé un problème que j'ai depuis longtemps: je n'arrivait pas à aller dans cette pièce depuis l'application ios, maintenant ca fonctionne aussi -
Oui j'avais essayé safari mais ca ne change rien. Sous chrome, il y a une erreur js: Uncaught TypeError: a.replace is not a function . C'est peut-être la cause. Et je n'ai pas les infos méteo non plus. Dommage parce que cette version à l'air pas mal. je regarderais encore un peu demain, et si ca ne va pas ce sera un rollback -
Pas mieux que la 4.091beta pour moi: Dans modules je ne vois pas tout et pourtant ils sont bien dans là. Clear cache et force refresh du browser ne change rien -
Hello, j'avais le même soucis après un passage en version 4.80. Du coup j'ai fait un recovery de làbox puis un restore et depuis 2 semaines je n'ai plus de problème . Le seul inconvénient, c'est la perte des icônes
Maintenant que le recovery est fait, ma box est en version 4.031, je voulais passer en version 4.056 parce que c'était le dernier stable àmes yeux mais il ne me propose que le 4.080, y'a t"il moyen de choisir une autre version que la dernière?
Voilà , après restore sur ma clé du dump de jojo et copie de mon repertoire backup et de mon fichier network, le recovery est en cours. Merci à tous pour votre aide
Merci, je vais faire ça. Le boot sans la clé c'était le temp de faire le dump. mais comme c'est inutile ...
Tout est toujours en cours, ca ne va pas vraiment pas très vite. Est-ce que je peux démarrer la box sans clé recovery? je voudrais quand même avoir du chauffage demain matin :-)
Non ma box n'est plus sous garantie. As-tu le lien pour l'écriture complete de la clé?
Bonjour à tous et merci pour vos réponses. Voici 2 images du boot. Je suis occupé à faire un backup de la clé mais aprés 6h, la comande dd n'a copié que 2,8giga
Bonjour à tous, Ma box est actuellement en version 4.080 mais j'ai ce bug (http://bugzilla.fibaro.com/view.php?id=3920) qui freeze le moteur zwave tout les X temps. J'ai donc décidé de faire un recovery vers la version 4.056, mais impossible de lancer le recovery: Je démarre bien la box avec les 2 boutons, le chenillard tourne en sens inverse et puis toutes les led restent allumées et impossible d'accèder à la box. Quand je la redémarre en mode normal, je n'ai aucun problème (sauf le bug du freeze) Est-ce que l'un de vous aurait une idée, est-ce ma clé qui posse problème? Merci d'avance.
oui, 4.054, d'aprés les sauvegarde, ils sont passé par une 4.049 avant
