jcosta
    6
Tout ce qui a été posté par jcosta
  1. Thanks Hexan. I did what you had sugested but since then I didn't experienced any crash. The script is running for more than 14h without any crash - a bit more than any time before... it seems to be related with the other way of running the script. Thanks again.
  2. Hi Hexan, one more thing... my tempupdate service is crashing after several hours. Since saturday it already crashes 3 times. Is there any place, log, etc where I may find some information about the reasons of the crash? Best regards.
  3. Hexan, I've just managed to put the scripts to work... it was "only" a problem with DOS line-endings (CRLF). Running the dos2unix command resolved the issue. By the way, I'm using an old net laptop with chromixium OS. Thanks, your scripts are great!!!
  4. thank you for your quick answer hexan. No, I didn't configure yet the restate service. I started with the tempupdate first. And yes, I've run all those commands... Thanks.
  5. Hi hexan, great work!! Sorry to be writing in english... I've limited knowledge about linux and I'm having difficulties to put this to work. I'm trying to setup first only the update of fibaro VD slider. I've done the 4 linux commands as you explain in GitHub, using the name temp update instead of restatmo. Everything goes OK but when I'm trying to start the service I got the following erros homeofir@homeofir-1008HA:~/netatmo$ sudo service tempupdate start : not found/tempupdate: 10: /etc/init.d/tempupdate: /etc/init.d/tempupdate: 12: .: Can't open /lib/lsb/init-functions homeofir@homeofir-1008HA:~/netatmo$ I've checked and the file tempupdate in in /etc/init.d/ lib and I've also the /lib/lsb/init-functions at root level. Could you please help me. Regards.
  6. Hi, I'm João, from Portugal. I'm sorry for not be abble to write in French... reading French is OK but not writing... I've just bought a Fibaro HCL and trying my 1st steps in Domotic. Regards.
