Nexus_77
    29
Tout ce qui a été posté par Nexus_77
  1. comment puis-je vérifier le pourcentage de la batterie?
  2. Nexus_77
    Gbay
    Mee too try Aeotec, good product with Lua but battery drain in 4 months without use it and no recarghable. Thanks for your information, Hope i find in Europe.. Bye Sent to my Amiga 500
  3. Nexus_77
    Gbay
    Hi, and welcome... excellent system .. as you are with the vision keyfob? How long does the the battery last? I can not find in Europe...
  4. hi guys, i have MCO Air Quality Monitor, temperature, humidity CO2 and VOC. It' fantastic item, i use to regulate a speed of VMC with lua.
  5. this is a main device: {"id":322,"name":"322","roomID":0,"type":"com.fibaro.zwaveDevice","baseType":"com.fibaro.device","enabled":true,"visible":false,"isPlugin":false,"parentId":1,"remoteGatewayId":0,"interfaces":["polling","zwave","zwaveAssociation","zwaveConfiguration","zwaveSlaveRouting"],"properties":{"associations":"[{\"endPointId\":0,\"groups\":[{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":1,\"singleChannel\":{\"max\":5,\"set\":[1],\"view\":[1]}},{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":2,\"singleChannel\":{\"max\":1,\"set\":[1],\"view\":[1]}}]}]","configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"28","deviceSpecificData":"","deviceSpecificIdType":"","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"parametersTemplate":"775","pollingInterval":"0","pollingTimeSec":0,"productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","useTemplate":"true","userDescription":"","zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveSoftwareVersion":"{}","zwaveVersion":"1.2"},"actions":{"getParameter":1,"poll":0,"reconfigure":0,"setParameter":2},"created":1476965482,"modified":1476965482,"sortOrder":134} Co2 sensor {"id":323,"name":"Co2 camera letto","roomID":5,"type":"com.fibaro.multilevelSensor","baseType":"com.fibaro.sensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["zwave"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"47","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","unit":"ppm","useTemplate":"true","userDescription":"","value":"1949.00"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":135} Temp sensor {"id":324,"name":"Temperatura","roomID":5,"type":"com.fibaro.temperatureSensor","baseType":"com.fibaro.multilevelSensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["zwave"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"30","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","offset":"0.00","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","showFireAlarm":"true","showFreezeAlarm":"false","smsNotificationID":"0","smsNotificationType":"0","unit":"C","useTemplate":"true","userDescription":"","value":"20.30"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":136} humidity sensor {"id":325,"name":"Umidità","roomID":5,"type":"com.fibaro.humiditySensor","baseType":"com.fibaro.multilevelSensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["zwave"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"31","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","unit":"%","useTemplate":"true","userDescription":"","value":"63.00"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":137} Gas sensor {"id":326,"name":"322.0.3","roomID":5,"type":"com.fibaro.gasDetector","baseType":"com.fibaro.lifeDangerSensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["fibaroBreach","zwave","zwaveAlarm"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"alarmLevel":"0","alarmType":"0","configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"21","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","lastBreached":"1476965495","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","useTemplate":"true","userDescription":"","value":"true"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":138}
  6. Ok tell me a procedure and i share asapInviato dal mio PLK-L01 utilizzando Tapatalk
  7. hi Lazer, i add a MCO Co2 i push all buttton to vd, but i don't read a Co2 in a graph, i have error not device found. i see new temp ad humidity but no co2.. you have a idea? thanks
  8. Nexus_77
    My Batteries
    i had a device in not assigned room. i change room and now it's works correctly. merci
  9. Nexus_77
    My Batteries
    hi guys, i have a problem, i import a vd and don't works. in debug i ha a error on line [ERROR] 14:42:28: line 56: attempt to concatenate a nil value line 56 is: table.insert(modules, {batt, v.name .. " (" .. v.id .. "-"..fibaro:getRoomName(fibaro:getRoomID(v.id))..")"}) where is a error? thanks
  10. before to reset password i had a error "password required", aftere reste a password, alarm changed in "database domotique unknow", after i create a new folder graphs and now it's works. i renamed old graphs
  11. hi Lazer, my sino update at last version Mariadb an PHP, graphs not worked. i reset Mariadb password and changed like a file config. now it's work but i missing all old graphs.. what's happen?? thanks
  12. video https://www.youtube.com/watch?v=VUbStZ-11bo cool...
  13. si vous voulez il y a aussi un bouton ZWave :Philio PSR04
  14. hi lazer, my qnap is dead, i replace with a sinology.. it's work... but, how i translate voices from french to italian? how files i modify? thanks
  15. wow... good job... no words
  16. Nexus_77
    Zipato Rgbw
    i attach a vd, sorry but in Italian, in case of problem use google translate or ask me. Lampadina_RGBW_.vfib
  17. Nexus_77
    Zipato Rgbw
    the bulb works, but with the app you can not choose the colors, I created a vd that allows me to choose colors and brightness, time taken five minutes if you want, I share it
  18. Today I tried again. nas formatted, followed the guide from the beginning, nothing, always errors. unfortunately I do not have the skills to find the error, I now I set aside for it, sorry because it was very nice. Lazer thanks for the work and support . I will continue with thingspeak
  19. yes: // MySQL Server hostname or IP address $server = '192.168.1.103'; // MySQL User account $login = 'nexus'; // MySQL User password $password = '123456'; // MySQL Database name $database = 'domotique'; i try other user (root, admin, ciccio..) but don't work. all user have a permission and all have a same password for semplicity
  20. ok I start from the beginning . i refollow tutorial, in vd i sue ip and port to nas i don't touch lua now. if i use debug on the each button: sensor: [DEBUG] 11:40:21: Error : Can not connect to NAS, errorCode=0, status=, payload=/graph/data_post.php, response= power: like sensor battery: it's work.. i see % of battery device: it's work but at the end i see error like sensor trend: [DEBUG] 11:42:10: Error : Can not connect to NAS, errorCode=1, status=, payload=/graph/generate_trend.php, response= energy: DEBUG] 11:42:34: Error : Can not connect to NAS, errorCode=1, status=, payload=/graph/teleinfo_energy_get.php, response= i begin to lose hope
  21. in a vd in ip address it's blank in a buttons i modify only local ip = fibaro:get(selfID, '192.168.1.xxx') local port = fibaro:get(selfID, '80') correct??
  22. yes, i follow tutorial.. i have qnap but it's same story in a database i see 28 item
  23. when i see http://192.168.1.xxx/graph/ in a lua debug , in each button i read: [ERROR] 00:17:06: line FHttp:
  24. hi, i have this error Use of undefined constant JSON_NUMERIC_CHECK - assumed 'JSON_NUMERIC_CHECK'
