Alexandru
    123
Tout ce qui a été posté par Alexandru
  1. Bonjour a vous , j'ai essayé de mettre cet code en LUA dans ma HC2 (vers 4.080) avec l'aide de IFTTT si il y'a une porte/fenêtre ouverte , on peut couper la chaleur tant qu'une porte ou fenêtre est ouverte . --[[ %% properties 239 value --here you add your sensor ID and the word value. This section is checking for changes in the --value field for your sensors to start below code. I am using 3 door/window sensors %% globals --]] local PorteCuisine --defining variables for window sensor local NestSetpoint local param1 local key PorteCuisine = fibaro:getValue(239, 'value') --this will pull a current state(value) of the sensor --1 is on and 0 is off NestSetpoint = fibaro:getValue(111, "setpointTemp2") --this is a current temperature you have set on Nest if (PorteCuisine == '1') then param1 = "17" --this is the termperature you want to be set when windows/door are open end if (PorteCuisine == '0') then fibaro:debug(NestSetpoint) param1 = NestSetpoint -- once all door/windows are closed, temperature will be set to previous set. end fibaro:debug(NestSetpoint) fibaro:debug(param1) -------------------------------------- --this section is used to send command to IFTTT with required Nest temperature key = "GWG27en7Bm6x5UHaAxOF6" --use your key from the Maker channel on IFTTT function PushData(key, event, param1) local httpClient = net.HTTPClient({ timeout = 2000 }); local url = 'https://maker.ifttt.com/trigger/set_nest_temperature/with/key/'..key..'?value1='..param1; --debug url print(url); httpClient:request(url, { success = function(response) if tonumber(response.status) == 200 then print("Updated at " .. os.date()); else print("Error " .. response.status) end end, error = function(err) print('error = ' .. err) end, options = { method = 'GET' } }); end PushData(key, event, param1); [DEBUG] 13:41:32: 17 [DEBUG] 13:41:32: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=17 [DEBUG] 13:41:33: Updated at Sat Mar 26 13:41:33 2016 [DEBUG] 13:45:42: 23 [DEBUG] 13:45:42: 23 [DEBUG] 13:45:42: 23 [DEBUG] 13:45:42: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=23 [DEBUG] 13:45:43: Updated at Sat Mar 26 13:45:43 2016 [DEBUG] 13:46:10: 23 [DEBUG] 13:46:10: 23 [DEBUG] 13:46:10: 23 [DEBUG] 13:46:10: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=23 [DEBUG] 13:46:10: Updated at Sat Mar 26 13:46:10 2016 [DEBUG] 14:52:14: 23 [DEBUG] 14:52:14: 17 [DEBUG] 14:52:14: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=17 [DEBUG] 14:52:15: Updated at Sat Mar 26 14:52:15 2016 le problème est que j'ouvre ou je ferme la porte rien qui se passe sur Nest, Es-ce que quelqu'un d'entre vous a une idée ... Merci d'avance
  2. Bonjour a vous , J'ai essayé de mettre le code de la scène présence dans ma HC2 , pour les cookie de Mother , mais j'ai une erreur de ce façon , Si quelqu'un d'entre vous qui peux aider , Merci d'avance , [DEBUG]22:50:00: call::checkUpdate ERROR [HTTPClient:request] status:401
  3. Alexandru
    Thermostat Nest
    Merci d'avance !
  4. Alexandru
    Thermostat Nest
    Aaa , j'ai déjà le plugin Nest Fibaro installée , plutôt je pense qua il faut éteindre car si il y a quelqu'un la intérieur le thermostat peut démarre le chauffage ,, mais je ne suis pas certain de cette avis ... peut être semaine prochain ,,
  5. Bonjour à tout le monde, J'ai un NEST thermostat qui gère le chauffage dans ma maison, je veux intégrer le thermostat dans certaines scènes, par exemple si j'ouvre une porte ou une fenêtre équipée avec le détecteur Fibaro FGK 101, alors le thermostat couper la chaleur, peut être un module virtuel ou une scène. Merci à tous pour votre aide,
  6. Bonjour a vous , j'utilise depuis certain période un software "audio|acacia"qui vient de Plethra.com pour stream audio multiroom , et je me demande si il est possible d'avoir un module virtuel en HC2 , comme ça on peut l'intégrer et aussi faire de scène avec. Je vous remercie pour votre aide .
  7. c'est le thermostat qui apparais sur la tablette et iPhone du panneau chauffage.
  8. je travaille dessus depuis 1 semaine et je n'arrive pas a mettre cet module en service si tu sais m'aider ????comment je peux amené des photos sur le forum???STP??Un grand merci àtoi.
  9. file:///Users/alexandrunichita/Desktop/IMG_3838.jpg
  10. Bonjour a tous , j'ai aussi une camera iCAM Pro FHD , j'arrive pas a l'intégrée dans ma HC2 , on a réussi a voir le striming live en Firefox depuis cette camera si ça peut vous aider ça , merci a vous tous ,
  11. Bonjour a tous , j'ai essayé plusieurs fois de mettre en service ce module virtuel 2 boutons (vacance et normal) liée à panneau chauffage , si une fenêtre /porte ouverte température demandée en rouge devrait passer la température vacance en bleu ) local HC2 = Net.FHttp("127.0.0.1",11111) local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating/"..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating/"..strefa, json)
  12. Merci , merci beaucoup ,JOJO aussi a vous tous , pour votre travail et de l'aide apportée
  13. Merci a vous , infiniment , pour pouvoir m'aider
  14. fibaro:setGlobal("Mode_Chauffage_SSA","ETE") fibaro:log("Mode ETE") HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json) fibaro:setGlobal("Mode_Chauffage_SSA","ETE") fibaro:log("Mode ETE") HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json)
  15. HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json)
  16. Je suis désolé , mais je ne peux pas zoomer ce code , désolé
  17. fibaro:setGlobal("Mode_Chauffage_SSA","ETE") fibaro:log("Mode ETE") HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json)
  18. HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json)
  19. fibaro:setGlobal("Mode_Chauffage_SSA","ETE") fibaro:log("Mode ETE") HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json)
  20. HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json)
  21. HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json)
  22. Bonjour a vous , j'ai essayé de mettre sur ma box HC2 version 4.057 ces modules virtuels en route pour pouvoir créer des scènes ,le chauffage s'arrête si il y a une porte/ fenêtre ouverte, mais j'arrive pas . J'ai entendu que il faut changé quelque chose la, (l'API dans les requêtes HC2:GET ) pour cette version. C'est possible que quelqu'un d'entre vous peut m'aider en arranger ce code . Merci a vous tous !! HC2 = Net.FHttp("192.168.1.83",80) HC2:setBasicAuthentication("admin", "admin") local strefa = 1 response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa) jsonTable = json.decode(response) jsonTable.properties.vacationTemperature = 7; json = json.encode(jsonTable); HC2:PUT("/api/panels/heating?id="..strefa, json fibaro:setGlobal("Mode_Chauffage_SSA","ETE")fibaro:log("Mode ETE")HC2 = Net.FHttp("192.168.1.83",80)HC2:setBasicAuthentication("admin", "admin")local strefa = 1response ,status, errorCode = HC2:GET("/api/panels/heating?id="..strefa)jsonTable = json.decode(response)jsonTable.properties.vacationTemperature = 7;json = json.encode(jsonTable);HC2:PUT("/api/panels/heating?id="..strefa, json)
  23. Bonjour a tous , j'ai la sirène ZW080 de Aeotec et je vais l'intègre dans ma HC2 avec la version 4.057 beta . ( si une des deux portes équipées avec détecteur FGK101 et un détecteur mouvement Fibaro armé détecte un cambriolage la sirène commence a sonner ). Merci d'avance pour votre soutien .
