stef1234
1 -
Tout ce qui a été posté par stef1234
Hi
Can you make something like in the old app HC2 to stream a content to my Sonos in HC3
Greetz Stef
STREAM: Pour utiliser la lecture de Stream depuis une scène ou un périphérique virtuel il faut exécuter le code LUA suivant avec les bons paramètres.
-- 408 is the Virtual Device ID -- 28 is the Process button ID local sid, bid = 408, 28 -- Create STREAM params object local params = { -- stream: the file / uri stream = "//s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", -- source: "local" or "http", "local" is setted by default source = "http", -- duration: play duration in seconds (option) or "auto" duration = 8, -- volume: the volume for playing the stream volume = 10 } local _f = fibaro local _x ={root="x_sonos_object",load=function(b)local c=_f:getGlobalValue(b.root)if string.len(c)>0 then local d=json.decode(c)if d and type(d)=="table"then return d else _f:debug("Unable to process data, check variable")end else _f:debug("No data found!")end end,set=function(b,e,d)local f=b:load()if f[e]then for g,h in pairs(d)do f[e][g]=h end else f[e]=d end;_f:setGlobal(b.root,json.encode(f))end,get=function(b,e)local f=b:load()if f and type(f)=="table"then for g,h in pairs(f)do if tostring(g)==tostring(e or"")then return h end end end;return nil end} -- Make a request to the remote to process params object instantly _x:set(tostring(sid), { stream = params }) _f:call(sid, "pressButton", bid)
