ericl78
    422
    8
Tout ce qui a été posté par ericl78
  1. moi fait à suivre
  2. Le forum est entrain de mourir ou quoi, plus rien !. Ou les produits deviennent géniaux ?
  3. Mise à jour effectuée RAS à cet instant
  4. Message de Fibaro : Dear users, The Beta version of update 5.171 has been temporarily disabled. The update will be available again after resolving the reported issues with refreshing views for QuickApp. We would like to apologize for the inconvenience. Regards, FIBARO Team
  5. oui merci modifié
  6. Firmware 5.171.13 BETA 28/11/2024 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Make sure that you are using the newset version of the mobile application for the best experience. What's new: Dashboard Added visual feedback for devices with power metering on the device tiles. Devices Performance improvements in binding processes from the mobile application. Heatit Z-Water2 device support added. Heatit Z-TRM6 DC device support added. Updated device dialog for Sound Switch device type. Added a hourglass icon for scheduled actions for HVAC devices. Improved handling of HVAC devices using Fahrenheit scale for temperature control. Elero Added support for legacy Combio JA Pulse device. Added support for Awning device role for various motor types. Nice* Updated chip SDK for stability and performance improvements. Other Updated definitions for binding instructions for the Yubii Home app. Implemented automatic restart of services in case of backup restoration failure and other errors. Quick Apps Improved loading time for content provided in the webview. Removed success toasts for webview content which covered the content of the Quick App. The exported QuickApp file now contains a device description. Added automatic code completion for RefreshStateSubscriber function. Scenes Function hub.setTimeout now returns a timeout ID that can be used to clear an ongoing timeout using the hub.clearTimeout. Z-Wave Various legacy devices support added to Z-Wave 3.0 engine.** Reconfiguration of the device now keeps original name of the devices entities.** Bug Fixes: Access The advanced user can't remove user's mobile device in Access settings even if right Access is granted. The installer can't upload a backup into the system. Small UI fixes in whole system for the advanced user depending on specific access rights. Dashboard Fixed issues with displaying large values on device tiles for sensors. Lack of state label for binary switches without power metering. Devices Fixed http error 404 when opening thermostat control dialog after deleting climate zone. The header in device protocol-specific notifications is incorrect. Fixed refreshing advanced parameter values when using mobile app device binding process. Inversion settings, device role and favorite positions are not restored in some cases after performing a soft-reconfiguration. Fixed an issue with setting the wake-up interval for battery devices to 0 in some cases after saving the configuration. Custom door lock icons are not displayed. LinkedDevice (binarySensor) does not update the last breach time. Elero UI fixes to the device binding process. Energy panel Billing periods comparsion - incorrect trend arrow status in UI. Garden Inconsistent behavior when saving settings for watering time when editing sequences. Gateway Connection Issue with Force Removing of the Z-Wave device from the Slave hub.** Nice* Rain detector state not always shows correct status for a Climatic Sensor. Other Fixed an issue with some translations refreshing on the fly when changing the Hub language. The e-mail notification from device added to Slave hub shows wrong device ID in the content. Changing home location using https does not work correctly in some cases. Plugins Fixed camera preview issue for the Nice Cameras plugin after changing the encoding from h265 to another one. Quick Apps Fixed an issue with cutting out dropdown content in new device control dialogs. Recovery UI fixes in the recovery interface on Linux based systems. Scenes Issues with saving scenes content via http API when content contains spaces. When adding a simple scenario via the Yubii Home App in installer mode, the description field is covered by the system keyboard. In some cases, in block scenes it is not possible to use push notifications for a specific mobile device. UI fixes in the Yubii Home scenario creator. It is not possible to use negative values in Energy Panel balance blocks. Z-Wave Removed not supported "Reconfigure" option for all Z-Wave devices in Z-Wave settings.** Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. En Français Maintenant Merci d'utiliser notre passerelle ! Veillez à mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations. Assurez-vous d'utiliser la nouvelle version de l'application mobile pour une expérience optimale. Nouveautés : Tableau de bord Ajout d'un feedback visuel pour les appareils avec mesure de puissance sur les tuiles de l'appareil. Appareils Amélioration des performances dans la liaison des processus depuis l'application mobile. Ajout de la prise en charge de l'appareil Heatit Z-Water2. Ajout de la prise en charge de l'appareil Heatit Z-TRM6 DC. Mise à jour de la boîte de dialogue des appareils pour le type d'appareil Sound Switch. Ajout d'une icône de sablier pour les actions programmées pour les appareils CVC. Amélioration de la gestion des appareils HVAC utilisant l'échelle Fahrenheit pour le contrôle de la température. Elero Ajout du support pour l'ancien dispositif Combio JA Pulse. Ajout de la prise en charge du rôle de l'appareil Awning pour différents types de moteurs. Nice* Mise à jour du SDK de la puce pour améliorer la stabilité et les performances. Autre Mise à jour des définitions pour les instructions de liaison pour l'application Yubii Home. Implémentation du redémarrage automatique des services en cas d'échec de la restauration de la sauvegarde et d'autres erreurs. Applications rapides Amélioration du temps de chargement pour le contenu fourni dans la webview. Suppression des toasts de réussite pour le contenu de la webview qui couvrait le contenu de l'application rapide. Le fichier QuickApp exporté contient désormais une description de l'appareil. Ajout de la complétion automatique du code pour la fonction RefreshStateSubscriber. Scènes La fonction hub.setTimeout renvoie maintenant un ID de timeout qui peut être utilisé pour effacer un timeout en cours en utilisant la fonction hub.clearTimeout. Z-Wave Ajout du support de divers périphériques anciens au moteur Z-Wave 3.0.** La reconfiguration du périphérique conserve désormais le nom original des entités du périphérique**. Corrections de bugs : Accès L'utilisateur avancé ne peut pas supprimer l'appareil mobile de l'utilisateur dans les paramètres d'accès même si l'accès droit est accordé. L'installateur ne peut pas télécharger une sauvegarde dans le système. Petites corrections de l'interface utilisateur dans l'ensemble du système pour l'utilisateur avancé en fonction des droits d'accès spécifiques. Tableau de bord Correction des problèmes d'affichage des grandes valeurs sur les tuiles des capteurs. Absence d'étiquette d'état pour les interrupteurs binaires sans mesure de puissance. Appareils Correction de l'erreur http 404 lors de l'ouverture de la boîte de dialogue de contrôle du thermostat après la suppression d'une zone climatique. L'en-tête des notifications spécifiques au protocole de l'appareil est incorrect. Correction de l'actualisation des valeurs des paramètres avancés lors de l'utilisation du processus de liaison des appareils de l'application mobile. Les paramètres d'inversion, le rôle de l'appareil et les positions favorites ne sont pas restaurés dans certains cas après avoir effectué une reconfiguration logicielle. Correction d'un problème avec le réglage de l'intervalle de réveil pour les dispositifs de batterie à 0 dans certains cas après avoir sauvegardé la configuration. Les icônes de verrouillage de porte personnalisées ne sont pas affichées. LinkedDevice (binarySensor) ne met pas à jour l'heure de la dernière infraction. Elero Corrections de l'interface utilisateur pour le processus de liaison des appareils. Panneau d'énergie Comparaison des périodes de facturation - statut incorrect de la flèche de tendance dans l'interface utilisateur. Jardin Comportement incohérent lors de la sauvegarde des paramètres pour le temps d'arrosage lors de la modification des séquences. Connexion à la passerelle Problème avec le retrait forcé du dispositif Z-Wave du hub esclave. Nice* L'état du détecteur de pluie n'indique pas toujours l'état correct pour un capteur climatique. Autre Correction d'un problème de rafraîchissement de certaines traductions à la volée lors du changement de langue du hub. La notification par e-mail d'un dispositif ajouté au hub esclave affiche un mauvais ID de dispositif dans le contenu. La modification de l'emplacement de la maison en utilisant https ne fonctionne pas correctement dans certains cas. Plugins Correction du problème de prévisualisation des caméras pour le plugin Nice Cameras après avoir changé l'encodage de h265 à un autre. Applications rapides Correction d'un problème de coupure du contenu de la liste déroulante dans les boîtes de dialogue de contrôle des nouveaux appareils. Récupération Correction de l'interface de récupération sur les systèmes basés sur Linux. Scènes Problèmes avec l'enregistrement du contenu des scènes via l'API http lorsque le contenu contient des espaces. Lors de l'ajout d'un scénario simple via l'application Yubii Home en mode installateur, le champ de description est couvert par le clavier du système. Dans certains cas, dans les scènes en bloc, il n'est pas possible d'utiliser les notifications push pour un appareil mobile spécifique. Corrections de l'interface utilisateur dans le créateur de scénario de Yubii Home. Il n'est pas possible d'utiliser des valeurs négatives dans les blocs d'équilibre du panneau d'énergie. Z-Wave Suppression de l'option « Reconfigurer » non supportée pour tous les appareils Z-Wave dans les paramètres Z-Wave.** Problèmes connus : Z-Wave Engine 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
  7. Bon, pour mon prb, la solution était : changer la pile qui était good à 75%. J'ai essayé de le rapprocher de la boxe, reinit,... rien à faire :=), seul le chgt de pile à été immédiat
  8. Bonjour à tous, Bon, de mon coté, j'en avait 7 à mettre à jour. 6 se sont mis à jour sans aucun problème, le 7 éme rien à faire. Une idée de votre coté pour les récalcitrant ? Merci
  9. Merci d'utiliser notre passerelle ! Veillez à mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations. Principales caractéristiques : 1. Nouvelles vues de contrôle des appareils Une nouvelle façon de contrôler tous les types d'appareils à partir du tableau de bord et de l'aperçu dans les paramètres de l'appareil pour une meilleure expérience utilisateur. 2. Utilisateur avancé Introduction d'un nouveau type d'utilisateur dans le système avec un accès configurable aux paramètres du système. Désormais, l'administrateur peut décider quelles parties de l'interface de configuration seront accessibles aux utilisateurs qui ne sont pas propriétaires du système. 3. Connexion à la passerelle avec le moteur Z-Wave 3.0 Les systèmes utilisant le nouveau moteur Z-Wave peuvent désormais utiliser la fonction Gateway Connection. Les nouveautés : Accès - Nouvelle interface utilisateur pour configurer les paramètres d'accès pour les utilisateurs normaux. Alarme - Par défaut, le déclenchement d'une alarme entraîne désormais l'envoi d'un Push critique (iOS) et d'un Push (Android) pour la nouvelle application Yubii Home. Climat - Une nouvelle façon de contrôler directement les zones à partir du tableau de bord climatique. Tableau de bord - Ajustement de la taille des icônes pour une meilleure visibilité. Appareils - Prise en charge du thème sombre pour les nouveaux assistants de reliure dans l'application mobile. - Mise à jour et ajout de nouvelles instructions de fixation aux assistants de fixation. - Prise en charge de FGDW-002 dans la version 3.3. - Mise à jour de certains modèles de paramètres pour divers appareils pris en charge. -Améliorations mineures de l'UI/UX dans les assistants de reliure. - Améliorations dans les dispositifs liés (stores). - L'étalonnage des appareils est désormais disponible dans les paramètres avancés de l'appareil. - Le réglage du décalage de température du capteur externe FGT-001 a été supprimé. Connexion à la passerelle - Désormais, la limite supérieure des hubs esclaves autorisés est fixée à 15. Nice* - Ajout de la prise en charge de la deuxième position favorite pour les écrans et les stores Nice. Autre - Désormais, la restauration d'une sauvegarde ou le changement de système ne désactivera pas l'accès à distance pour le support s'il était activé avant la procédure. Plugins Correction de l'interface utilisateur du plugin WakeOnLan. Améliorations dans le plugin Nice Cameras pour une meilleure performance du streaming. Applications rapides Ajout de la possibilité de définir des vues personnalisées pour les appareils enfants. Ajout de la possibilité de copier les définitions de vues dans le presse-papier (fonctionne avec les connexions HTTPS uniquement). Ajout de la possibilité d'ajouter des éléments de vue personnalisés aux vues de thermostat. Amélioration des performances des webviews. Scènes Prise en charge du thème sombre pour les scénarios simples. Le type de périphérique Sound Switch a été ajouté aux scénarios simples. Z-Wave Ajout du support de la classe de commande User Code.** Ajout du support de la classe de commande Simple AV Control.** Amélioration des performances de l'inclusion et de la configuration des dispositifs pris en charge**. Ajout de la prise en charge de nombreux dispositifs d'ancienne génération (série ZW300, ZW500).** Désactivation du flou sur la console Z-Wave pendant la procédure d'ajout de périphérique. Désactivation du mode d'ajout Security S0 disponible.** Zigbee Amélioration des performances lors de l'exécution d'actions de masse. Amélioration du module de vérification de la disponibilité des dispositifs (marquage des dispositifs non joignables). Ajout de la prise en charge du capteur de présence humaine MOES ZSS-QY-HP. Corrections de bugs : Sauvegarde Correction d'une erreur rare lors de la restauration d'une sauvegarde. Caméras Correction des aperçus de caméra dans certains cas. Appareils Correction des icônes par défaut pour certains types d'appareils. Correction de la prise en charge de l'action de basculement pour le type d'interrupteur multipositions. Correction d'un message incorrect lors de l'étalonnage de l'appareil FGD-221.** Correction du graphique du point de consigne pour FGT-001, qui ne s'affichait pas correctement dans certains cas. Impossible d'ajouter un appareil dans Security S2 si le PIN était incorrect (hors de la plage autorisée).** Corrections mineures de l'interface utilisateur dans les paramètres avancés de FGR-224/Roll-Control 2. L'actualisation des valeurs des paramètres avancés dans la procédure de liaison de l'assistant ne fonctionnait pas correctement. Correction du réglage des positions favorites pour certains stores. Connexion à la passerelle Correction d'un problème avec les caractères spéciaux dans les mots de passe pour les concentrateurs esclaves. La visibilité de la mise à jour pour le concentrateur esclave ne fonctionnait pas correctement. Historique Suppression de certains événements en double. Nice* Correction de la prise en charge des portes du protocole MHouse avec la nouvelle révision du matériel. Le BiDi-Multisensor est temporairement marqué comme déconnecté lors de la réinitialisation par défaut de certains paramètres de l'appareil. Notifications Les intervalles redondants ont été supprimés de la page de configuration pour les notifications de type événement. Autres Corrections mineures de la traduction. Corrections mineures de l'interface utilisateur. L'utilisateur est déconnecté du système après avoir créé une sauvegarde. Applications rapides L'application rapide ajoutée est placée dans la mauvaise pièce dans certains cas. Récupération Correction d'un problème lors de la mise à jour du hub de Recovery de 5.140 à 5.153 Beta. Correction d'un problème de vérification de la version du système lors de l'utilisation de l'option de réparation. Salles Correction d'un problème lors de la définition de l'icône de salle par défaut après avoir supprimé une icône personnalisée du système. Impossible de supprimer l'icône SVG personnalisée dans les paramètres de la salle. L'icône de la salle personnalisée n'est pas visible lors de l'édition des paramètres de la salle. Scènes Lorsqu'une nouvelle scène est ajoutée, la fenêtre ne défile pas jusqu'à l'élément nouvellement ajouté. Possibilité de taper un nom trop long pour un scénario simple, ce qui bloque la possibilité de le sauvegarder. Absence de certaines icônes de scènes après le redémarrage du système dans de rares cas. Petites corrections de l'interface utilisateur dans les scénarios simples. Principaux dispositifs Z-Wave disponibles dans le sélecteur de dispositifs des scènes en bloc. Correction d'un problème avec la fonction d'activation de scène dans les scènes en bloc. Remplacement du déclenchement de la scène sur l'état de verrouillage de la porte. Mise à jour La visibilité de la barre de progression du téléchargement dépend de la sélection de la case à cocher (beta). Z-Wave Erreur 500 dans quelques rares cas pendant le processus de reconfiguration du périphérique Z-Wave. L'action de mise à jour « Requesting Neighbors » ne se déclenche pas toujours correctement. Correction du réglage manuel de l'intervalle d'interrogation du périphérique. Le périphérique BiDi-Zwave est ajouté avec un mauvais rôle système par défaut. Les paramètres du Qubino 0-10V Dimmer sont restaurés par défaut lors de l'inclusion. Zigbee Correction de la procédure de suppression des dispositifs. Problèmes connus : Z-Wave Engine 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - ne s'applique pas au HC3L (Home Center 3 Lite) ** - s'applique uniquement au Z-Wave Engine 3.0
  10. Firmware 5.161.15 BETA 25/07/2024 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. New device control views A new way of controlling all device types from the Dashboard and preview in device settings for a better user experience. 2. Advanced user Introduction of a new type of user in the system with configurable access to system settings. From now on, the administrator can decide which parts of the configuration interface will be accessible to users who are not system owners. 3. Gateway Connection with Z-Wave Engine 3.0 Systems using the new Z-Wave engine can now use the Gateway Connection feature. What's new: Access New UI for configuring access settings for normal users. Alarm By default, triggering an alarm will now result in sending a Critical Push (iOS) and Push (Android) for the new Yubii Home app. Climate A new way of direct zone control from the climate dashboard. Dashboard Adjusted icon sizes for better visibility. Devices Support for the dark theme for the new binding wizards in the mobile application. Updated and added new binding instructions to the binding wizards. Support for FGDW-002 in version 3.3 added. Updated some parameter templates for various supported devices. Minor UI/UX improvements in the binding wizards. Improvements in Linked Devices (blinds). Calibration of devices now available in advanced device settings. FGT-001 external sensor temperature offset setting removed. Gateway Connection From now on, the upper limit for allowed slave hubs is set to 15. Nice* Added support for 2nd favorite position for Nice screens and blinds. Other From now on, restoring a backup or switching the system won't disable Remote Access for support if it was enabled before the procedure. Plugins WakeOnLan plugin UI fixes. Improvements in Nice Cameras plugin for better streaming performance. Quick Apps Added the possibility to set custom views for child devices. Added the possibility to copy view definitions to the clipboard (works with HTTPS connections only). Added the possibility to add custom view elements to thermostat views. Improved webview performance. Scenes Support for the dark theme for Simple Scenarios. The Sound Switch device type added to Simple Scenarios. Z-Wave User Code command class support added.** Simple AV Control command class support added.** Inclusion and configuration of supported devices performance improvements.** Added support for numerous old-gen devices (ZW300, ZW500 series).** Disabled blur on the Z-Wave console during the device-adding procedure. Disabling the Security S0 adding mode available.** Zigbee Improved performance for executing bulk actions. Improved device availability-check module (marking devices as not reachable). Support for MOES Human Presence Sensor ZSS-QY-HP added. Bug fixes: Backup Fixed rare error during backup restoration. Cameras Fixed camera previews in some cases. Devices Fixed default icons for some device types. Toggle action support fixed for the multiposition switch device type. Fixed incorrect message when performing calibration of FGD-221 device.** Fixed setpoint graph for FGT-001, which was not correctly shown in some cases. Unable to add device in Security S2 if the PIN was incorrect (out of allowed range).** Minor UI fixes in FGR-224/Roll-Control 2 advanced settings. Refreshing advanced parameter values in the wizard binding procedure did not work correctly. Fixed setting favorite positions for some blinds. Gateway Connection Fixed issue with special characters in passwords for the slave hubs. Update visibility for slave hub did not work correctly. History Some duplicated events removed. Nice* Fixed support for MHouse protocol gates with new hardware revision. BiDi-Multisensor is temporarily marked as disconnected when resetting some device parameters to default. Notifications Redundant intervals removed from the configuration page for event-type notifications. Other Minor translation fixes. Minor UI/UX fixes. User is logged out from the system after creating a backup. Quick Apps Added QuickApp is placed in the incorrect room in some cases. Recovery Fixed issue with updating the hub from Recovery from 5.140 to 5.153 Beta. Fixed issue with checking system version when using the Repair option. Rooms Fixed issue with setting the default room icon after removing a custom icon from the system. Cannot remove custom SVG icon in room settings. Custom room icon is not visible when editing the room settings. Scenes When a new scene is added, the window does not scroll to the newly added element. Possibility to type too long a name for Simple Scenario, which blocks the possibility to save it. Lack of some scene icons after system restart in rare cases. Small UI fixes in Simple Scenarios. Main Z-Wave devices available in block scenes device selector. Fixed issue with Scene Activation feature in block scenes. Swapped triggering the scene on Doorlock state. Update Download progress bar visibility depends on the checkbox selection (beta). Z-Wave Error 500 in some rare cases during the Z-Wave device reconfiguration process. Requesting Neighbors update action not always triggers correctly. Fixed setting the device polling interval manually. BiDi-Zwave device is added with a wrong system role by default. Qubino 0-10V Dimmer parameters are being restored to default during inclusion. Zigbee Device removal procedure fixed. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0
  11. et voilà en Français :=) Firmware 5.160.30 STABLE 16/04/2024 Caractéristiques principales : 1. Scénarios utilisateur Les utilisateurs peuvent maintenant créer leurs propres scénarios (scènes) dans l'application mobile en utilisant un assistant d'ajout spécialement préparé. Pour utiliser les scénarios, mettez à jour votre application Yubii avec au moins la version 1.21 ou installez la nouvelle application mobile (description ci-dessous). 2. Nouveau processus d'ajout d'appareils dans l'application mobile Désormais, les utilisateurs peuvent plus facilement ajouter leurs appareils au système via l'application mobile en utilisant le nouvel assistant d'ajout. Pour utiliser la nouvelle méthode d'ajout, installez la nouvelle application mobile. 3. Changements pour la nouvelle application mobile App Store : https://apps.apple.com/app/id6477485519 Google Play : https://play.google.com/store/apps/details?id=com.niceforyou.yubii Ajout de nouveaux jeux d'icônes par défaut pour les appareils, les scènes et les pièces. Nouvelle façon d'afficher le contenu de l'application rapide. Possibilité d'utiliser l'ancien style d'affichage de l'application rapide à des fins de rétrocompatibilité. Nouveau look pour les plugins Sonos et Husqvarna. Nouveau design pour les scénarios d'utilisation. Nouveautés : Appareils Correction de l'affichage des valeurs du compteur des mises à jour disponibles pour les appareils. Suppression des rôles inutilisés pour les types baseShutter et rollerShutter. Ajout de la prise en charge du dispositif REMOTEC ZXT800. Ajout de la prise en charge de l'appareil Heatit Z-TRM6. Ajout de la prise en charge de l'appareil MCOHome Keypad Switch K-ES2. Ajout de la prise en charge des capteurs de présence MCOHome OS11 et OS12. Ajout de la prise en charge des dispositifs dans le moteur Z-Wave 3.0** : FGD-211 FGS-221 FGR-221 FGS-211 FGBS-321 FGWPE-102 FGWPI-121 Suppression du contrôle redondant des lamelles pour les types de stores qui n'ont pas cette fonctionnalité. Elero Mise à jour du micrologiciel du module radio. Ajout de la prise en charge des anciennes versions des moteurs de stores RolTop. Connexion à la passerelle Déplacement de la sélection centrale des paramètres avancés directement vers l'écran d'ajout de périphérique Z-Wave. Nice* Amélioration de l'appairage des appareils Mono à l'aide de la télécommande existante. Réduction de la charge du réseau pour une meilleure performance. Ajout de la prise en charge du calibrage automatique pour les dispositifs BiDi-Shutter et BiDi-Awning. Mise à jour du firmware du module radio. Autre Amélioration de la gestion des erreurs lors de l'ajout d'un modèle d'utilisateur pour un appareil. Amélioration du fonctionnement des notifications du système en mettant à jour leurs données en fonction des paramètres actuels du système (noms des pièces, langue, etc.). Introduction d'optimisations du système pour améliorer les performances des concentrateurs. Mise à jour du firmware WLAN. Plugins Alignement de la vue des plugins avec le nouveau style de l'application. Les icônes Satel par défaut ont été mises à jour avec les nouveaux jeux. Ajout de la prise en charge du Satel Integra 256. QuickApps L'affichage des QuickApps a été aligné sur le nouveau style de l'application. Ajout d'une vue native pour le type de périphérique com.fibaro.player. Ajout de la gestion de la méthode uploadExternalIconSet() pour le type de périphérique com.fibaro.player. Scènes Amélioration de l'aspect visuel des curseurs de couleur dans les nouveaux scénarios simples. Masquage de l'option " True for a specified time " pour les conditions et les déclencheurs basés sur des événements. Ajout d'une nouvelle apparence pour le modèle d'e-mail envoyé à partir des scènes de bloc. Amélioration de l'action de basculement (marche/arrêt) du dispositif Unio-868. Z-Wave Amélioration de l'heure de démarrage du service. Ajout d'un support pour les dispositifs : ZVIDAR Z-TRV-V01 NICE Warm-Control NICE Clima-Control Contrôle NICE Fan2 Contrôle NICE Fan4 MCO OS11/OS12 pour les fréquences US et ANZ Support FGDW-002 pour la version 3.3. Améliorations de la stabilité. Améliorations de la performance du réseau.** Mise à jour du firmware du module radio (YH/HC3L). Amélioration du processus d'ajout du dispositif Schlage BE369.** Amélioration de la communication en cas de charge élevée du réseau et élimination du phénomène rare de "gel" du moteur Z-Wave.** Amélioration des paramètres par défaut pour les compteurs d'énergie domestique Aeotec et les compteurs Qubino 1p et 3p. Corrections de bugs : Sauvegarde Correction d'un problème d'affichage de l'écran de connexion après la création d'une sauvegarde. Résolution d'un problème de redémarrage redondant du hub lors de la création d'une sauvegarde. Climat Correction de l'affichage des noms des thermostats sélectionnés sur le sélecteur. Correction du décalage entre les valeurs de refroidissement et de chauffage pour les unités Fahrenheit. Appareils Correction du problème lié au réglage du type d'entrée pour le FGRGBW-442/RGBW-Control en mode RGBW/RGB. Bouton d'arrêt redondant pour certaines portes. Correction des icônes personnalisées pour les compteurs. Les doublons redondants des jeux d'icônes ont été supprimés dans certains cas. Les icônes de position favorite ne fonctionnent pas pour certains volets simples. Icône FGWC par défaut incorrecte dans l'interface web. Correction de l'affichage de l'icône de l'état de la position favorite pour le type d'interrupteur multipositions. La sauvegarde de l'angle des lamelles dans la position favorite pour le FGR-224 a été améliorée. Correction de l'apparence de la fenêtre modale pour l'ajout d'icônes personnalisées pour les dispositifs à plusieurs états. Fibaro RGBW2/Nice RGBW-Control se déconfigure dans de rares cas. Heatit Z-Smoke ne signale plus la détection de mouvement. Problèmes avec le contrôle de Fibaro RGBW1 après l'appairage du dispositif. Correction de l'opération de reconfiguration pour l'appareil Heatit ZTERM3. Corrections stylistiques mineures pour les écrans coulissants. Amélioration du fonctionnement de l'appareil Unio 868 avec l'option de logique inversée activée. Correction de la configuration des couleurs favorites pour l'appareil RGBW Linked Device. Correction des plages d'hystérésis de température et d'humidité dans les dispositifs liés. Correction d'un problème avec la restauration des paramètres par défaut pour le capteur climatique Domii après le redémarrage du système. Correction du marquage du capteur climatique Domii (solaire) comme mort après le redémarrage ou la mise à jour de l'unité centrale. Correction de l'erreur 502 lors de l'ajout de dispositifs Elero. FTI Erreur lors de la configuration de l'installateur lors de l'exécution du FTI par l'application mobile. Connexion à la passerelle Correction de l'affichage de l'état et du problème de redémarrage automatique de la passerelle maître après la mise à jour. Amélioration du fonctionnement du réseau et de la gestion du DNS lors de la liaison des hubs. Appareils liés Les paramètres d'hystérésis pour la température et l'humidité ont été améliorés - dorénavant, ils ne peuvent pas être supérieurs à la différence entre les valeurs minimales et maximales. Améliorations de style pour les appareils liés - Choisir l'option de l'appareil maître. Nice* Correction de la prise en charge de la ligne de portes Nice Home. Optimisation de la gestion des appareils fonctionnant sur batterie. Amélioration des performances du réseau. L'intervalle d'interrogation de Nice rétablit la valeur par défaut après l'avoir désactivé. Correction de la prise en charge du paramètre 5 du dispositif BiDi-Shutter. Correction d'un problème où les dispositifs couplés avec l'autorisation à distance BiDi utilisant un canal ne répondent pas jusqu'à ce que le hub soit redémarré. Autres problèmes Impossible de créer une pièce lorsque l'icône personnalisée est utilisée pendant le processus. Amélioration de la stabilité du pilote WiFi pour les hubs YH/HC3L. Correction de l'interface utilisateur dans le sélecteur d'arborescence. Suppression du bouton "Retour" redondant dans le processus de nouvelle liaison dans certains cas. Correction de l'effacement en bloc dans le panneau des notifications. Corrections de l'interface utilisateur dans le panneau de l'historique. L'apparence de la liste des notifications après l'utilisation de l'option "Effacer tout" a été améliorée. Correction des problèmes liés à la modification de l'ordre des pièces dans l'interface. Correction du problème d'apparition de l'écran de connexion dans l'interface après l'utilisation de l'option de restauration des paramètres d'usine de la passerelle. Erreur 502 aléatoire dans l'interface web dans certains cas. Problème de démarrage du système dans de très rares cas. Erreur 409 après l'ajout d'un Smart Start DSK.** précédemment ajouté. Améliorations mineures de l'UX et de l'UI. Restriction des permissions de l'installateur pour les changements dans les paramètres d'accès. Correction des valeurs arrondies en unités Fahrenheit pour les notifications de gel et d'incendie. Amélioration de l'affichage des horodatages de notification dans le panneau de notification. Améliorations stylistiques mineures apportées aux fenêtres modales, au modèle d'e-mail de réinitialisation du mot de passe utilisateur, aux boutons du menu latéral et à l'affichage des traductions. Correction de l'affichage des tarifs dans le panneau Énergie pour les langues brésilienne, portugaise et anglaise. Amélioration de la suppression des dispositifs depuis l'application mobile pour Z-Wave 3.0**. Amélioration de la stabilité du réseau Wi-Fi pour les hubs HC3L et YH. Plugins Correction des problèmes de chargement des vues de contrôle pour les enfants du plugin (ex. Philips Hue). Suppression du plugin DSC pour cause d'incompatibilité. Correction d'une erreur de connexion pour le plugin Heos. Corrections de traductions mineures pour le plugin Tedee. Applications rapides Correction du problème avec la gestion des actions onLongPressDown et onLongPressReleased. Correction du problème lié à l'envoi de messages push. Prise en charge de l'appui long sur un bouton dans l'application rapide. Correction d'un problème avec le gestionnaire de fichiers dans l'éditeur. Correction du rapport d'erreur dans la fonction fibaro.setTimeout. Amélioration de l'effacement sélectif de la console de débogage. Correction d'un problème lié à l'envoi d'e-mails concernant des tentatives de connexion suspectes avec une autorisation incorrecte dans l'application rapide. Correction de la couleur d'arrière-plan de l'application rapide en mode sombre. Scènes Correction du bloc de consommation d'énergie non fonctionnel dans les scènes de blocs. Correction des traductions pour certains appareils dans les blocs. Correction de l'exécution des scènes LUA. Amélioration de l'affichage de l'état des capteurs de CO lors de la sélection des déclencheurs dans les scènes en bloc. Correction de l'erreur de suppression d'une scène qui utilise des variables globales. Correction de la conversion de la valeur de l'heure dans les conditions liées au lever et au coucher du soleil dans les scènes en bloc. Utilisateurs Amélioration de l'attribution de dispositifs aux utilisateurs en cas de sections vides dans la gestion des accès. Correction de la fonctionnalité d'octroi de l'accès aux actions à distance pour l'installateur dans des cas spécifiques. Amélioration de l'affichage des statuts dans la liste des utilisateurs lors de l'invitation d'utilisateurs d'accès à distance. Résolution du problème de la suppression des autorisations des utilisateurs pour les salles après la création d'une nouvelle section. Zigbee de rares cas, le moteur Zigbee ne démarre pas après une modification des paramètres du réseau WiFi. Z-Wave Correction du paramètre de rôle par défaut après l'ajout du FGRGBW-441device.** Correction de la mise à jour de la version 25.25 à 27.27 pour le dispositif FGRGBW-441 pour la fréquence KR. Correction du problème de réinitialisation de tous les paramètres par défaut dans de rares cas**. Résolution du problème d'affichage incorrect des valeurs des paramètres Z-Wave pour l'unité centrale HC3L. Amélioration de l'affichage du nombre de paramètres en file d'attente pour les dispositifs Z-Wave. Amélioration des actions de réglage de la température pour les thermostats par rapport à la précision supportée par les dispositifs. Amélioration des modèles pour les compteurs Qubino 3-Phase/1-Phase. Amélioration de l'affichage des échelles pour certains terminaux Qubino.** Amélioration de l'affichage de la consommation électrique et de l'énergie pour les appareils Qubino. Correction d'un problème lié à l'ajout de dispositifs Z-wave+ d'ancienne génération**. Correction de l'impossibilité de contrôler certains stores d'autres fabricants. Problèmes connus : Z-Wave Engine 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave. Les compteurs d'énergie domestique Aeotec Gen5, version monophasée, ne permettent pas de modifier certains paramètres de configuration. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
  12. Hi Mise à jour effectuée, plus qu'à attendre :=)
  13. Bonjour à tous Je viens d'installer la nouvelle appli sur iPhone, je la trouve beaucoup plus WAF :=) Mes QA, comme avant fonctionnent, peut être de la change, pour info, je n'ai pas mis en place ce dernier firmware. Je trouve cette nouvelle appli pas mal, nous pouvons mettre sur une page ce que nous utilisons le plus. Nous devons laisser du temps à Fibaro pour la finaliser.
  14. Oui, Beta signifie bien qu'ils demandent aux volontaires de bien vouloir tester le programme non finalisé. Donc, ils ne garantissent rien. Moralité, si la version n'est pas en mode STABLE, aucune critique à apporter :=) mais remonter les problèmes à Fibaro pour permettre d'obtenir une vraie version stable.
  15. Pour info lu sur le fofo officiel
  16. 5.153.120- BETA Merci d'utiliser notre passerelle ! Veillez à mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations. Principales caractéristiques : 1. Nouvelle procédure d'ajout d'appareils dans l'application mobile Désormais, les utilisateurs peuvent plus facilement ajouter leurs appareils au système via l'application mobile en utilisant le nouvel assistant d'ajout. Pour utiliser la nouvelle méthode d'ajout, installez la nouvelle application mobile. 2. Changements pour la nouvelle application mobile App Store : https://apps.apple.com/app/id6477485519 Google Play : https://play.google.com/store/apps/details?id=com.niceforyou.yubii Ajout de nouveaux jeux d'icônes par défaut pour les appareils, les scènes et les pièces. Nouvelle façon d'afficher le contenu de l'application rapide. Possibilité d'utiliser l'ancien style d'affichage de l'application rapide à des fins de rétrocompatibilité. Nouveau look pour les plugins Sonos et Husqvarna. Nouveau design pour les scénarios d'utilisation. Nouveautés : Appareils Correction de l'affichage des valeurs du compteur des mises à jour disponibles pour les appareils. Suppression des rôles inutilisés pour les types baseShutter et rollerShutter. In English Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. New process for adding devices in the mobile app From now on, users can more easily add their devices to the system via the mobile app using the new addition wizard. To use the new way of adding, install the new mobile application. 2. Changes for the new mobile application App Store: https://apps.apple.com/app/id6477485519 Google Play: https://play.google.com/store/apps/details?id=com.niceforyou.yubii Added new default icon sets for devices, scenes, and rooms. New way of displaying Quick App's content. Possibility to use Quick App's old style view for backward compatibility. New look for Sonos and Husqvarna plugin. New design for user scenarios. What's new: Devices Corrected the display of values for the device available updates counter. Removed unused roles for baseShutter and rollerShutter types.
  17. Mise à jour effectuée, RAS pour l'instant
  18. Comme d'habitude, en français :=) Firmware 5.152.24 BETA 07/02/2024 Merci d'utiliser notre passerelle ! N'oubliez pas de mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et améliorations. Nouveautés : Elero Mise à jour du firmware du module radio. Nice Mise à jour du firmware du module radio. Z-Wave Amélioration de la stabilité**. Amélioration de la performance du réseau**. Mise à jour du firmware du module radio (YH/HC3L). Corrections de bugs : Appareils Fibaro RGBW2/Nice RGBW-Control se déconfigure dans de rares cas. Heatit Z-Smoke ne signale plus la détection de mouvement. Problèmes de contrôle du Fibaro RGBW1 après l'appairage du dispositif. FTI Erreur pendant la configuration de l'installateur lors de l'exécution du FTI par l'application mobile. Autre Erreur 502 aléatoire dans l'interface web dans certains cas. Problème de démarrage du système dans de très rares cas. Erreur 409 après l'ajout d'un DSK Smart Start précédemment ajouté.** Améliorations mineures de l'UX et de l'UI. Applications rapides Correction d'un problème avec le gestionnaire de fichiers dans l'éditeur. Z-Wave Correction d'un problème avec la réinitialisation de tous les paramètres par défaut dans de rares cas**. Problèmes connus : Moteur Z-Wave 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
  19. Pour les allergiques à l' anglais :=) Merci d'utiliser notre passerelle ! N'oubliez pas de mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations. Principales caractéristiques : 1. Scénarios pour l'utilisateur Les utilisateurs peuvent désormais créer leurs propres scénarios (scènes) dans l'application mobile à l'aide d'un assistant d'ajout spécialement préparé. Pour utiliser les scénarios, mettez à jour votre application Yubii avec la version 1.21. Nouveautés : Appareils Ajout de la prise en charge de l'appareil REMOTEC ZXT800. Ajout de la prise en charge de l'appareil Heatit Z-TRM6. Ajout de la prise en charge de l'appareil MCOHome Keypad Switch K-ES2. Ajout de la prise en charge des capteurs de présence MCOHome OS11 et OS12. Ajout de la prise en charge des dispositifs dans le moteur Z-Wave 3.0** : FGD-211 FGS-221 FGR-221 FGS-211 FGBS-321 FGWPE-102 FGWPI-121 Suppression du contrôle redondant des lamelles pour les types de stores qui n'ont pas cette fonctionnalité. Elero* Ajout de la prise en charge des anciennes versions des moteurs de stores RolTop. Connexion à la passerelle Déplacement de la sélection centrale des paramètres avancés directement vers l'écran d'ajout de périphérique Z-Wave. Autre Amélioration du fonctionnement des notifications du système en mettant à jour leurs données en fonction des paramètres actuels du système (noms des pièces, langue, etc.). Introduction d'optimisations du système pour améliorer les performances des concentrateurs. Mise à jour du firmware du WLAN. Plugins Ajout de la prise en charge du Satel Integra 256. Scènes L'option "True for a specified time" a été cachée pour les conditions et les déclencheurs basés sur des événements. Ajout d'un nouveau look pour le modèle d'e-mail envoyé à partir des scènes de bloc. Amélioration de l'action de basculement (on/off) du dispositif Unio-868. Z-Wave Amélioration du processus d'ajout du dispositif Schlage BE369**. Amélioration de la communication en cas de charge élevée du réseau et élimination du phénomène rare de "gel" du moteur Z-Wave**. Corrections de bugs : Sauvegarde Correction d'un problème d'affichage de l'écran de connexion après la création d'une sauvegarde. Résolution d'un problème de redémarrage du hub redondant lors de la création d'une sauvegarde. Climat Correction du décalage entre les valeurs de refroidissement et de chauffage pour les unités Fahrenheit. Appareils Correction de l'opération de reconfiguration pour l'appareil Heatit ZTERM3. Corrections stylistiques mineures pour l'affichage des curseurs. Amélioration du fonctionnement de l'appareil Unio 868 avec l'option de logique inversée activée. Correction de la configuration des couleurs favorites pour l'appareil RGBW Linked. Correction des plages d'hystérésis de température et d'humidité dans les dispositifs liés. Correction d'un problème avec la restauration des paramètres par défaut pour le capteur climatique Domii après le redémarrage du système. Correction du marquage du capteur climatique Domii (solaire) comme mort après le redémarrage ou la mise à jour de l'unité centrale. Correction de l'erreur 502 lors de l'ajout de périphériques Elero. Connexion à la passerelle Amélioration du fonctionnement du réseau et de la gestion des DNS lors de la connexion des hubs. Nice* Correction d'un problème où les appareils couplés avec l'autorisation à distance BiDi utilisant un seul canal ne répondent pas jusqu'à ce que le hub soit redémarré. Autre Restriction des autorisations de l'installateur pour les changements dans les paramètres d'accès. Correction des valeurs arrondies en unités Fahrenheit pour les notifications de gel et d'incendie. Amélioration de l'affichage des horodatages des notifications dans le panneau de notification. Améliorations stylistiques mineures apportées aux fenêtres modales, au modèle d'e-mail de réinitialisation du mot de passe utilisateur, aux boutons du menu latéral et à l'affichage des traductions. Correction de l'affichage des tarifs dans le panneau Énergie pour les langues brésilienne, portugaise et anglaise. Amélioration de la suppression des dispositifs depuis l'application mobile pour Z-Wave 3.0**. Amélioration de la stabilité du réseau Wi-Fi pour les hubs HC3L et YH. Plugins Suppression du plugin DSC pour cause d'incompatibilité. Correction de l'erreur de connexion pour le plugin Heos. Corrections de traductions mineures pour le plugin Tedee. Applications rapides Correction du rapport d'erreur dans la fonction fibaro.setTimeout. Amélioration de l'effacement sélectif de la console de débogage. Correction d'un problème lié à l'envoi d'e-mails concernant des tentatives de connexion suspectes avec une autorisation incorrecte dans l'application rapide. Correction de la couleur d'arrière-plan de l'application rapide en mode sombre. Scènes Correction de l'exécution des scènes LUA. Amélioration de l'affichage de l'état des capteurs de CO lors de la sélection des déclencheurs dans les scènes en bloc. Correction de l'erreur de suppression d'une scène qui utilise des variables globales. Correction de la conversion de la valeur de l'heure dans les conditions liées au lever et au coucher du soleil dans les scènes en bloc. Utilisateurs Amélioration de l'affichage des statuts dans la liste des utilisateurs lors de l'invitation d'utilisateurs d'accès à distance. Résolution du problème lié à la suppression des autorisations des utilisateurs pour les salles après la création d'une nouvelle section. Z-Wave Résolution du problème d'affichage incorrect des valeurs des paramètres Z-Wave pour l'unité centrale HC3L. Amélioration de l'affichage du nombre de paramètres en file d'attente pour les dispositifs Z-Wave. Amélioration des actions de réglage de la température pour les thermostats par rapport à la précision supportée par les dispositifs. Amélioration des modèles pour les compteurs Qubino 3-Phase/1-Phase. Amélioration de l'affichage des échelles pour certains terminaux Qubino.** Amélioration de l'affichage de la consommation électrique et de l'énergie pour les appareils Qubino. Correction d'un problème lié à l'ajout de dispositifs Z-wave+ d'ancienne génération**. Correction de l'impossibilité de contrôler certains stores d'autres fabricants. Problèmes connus : Z-Wave Engine 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
  20. HC3 & HCL3 - 5.150.18 - 06/12/2023 Merci d'utiliser notre passerelle ! Veillez à mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations. AVIS IMPORTANT La version 5.150.18 est un correctif pour la version 5.150.15. Elle résout un problème lié aux mises à jour bêta sur la plateforme. Lors de la mise à niveau du système à partir de la version 5.141 Beta, une erreur peut se produire pendant la procédure de sauvegarde. Le système redémarre, mais reste sur l'ancienne version. La solution se trouve ici : HC3 : bit.ly/46w8Awu HC3L : bit.ly/3S6noh1 Yubii Home : bit.ly/406dNbV Caractéristiques principales : 1. Ajout de la prise en charge des modes Auto et Manuel pour les appareils Elero. A partir de maintenant, pour les appareils qui supportent le changement de mode, vous pouvez exclure des appareils spécifiques de l'automatisation (comme les scènes ou les profils) en changeant une seule option dans la barre latérale. 2. Ajout d'un onglet Z-Wave Network Diagnostics. Désormais, pour les deux versions du moteur Z-Wave, le système permet d'analyser le trafic et les problèmes de réseau à des fins de diagnostic. 3. Ajout de la prise en charge des périphériques Nice et Elero dans la connexion Gateway. Dans le cadre de l'extension des capacités du système, la prise en charge des protocoles Nice et Elero a été ajoutée à la fonction Gateway Connection, ce qui améliore la connectivité entre les hubs. 4. Ajout de la prise en charge des périphériques Nice et Elero dans la connexion Gateway. La liste des appareils mobiles a été redessinée dans les paramètres d'accès. L'accès aux zones d'alarme, aux zones climatiques et aux profils nouvellement ajoutés est désormais automatiquement accordé à un nouvel utilisateur si l'option 'tous' est sélectionnée. Les informations relatives à la dernière synchronisation avec le service en nuage sont désormais visibles dans la liste des utilisateurs. De nouvelles commandes de sélection ont été ajoutées pour faciliter l'accès à des appareils, scènes, zones et profils spécifiques. En outre, une méthode rapide et facile pour inviter des utilisateurs dans le système a été introduite. Nouveautés : Sauvegarde Amélioration des performances de la liste de sauvegarde et des demandes d'état. Tableau de bord Ajout de la possibilité pour le compte administrateur de masquer les tuiles "Add Device" et "Add Scene" sur le tableau de bord dans les paramètres généraux du hub. Appareils Le capteur de pluie binaire est maintenant disponible en tant que dispositif optionnel pour l'arroseur afin d'empêcher l'arrosage. Amélioration des visuels d'ajout de dispositif. Ajout de la possibilité de filtrer les notifications du système en fonction des canaux de notification pris en charge. Amélioration de la prise en charge de l'Aeotec Multi-Sensor 6 (reconfiguration logicielle requise). L'onglet de prévisualisation de la caméra n'est disponible que si un dispositif de caméra a été configuré. Amélioration des dispositifs liés aux volets roulants. Amélioration de la navigation pour la création de scènes à partir des paramètres avancés du dispositif. Organisation des rôles pour les stores dans les dispositifs liés. Organisation de la liste des rôles et des catégories pour les dispositifs. Ajout de paramètres d'hystérésis pour le contrôleur d'humidité et les thermostats dans les dispositifs liés. L'intégration des compteurs Qubino 1Phase et 3Phase a été simplifiée pour améliorer la manipulation dans le système. Elero Améliorations pour le réveil des appareils Elero. Énergie Amélioration du menu de sélection pour la configuration des compteurs d'énergie dans les paramètres du panneau d'énergie. Amélioration de la lisibilité des info-bulles pour les tarifs dans le panneau d'énergie. Les mesures de puissance pour les appareils cachés sont maintenant exclues par défaut. FTI Ajout d'une information pendant le FTI si l'utilisateur n'est pas en mesure de changer la version du moteur Z-Wave lorsque certains dispositifs sont déjà ajoutés au système. Ajout de la possibilité de restaurer les sauvegardes de l'utilisateur sauvegardées dans le Cloud pendant le processus FTI. Amélioration de la sélection du moteur Z-Wave pendant le FTI pour les hubs qui ne sont plus connectés à la passerelle Master. Jardin Ajout de la possibilité d'effectuer un test de séquence et de démarrer manuellement l'irrigation à partir du panneau Garden. Nice Amélioration de la gestion des périphériques morts. Ajout de la prise en charge de l'état d'ouverture partielle des portails. Ajout de la prise en charge de la synchronisation des dispositifs fonctionnant sur batterie. Autre Nouveaux visuels des infobulles. Ajout d'une notification pour la restauration automatique du système en cas d'instabilité. Boucle de récupération limitée en cas de défaillance des deux systèmes. Les capteurs cachés peuvent désormais être sélectionnés comme capteurs principaux dans les pièces. Le redémarrage n'est plus nécessaire après la première configuration du système. Améliorations mineures de l'UX et de l'UI. Amélioration de la validation du mot de passe de l'utilisateur. Refonte de l'apparence des fenêtres modales dans l'interface. Augmentation de la limite de caractères pour les variables dans le hub. Optimisation de la base de données. Profils Suppression des actions redondantes pour les stores vénitiens Elero. Applications rapides Amélioration de l'auto-nommage des éléments et étiquettes QuickApp. Ajout de la prise en charge des interrupteurs. Ajout de la prise en charge des listes déroulantes. Changements pour les identifiants de contrôle. Une classe RefreshStateSubscriber a été ajoutée pour gérer les événements système avec des méthodes pour s'abonner, se désabonner et démarrer/arrêter l'écoute des événements, offrant un meilleur contrôle sur les actions basées sur les événements. Scènes Ajout de la prise en charge des modes de thermostat personnalisés dans l'éditeur de scène de bloc. Amélioration de l'option "Vrai pour la durée spécifiée" pour les conditions dans l'éditeur de scène de bloc. Ajout de la possibilité de lancer manuellement des séquences d'arrosage à partir d'une scène. Dans les scènes de blocs, ajout de nouveaux blocs liés au panneau d'énergie : Production actuelle, Consommation actuelle et Solde actuel. Ajout d'une autorisation automatique pour l'API des éléments du système en Lua. Mise à jour Ajout du tri de la liste des mises à jour disponibles pour les appareils. La section de mise à jour du Hub a été déplacée dans Paramètres -> Général. La section de mise à jour des appareils a été déplacée dans Paramètres -> Appareils. Corrections de traductions mineures. Zigbee Ajout d'un nom par défaut pour les appareils nouvellement appariés. Mise à jour de la compatibilité générale avec les appareils du marché. Ajout de la possibilité de forcer la suppression des appareils Zigbee qui ne fonctionnent pas. Ajout de la prise en charge des capteurs de fumée, de pression, de gaz, de composés organiques volatils, de vibration et de présence. Ajout de la prise en charge des paramètres de rôle des appareils. Ajout de la prise en charge des capteurs de température de l'appareil. Z-Wave Améliorations de la stabilité.** Amélioration de la fonction "marquer comme mort".** Ajout du support pour les dispositifs Qubino Flush Shutter DC. Modification de la valeur de l'intervalle de réveil par défaut pour les dispositifs connus d'ancienne génération. Mise à jour du support pour Aeon Multisensor 6. Ajout de la prise en charge des broches pour la serrure Danalock V3. Introduction de correctifs pour la suppression des nœuds Z-Wave endommagés. Ajout d'un support pour les anciennes générations FGFS-101 et FGK-101. Corrections de bugs : Sauvegardes Correction du comportement de la limite de sauvegarde locale. Correction de problèmes occasionnels d'exécution des sauvegardes. Climat Impossible de modifier les programmes climatiques si un thermostat de cette zone est caché. Résolution d'un problème avec la gestion des thermostats depuis le panneau climatique pour les unités Fahrenheit. Tableau de bord Suppression des boutons redondants pour les interrupteurs multiniveaux dans la barre latérale. Légende "Transfert Ok" permanente sur la tuile de l'appareil pour les appareils Elero dans de rares cas. Présentation incorrecte du contrôle de la température de couleur pour les appareils Zigbee. Appareils Correction de la mise à l'échelle des paramètres des appareils Z-Wave après l'action "Réinitialiser tout". Les tuiles cachées pour le dispositif Smart Implant ne restent plus cachées dans certaines situations. Qubino 3-phase meter has redundant tiles presenting voltage per phase (soft-reconfiguration required). Le graphique du point de consigne FGT-001 n'est pas toujours correctement dessiné. Le téléchargement du modèle d'appareil boucle dans certains cas. Correction de la gestion du contrôleur de couleur dans les dispositifs liés. Correction de la prise en charge des dispositifs liés pour les stores. Correction de la liste des entités des dispositifs liés après l'ouverture de l'onglet "Général" dans les paramètres des dispositifs. Elero* Les paramètres d'inversion pour les stores et les pergolas ne fonctionnent pas correctement. Energie Correction des problèmes liés à la génération incorrecte d'un graphique d'économies hebdomadaires. Connexion à la passerelle Problème de configuration du contrôleur Walli à partir de la passerelle esclave. La modification de la description du dispositif ajouté à l'esclave ne fonctionne pas. La configuration de la position favorite pour les appareils à partir de la passerelle esclave ne fonctionne pas. Correction de l'impossibilité de configurer l'association Lifeline pour les appareils à partir du hub esclave dans certains cas. Sympathique Après le redémarrage de la passerelle, le système écrase les paramètres par défaut du capteur BiDi-Multi. Correction de la gestion des paramètres du BiDi-Multisensor. Résolution de problèmes avec les télécommandes Nice ON4E. Bouton d'ouverture partielle manquant pour les portails Nice. Icône d'attente manquante pour les actions en cours lors de la modification des paramètres des dispositifs dormants. Amélioration de la gestion des notifications de batterie faible pour le BiDi-Multisensor. Correction de la gestion du dispositif Nice après la restauration de la sauvegarde. Correction du mécanisme de configuration des paramètres des dispositifs. Autres problèmes Problèmes avec les appareils ajoutés de manière sécurisée avant la migration vers HC3. Résolution des problèmes de croissance excessive de la base de données. Correction de la version linguistique des messages d'état en mode récupération pour certains scénarios. Correction de la validation du nombre de caractères du mot de passe à 10 caractères. L'accès à distance accordé au support a été étendu à 14 jours. Corrections mineures de l'UX et de l'UI. Problème occasionnel avec le contenu de l'interface web qui ne se charge pas. Ecrasement des catégories de pièces à "Autre" pendant l'édition dans la fenêtre modale. Plugins Ajout de la prise en charge du flux RTSP dans l'interface web pour le plugin Dahua. Rapport incorrect de l'état du verrou Tedee lors d'une perte temporaire des services cloud. Correction de la gestion de la rétractation du loquet pour la serrure Tedee. Correction de la génération d'un nouveau code d'autorisation pour la serrure Tedee. Corrections mineures dans la configuration du plugin de la caméra Dahua. Corrections pour le plugin CoolAutomation. Applications rapides Correction de l'affectation des QuickApps aux pièces lors de l'ajout d'une nouvelle intégration depuis le tableau de bord. Correction de la gestion des Fahrenheit pour les QuickApps de type thermostat. Correction de la gestion des caractères spéciaux pour les variables de type secret. Scènes Correction d'un problème avec les scènes lua au démarrage automatique qui ne fonctionnaient pas dans certains scénarios. Correction du contrôle des modes de ventilation dans les thermostats lorsqu'ils sont déclenchés par des scènes en bloc. Complétion des traductions manquantes pour les actions des thermostats dans les scènes en bloc. Correction du renommage des scènes depuis l'éditeur. Correction de la gestion des actions pour les thermostats (annulation temporaire de l'horaire). Mise à jour La cible de l'appareil suivant peut maintenant être mise à jour à partir d'un fichier sans reconfiguration. Correction d'un bug produisant un statut incorrect du premier fichier cible lors d'une mise à jour pour un appareil dormant**. Utilisateurs Correction de l'octroi de permissions pour les pièces vides. Corrections stylistiques pour le thème sombre dans la gestion de l'accès. Zigbee Le réglage de la couleur Philips Hue lorsque l'appareil est éteint ne fonctionne pas. Corrections pour forcer le retrait du périphérique. Amélioration du compteur de périphériques ZigBee dans l'onglet de configuration. Z-Wave Correction de la conversion de la température pour la première lecture en Fahrenheit. Correction de l'affichage de l'heure estimée du prochain réveil du périphérique. Amélioration des performances de communication. Ajout de la prise en charge des nouvelles versions des appareils MCO - MH-S412, MH-DT411. Élimination des problèmes de mise à zéro du temps de réveil pour FGD-002. Problèmes connus : Z-Wave Engine 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave. L'intégration simplifiée des compteurs Qubino 1Phase et 3Phase sera disponible dans la prochaine version du hub. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
  21. Désolé, avec du retard, version française pour les allergiques à l'anglais. Lors de la mise à niveau du système à partir de la version 5.141 Beta, une erreur peut se produire pendant la procédure de sauvegarde. Le système redémarre, mais reste sur l'ancienne version. La solution se trouve ici : HC3 : bit.ly/46w8Awu HC3L : bit.ly/3S6noh1 Yubii Home : bit.ly/406dNbV Caractéristiques principales : 1. Ajout de la prise en charge des modes Auto et Manuel pour les appareils Elero. A partir de maintenant, pour les appareils qui supportent le changement de mode, vous pouvez exclure des appareils spécifiques de l'automatisation (comme les scènes ou les profils) en changeant une seule option dans la barre latérale. 2. Ajout d'un onglet Z-Wave Network Diagnostics. Désormais, pour les deux versions du moteur Z-Wave, le système permet d'analyser le trafic et les problèmes de réseau à des fins de diagnostic. 3. Ajout de la prise en charge des périphériques Nice et Elero dans la connexion Gateway. Dans le cadre de l'extension des capacités du système, la prise en charge des protocoles Nice et Elero a été ajoutée à la fonction Gateway Connection, ce qui améliore la connectivité entre les hubs. 4. Ajout de la prise en charge des périphériques Nice et Elero dans la connexion Gateway. La liste des appareils mobiles a été redessinée dans les paramètres d'accès. L'accès aux zones d'alarme, aux zones climatiques et aux profils nouvellement ajoutés est désormais automatiquement accordé à un nouvel utilisateur si l'option 'tous' est sélectionnée. Les informations relatives à la dernière synchronisation avec le service en nuage sont désormais visibles dans la liste des utilisateurs. De nouvelles commandes de sélection ont été ajoutées pour faciliter l'accès à des appareils, scènes, zones et profils spécifiques. En outre, une méthode rapide et facile pour inviter des utilisateurs dans le système a été introduite. Nouveautés : Sauvegarde Amélioration des performances de la liste de sauvegarde et des demandes d'état. Tableau de bord Ajout de la possibilité pour le compte administrateur de masquer les tuiles "Add Device" et "Add Scene" sur le tableau de bord dans les paramètres généraux du hub. Appareils Le capteur de pluie binaire est maintenant disponible en tant que dispositif optionnel pour l'arroseur afin d'empêcher l'arrosage. Amélioration des visuels d'ajout de dispositif. Ajout de la possibilité de filtrer les notifications du système en fonction des canaux de notification pris en charge. Amélioration de la prise en charge de l'Aeotec Multi-Sensor 6 (reconfiguration logicielle requise). L'onglet de prévisualisation de la caméra n'est disponible que si un dispositif de caméra a été configuré. Amélioration des dispositifs liés aux volets roulants. Amélioration de la navigation pour la création de scènes à partir des paramètres avancés du dispositif. Organisation des rôles pour les stores dans les dispositifs liés. Organisation de la liste des rôles et des catégories pour les dispositifs. Ajout de paramètres d'hystérésis pour le contrôleur d'humidité et les thermostats dans les dispositifs liés. L'intégration des compteurs Qubino 1Phase et 3Phase a été simplifiée pour améliorer la manipulation dans le système. Elero Améliorations pour le réveil des appareils Elero. Énergie Amélioration du menu de sélection pour la configuration des compteurs d'énergie dans les paramètres du panneau d'énergie. Amélioration de la lisibilité des info-bulles pour les tarifs dans le panneau d'énergie. Les mesures de puissance pour les appareils cachés sont maintenant exclues par défaut. FTI Ajout d'une information pendant le FTI si l'utilisateur n'est pas en mesure de changer la version du moteur Z-Wave lorsque certains dispositifs sont déjà ajoutés au système. Ajout de la possibilité de restaurer les sauvegardes de l'utilisateur sauvegardées dans le Cloud pendant le processus FTI. Amélioration de la sélection du moteur Z-Wave pendant le FTI pour les hubs qui ne sont plus connectés à la passerelle Master. Jardin Ajout de la possibilité d'effectuer un test de séquence et de démarrer manuellement l'irrigation à partir du panneau Garden. Nice Amélioration de la gestion des périphériques morts. Ajout de la prise en charge de l'état d'ouverture partielle des portails. Ajout de la prise en charge de la synchronisation des dispositifs fonctionnant sur batterie. Autre Nouveaux visuels des infobulles. Ajout d'une notification pour la restauration automatique du système en cas d'instabilité. Boucle de récupération limitée en cas de défaillance des deux systèmes. Les capteurs cachés peuvent désormais être sélectionnés comme capteurs principaux dans les pièces. Le redémarrage n'est plus nécessaire après la première configuration du système. Améliorations mineures de l'UX et de l'UI. Amélioration de la validation du mot de passe de l'utilisateur. Refonte de l'apparence des fenêtres modales dans l'interface. Augmentation de la limite de caractères pour les variables dans le hub. Optimisation de la base de données. Profils Suppression des actions redondantes pour les stores vénitiens Elero. Applications rapides Amélioration de l'auto-nommage des éléments et étiquettes QuickApp. Ajout de la prise en charge des interrupteurs. Ajout de la prise en charge des listes déroulantes. Changements pour les identifiants de contrôle. Une classe RefreshStateSubscriber a été ajoutée pour gérer les événements système avec des méthodes pour s'abonner, se désabonner et démarrer/arrêter l'écoute des événements, offrant un meilleur contrôle sur les actions basées sur les événements. Scènes Ajout de la prise en charge des modes de thermostat personnalisés dans l'éditeur de scène de bloc. Amélioration de l'option "Vrai pour la durée spécifiée" pour les conditions dans l'éditeur de scène de bloc. Ajout de la possibilité de lancer manuellement des séquences d'arrosage à partir d'une scène. Dans les scènes de blocs, ajout de nouveaux blocs liés au panneau d'énergie : Production actuelle, Consommation actuelle et Solde actuel. Ajout d'une autorisation automatique pour l'API des éléments du système en Lua. Mise à jour Ajout du tri de la liste des mises à jour disponibles pour les appareils. La section de mise à jour du Hub a été déplacée dans Paramètres -> Général. La section de mise à jour des appareils a été déplacée dans Paramètres -> Appareils. Corrections de traductions mineures. Zigbee Ajout d'un nom par défaut pour les appareils nouvellement appariés. Mise à jour de la compatibilité générale avec les appareils du marché. Ajout de la possibilité de forcer la suppression des appareils Zigbee qui ne fonctionnent pas. Ajout de la prise en charge des capteurs de fumée, de pression, de gaz, de composés organiques volatils, de vibration et de présence. Ajout de la prise en charge des paramètres de rôle des appareils. Ajout de la prise en charge des capteurs de température de l'appareil. Z-Wave Améliorations de la stabilité.** Amélioration de la fonction "marquer comme mort".** Ajout du support pour les dispositifs Qubino Flush Shutter DC. Modification de la valeur de l'intervalle de réveil par défaut pour les dispositifs connus d'ancienne génération. Mise à jour du support pour Aeon Multisensor 6. Ajout de la prise en charge des broches pour la serrure Danalock V3. Introduction de correctifs pour la suppression des nœuds Z-Wave endommagés. Ajout d'un support pour les anciennes générations FGFS-101 et FGK-101. Corrections de bugs : Sauvegardes Correction du comportement de la limite de sauvegarde locale. Correction de problèmes occasionnels d'exécution des sauvegardes. Climat Impossible de modifier les programmes climatiques si un thermostat de cette zone est caché. Résolution d'un problème avec la gestion des thermostats depuis le panneau climatique pour les unités Fahrenheit. Tableau de bord Suppression des boutons redondants pour les interrupteurs multiniveaux dans la barre latérale. Légende "Transfert Ok" permanente sur la tuile de l'appareil pour les appareils Elero dans de rares cas. Présentation incorrecte du contrôle de la température de couleur pour les appareils Zigbee. Appareils Correction de la mise à l'échelle des paramètres des appareils Z-Wave après l'action "Réinitialiser tout". Les tuiles cachées pour le dispositif Smart Implant ne restent plus cachées dans certaines situations. Qubino 3-phase meter has redundant tiles presenting voltage per phase (soft-reconfiguration required). Le graphique du point de consigne FGT-001 n'est pas toujours correctement dessiné. Le téléchargement du modèle d'appareil boucle dans certains cas. Correction de la gestion du contrôleur de couleur dans les dispositifs liés. Correction de la prise en charge des dispositifs liés pour les stores. Correction de la liste des entités des dispositifs liés après l'ouverture de l'onglet "Général" dans les paramètres des dispositifs. Elero* Les paramètres d'inversion pour les stores et les pergolas ne fonctionnent pas correctement. Energie Correction des problèmes liés à la génération incorrecte d'un graphique d'économies hebdomadaires. Connexion à la passerelle Problème de configuration du contrôleur Walli à partir de la passerelle esclave. La modification de la description du dispositif ajouté à l'esclave ne fonctionne pas. La configuration de la position favorite pour les appareils à partir de la passerelle esclave ne fonctionne pas. Correction de l'impossibilité de configurer l'association Lifeline pour les appareils à partir du hub esclave dans certains cas. Sympathique Après le redémarrage de la passerelle, le système écrase les paramètres par défaut du capteur BiDi-Multi. Correction de la gestion des paramètres du BiDi-Multisensor. Résolution de problèmes avec les télécommandes Nice ON4E. Bouton d'ouverture partielle manquant pour les portails Nice. Icône d'attente manquante pour les actions en cours lors de la modification des paramètres pour les dispositifs endormis. Amélioration de la gestion des notifications de batterie faible pour le BiDi-Multisensor. Correction de la gestion du dispositif Nice après la restauration de la sauvegarde. Correction du mécanisme de configuration des paramètres des dispositifs. Autres problèmes Problèmes avec les appareils ajoutés de manière sécurisée avant la migration vers HC3. Correction des problèmes de croissance excessive de la base de données. Correction de la version linguistique des messages d'état en mode récupération pour certains scénarios. Correction de la validation du nombre de caractères du mot de passe à 10 caractères. L'accès à distance accordé au support a été étendu à 14 jours. Corrections mineures de l'UX et de l'UI. Problème occasionnel avec le contenu de l'interface web qui ne se charge pas. Ecrasement des catégories de pièces à "Autre" pendant l'édition dans la fenêtre modale. Plugins Ajout de la prise en charge du flux RTSP dans l'interface web pour le plugin Dahua. Rapport incorrect de l'état du verrou Tedee lors d'une perte temporaire des services cloud. Correction de la gestion de la rétractation du loquet pour la serrure Tedee. Correction de la génération d'un nouveau code d'autorisation pour la serrure Tedee. Corrections mineures dans la configuration du plugin de la caméra Dahua. Corrections pour le plugin CoolAutomation. Applications rapides Correction de l'affectation des QuickApps aux pièces lors de l'ajout d'une nouvelle intégration depuis le tableau de bord. Correction de la gestion des Fahrenheit pour les QuickApps de type thermostat. Correction de la gestion des caractères spéciaux pour les variables de type secret. Scènes Correction d'un problème avec les scènes lua au démarrage automatique qui ne fonctionnaient pas dans certains scénarios. Correction du contrôle des modes de ventilation dans les thermostats lorsqu'ils sont déclenchés par des scènes en bloc. Complétion des traductions manquantes pour les actions des thermostats dans les scènes en bloc. Correction du renommage des scènes depuis l'éditeur. Correction de la gestion des actions pour les thermostats (annulation temporaire de l'horaire). Mise à jour La cible de l'appareil suivant peut maintenant être mise à jour à partir d'un fichier sans reconfiguration. Correction d'un bug produisant un statut incorrect du premier fichier cible lors d'une mise à jour pour un appareil dormant**. Utilisateurs Correction de l'octroi de permissions pour les pièces vides. Corrections stylistiques pour le thème sombre dans la gestion de l'accès. Zigbee Le réglage de la couleur Philips Hue lorsque l'appareil est éteint ne fonctionne pas. Corrections pour forcer le retrait du périphérique. Amélioration du compteur de périphériques ZigBee dans l'onglet de configuration. Z-Wave Correction de la conversion de la température pour la première lecture en Fahrenheit. Correction de l'affichage de l'heure estimée du prochain réveil du périphérique. Amélioration des performances de communication. Ajout de la prise en charge des nouvelles versions des appareils MCO - MH-S412, MH-DT411. Élimination des problèmes de mise à zéro du temps de réveil pour FGD-002. Problèmes connus : Z-Wave Engine 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave. L'intégration simplifiée des compteurs Qubino 1Phase et 3Phase sera disponible dans la prochaine version du hub. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
  22. Moi, mis à jour effectuée hier soir, la CPU est revenue normale :=). Avec la dernière beta, j'étais passé de 3% à 10%, maintenant retour à 3%. Autrement, après 12h RAS
  23. Merci @Lazer La même chose en français Merci d'utiliser notre passerelle ! Veillez à mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations. Principales caractéristiques : 1. Ajout de la prise en charge des modes Auto et Manuel pour les appareils Elero. A partir de maintenant, pour les appareils qui supportent le changement de mode, vous pouvez exclure des appareils spécifiques de l'automatisation (comme les scènes ou les profils) en changeant une seule option dans la barre latérale. 2. Ajout d'un onglet Z-Wave Network Diagnostics. Désormais, pour les deux versions du moteur Z-Wave, le système permet d'analyser le trafic et les problèmes de réseau à des fins de diagnostic. 3. Ajout de la prise en charge des périphériques Nice et Elero dans la connexion Gateway. Dans le cadre de l'extension des capacités du système, la prise en charge des protocoles Nice et Elero a été ajoutée à la fonction Gateway Connection, améliorant ainsi la connectivité entre les hubs. Les nouveautés : Mise à jour Corrections de traductions mineures. Tableau de bord Ajout de la possibilité pour le compte administrateur de cacher les tuiles "Add Device" et "Add Scene" sur le tableau de bord dans les paramètres généraux du hub. FTI Ajout de la possibilité de restaurer les sauvegardes de l'utilisateur sauvegardées dans le Cloud pendant le processus FTI. Amélioration de la sélection du moteur Z-Wave pendant le FTI pour les hubs qui ne sont plus connectés à la passerelle maître. Jardin Ajout de la possibilité d'effectuer un test de séquence et de démarrer manuellement l'irrigation à partir du panneau Garden. Elero Améliorations pour le réveil des appareils Elero. Energie Amélioration de la lisibilité de l'infobulle pour les tarifs dans le panneau Energie. Les mesures de puissance pour les appareils cachés sont maintenant exclues par défaut. Sympathique Amélioration de la gestion des appareils morts. Ajout de la prise en charge de l'état d'ouverture partielle des portails. Ajout de la prise en charge de la synchronisation des appareils fonctionnant sur batterie. Utilisateurs Amélioration de la gestion des utilisateurs - simplification du partage de l'accès à distance. Autres Amélioration de la validation du mot de passe de l'utilisateur. Refonte de l'apparence des fenêtres modales dans l'interface. Augmentation de la limite de caractères pour les variables dans le hub. Optimisation de la base de données. Applications rapides Ajout de la prise en charge des commutateurs. Ajout de la prise en charge des listes déroulantes. Changements pour les identifiants de contrôle. Scènes Ajout de la possibilité de démarrer manuellement des séquences d'arrosage à partir d'une scène. Dans les scènes de blocs, ajout de nouveaux blocs liés au panneau d'énergie : Production actuelle, Consommation actuelle et Solde actuel. Ajout d'une autorisation automatique pour l'API des éléments du système en Lua. Appareils Organisation des rôles pour les stores dans les dispositifs liés. Organisation de la liste des rôles et des catégories pour les appareils. Ajout de paramètres d'hystérésis pour le contrôleur d'humidité et les thermostats dans les dispositifs liés. Zigbee Ajout de la prise en charge des capteurs de fumée, de pression, de gaz, de composés organiques volatils, de vibration et de présence. Ajout de la prise en charge des paramètres de rôle des appareils. Ajout de la prise en charge des capteurs de température de l'appareil. Z-Wave Ajout de la prise en charge des dispositifs Qubino Flush Shutter DC. Modification de la valeur de l'intervalle de réveil par défaut pour les dispositifs connus d'ancienne génération. Mise à jour du support pour Aeon Multisensor 6. Ajout de la prise en charge des broches pour la serrure Danalock V3. Introduction de correctifs pour la suppression des nœuds Z-Wave endommagés. Ajout d'un support pour les anciennes générations FGFS-101 et FGK-101. Corrections de bugs : Climat Résolution d'un problème avec la gestion des thermostats à partir du panneau climatique pour les unités Fahrenheit. Connexion à la passerelle Correction de l'impossibilité de configurer l'association Lifeline pour les appareils du hub esclave dans certains cas. Sauvegardes Correction du comportement de la limite de sauvegarde locale. Correction des problèmes occasionnels d'exécution des sauvegardes. Nice Correction de la gestion des paramètres du BiDi-Multisensor. Résolution de problèmes avec les télécommandes Nice ON4E. Bouton d'ouverture partielle manquant pour les portails Nice. Icône d'attente manquante pour les actions en cours lors de la modification des paramètres pour les dispositifs dormants. Amélioration de la gestion des notifications de batterie faible pour le BiDi-Multisensor. Correction de la gestion du dispositif Nice après la restauration de la sauvegarde. Correction du mécanisme de configuration des paramètres des dispositifs. Utilisateurs Correction de l'octroi de permissions pour les pièces vides. Corrections stylistiques pour le thème sombre dans la gestion des accès. Plugins Rapport incorrect de l'état de la serrure Tedee lors de la perte temporaire des services cloud. Correction de la gestion de la rétractation du loquet pour la serrure Tedee. Correction de la génération d'un nouveau code d'autorisation pour la serrure Tedee. Corrections mineures dans la configuration du plugin de la caméra Dahua. Corrections pour le plugin CoolAutomation. Autre Problème occasionnel avec le contenu de l'interface web qui ne se charge pas. Remplacement des catégories de pièces par "Autres" lors de l'édition dans la fenêtre modale. Corrections mineures de l'interface utilisateur pour les onglets Appareils et Réseau. Applications rapides Correction de l'affectation des QuickApps aux pièces lors de l'ajout d'une nouvelle intégration depuis le tableau de bord. Correction de la gestion des Fahrenheit pour les QuickApps de type thermostat. Correction de la gestion des caractères spéciaux pour les variables de type secret. Scènes Complété les traductions manquantes pour les actions de thermostat dans les scènes de bloc. Correction du renommage des scènes depuis l'éditeur. Correction de la gestion des actions pour les thermostats (annulation temporaire de l'horaire). Appareils Correction de la gestion des contrôleurs de couleur dans les dispositifs liés. Correction de la prise en charge des stores dans les dispositifs liés. Correction de la liste des entités des dispositifs liés après l'ouverture de l'onglet "Général" dans les paramètres des dispositifs. Zigbee Corrections pour forcer la suppression d'un périphérique. Amélioration du compteur de périphériques ZigBee dans l'onglet de configuration. Z-Wave Correction de la conversion de la température pour la première lecture en Fahrenheit. Correction de l'affichage de l'heure estimée de réveil du prochain périphérique. Amélioration des performances de communication. Ajout de la prise en charge des nouvelles versions des appareils MCO - MH-S412, MH-DT411. Élimination des problèmes de mise à zéro du temps de réveil pour le FGD-002. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
  24. bonsoir, Je suis interessé par cette article, mais une question : peux tu différencier la touche déverrouillage et celle de verrouillage ? ou cela se limite t'il au code rentré ? Merci d'avance
  25. Merci à toi @chrisalex Je vais essayer cela ce soir, une sauvegarde de plus, cela est toujours sécurisant.
