jjacques68
4 346 -
39
j'étais en 4.504, la dernière, enfin l'avant dernière maintenant...
Après un reboot forcé, ça semble ok.
Bloquer sur "start services"... comme d'hab... j'attends encore un peu...
En cours...
Version 4.510 This update introduces new and optimized operating system, modified file structure and the following brand new features: - Update package downloaded in the background, without locking the interface. - Creating encrypted local backup that can be downloaded to your hard drive and later restored. - Creating encrypted backups, stored in Fibaro cloud that can be later restored. - Customized icons included to backup. - Restoring backup with full rollback (restores also software version) or with current software version (up from 4.503). Backups created so far become incompatible. - System configuration transfer between gateways linked to the same Fibaro ID account via id.cloud.fibaro.com. Changes related to GDPR: - Displaying the number of remaining attempts to log in. - Blocking the possiblity to log in for 30 minutes after 5 unsuccessful attempts from a given IP address. - Displaying the value of time remaining to unlock the ability to log in. - E-mail notification sent to admin after 5 unsuccessful attempts to log in. - E-mail message sent every 90 days that recommends changing your password. Other improvements: - New, more reliable file structure. - No need to use the recovery pendrive. - Optimized software update process minimizing the risk of potential errors during system update. - Easier and more intuitive setting of advanced parameters. - New user interface of recovery system. - Information about scenes used by a given device available in its configuration. - Notification after successful update recommending to create a backup if there is no compatible backup. - Possibility to disable creating auto-backup in Fibaro cloud before performing update. - Indication of exceeding 90% of cloud backup storage. - Compatibility with cameras connecting through https protocol. - Caching icons in the browser cache for faster loading. - Adjustable brightness of device LEDs in Configuration - General. - Added new plugins: Samsung Smart Appliances, Philips TV, Cool Master, Power View (Hunter Douglas), Initial State. - Added support for FIBARO Wall Plug UK - type G. - Added Kuwait time zone. Resolved issues: - Losing the synchronization of the set time. - No variables list while creating a virtual device. - No icon change lock via the remote access. - Switching a number of grouped devices results in 503 error. - Non-admin users cannot modify their own e-mail address and password. - Number of devices counted in a particular backup contains all endpoints, active plugins and users instead of devices only. - Notification suggesting replacing the battery of FIBARO The Heat Controller instead of charging. - Scene based on time condition results in 'timer handler failed with error' message. - No possibility to set time manually. - No power consumption bars in 'Top 5' section. - No content for notification recommending to create a backup. - Error while changing configuration from DHCP to Static IP. - No possibility to disable the remote access in LAN configuration. - LEDs do not indicate the available update. - System hangs on starting services after update or backup procedure. - Notification about disabled remote support does not link to LAN configuration. - Possibility to disable scene by the user with no sufficient rights. - Incorrect Z-Wave region set in some cases after performing update for chip versions other than EU. - Unable to activate remote support. - 'Invalid access token' error while trying to connect with Samsung Smart Appliances plugin. - Unable to add device with Philips TV plugin. - Onkyo plugin uses a lot of resources. - Other minor fixes.
[Résolu] Scènes allumage spots qui ne marche pas
jjacques68 a répondu à un(e) sujet de atalec dans HCL
justement... dans l'onglet général du device, tu vois l’arborescence maitre/esclave ! Il faudrait que tu vérifie l'ID du module que tu actionnes, pas sûr que ce soit le 7.0... peut être c'est le 7.2 ou 1 ! et quand tu dis "fgr-222" c'est pas plutôt FGS-222 ? car le FGR c'est pour les volets. -
Etrange, je viens de tester chez moi et ça marche bien... Tu es sûr que tu actionnes le bon module ? -
Pour le parafoudre de ligne téléphonique, j’ai mis le 412200 de chez legrand. https://www.manomano.fr/parafoudre-pour-tableau-electrique-2123?model_id=529685&referer_id=537135&ach=74005&achsqrt=2d3a4&gclid=EAIaIQobChMIhKCe7M7I3AIVx_ZRCh0rygfEEAQYAiABEgLbB_D_BwE Installer avant la box ADLS. Il me parait un peu light comme appareil, en espérant q’il fasse le job le jour où.
YES merci @Titof_44 !! Cet exemple m'a permis d'y arriver. pour le reboot ET pour le shutdown... Voici le code pour ceux que ça intéresse... local HC2 = Net.FHttp("127.0.0.1", 80) local User = "adresse_mail_complète_ENCODEE" -- @ = %40 local Pass = "mot_de_passe_ENCODE" HC2:setBasicAuthentication(User, Pass) --pour le reboot local response,status,errorCode = HC2:GET('/services/system/reboot.php') --pour le shutdown local response,status,errorCode = HC2:GET('/services/system/shutdown.php') En espérant qu'ils ne changent pas à chaque mise à jour leur API...
faut que je trouve une solution, parce qu’il faut que je puisse l’etiendre depuis une scène où un VD...
Dans une scène, j'ai essayé ça : au moins pour tester le reboot ! local http = net.HTTPClient() http:request("http://Mon_Adresse%40Mon_FAI%3AMon_Mdp@192.168.xx.yy/services/system/reboot.php", { options = {method = 'GET'}, success = function(response) print("OK") end, error = function(response) print("Error : " ..response) end }) Marche pas... ai essayé avec la méthode POST ou PUT mais rien non plus. Il me répond "OK"...
J'ai trouvé ça mais aucune réaction : HomeCenter.SystemService.shutdown()
nan mais attend ! J'avais un super script couplé avec l'onduleur pour éteindre proprement la HC2 si coupure de courant, et là on peut plus le faire ?
oui mais je veux pas faire un reboot !!! je veux l'éteindre !!!
je viens d'essayer : local response, status, errorCode = HC2:GET("/services/system/shutdown.php") mais sans resultats...
Bonjour tout le monde ! La fonction : local response, status, errorCode = HC2:GET("/shutdown.php") ne fonctionne plus ? Je l'ai testé il y a encore quelques semaine (4 ou 5), avant les dernières mises à jour, et c'était ok !!! Qqun a une idée ?
ah ! elle semble être à nouveau dispo... je regarde demain...
oui je confirme elle n'est plus dispo...
oui voilà, c'était ma question...
ok d'accord... - merci !
@jojo, très juste, mais cela prouve aussi qqch, les scripts sont pas toujours bien optimisés... du moins les miens...
nan chez moi la ram semble OK, moyenne a 35 %. Je viens de me rendre compte qu’une scène avec dans l’entête %%killOtherInstances faisait monter la charge CPU !!! (qui était appelée par moment avec des répétitions très très soutenues) Je viens de remettre le bon vieux if fibaro:countScenes() > 1 then fibaro:abort() et depuis j’ai l’impression que ça va mieux. à suivre...
alors moi je viens de la faire... etrange... bloquée sur start service, comme ont n’a pu l’entendre sur le topic. je l’ai éteinte puis rallumer. Au redémarrage, tous les volets se sont fermés et les lumières allumées. son réglage de l’heure était au 01/01/2010 à 01:00 ! j’ai modifié en sélectionnant mise à jour de l’heure par le net. Elle a redémarré et puis ça semble ok. j’avais jamais eut de problème jusqu’à cette mise à jour... je viens de faire un backup local. Suis entrain d’en faire un sur le cloud. Après je récupère la sauvegarde local, dans un rep de mon NAS.. a suivre...
