Shyrka973
758 -
5
Mais ceux qui sont en 3.601 ne peuvent toujours pas passer en V4 Un problème de conversion de DB entre la V3 et V4. Cette mise à jour n'est proposée que pour ceux qui sont déjà en V4.
4.053 > New Features: - Fibaro Dimmer 2 support - Multichannel Associations support - to use that feature re-inclusion or soft reconfiguration is required - Notification Center in web interface - basic set of notifications is currently available, this feature will be developed - It is possible to choose whether the device should be added in secure mode - for devices other than doorlocks, sirens, roller blinds it is strongly advised to use non secure mode due to Z-Wave protocol performance - Secure update availability check via https - It is possible to interrupt the process of device reconfiguration - Reworded notification messages > New Plugins: - Planika - Bio Fireplace - New video cameras support (check on plugin list) > Resolved Issues: #0003316 Z-Wave communication breakdown after sending an empty argument #0002493 FortrezZ SSA2 siren no template #0002622 Home Center 2 is not supporting multichannel associations #0002706 Cant set parameters on Fibaro Sensor (FGMS) #0001705 POP_123665 Z-Wave UK Plug-in Switch plus Power Meter does not display measured power #0002052 MCOHOME touch panel switch #0002227 Association to Vitrum's slave button is not working #0002276 FGS-221 + WCD2 – cannot associate the second channel #0001771 Metering Report #0002432 unable to change any parameters on Home Energy Meter DSB28-ZWEU E2 #0003345 Display truncated in 4.048 Satel alarm disarming > Other changes: - Z-Wave Stability Improvements - Z-Wave Network Reconfiguration Improvement - Many other system improvements > Known issues: - Using multichannel associations requires soft reconfiguration of devices - Android version of the Fibaro mobile app does not display icons for following devices properly: - NetAtmo Thermostat - NetAtmo Weather Station - Sonos - Inconsistencies in Satel interface. - Power Metering may not work properly for some devices - Alarm Panel doesn't work in some specific configurations - Plugins for TV Sets of various manufacturers may not work with its newer firmware due to restrictions provided by new devices firmware. There will be added detailed information about supported firmware versions within plugins. - Breached sensor with Arm Delay causes instant alarm after being armed - Data range selection in event panel doesn't work properly - Devices imported via Gateway Connection may have no icons - Gateway Connection status of dead device between master and slave controller may be different - Devices not properly configured on 3.X may not be converted properly - On mobile clients devices may be visible in different categories than configured - Horstmann Thermostat HRT4-ZW higher battery usage in some cases - Doorlocks some functions may not work properly IMPORTANT! After performing upgrade please re-save your time settings in Configuration -> Location page, since in some cases inappropriate time might be set.
Plugin Developer Intégration Bticino Myhome
Shyrka973 a répondu à un(e) sujet de PatrickVH dans Plugins Developpeur
Salut, Essaies de passer "Net.FTcpSocket" comme cela: local ip = "192.168.1.40" local port = 20000 function GetTcp(cmd) -- construct the sting to send local stringtosend = cmd .. string.char(10) --open the socket local tcpSocket = Net.FTcpSocket(ip, port) --set the read timeout tcpSocket:setReadTimeout(2*1000) --send the command local bytes, errorCode = tcpSocket:write(stringtosend) -- Transforme "result" en chaine de caractere return tcpSocket:read() or string.char() end local res = GetTcp("*1*33##") if res == "*1*1*33#" then fibaro:debug("Ok") else fibaro:debug("Error: " .. res) end -
Parametre 19: On peut fixer une valeur au dimmer par défaut pour sa prochain "utilisation". Actuellement, si je veux qu'à la prochaine utilisation du dimmer, il s'allume à 40%, je dois fixer la valeur à 40% qui a pour conséquence d'allumer la lampe. Puis j'attends 2s et j'éteins.
Si, le 650 et 660 sont bien disponibles mais neuf, pas en reconditionné. Avec le Thinking Cleaner, ton phone devient une télécommande pour l'aspi.
Merci à pepite et Moicphil pour cette idée d'achat. Je viens de commander le mien: Roomba 631 re-conditionné sur Robot-Advance.com. C'est un autre site du même groupe que Robopolis.com mais qui livre dans les DOM. Cela fait quelques mois que mon robot aspirateur Homday a rendu l'âme. Quand on y a pris goà»t, il est difficile de s'en passer.
Sur deux de mes trois ZXT-120, je peux avoir une remonté de la température régulière en forçant le polling mais cela ne dure pas longtemps. Sur le dernier inclu, je n'ai pas accès au polling. Un peu plus loin dans ce sujet, il y a un VD avec les commandes pour allumer et éteindre la clim.
Bonjour à tous, En attendant que Fibaro intègre IFTTT directement dans leur box, il y a: Maker Channel. Je vais tester de ce pas.
- 2
Si Qlima est bien la marque du climatiseur, il n'y a pas de code prédéfini pour cette marque mais le ZXT a un mode apprentissage et donc peut apprendre les codes àenvoyer.
@Moicphil Tu l'as commandé où ? Merci.
Salut, Il faut décocher "Utiliser le modèle pour les paramètres" dans "Avancé".
Compatible V3-V4-Lite Greenwave - Multiprise Powernode 6
Shyrka973 a répondu à un(e) sujet de Shyrka973 dans GreenWave
Je veux dire "Configuration douce du dispositif". -
As-tu essayé de faire un "Soft reconfigure" de la multiprise dont le numéro est 25.25 ? -
Salut, Qu'as tu comme version ? La mienne est la 4.20. J'ai aussi une 7ème prise (1ère dans la liste) mais qui elle commande que la première prise. Je pense que ce 2ème bouton permet le réamorcer le disjoncteur interne en cas de dépassement de la charge. -
Un post d'un admin Fibaro sur leur forum: That is not entirely true, Z-wave Plus can be implemented on older chips, it is mandatory for gen5 chip but optional for gen3. So no hardware update needed for that Je suis assez surpris
Je pense que c'est une scène avec l'option %autostart. Ce qui veut dire qu'au démarrage de la box, cette scène est lancée. Le but de cette scène étant de rebooter la box, on tourne en rond. Pour palier à ce type de problème, il faudrait un mode "démarrage sans échec" où toutes les scènes sont désactivées.
Bonjour à tous, Si je resume bien, si tout va bien en v4.042, il n'est pas nécessaire de passer à cette version. Il y a le template pour le ZXT-120, mais pas d'une grande utilité pour moi: mes ZXT commandent déjà mes clims sans problème. Le nouveau mode de notification fonctionne aussi sur la v4.042. Je vais pouvoir l'adopter dans quelques scènes. A-t-on toujours le problème des scènes déclenchées par les détecteurs de fumée et les détecteurs d'inondation lors d'un reboot de la box ? Merci.
Salut taieb, Voici mes commandes LUA pour: - On à 25°C fibaro:call(id["CLIM_PAPA_THER"], "setTargetLevel", 25) fibaro:call(id["CLIM_PAPA_THER"], "setMode", id["CLIM_MODE_CLIM"]) -Off fibaro:call(id["CLIM_PAPA_THER"], "setMode", id["CLIM_MODE_OFF"]) Les valeurs pour "setMode": local id = { CLIM_MODE_OFF = 0, CLIM_MODE_HEAT = 1, CLIM_MODE_CLIM = 2, CLIM_MODE_AUTO = 3, } Si tu trouves d'autres commandes LUA qui fonctionne, partages les.
Le post contenant cette capture d'écran date de février 2013. Les plugins n'existaient pas à cette époque. Si tu regardes bien la capture d'écran, il manque un bouton en forme de croix juste avant le clé à molette. J'en déduis que l'affiche des VD n'était comme actuellement: maintenant pour afficher l'interface d'un VD, il faut cliquer sur le bouton en forme de croix, et avant, tous les boutons était accessible directement. J'espère que tu me comprendras
Bizarre. Je ne vois pas comment faire ce type de VD car on n'a pas vraiment le choix pour le placement des boutons. Est-ce des plugins officiels ou utilisateurs ? Où as-tu pris cette capture d'écran ?
J'ai utilisé ma Zipabox pour paramétrer mes ZXT-120. Après je les ai exclus puis inclus dans la HC2. Je n'ai pas eu donc besoin d'utiliser le paramètre 27 sur la HC2 car ce paramètre a déjàété enregistré par la Zipabox.
Salut taieb, Comme certains codes sont plus grand que 255, le paramètre 27 devrait au moins 2d. 1d: un octet de 0 à 255 2d: deux octets de 0 à 65535
Bonjour, Selon cet article (fin chapitre 3) sur le Blog de Domadoo, il existe aussi un autre paramètre que le paramètre 1: Delta de puissance pour transmission de l’information de consommation : Paramètre 0 , taille 1, valeur 1 à 64 (1 à 100%). Vous étiez au courant ? -
@Lazer Le bug ouvert est le 3276, non pas le 2866.
