14 705 -
155
Bah Lazer il met de toute façon toujours sa tenue de cosmonaute
Alors j'ai : Pluie 1 heure : { "id": 363, "name": "Pluie 1h", "roomID": 22, "type": "com.fibaro.multilevelSensor", "baseType": "com.fibaro.sensor", "enabled": true, "visible": true, "isPlugin": true, "parentId": 362, "remoteGatewayId": 0, "interfaces": [], "properties": { "dead": false, "deviceControlType": 0, "deviceIcon": 1006, "emailNotificationID": 0, "emailNotificationType": 0, "liliOffCommand": "", "liliOnCommand": "", "log": "", "logTemp": "", "manufacturer": "Oregon", "model": "Pluie 1h", "pushNotificationID": 0, "pushNotificationType": 0, "remoteGatewayId": 0, "saveLogs": true, "smsNotificationID": 0, "smsNotificationType": 0, "unit": "mm", "userDescription": "", "value": 0 }, "actions": {}, "created": 1443209625, "modified": 1443209625, "sortOrder": 225 } Pluie total (Inutile je pense) : { "id": 361, "name": "Pluie totale", "roomID": 22, "type": "com.fibaro.multilevelSensor", "baseType": "com.fibaro.sensor", "enabled": true, "visible": true, "isPlugin": true, "parentId": 360, "remoteGatewayId": 0, "interfaces": [], "properties": { "dead": false, "deviceControlType": 0, "deviceIcon": 1005, "emailNotificationID": 0, "emailNotificationType": 0, "liliOffCommand": "", "liliOnCommand": "", "log": "", "logTemp": "", "manufacturer": "Oregon", "model": "Pluie totale", "pushNotificationID": 0, "pushNotificationType": 0, "remoteGatewayId": 0, "saveLogs": true, "smsNotificationID": 0, "smsNotificationType": 0, "unit": "mm", "userDescription": "", "value": 515 }, "actions": {}, "created": 1443209506, "modified": 1443209506, "sortOrder": 223 } Vent : { "id": 365, "name": "Vent", "roomID": 22, "type": "com.fibaro.multilevelSensor", "baseType": "com.fibaro.sensor", "enabled": true, "visible": true, "isPlugin": true, "parentId": 364, "remoteGatewayId": 0, "interfaces": [], "properties": { "dead": false, "deviceControlType": 0, "deviceIcon": 1007, "emailNotificationID": 0, "emailNotificationType": 0, "liliOffCommand": "", "liliOnCommand": "", "log": "", "logTemp": "", "manufacturer": "Oregon", "model": "Vent", "pushNotificationID": 0, "pushNotificationType": 0, "remoteGatewayId": 0, "saveLogs": true, "smsNotificationID": 0, "smsNotificationType": 0, "unit": "km/h", "userDescription": "", "value": 3.96 }, "actions": {}, "created": 1443209676, "modified": 1443209676, "sortOrder": 227 }
- 1 285 réponses
- tuto multimã©dia
- graphiques
Installé en mode mise àjour, nickel, excellent boulot !! Juste un petit point : J'ai mes Virtual Sensor de chez Krikri qui remonte dans la HC2, avec vent, pluie etc. Mais je ne les ai pas la dedans. Une idée du pourquoi ? Krikri n'utiliserai pas les bons types ? De mémoire on avait vu avec lui, et il utilisait les standards Fibaro.
- 1 285 réponses
- tuto multimã©dia
- graphiques
EDIT : En fait c'est pire que ça, cela plante presque le NAS : Les ressources du NAS passent à100% ou presque quand on clique dessus... Pourtant je n'ai mis que 25 titres environ.
Bon test fait, j'ai un souci avec la playlist : Il faut bien mettre le nom de la playlist directement dans le bouton après le "_" ? J'ai fais ça, et rien ne se passe quand on clique sur le bouton. fibaro:setGlobal('DSAudio_Control', 'playlist_Liste_SDB_Nico')
Bon c'est passé nickel, et l'astuce pour les plugins persos passent bien.
Si, cela existe, j'en ai plusieurs, mais par contre pas des 1 m, je dirai 30/40 cm max et effectivement, diamètre 20 max je dirai et encore. Jamais de soucis sur ma makita avec. En fait le beton ne m'a jamais resisté, la seule que j'ai trouvé cata, c'était chez mon frère : Des poutres en chêne massif de 30/35 cm de 1750 dans sa maison... Juste une catastrophe, on en a laissé des forêt la dedans. Et pourtant il s'y connais pour le bois, avec des forêts qui coutaient des bras, refroidis dans de l'huile. Le chêne si vieux, une véritable horreur...
Je teste tout ça et te dis.
Et les plugins persos, qqun àtester, on peut les mettre avec l'astuce ?
Oui, le ST814 fait ça sur HC2 également, moi j'en ai caché un de chaque.
Et ce soir Fanou, tout est cool ?
Nickel, ça roule. Tu as pu jeter un oeil au play list du coup ?
Bon, vais voir si j'ai le temps, je ferai. Question : On peut toujours rajouter les plugins persos avec l'astuce habituelle ?
Hum... Je ne dirai rien. Sinon moi hier soir, erreur 503... Par contre sur mon interface, j'avais un bouton restart service, et en cliquant dessus, tout est reparti. Qqun avait déjàça ?
Bon, bah à priori ils sont attaqués... : We are really sorry for keeping you waiting. We would like to release the update, as it is ready, but we are holding back due to possible attack on our servers. We will try to release it later today, after managing the situation. I apologize on behalf on our whole team for any inconvenience, we are doing our best to stop it as soon as possible. I will keep you posted in that matter.
Mais l'astuce par l'injection n'a pas été fermée du coup ?
L'astuce des plugins persos passent encore ?
Ahhh oki. Je ne vois pas trop pourquoi. Comment serait il pirater, il ne sera utiliser qu'en interne. Mets lui un mot de passe de malade au pire, de toute façon il sera en dur dans la HC2...
Testé et ok pour moi avec mon user autre. Indyana, tu as suivi ma procédure un peu plus haut pour paramétrer le compte autre que admin, sinon cela ne fonctionnera pas.
Clair, et il fait ça dans son nouveau champs
Yes, et pareil pour la HC2.
Yes, et on met une grande banderole domotique-fibaro derrière Pascal, tu veux mettre quoi sur ce bout de terre ?
Il est comme les marmottes, et l'hiver arrive...
Pour moi le VPN c'est prohibitif... Moi je veux un accès direct. Et clairement, je ne vois pas trop ce qu'on risque, car il faudrait déjàque le Hacker sache qu'il y a une HC2 derrière, ensuite qu'il sache la craquer, et surtout pourquoi faire...
La 4.057 beta est annoncé... Et enfin on dirait qu'elle règle tous les problèmes de migration de V3.6 vers V4.x ! Donc tout ceux qui ont fait avant et qui n'ont pas réinstallé, doivent trainer des mer**s de partout, qui ressortiront à un moment ou un autre. Du coup je me répète, mais je pense que toutes ces personnes devraint dès maintenant songer à tout refaire en V4.x direct, ou alors recovery en V3.6 et remigrer avec cette nouvelle version. Sinon bah ils reparlent des plugins, mais je pense que cela les plugins standards...
