Kage
    6
    next
  • Intéret :
    nothing
    4.042
617 visualisations du profil
Kage's Achievements
  1. The Quit button is now in. But the Kodi has a new version Kodi 20 it got stuck on python 2.25 have you manage to create i new version of the addon. regards Kage
  2. Kage
    Telegram HC3
    thx for QA but how to send a picture
  3. obtenir une erreur, s'il vous plaît aider *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* [QuickApp167] onInit *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* [23.11.2022] [10:29:23] [WARNING] [QUICKAPP167]: Variable iconId not found [23.11.2022] [10:29:23] [WARNING] [QUICKAPP167]: onInit>>>Variable "iconId" not defined. [23.11.2022] [10:29:23] [TRACE] [QUICKAPP167]: onInit>>>HC2 IP address : 192.***.*.*** [23.11.2022] [10:29:23] [TRACE] [QUICKAPP167]: onInit>>>variable "refreshPeriod"=60 [23.11.2022] [10:29:23] [DEBUG] [QUICKAPP167]: onInit>>>type(refreshPeriod)=string [23.11.2022] [10:29:23] [TRACE] [QUICKAPP167]: QuickApp:onInit>>>variable "devicesMap"={} [23.11.2022] [10:29:23] [DEBUG] [QUICKAPP167]: printChildDevices>>>Child devices: [23.11.2022] [10:29:23] [TRACE] [QUICKAPP167]: QuickApp:onInit>>>HC2SectionId = 227 [23.11.2022] [10:29:23] [TRACE] [QUICKAPP167]: QuickApp:onInit>>>This is the end... [23.11.2022] [10:29:26] [ERROR] [QUICKAPP167]: getHC2Sections>>>Fatal error, will wait for a manual restart, err : No route to host
  4. salut, j'essaie d'ajouter le bouton quitter mais cela ne fonctionne pas tout à fait. Pouvez-vous m'aider et m'améliorer si nécessaire. merci d'avance. bouton créé. main: function QuickApp:buttonQuit_onReleased(event) if debug then self:debug("QuickApp:buttonQuit_onReleased() - deviceId :", event.deviceId, "- Element name :", event.elementName, "- Event :", event.eventType) end self:quit() -- -- Quit -- function QuickApp:quit() if debug then self:debug("QuickApp:quit()") end self:playerAction("Quit", false, "Quiting Player", KODI.ApplicationQuit) end KODI: -- -- Quit player -- function KODI:ApplicationQuit(callback) if debug then self:debug(tools:args("KODI:ApplicationQuit", callback)) end -- {"jsonrpc":"2.0","method":"Application.Quit","params":{},"id":"1"} local payload = {jsonrpc="2.0", method="Application.Quit", id={"ApplicationQuit"}} self:postAPI("/jsonrpc", payload, function(result) return type(result) == "string" and result == "OK" and true or false end, callback) end Je reçois Quit failed pouvez-vous m'aider en cas de besoin. je vous remercie d'avance cela peut-il aussi être fait avec des sous-titres
  5. hello everybody
