14 328 -
239
Cool ça me rappelle quelques choses ça [emoji16] Joli travail [emoji106] Envoyé de mon BLA-L29 en utilisant Tapatalk
chez moi cela fonctionne http://192.168.1.8/api/devices/649 id 649 name "Samsung TV" roomID 0 type "com.fibaro.samsungTv" baseType "com.fibaro.television" enabled true visible true isPlugin true parentId 0 remoteGatewayId 0 interfaces 0 "externalView" view 0 name "POWER_Button" type "button" properties categories "[\"multimedia\"]" dead "false" deadReason "" deviceControlType "0" deviceIcon "28" emailNotificationID "0" emailNotificationType "0" ip "" log "" logTemp "" manufacturer "" model "" mute "false" power "false" pushNotificationID "0" pushNotificationType "0" remoteGatewayId "0" saveLogs "true" smsNotificationID "0" smsNotificationType "0" state "" ui.A_Button.caption "A" ui.B_Button.caption "B" ui.CHANNEL_DOWN_Button.caption "" ui.CHANNEL_UP_Button.caption "" ui.CH_LIST_Button.caption "CH LIST" ui.C_Button.caption "C" ui.DOWN_Button.caption "" ui.D_Button.caption "D" ui.EXIT_Button.caption "" ui.FAST_FORWARD_Button.caption "" ui.FAST_REWIND_Button.caption "" ui.GUIDE_Button.caption "GUIDE" ui.HDMI_Button.caption "HDMI" ui.INFO_Button.caption "INFO" ui.LEFT_Button.caption "" ui.MENU_Button.caption "MENU" ui.NUM_0_Button.caption "0" ui.NUM_1_Button.caption "1" ui.NUM_2_Button.caption "2" ui.NUM_3_Button.caption "3" ui.NUM_4_Button.caption "4" ui.NUM_5_Button.caption "5" ui.NUM_6_Button.caption "6" ui.NUM_7_Button.caption "7" ui.NUM_8_Button.caption "8" ui.NUM_9_Button.caption "9" ui.OK_Button.caption "OK" ui.PAUSE_Button.caption "" ui.PLAY_Button.caption "" ui.PRE_CH_Button.caption "PRE-CH" ui.RECORD_Button.caption "" ui.RETURN_Button.caption "RETURN" ui.RIGHT_Button.caption "" ui.SMART_Button.caption "SMART HUB" ui.SOURCE_Button.caption "" ui.STOP_Button.caption "" ui.TOOLS_Button.caption "TOOLS" ui.TTX_MIX_Button.caption "TTX/MIX" ui.UP_Button.caption "" ui.VOLUME_DOWN_Button.caption "" ui.VOLUME_UP_Button.caption "" ui._label3.caption "VOL" ui._label4.caption "CH" ui.config.ip.caption "IP address" ui.config.ip.enabled true ui.config.section1.caption "Network configuration" ui.config.section1.enabled true userDescription "" volume "0" actions runMedia 0 setMute 1 setVolume 1 turnOff 0 turnOn 0 created 1594468092 modified 1594468092 sortOrder 297
mprinfo a répondu à un(e) sujet de eric_le_belge dans Annonces et suggestions
La HC3 est très prometeuse même si elle a des défauts de jeunesse. la hc2 a permis à fibaro d'avoir une solide expérience. Après ce que je crains avec Fibaro c'est qu'il y a toujours un monde entre les annonces et la réalité. J'espère que Nice saura corriger tout cela. jeedom sur RPI c'est vraiment pas un bon choix. Je ne mettrai jamais ma domotique sur un RPI. Envoyé de mon BLA-L29 en utilisant Tapatalk -
Regarde via l'api tu auras tout ce que tu as besoin pour utiliser Exemple si ton plugin a id 54 192.168.1.8/api/devices/54 Envoyé de mon BLA-L29 en utilisant Tapatalk
Tu appel un méthode (fonction) qui n'existe pas Mets en commentaire ce code self:connect(cmd) --self:connect(cmd) Envoyé de mon BLA-L29 en utilisant Tapatalk
Salut Il faut faire une scène triggers comme sur hc2 C'est vrai qu'avec GEA sur hc2 on n'a pas besoin de ce prendre la tête avec le lua Envoyé de mon BLA-L29 en utilisant Tapatalk
@jacques68 c'est prêt tu peux venir le chercher quand tu veux [emoji1787][emoji1787] Envoyé de mon BLA-L29 en utilisant Tapatalk
Un selphie je veux bien mais pas de câlins, Je veux pas d'histoire avec nom très chère voisin qui lui est en manque de câlins a chaque mise a jours
Je sais plus ou mais @tonyc explique le problème avec ces modules. c'est pas dit que cela ne fonctionne pas mais il y a des risques et le problème ne vient pas de suite il faut attendre un petit moment avant que l'on s'en rende compte
Chez moi cela fonctionne [emoji16] Envoyé de mon BLA-L29 en utilisant Tapatalk
Tu nous joue plutôt souvent du pipo avec Fibaro [emoji1787][emoji1787][emoji1787] Envoyé de mon BLA-L29 en utilisant Tapatalk
Oui d'accord avec toi mais pour la mise a jour des relais en temps réel on n'a pas trop le choix c'est EDRT2 dans mon cas qui doit mettre a jour l'information de retour d'état car si je ne passe pas par la HC3 pour actionner le relais il faut bien que celle-ci en soit informée J'ai opté pour une mise a jour des valeurs de conso aussi pour que ce soit EDRT2 qui fasse cela L'avantage dans mon cas c'est que je n'ai qu'une seule requet qui est envoyer /api/callAction?deviceID=85&name=UPEnery&arg1=$DIP01&arg2=$TI04&arg3=$DIP02&arg4=$C01&arg5=$DIP03&arg6=$C02&arg7=$S25&arg8=$S26&arg9=$S27 si je devais faire cela sur ma HC3 je devrais faire 3 requettes pour ne récupérer qu'une partie du json de chaque requette Donc je sais pas trop qu'elle solution serait la moins couteuse en ressource Merci pour toute ces information je vais relire tout ce que tu as écris pour comprendre Pour le typage peux aussi m'éclairer pourquoi tu as choisis "com.fibaro.multilevelSensor" plutôt que "com.fibaro.powerSensor"
Salut @barelle Jolie travail Moi je suis entrain de bidouiller pour EDRT2 pour le moment j'ai ceci Pour les QA est application mobile il est exact que le parent n'est pas affiché dans l'application mobile Après si on réfléchi un peu cela peu semblé cohérent si on compare un QA a un module le parent est caché et n'est donc pas visible non plus J'ai quelque question au sujet de la méthode a employer pour la mise a jour de ce type de QA Quel protocole doit t'on employer pour le mettre a jour ? Après quelques recherche l'ecodevice est accessible en HTTP ou M2M (machine to machine) Je pose la question si on ne pourrait pas utilisé le protocole MQTT ? Pour la mise a jour j'ai opté pour cette méthode C'est l'EDRT2 qui fait des GET via push vers la HC3 Donc tout les compteurs et l'état des relais est mis a jour par le EDRT2 c'est un peu galère pour trouver le nom des variables mais après cela fonctionne très bien. J'envoie tout mes GET vers le parent et je mets a jours les CHILDS avec la commande fibaro.call cela me permet de n'avoir qu'un seul pusch pour mettre a jour plusieurs childs autre petite question au niveau du typage des enfants "com.fibaro.multilevelSensor" Moi après avoir chercher un peu j'ai mis "com.fibaro.powerSensor" tu as mis Qu'en pense tu ?
@lazer j'avais bien compris. J'ai juste fais un peu d'humour [emoji16] Après c'est pas forcément simple de crée du code. Par contre certains veulent du tout cuit est la ça bloc Envoyé de mon BLA-L29 en utilisant Tapatalk
Tout le monde ? On va dire un petit village d'irréductibles gaulois [emoji1787] Abraracourcix[mention=3]krikroff[/mention] Asterix[mention=133]lazer[/mention] parfois idefix [emoji16] Panoramix[mention=5094]jjacques68[/mention] Obelix[mention=374]mprinfo[/mention] Et bientôt Assurancetourix[mention=404]nico[/mention] Dommage que @Falbala@did nous lache[emoji1787] Je pense qu'on est pas si nombreux que cela. Moi je demande rien [emoji1787][emoji1787] Ah oui qui ce lance pour le QA onkyo je suis pas motivé en plus il faut que je démonté l'ampli pour le mettre à côté de l'ordinateur Envoyé de mon BLA-L29 en utilisant Tapatalk
Tu as regardé ici https://manuals.fibaro.com/home-center-3-quick-apps/ Envoyé de mon BLA-L29 en utilisant Tapatalk
Oui comme pour les mises à jour pas le temps d'un apero [emoji1787] Et le pire c'est qu'on peut même plus râlé [emoji24] Envoyé de mon BLA-L29 en utilisant Tapatalk
Tu commences pas du pas simple Tu devrais déjà t'amuser à écrire du code dans une étiquette puis lorsque tu clic sur un bouton cela s'affiche dans l'étiquette Afin de comprendre comment fonctionne les fonctions Envoyé de mon BLA-L29 en utilisant Tapatalk
Le plus dur est fait [emoji16][emoji106] Envoyé de mon BLA-L29 en utilisant Tapatalk
Je me suis trompé c'est quickapp generic Un peu de lecture https://manuals.fibaro.com/home-center-3-quick-apps/ Envoyé de mon BLA-L29 en utilisant Tapatalk
Après je pense que fibaro va vite remédier à ce problème car des modules Fibaro pas 100 % compatibles avec une box Fibaro ça fait un peu tâche Envoyé de mon BLA-L29 en utilisant Tapatalk
Si c'est pour faire une télécommande Device générique Ce code ne fonctionnera pas en l'état Car c'est le code d'une scène et le client tcp n'est pas bon Il y a un peu de travail pour traduire tout cela [emoji16] Envoyé de mon BLA-L29 en utilisant Tapatalk
oui pour les instances c'est cela Pour les modules en version 3.352 tu crées une scène sur la HC2 et tu colles ce code local TousLesModules = api.get("/devices/") local IdEnd = TousLesModules[#TousLesModules].id print ("Nombres de modules : " ..#TousLesModules) print ("Dernier ID : "..IdEnd) print ("-----------------------------------------------------------") print ("------- Listes de modules version 3,3,52") print ("-----------------------------------------------------------") local cpte = 0 for i,v in ipairs(TousLesModules) do --local id = TousLesModules[i].id local Nom = TousLesModules[i].name local parentId = TousLesModules[i].parentId local modifier = TousLesModules[i].modified local Valeur = TousLesModules[i].properties.value local zwaveInfo = TousLesModules[i].properties.zwaveInfo local theType = TousLesModules[i].type if parentId == 1 and zwaveInfo ~= nil then if zwaveInfo == "3,3,52" then cpte = cpte + 1 local id = TousLesModules[i].id print (cpte.." - "..zwaveInfo.." - Type = "..theType.." Id = "..id.." - Nom = "..Nom) end end end print ("total : ", cpte) Cela vas te donner tout les modules qui utilises les Zwave 3.52 Tu copies la réponse dans notepad ++ et tu gardes bien cela de coté Ces modules peuvent par la suite te posés des soucis au niveau du réseau zwave
GEA ne fonctionne pas sur hc3 est ne sera je pense jamais porté sur hc3. Et pour le moment c'est presque impossible de faire un GEA sous hc3 car les scènes ne peuvent avoir qu'une seule instance Pour l importation des codes lua attention si vous avez du code avec while do True c'est plantage de la box obligatoire Le client fhttp n'existe plus donc il faut revoir complètement le code pour le client http qui lui est asynchrone Donc pour un convertisseur de code je pense que ça risque d'être compliqué De plus certains VD sont à revoir complètement puisque maintenant on peut type un QA pour qu'il soit reconnu comme un module zwave et ça c'est top Attention avec les modules zwave en 3.52 qui peuvent poser problème Avant de tout migrer il vaut mieux déjà migrer son code est ensuite faire la migration des modules Je ne suis pas fan de la méthode de[mention=5094]jjacques68[/mention] de migrer tout en peu de temps. Il n'a pas du connaître fibaro lors de la migration en V4. Heureusement pour lui il a de solide compétences donc il a pu guèré les problèmes sans trop de soucis. La hc2 est très stable donc il n'y a pas urgence ATTENTION bien identifié les modules Fibaro en 3.52 Envoyé de mon BLA-L29 en utilisant Tapatalk
À partir d'un certain âge il vaut mieux éviter de commencer le lundi@did est un homme sage [emoji16] Envoyé de mon BLA-L29 en utilisant Tapatalk
