290 -
Tout ce qui a été posté par Bono2007
Topic unique Optimisation Chauffage, Idées, Conseils... Aide La Bienvenue
Bono2007 a répondu à un(e) sujet de Bono2007 dans Chauffage et Energie
Le shunt ne fonctionne pas. L'icône clignote mais la chaudière ne se lance pas -
Oui, avec json_viewer j'obtiens : Warning: file_get_contents(https://api.netatmo.net/api/devicelist?access_token=xxx) [function.file-get-contents]: failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /home/kwartz/www/llc/thermtatmo.php on line 172 nombre de devices: 0 nombre de modules: 0 Ligne 172 : $resulat_device = file_get_contents($url_devices); Quand je rentre https://api.netatmo.net/api/devicelist?access_token=xxx j'ai {"error":{"code":9,"message":"Device not found"}} J'ai eu les paramètres en entrant directement https://api.netatmo.net/api/devicelist?access_token=xxx&app_type=app_thermostat avec le bon access_token ( j'ai repris ce que tu avais mis en php ) J'obtiens : {"body":{"modules":[{"_id":"04:00:00:07:8b:7c","date_setup":{"sec":1444732642,"usec":642000},"main_device":"70:ee:50:07:90:c6","module_name":"Thermostat","type":"NATherm1","firmware":31,"last_message":1444851431,"last_seen":1444851431,"rf_status":93,"battery_vp":4787,"therm_orientation":3,"therm_relay_cmd":0,"dashboard_data":{"time_utc":1444851420,"device_id":22,"BoilerOn":0,"BoilerOff":10,"Temperature":22.9,"date_max_temp":1444849031,"date_min_temp":1444796151,"min_temp":17.4,"max_temp":23.2},"data_type":["Temperature","BoilerOn","BoilerOff","Sp_temperature"]}],"devices":[{"_id":"70:ee:50:07:90:c6","cipher_id":"enc:16:wG9\/XkkkkkU\/IJyh5ygkkklrxqKS0CrQfWv4LqCSzy+W7","date_setup":{"sec":1444732657,"usec":34000},"firmware":43,"heating_system":{"heating_energy":"gas","heating_system_window_seen":true,"home_size":210,"home_type":"house"},"hw_version":248,"last_status_store":1444851431,"last_upgrade":1440210137,"modules":["04:00:00:07:8b:7c"],"place":{"city":"Boussois","country":"FR","from_ip":true,"location":[4.0412001609802,50.289100646973],"timezone":"Europe\/Paris"},"setpoint":[],"setpoint_order":{"04:00:00:07:8b:7c":[]},"station_name":"Maison","therm_program":{"04:00:00:07:8b:7c":{"zones":[{"type":0,"name":"Confort","temp":19,"id":0},{"type":1,"name":"Nuit","temp":17,"id":1},{"type":2,"temp":12,"id":2},{"type":3,"temp":7,"id":3},{"type":5,"name":"\u00c9co","temp":16,"id":4}],"timetable":[{"id":1,"m_offset":0},{"id":0,"m_offset":405},{"id":4,"m_offset":450},{"id":0,"m_offset":990},{"id":1,"m_offset":1380},{"id":0,"m_offset":1845},{"id":4,"m_offset":1890},{"id":0,"m_offset":2100},{"id":1,"m_offset":2820},{"id":0,"m_offset":3285},{"id":1,"m_offset":4260},{"id":0,"m_offset":4725},{"id":4,"m_offset":4770},{"id":0,"m_offset":5040},{"id":1,"m_offset":5700},{"id":0,"m_offset":6165},{"id":4,"m_offset":6225},{"id":0,"m_offset":6750},{"id":1,"m_offset":7140},{"id":0,"m_offset":7605},{"id":1,"m_offset":8580},{"id":0,"m_offset":9165},{"id":1,"m_offset":10020}],"program_id":{"$id":"561cdf2ec8bd00cf718b45c3"},"name":"Default"}},"therm_program_order":{"04:00:00:07:8b:7c":[]},"type":"NAPlug","udp_conn":true,"wifi_status":59,"data_type":[]}]},"status":"ok","time_exec":3.8978931903839,"time_server":1444851642}
Je dois affiner ma programmation, j'ai reçu le netatmo hier, et j'avais zappé cette histoire de thermostat qui n'atteignait jamais la tp de consigne puisque ma hc2 ordonnait à la tête des radiateurs de rester fermée. Bilan, 2h de fonctionnement de chaudière pour rien. Tu ne m'as pas répondu pour les sondes de TP sur les circuits AR. Comment utilises tu les résultats ? -
Je ne peux pas agir sur la chaudière, le thermostat d'origine a bien une fonction pour un contact à distance avec circuit sans potentiel, mais il ne fonctionne pas. Et le service technique fait la sourde oreille. L'an dernier je devais monter le thermostat à 21 la nuit pour avoir la chaleur dans la chambre, seule pièce la nuit à avoir le radiateur ouvert avec la sdb. J'avais d'ailleurs branché un FGS221 sur ce fameux bornier mais elle ne se mettait pas en marche. En attendant un retour du service technique Wolf, j'ai trouvé un pis-aller avec le Netatmo. Ex actuellement, le poele fonctionne, le thermostat affiche 21, mais la chambre de ma fille est à 18, j'ai donc via une fonction dans HC2, envoyé une requête à IFTTT pour qu'il mette le thermostat Netatmo à 24. Ainsi la chaudière tourne et seul le radiateur de ma fille chauffe. Quand elle aura atteint la tp de consigne, le thermostat revient à 19 et la chaudière s'éteint. Avec un FGS certes, c'était plus "facile". Comment utilises-tu les sondes sur le circuit aller/retour ? -
Bono2007 a posté un sujet dans Chauffage et Energie
Bonjour, certains me connaissent par certains posts autour du chauffage. Nico m'a bien aidé, et m'a convaincu d'acheter pas mal de matos ^^. J'ai donc une hc2, des vannes Hemeier sur les nourrices de mes radiateurs, et rien que le changement par des vannes m'a fait faire pas mal d'économies ! J'ai scripté en LUA, je voulais tout avoir dans un seul scénario, je n'ai donc pas utilisé de panneaux, à l'époque mes sondes de T° remontaient via ma jeedom en rfxcom donc je récupérais via une lecture par http. J'ai donc un bout de script comme suit, qui résume ce que j'ai fait. local TSalon=16; local TSalonConsigne=21; -- Pour laisser les têtes ouvertes si Netatmo à 18,8° et que TSalon = 19,1° auquel cas, la chaudière tourne tout le temps if (day=="monday") then if (hour>0600 and hour<0930) or (hour>1630 and hour<2200) then TSalon=TSalonConsigne;end;end if (day=="tuesday") or (day=="wednesday") or (day=="thursday") then if (hour>0600 and hour<0730) or (hour>1200 and hour<2200) then TSalon=TSalonConsigne;end;end if (day=="friday") then if (hour>0600 and hour<1030) or (hour>1630 and hour<2200) then TSalon=TSalonConsigne;end;end if (day=="friday") and (garde) then if (hour>0600 and hour<1030) or (hour>1200 and hour<2200) then TSalon=TSalonConsigne;end;end if (day=="saturday") or (day=="sunday") then if (hour>0800 and hour<2200) then TSalon=TSalonConsigne;end;end TCuisine=TSalon-TSalonConsigne+19; TBureau=TSalon-TSalonConsigne+19; TSalon est lue depuis la sonde ( rfxcom ou DS18B20 & zwave ) Chaque année suivant les horaires de travail/présence/garde des enfants je modifie les horaires, c'est assez simple, ça me prend 5 minutes pour régler les plages horaires J'ai un problème, le thermostat. Il est dans le salon, et la nuit, si la t° de consigne de 16 du salon est ok, le thermostat s'éteint et la chaudière aussi. Un grand classique ! J'ai donc acheté un Netatmo pour pouvoir allumer la chaudière à la demande, j'ai remplacé celui de ma chaudière d'ailleurs. J'arrive à lancer la chaudière quand je veux par le Netatmo grace à Maker & IFTTT. MAIS, j'ai du augmenter la temperature max de mon salon à 21 dans ma homecenter, car sinon elle fermait les têtes des radiateurs et la température bloquait à 19, sachant que le Netatmo marquait 18,5, la chaudière tournait tout le temps pour rien. Donc si vous avez des solutions plus pro je suis preneur. Merci -
{"body":{"modules":[{"_id":"04:00:00:07:8b:7c","date_setup":{"sec":1444732642,"usec":642000},"main_device":"70:ee:50:07:90:c6", "module_name":"Thermostat","type":"NATherm1" "devices":[{"_id":"70:ee:50:07:90:c6","cipher_id":"enc:16:wG9\/XGBTiOv4lMOv J'ai pris les id ici dans le résultat. $therm1_device = $therm_json_devices["body"]["modules"][1]["_id"]; 04:00:00:07:8b:7c $therm1_relay = $therm_json_devices["body"]["devices"][0]["_id"]; 70:ee:50:07:90:c6
Bonsoir, je viens de monter mon netatmo et je suis emm... Je voudrais déclencher ma chaudière via le netatmo Faisable via IFTTT & DO J'ai regardé le plugin, mais je ne vois pas la commande pour passer en manuel et mettre la T° de consigne Je récupère bien via http direct https://api.netatmo.net/api/devicelist?access_token=xxx&app_type=app_thermostat les param de mon netatmo mais en testant https://api.netatmo.net/api/setthermpoint?access_token=xxx&device_id=04:00:00:07:8b:7c&module_id=70:ee:50:07:90:c6&setpoint_mode=manual J'ai {"error":{"code":9,"message":"Device not found"}} A l'aide svp
Bono2007 a répondu à un(e) sujet de Moicphil dans Modules Fibaro
Drole de souci maintenant, les 4 sondes de température fonctionnent sans pb depuis presque une semaine, et en voulant optimiser mon scénario, j'ai actualisé pas mal la page de la hc2, et là les températures des 4 sondes restent bloquées depuis 40 minutes. Elles ne changent pas. J'ai une réinterrogation toutes les 20 secondes. Transfert ok. Est-ce normal ? Au secours ! Edit : dans Avancé, à "Délai entre chaque interrogation", j'ai du remettre à global puis enregistrer, puis revenir à interroger toutes les 60 secondes, et là les sondes se sont affichées. Des idées ? -
@jojo, oui, https://github.com/andersesbensen/rtl-zwave Avec une simple clé tnt à 22€... 24 – 1766 MHz Je viens d'acheter ça : http://www.rtl-sdr.com/buy-rtl-sdr-dvb-t-dongles/ RTL-SDR Blog R820T2 RTL2832U 1PPM TCXO SMA Software Defined Radio with 2x Telescopic Antennas
Tu peux toujours essayer de "voir" ton signal sur 433 MHz Chercher SDR 433 sur le net, avec une clé usb tnt à 20 €. http://www.passion-radio.org/blog/sdr-sharp-dongle-rtl2832-r820t-e4000/76466
Problème résolu en passant à la dernière béta Merci mprinfo ! -
Ah ben je me sens moins con alors si c'est ça. Et dégouté aussi, ça fait 2h à refaire le cablage et raccourcir les fils pour rien ^^ Pkoi est tu resté en 4.31 ? Il y a beaucoup de versions depuis -
Bonjour, j'ai le même souci que Chris6783, 3 sondes visibles au lieu de 4, malgré plusieurs recablages, réinclusion, tests. De plus, les sondes reconnues à chaque fois ne sont pas les mêmes. La 4e sonde est aléatoire. Donc ce n'est pas un pb de sonde ou de cablage à mon avis. Peut être un pb de longueur totale ? -
Si tu enlèves les modules, tu as le même problème ?
Bonsoir, si le zwave est sur 868,42 MHz j'en doute. Le phénomène est aléatoire ? Tu as peut être un transmetteur IR qui envoie les données sur la même fréquence ? Ex : http://www.touteladomotique.com/index.php?option=com_content&view=article&id=725:2012010101&catid=11:audiovideo&Itemid=86#.VgcHpPntlBc
ici : lien ( italien mais facile à comprendre pour acheter ) L'oeil de Sauron à 29,89 € Facile à commander, il suffit de s'inscrire avec son compte fr. Pas de pb pour la réception, c'est assez rapide
J'avais prévu de souder sur des plaques, mais j'avoue que l'investissement temps/fric n'est pas assez rentable. J'ai déjà des gaines thermo prévues pour les sondes à souder aux fils, ainsi que les dominos. Prévu 5 dominos par module, ça ira plus vite que souder les plaques. Je vais prévoir une alim un peu plus costaud qu'un simple chargeur de téléphone low cost, j'ai déjà le tour avec un pc stick Meegopad, les chargeurs mini usb que j'ai ne suffisent pas. J'ai du câble réseau bon marché, est ce que je peux utiliser 3 fils monobrins pour relier les sondes ? En les sortant de la gaine bien sur. Et sur une dizaine de mètres. Ou faut-il un fil plus "gros"?
Ouh ouh, sale ! ^^ J'envisageais un truc dans ce genre : _http://domotica4all.com/video-game-review/fibaro-universal-binary-sensor/ Mais je suis tenté par les dominos du coup ^^
Salut, tu aurais une photo de ton bricolage?
Bonsoir, je voudrais monter 4 FGBS 001 pour gérer 4x4 sondes de température. Puis-je alimenter ces 4 modules avec 1 simple chargeur en dénudant les fils et un bornier par exemple ? Je ne me vois pas trop brancher 4 chargeurs... Et je ne me vois pas investir encore trop d'argent dans un boîtier avec rail etc. Merci
Bonjour, j'ai testé un truc tout bête ce matin et qui fonctionne. Je pars en vacances et je voulais un accès via l'application Fibaro que j'utilise en intranet seulement. Je sais qu'on peut y accéder par l'extérieur, mais cela me semblait un peu compliqué à gérer de mon smartphone, donc j'ai considéré un truc tout simple : Ayant une fbox V6, on dispose d'un serveur VPN ( OpenVPN ). Dans la Freebox, raccourci Serveur VPN : ajouter un utilisateur avec son mot de passe / Activer PPTP / Activer OpenVPN routé et désactiver la fragmentation Télécharger la configuration ( cliquer sur la disquette ), et se l'envoyer sur le smartphone ( par ex par gmail ) Sur le smartphone ( Android pour ma part mais iphone a sa version aussi ) : télécharger OpenVPN pour Android ( et non OpenVPN connect qui ne fonctionne pas avec la fbox ). Dans l'appli, importer le fichier extension .ovpn, se connecter et voilà ... Pratique aussi si on veut accéder à tout équipement dans son intranet.
- 2
Jeedom a bien évolué, depuis, tourne sur raspberry 2 sans pb. J'avais déjà la mini sur rasp1 avec qqes dizaines de modules et ça allait encore.
Salut, j'ai la HC2 et la Jeedom. La 2e est bien moins chère et à mon sens, avec les dernières sorties matérielles de la team Jeedom, suffisante. J'ai regretté mon achat de HC2, mais j'avoue être fan du LUA. Un autre avantage de Jeedom, la team réagit vite.
Topic unique Chauffage Au Sol
Bono2007 a répondu à un(e) sujet de gars_toff dans Chauffage et Energie
Oui sèche serviette toujours ouvert. A priori sur ton site j'ai retrouvé la même nourrice : http://www.commercecenter.eu/fr/983-repartiteur-dn-25-1-type-m-6 Juste le répartiteur à changer, du coup j'ai juste à démonter les sorties ( eurocone) et l'entrée. J'économise un peu, environ 50€ par nourrice. Ton site est de confiance ? -
De retour après mures réflexions. Je pense devoir faire l'investissement suivant : http://www.plomberie-pro.com/Catalogue/plancher-chauffant/plancher-chauffant-traditionnel/collecteur/collecteur-laiton-chrome-pro/pcolstdeb7a.htm 208€ Les mêmes nourrices au rez de chaussée que j'avais acheté avec débitmètre et surtout mêmes dimensions de la nourrice ( pratique pour remplacer quand les tuyaux sont déjà fixés au mur ! ) 7 électrovannes Heimeier à 12,40 € sur le lien que Nico a donné 2 FGS 221 pour commander 3 électrovannes du séjour , 2 de la cuisine ( 1e fgs ) et bureau, wc avec le 2e fgs. Je garde la nourrice de l'étage car les chambre ont déjà une tête LC13. A priori, je pourrais à la demande ouvrir le bas, fermer tout le bas quand la t° est atteinte et chauffer ainsi le haut sans pb. Cela semble-t-il logique ? Merci
