Bono2007
    290
Bono2007 a gagné pour la dernière fois le 23 juillet 2024
Bono2007 a eu le contenu le plus aimé !
À propos de Bono2007
  • Date de naissance 22/06/1969
    Male
    Boussois
3 068 visualisations du profil
Bono2007's Achievements
  • First Post Rare
  • Collaborator Rare
  • Week One Done Rare
  • One Month Later Rare
  • One Year In Rare
Recent Badges
51
  1. En triant mon nas j'ai retrouvé mes docs, si jamais ça peut aider Pour remplacer la box SFR par USG4 (et conserver le player) : configure set interfaces ethernet eth2 dhcp-options client-option "retry 60;" set interfaces ethernet eth2 dhcp-options client-option "send vendor-class-identifier "neufbox";" commit save { "interfaces": { "ethernet": { "eth0": { "address": [ "192.168.1.1/24" ], "description": "LAN", "dhcp-options": { "default-route": "update", "default-route-distance": "210", "name-server": "update" }, "duplex": "auto", "firewall": { "in": { "ipv6-name": "LANv6_IN", "name": "LAN_IN" }, "local": { "ipv6-name": "LANv6_LOCAL", "name": "LAN_LOCAL" }, "out": { "ipv6-name": "LANv6_OUT", "name": "LAN_OUT" } }, "speed": "auto" }, "eth1": { "disable": "''", "duplex": "auto", "speed": "auto" }, "eth2": { "address": [ "dhcp" ], "description": "WAN", "dhcp-options": { "client-option": [ "retry 60;", "send vendor-class-identifier "neufbox";" ], "default-route": "update", "default-route-distance": "1", "name-server": "update" }, "duplex": "auto", "firewall": { "in": { "ipv6-name": "WANv6_IN", "name": "WAN_IN" }, "local": { "ipv6-name": "WANv6_LOCAL", "name": "WAN_LOCAL" }, "out": { "ipv6-name": "WANv6_OUT", "name": "WAN_OUT" } }, "speed": "auto" }, "eth3": { "disable": "''", "duplex": "auto", "speed": "auto" } }, "loopback": { "lo": "''" } } } et pour l'USG que j'avais avant encore : Installation UniFi/ USG Schéma : USG : 192.168.1.1 Contrôleur : 192.168.1.9 Switch 24 : 1.2 Switch 8 : 1.3 AP : 1.4 Réception USG : Brancher l'USG courant Reset le Switch 24 ports apres avoir tout enlevé Connecter le MSI dessus Connecter le contrôleur dessus Couper tout le reste [USG]----Switch 24 ---- MSI Brancher réseau switch mais pas controleur (adoption + update bloquante) PC ---- switch ---- USG ---- ONT Prévoir controleur 192.168.1.9 ssh ubnt@192.168.1.1 car pas encore provisionné (mdp ubnt) sudo su configure set interfaces ethernet eth0 dhcp-options client-option "retry 60;" set interfaces ethernet eth0 dhcp-options client-option "send vendor-class-identifier "neufbox";" commit save redémarrer Lancer le controleur, adopter les bidules Laisser "updating" et voilà... Quand c'est ok : A faire pour le provisionning plus tard : mca-ctrl -t dump-cfg pour exporter en json format Par contre si coupure de courant : rebelote Donc rendre persistant Modif : le root du USG change : root admin@192.168.1.1 avec le mdp défini pour le device à l'installation du contrôleur ------------------- Modif du provisionning du contrôleur : ssh user@192.168.1.9 (attention à avoir changé le sshd_config pour un accès externe si root@ sinon on doit être sudo) find / -name default donnera /var/lib/unifi/sites/default on doit y trouver un dossier map on doit y créer : nano config.gateway.json Copier coller sauver (reboot ?) Dans le contrôleur : Choisir l'USG, dans config, aller à Manage device et forcer le provisionning
  2. Salut Sakkhho, non ce n'est pas possible. L'ont est dans la Freebox Ultra et on n'a pas trouvé pour l'instant de solution (il y a pas mal de recherche sur lafibre.info, j'ai posté d'ailleurs à ce sujet) Pour l'UDM Pro elle suffisait, j'avais testé pas mal de trucs, on peut installer pas mal d'applications (unifi-os shell). Au final, c'est le fait de ne pas pouvoir me passer de la Freebox Delta qui m'a fait tout revendre. Surcharge de conso pour 3 trucs en wifi, 1 PC fixe en fibre 10GB, et 1 serveur Proxmox en 10GB. Maintenant j'utilise Opnsense, avec 2 cartes 10GB sur le Proxmox. Freebox 10GB --> VM Opnsense/carte 1 --> [les VM et LXC en 10GB] et sortie carte 2 --> Mikrotik CS305 pour alimenter mon PC fixe en 10GB/s et un switch classique 1GB. J'ai recyclé de l'ancien aussi.
  3. Bonjour, je suis revenu faire un petit tour, les anciens sont toujours là ;-) Dès que j'ai eu la fibre (à l'époque SFR), j'avais acheté Unifi. Un USG 4. Remplacement de la box par l'USG. C'était facile. Puis la fibre 10GB de la Freebox Delta, alors là l'USG 4 était saturé meme sans IDS. J'ai craqué pour la Dream Machine Pro. Impossible de se passer de la Freebox, mais j'ai pu la mettre en bridge complet et récupérer l'ipv6 pour le player, dans Unifi. Au final : des débits un peu bridés mais c'était top. Un beau jouet. Avec l'augmentation de l'électricité, j'ai fait quelques mesures et bon ben j'ai revendu mon jouet, dans les 100W rien que pour l'UDM... J'ai aussi viré mon serveur DIY par un serveur DIY Proxmox mais avec conso réduite. Voilà voilà ^^
  4. Hello les anciens. Je reste sur mon Jeedom toujours virtualisé sous Proxmox, ça fait un bail maintenant. Après plus le temps de faire joujou non plus. J'ai mes volets qui fonctionnent avec l'heure du soleil, de l'éclairage connecté, quelques mesures que je ne regarde plus ^^ Ca me rappelle des souvenirs tout ça.
  5. Je peux le vendre en fait, plusieurs fois
  6. Hello les anciens. Bien content d'avoir vendu la mienne au bon moment :) Toujours satisfait de mon Jeedom virtualisé sous Proxmox.
  7. Bonjour les "anciens". Un retour sur ce portier ? Comme je suis full Unifi à la maison. Merci
  8. Bono2007
    Mon Test Jeedom
    Oui, après un premier serveur un peu léger, j'ai investi et aussi 6 ou 7 VM dont un serveur Plex + plexdrive. Quand je suis passé à la v4 de Jeedom, j'ai pu cloner mon Jeedom fonctionnel et jouer avec avant de la passer en définitif. Pratique aussi de virtualiser un NAS XPenology installé en 5 minutes à partir d'un template. (je suis fan du Synology mais j'avais pas les moyens à l'époque) J'en ai profité pour virtualiser un Windows 10 pour certains trucs, vu que je suis passé au 100% Kubuntu.
  9. Bono2007
    Mon Test Jeedom
    Sur rasberry il vaut mieux remplacer la sd par un mini ssd (20 Go). Il a fonctionné ainsi pendant 2 ans. Le montage d'un serveur sous Ryzen / 32 Go de ram et une carte 10 GB m'a permis de la passer sous Proxmox en virtualisé avec backup du pc virtualisé 1x par semaine (2 minutes à remettre si pb) et backup de la sauvegarde journalière avec un bon vieux crontab & rsync, sur mon NAS. Et depuis c'est hyper stable, juste que lors du passage en v4 j'ai du virer les widgets et refaire un design pour ma tablette.
  10. Bono2007
    Mon Test Jeedom
    Bonjour, il y a pas mal de retours négatifs de l'installation de Jeedom sur NAS ou Freebox en virtualisé. Des problèmes liés aux protocoles via clés usb. Attention je ne dis pas que ça ne marche pas, mais j'ai vu passer pas mal de problème sur ces 2 types d'installation. Aucun problème en tout cas de mon côté sous Proxmox.
  11. Bono2007
    Mon Test Jeedom
    Bonjour, quelques changements : - passage à la V4 de Jeedom, après modification/suppression d'une tonne de widgets/virtuels inutiles et non fonctionnels. - Proxmox en v6 - Grafana fonctionnel (Unifi + NAS sous XPenology) Concernant Grafana, difficile de modifier le template que j'ai trouvé, donc peu d'informations utilies de mon Unifi USG Pro 4. Par contre, le plugin Unifi de Jeedom permet un réel suivi des téléphones présents dans la maison (fiable via le wifi). En plus des infos via SNMP. Évidemment toujours pas d'informations en temps réel. Hors sujet mais comme ici il y a des geeks barbus, certains ont-il la fibre via le port sfp+ de la Freebox ? J'envisage de revenir à Free maintenant qu'ils sont disponibles (actuellement j'ai du 1 gbps réel) car je pourrais avoir du 8 gbps réel. J'envisage donc : - soit me faire un NAS DIY avec une carte réseau 10 Gbps connectée directement au port sfp+ de la Freebox - soit investir dans un vrai Synology DS1918+ avec carte 10 Gbps - soit compléter mon PC sous Proxmox avec une 2e carte réseau 10 Gbps. J'avais pensé amener le 10 Gbps à mon routeur Unifi mais il est SFP et pas SFP+ Des avis ? Merci !
  12. Bono2007
    Mon Test Jeedom
    Je demandais si certains utilisaient Grafana, avec Jeedom ou autre. Pas de plugin Jeedom non, juste une url à push http://ip.debian.grafana:1234/updateData?name=#cmd_name#&cmd_id=#cmd_id#&val=#value#&location=Maison tout est automatique
  13. Bono2007
    Mon Test Jeedom
    Bonsoir, petite question, y en a-t-il qui utilisent Grafana ? J'ai installé InfluxDB+Grafana sur une Debian et réussi sans trop de problème à grapher les données de Jeedom, mais par exemple, sur ecoDevice (via le plugin), j'ai la conso journalière du gaz en kWh, par ex. Cela dit je ne sais pas si on peut avoir directement les données de l'ecoDevice (par la lecture du json) par exemple. J'essaie aussi de récupérer les données de mon matos Unifi, mais là je galère, il faut installer un autre influxDB sur le contrôleur. D'autres utilisations/exemples ?
  14. Bono2007
    Mon Test Jeedom
    Bonjour, je repasse à nouveau en V4, j'ai un peu de temps pour remettre les mains dans le cambouis de Jeedom. J'avais déjà fait du tri, dans mes plugins obsolètes, virtuels obsolètes, scripts et scénarios inutilisés. J'ai même réinitialisé le suivi-conso, qui buguait sur des données de la base sql que je n'ai pas réussi à retirer (3 ans de données). Dommage qu'il ne soit plus suivi et ne soit pas passé en officiel. Il est top. J'ai, en parallèle, programmé un suivi conso maison, mais la gestion des variables et la programmation c'est bof. Je préférais le lua. Je regrette le cassage des designs de la V3 à la V4, cela a découragé pas mal d'utilisateurs. Je pense à lui par exemple : ici En tout cas mon chauffage marche toujours Par contre, mon ecodevice ne fonctionne plus, 0W 0A... lol A priori problème plus ou moins déjà vu. En essayant "configuration", roue crantée infinie... En essayant la beta des plugins, pareil. Bon ben " restore vma archive: lzop -d -c /mnt/pve/DS918/dump/vzdump-qemu-104-2019_12_28-01_07_33.vma.lzo | vma extract -v -r /var/tmp/vzdumptmp1566.fifo - /var/tmp/vzdumptmp1566 "
  15. Bono2007
    Mon Test Jeedom
    Salut, plusieurs choses à tester : df -h : (en ssh), pour vérifier si pb de place sur le système de fichier Possible problème de corruption, dans ce cas le mieux est de réinstaller Jeedom et remettre un backup. Avec nouvelle carte SD. mysql ne démarre pas, voir en tapant (en ssh) : sudo su- service mysql stop mysqld --verbose C'est dans la doc, la base. Après si tu as du Xiaomi : https://www.ladomopratique.com/erreur-sqlstatehy000-2002-resolu/
