Hello,
J'ai avancé sur le sujet de la Homelive 'libre' :
U-Boot 1.1.4 (Mar 31 2014 - 18:03:47) Board: Ralink APSoC DRAM: 256 MB relocate_code Pointer at: 8ffb4000 enable ephy clock...done. rf reg 29 = 5 !!! nand page size = 2048, addr len=4 ..ethaddr D4:21:22:71:01:FD ============================================ Ralink UBoot Version: 4.0.S.4 -------------------------------------------- ASIC 7620_MP (Port5<->Phy) DRAM_CONF_FROM: Auto-detection DRAM_TYPE: DDR2 DRAM component: 2048 Mbits DRAM bus: 16 bit Total memory: 256 MBytes Flash component: 128 MBytes NAND Flash Date:Mar 31 2014 Time:18:03:47 ============================================ icache: sets:512, ways:4, linesz:32 ,total:65536 dcache: sets:256, ways:4, linesz:32 ,total:32768 ##### The CPU freq = 580 MHZ #### estimate memory size =256 Mbytes Atheros Phy detected EXT PHY5 RALINK 2300 DIR: ff807e RALINK 7140 DIR: 34000020 Please choose the operation: 1: Load system code to SDRAM via TFTP. 2: Load system code then write to Flash via TFTP. 3: Boot system code via Flash (default). 4: Entr boot command line interface. 7: Load Boot Loader code then write to Flash via Serial. 9: Load Boot Loader code then write to Flash via TFTP. 0: Enter SerComm upgrade mode. first scan: 3c5879 scan 2: 3c5879 scan 3: 3c5879 sum :3 You choosed 3 3: System Boot system code via Flash Kernel 1 partition. ## Booting image at bc640000 ... Image Name: MIPS OpenWrt Linux-3.10.28 Image Type: MIPS Linux Kernel Image (lzma compressed) Data Size: 1179584 Bytes = 1.1 MB Load Address: 80000000 Entry Point: 80000000 .................. Verifying Checksum ... OK Uncompressing Kernel Image ... OK No initrd ## Transferring control to Linux (at address 80000000) ... ## Giving linux memsize in MB, 256 Starting kernel ... [ 0.000000] Linux version 3.10.28 (builder@builder1204) (gcc version 4.6.4 (O penWrt/Linaro GCC 4.6-2013.05 r39638) ) #72 Thu Sep 4 04:46:32 PDT 2014
J'arrive pas encore a prendre la main totalement, mais je vais persévérer
Je reviendrai vous tenir au courant
