TonyC
    1 480
    28
Tout ce qui a été posté par TonyC
  1. Je ne voyais pas où ça se trouvait merci @Lazer.
  2. Main feature: QuickApps encryption Encrypt QuickApps to share integration with the community without access to the source code. Define specific serial numbers for gateways that will be able to open the file. What's new: Devices Z-Wave blinds now show favorite position state. Redesigned support for the energy meters (Qubino, Aeon) - soft-reconfiguration required. Search field for device' name filter supports "Enter" and "ESC" key functions. Energy Improved data handling support when option "Grid consumption" is selected in panel configuration. Network Wi-Fi stability improvements for Yubii Home and HC3L gateways. Bug fixes: Devices Missing translations for thermostats sidebar in some languages. Editing device name expands device tab. All roles for binary switches treated as lights. Gateway Connection Adding FIBARO RGBW 1 device to slave gateway may not work properly. Network In some rare cases list of available Wi-Fi network is empty. Other Issues when using Fahrenheit temperature unit in system. Quick Apps Issue with sending push notifications from the QuickApp code. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0
  3. TonyC
    Déboire avec un roller shutter
    Sur les volets roulants il y a des attaches qui jouent le rôle de « fusible » pour éviter que tout casse lorsque le moteur force, elles ont très probablement lâchées. Il va falloir ouvrir le coffret et les remplacer, regarde bien le modèle avant d’en racheter, il y en a plusieurs. généralement des languettes métalliques ou plastiques lorsqu’elles sont anti effraction.
  4. Bienvenue @SmartHomeEddy c’est super que tu nous rendes visite sur le forum français !
  5. TonyC
    Bouteille à la mer
    C'est tout à fait probable que tu ais un module qui jam en tout cas ça y ressemble fort, pas évident à identifier sans avoir un sniffer zwave pour confirmer. Tu as essayé de restaurer une version récente ?ça ne mange pas de pain si t'en as une sous le coude. Tu peux essayé avant toute autre chose, de coupé le jus au général et voir si ça change qlq chose également. Si c'est un module sur batterie ça ne changera évidement rien. dernier recours tu peux faire une full reconfiguration de tes modules sur courant (menu zwave tt en haut) et reconfigurer 1 à 1 tes modules sur pile en les réveillant à chaque fois. C'est laborieux mais sans sniffer dans ces rares cas où ça arrive, ça devient vite très pénible.
  6. TonyC
    Bouteille à la mer
  7. @Doudoubidou, hey hey ça progresse bien je vois pense à faire des sauvegardes régulières pour éviter un éventuel problème. Bonne continuation dans ton re-setup !
  8. Purée j'avais pas fait gaffe, en effet c'est un template de wall plug !! c'est quoi ce beans J'étais parti dans un délire sur la version du moteur mais là ??? @Doudoubidou, quand t'ouvres le frigo tu entends la radio ? Plus sérieusement tu as essayé de juste l'exclure et le réinclure ton module ?
  9. Je n'ai pas souvenir de à quoi ressemble les écrans sous la V3, sinon tu peux créer une scène et y coller : a = api.get("/devices/1") print (json.encode(a)) Le device 1 est le controller, si tu peux coller le résultat du print
  10. Désolé je ne connais que cette façon de vérifier, mais en effet il n'y a que les slaves. Cependant étant donné que tu es reparti from scratch à ta place si tu me permets je ferai un factory reset puis je m'assurerai de bien partir su la V2 du moteur.
  11. @Doudoubidou, il faut vraiment aider à comprendre ton problème, pour ça faut faire les vérifs demandées sinon ça va être compliqué de dépanner . Quelle est ta version du zwave engine ? tu peux vérifier la version dans le menu "Connexion Des Box Domotique"
  12. ça n'a rien à voir ave une beta ou pas du firmeware c'est lors de la config de ta box. tu peux vérifier la version dans le menu "Connexion Des Box Domotique"
  13. Oui c'est vrai ça, sauf si tu sélectionnes de ne pas en faire, ce qui dans ce cas serait dommage. Suis quasi sur qu'il y a juste une corruption entre le compte et la box, m'enfin ... Dernière tentative @Doudoubidou, est ce que tu vois ta box active sur ton fibaro id?
  14. tu es sous quelle version du zwave engine? Tu n'as pas configurer la V3 par hasard ? Cette version en en beta et les template ne sont pas terminés. Si c'est le cas je te conseil de recommencer encore une fois ta configuration et de bien sélectionner la V2. Pour ça il faut repasser par la case factory reset.
  15. @Doudoubidou Tu as déjà fait un backup sur ta HC3 ou pas ? je vois que la question à déjà été posée mais je ne vois pas de réponse claire. Si oui et que tu ne les vois pas, il faut vraiment que tu contacte le support ils ont moyen de les récupérer, pour une raison obscure tu semble avoir cassé le lien entre ta HC et ton compte cloud. Ca prendra 3 mn au support pour te dépanner plutôt que de perdre ton temps à tout exclure/inclure/setuper et reprogrammer toutes tes scènes, même si je ne connais pas ta conf, ça me semble tout de même être le plus rapide. Edit: Tu as regardé sur ton compte cloud si tu voyais ta box ? et si elle était active ?
  16. Bon je crois que je viens de craquer Un S7+ avec station d'aspiration et son grand frère le maxv ultra pour le bas, bon en faut encore pour le haut mais ça, ça va attendre la prochaine génération ! EDIT : Pour info j'ai trouvé le S7 maxv seul à 699€ chez boulanger. La station à 703€ chez amazon mais malheureusement, le prix à immédiatement mis à jour et n'est plus concurrentiel.
  17. TonyC
    Bon anniversaire Dragoniacs
    Bon anniversaire ensoleillé @Dragoniacs !
  18. TonyC
    Bonne anniversaire Steven
    Bien vu @jojo ! l'animal se fait rare Il fut le tout premier à me donner un coup de main il a 8 ou 9 ans pour m'aider à faire fonctionner le vd netatmo il me semble... mais peu importe le vd il est resté jusqu'à plus de 3h du mat et ça jusque ça marche ! Bon anniversaire @Steven !
  19. Bon anniv @Lazer
  20. Salut à tous, @mprinfo tu mets ta box en inclusion zigbee, tu allumes/éteins ta hue 2/3/4 fois, l'inclusion peut prendre un peu de temps, donc attendre un peu et pas trop se speeder . Il faut être certain qu'elle soit bien exclue de son hub d'origine, sinon tu ne pourras pas. C'est un coup de main à prendre mais au bout de qlqs unes on s'y fait
  21. L'un d'entre vous qui aurait fait cet update et ayant des QA créant des childs de type switch pourrait-il essayer de le lancer en générant les childs (longue phrase ... ) ? J'ai eu à le faire et le résultat n'est pas beau, les childs perdent leur interfaces. Je n'en ai pas d'autre en stock de ce type et je ne sais pas si c'est mon QA ou une régression. @mprinfo c'est avec ton QA que j'ai eu le problème. J'ai raconté la même histoire sur le fofo officiel, j'espère que quelqu'un aura le courage d'y jeter un oeil. Merci pour vos retours ! Faut que j'arrête l'apéro ... EDIT: Coupable trouvé, j'ai mis à jour mes switchs aujourd'hui et l'un d'entre eux a un gros bug, le QA ne pouvait plus piloter le port et ce dernier ne remonte plus la charge. j'ai suspecté à tors fibaro... chose étrange c'est ok sur les autres switches, les modèles sont différent mais la version du firmware est la même. Je vais me plaindre sur le fofo ubiquiti
  22. Faut jamais écouter mon petit doigt Tu as raison, faudra espérer que si investissement il y a eut sur zigbee, ils pourront capitaliser dessus au passage sur thread, enfin s'ils y vont, ce dont je doute pas (ça me rassure de dire ça) .
  23. Peut-être est il déjà là et on ne le sait pas. Qui sait Plaisanteries mis à part, je pense que ça ne devrait plus trop tarder, mais ce n'est que mon avis, je pensais vraiment que cette version allait l'embarquer, mais me suis trompu .
  24. Update passé RAS, pour le moment ...
  25. Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. What's new: Alarm Added checking sensors status before arming the alarm. Dashboard Added translations for thermostat modes on dashboard tiles and sidebar. Added possibility to open device settings directly from device tile. Improved styling of units for sensors on dashboard and sidebar. Changed icon for opening sidebar from device tile. Devices Updated parameters template for Nice BiDi-Shutter and Nice BiDi-Awning. Added support for Eurotronic Air Quality Sensor. Improved handling of long operations for Color Controllers and Multilevel Switches.** Added support for new revisions of Fibaro devices. Default configuration for RGBW441 set as RGBW after adding device to the system. Added rounding for virtual power consumption values. Added support for Donexon thermostatic valve.** Custom parameters for Z-Wave devices sorted by ID. Elero* Improvements for pairing process. Improved polling mechanism for Elero devices. Energy Warning about unsaved changes in Panel Settings. Added support for declaring fixed cost for a period. General Optimized calculation of sunrise/sunset time. Network Improved changing network settings between DHCP and Static. Nice* Added possibility to Read, Set default and Reset all parameters in devices settings. Changed default role for mono-directional devices from remotes to Blinds/Gates. Added requesting current parameters values during pairing process. Added possibility to configure and use favourite position for mono-directional devices. Other Improved auto-logging feature. Plugins Thermostat & Heating Zone plugin optimization. Added possibility to set the URL manually for Dahua plugin. Quick Apps Changed function calling format (backwards compatible). Changed auto-complete function for new function format in Lua. Scenes Changed functions calling format (backwards compatible). Changed auto-complete function for new functions format in Lua. Added icons for group actions. Changed font color in dark-mode of Lua editor. Update Added reconfiguration button for device after successful update.** Z-Wave devices update process improvements. Z-Wave Improved handing of communication errors. Optimized service start-up. Bug fixes: Alarm Unnecessary notification about wrong pin when trying to disarm the system. Cameras Inactive camera preview tab after saving device settings. Dashboard No automatic refresh of color components on device sidebar.** Missing polish translations for states of simple shutter. Devices Missing barrier role for simple shutter device type. Issue with adding Fibaro devices (Wall Plug UK, Smart Module, BiDi-ZWave) in Security Mode. Rejected association settings visible on the list until page refresh.** Power graphs in advanced tab do not scale when zooming. Uploading custom icon for Fibaro CO Sensor not possible. No possibility to change parameters in Z-Wave devices if "use template for parameters" is disabled. Issue with opening 1P Smart Meter Qubino configuration.** Incorrect devices grouping on settings page for QuickApps and Linked Devices. Additional not applicable icons for devices. Redundant device roles for Walli Roller Shutter and Roller Shutter 3. Diagnostics Issue with starting reconfiguration from Z-Wave tab.** CPU graphs issues. Energy Wrong rounding of percentage consumption on Savings tab. Production devices listed on Top consuming devices and on devices list on Savings tab. Gateway Connection Changing Fan Mode for thermostats from slave gateway is not possible. General Home location settings change does not alter sunrise/sunset calculation. Location map does not show if longitude/latitude is out of range. History Device icon does not correspond with the state from history. Network No information about possible connection loss after changing network settings. Nice* Not migrated device roles for Nice Mono devices added in the system on 5.080. Nice Mono devices added on 5.080 lost the icons after updating to 5.100. Issue with pairing some Nice Mono devices. Notifications Devices icons in wrong states on notifications list. Non-admin user cannot remove notifications. Other Additional credentials popup during log-in in some cases. Text in reboot modal not centered on Safari browser. Rejecting custom icons upload if file extension is in uppercase. Plugins Removed additional button on sidebar for Fibaro Intercom. Scenes Scene does not start in specific configuration when trigger is used in more than one scene. Differences between calls in Scenes and QuickApps. Update No translations of errors for devices update service.** Known issues: Nice* After adding Nice device page refresh is required. Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0
