Moicphil
Co-Administrateur
    8 501
    66
  1. Moicphil
    Nouveau
    Bonjour, bienvenue sur le forum. ​
  2. Moicphil
    Salut
  3. Bonjour, bienvenue sur le forum.
  4. Je ne connais pas ios, y'a rien d'équivalent àTasker ou Automateit sur l'apple store ?
  5. En interrogeant le device, tu as toute sa config : Exemple sur un FGS : 192.168.0.xxx/api/devices/xx // 20150308110215 // http://192.168.0.100/api/devices/83 { "id": 83, "name": "Sdb Haut", "roomID": 14, "type": "com.fibaro.binarySwitch", "baseType": "com.fibaro.actor", "enabled": true, "visible": true, "isPlugin": false, "parentId": 373, "remoteGatewayId": 0, "interfaces": [ "zwave" ], "properties": { "parameters": [ { "id": 1, "lastSetValue": 255, "size": 1, "value": 255 }, { "id": 3, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 4, "lastSetValue": 0, "size": 2, "value": 0 }, { "id": 6, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 13, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 14, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 15, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 16, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 30, "lastSetValue": 3, "size": 1, "value": 3 }, { "id": 31, "lastSetValue": 2, "size": 1, "value": 2 }, { "id": 32, "lastSetValue": 3, "size": 1, "value": 3 }, { "id": 33, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 39, "lastSetValue": 600, "size": 2, "value": 600 } ], "associationSet": [ { "devices": [ 1 ], "groupID": 1 }, { "devices": [ 1 ], "groupID": 2 }, { "devices": [ 1 ], "groupID": 3 } ], "associationView": [ { "devices": [ 1 ], "groupID": 1 }, { "devices": [ 1 ], "groupID": 2 }, { "devices": [ 1 ], "groupID": 3 } ], "zwaveCompany": "Fibar Group", "zwaveInfo": "3,3,42", "zwaveVersion": "", "pollingTimeSec": 0, "configured": "true", "dead": "false", "deviceControlType": "20", "deviceIcon": "1026", "emailNotificationID": "0", "emailNotificationType": "0", "endPointId": "0", "liliOffCommand": "", "liliOnCommand": "", "log": "", "logTemp": "", "manufacturer": "", "markAsDead": "true", "model": "", "nodeId": "40", "parametersTemplate": "80", "productInfo": "", "pushNotificationID": "0", "pushNotificationType": "0", "remoteGatewayId": "0", "saveLogs": "true", "smsNotificationID": "0", "smsNotificationType": "0", "useTemplate": "true", "userDescription": "", "value": "false" }, "actions": { "reconfigure": 0, "turnOff": 0, "turnOn": 0 }, "created": 1425589356, "modified": 1425589356, "sortOrder": 52 } . Reste maintenant à faire le code, pour récupérer ce qu'il y a dans "parameters".
  6. Moicphil
    Philips Hue
    Non, pas la peine d'ajouter "newprofil" Tu es sur de ton ip ? Voici un exemple, colorloop, à mettre dans un bouton d'un module virtuel : ( changer l'ip par celle de la lampe à piloter ). id=fibaro:getSelfId() huelightid=1 hueuser = "newdeveloper"; hueIP = "192.168.0.69" huePort = 80; Hue = Net.FHttp(hueIP,huePort) response ,status, errorCode = Hue:PUT('/api/'..hueuser..'/lights/'..huelightid..'/state', '{"on":true, "sat":200, "bri":100, "effect":"colorloop"}') . Voici le module virtuel complet : Hue_Lampe_1 (1).vfib
  7. Bonsoir, bienvenue sur le forum.
  8. Bonsoir, bienvenue sur le forum.
  9. Bonsoir, bienvenue sur le forum.
  10. Tu as bien créé la variable "pushover" ? dans: fibaro:call(xx, "pressButton", "1"); --bouton du Virtual Device avec script Tu as bien remplacé xx par l'id du module virtuel ?
  11. Bah! moi j'ai rien fait...je n'ai pas de mérite. J'utilise juste des fonctions/applis déjà présentes . Toi tu parts de zéro, et là chapeau ! hâte de tester ta version.
  12. Tout est déjà sur ce fil >> http://www.domotique-fibaro.fr/index.php/topic/670-utiliser-le-service-pushover-pour-les-notifications/?p=11040
  13. Mise àjour du post n°1 > Tuto
  14. même problème qu'au dessus, que je n'explique pas http://www.domotique-fibaro.fr/index.php/topic/670-utiliser-le-service-pushover-pour-les-notifications/?p=55906 En "string" la syntaxe a du changer suite au passage en V4. Comme tu as une HC2, pourquoi n'utilises-tu pas un code Lua? là , c'est sur que ça fonctionne.
  15. Si ça t'embête pas, je regarderais ce soir, je ne suis pas chez moi.
  16. Pour ma part, ça fonctionne correctement en V4.035. Dois avoir un autre pb.
  17. ah? j'ai pas vu passé celui d’Hervé... Je ne maîtrise pas le php et encore moins Java. J'ai donc trouvé quelque chose de très simple et accessible à tout le monde. Personnellement je trouve Tasker extrêmement puissant mais dur à maîtriser quand on a pas l'habitude.
  18. Je viens de retrouver le tuto de notre ami Steven ( ici ) , c'est la même chose, mais sans Tasker et moins pointu que le sien ( pas de code javascript ).
  19. Contrôler sa Home Center avec un simple envoi de SMS AutomateIt pour smartphone et tablette Android Présentation de l'application AutomateIt : Disponible sur le Play Store en version gratuite ou payante, cette application permet d'automatiser des tâches prédéfinies. A la manière de l'application "Tasker" mais avec une interface plus intuitive et accessible. Pour ceux qui souhaitent des scripts "plus poussés", je vous conseille néanmoins d'utiliser Tasker. Notre ami Steven a d'ailleurs réalisé un excellent tuto sur le sujet, il se trouve : ici Lien vers le site officiel : http://automateitapp.com/ Lien Google Play vers la version gratuite : https://play.google.com/store/apps/details?id=AutomateIt.mainPackage Lien Google Play vers la version payante : https://play.google.com/store/apps/details?id=AutomateItPro.mainPackage --------------------------------------------------------------------- Prérequis : - Avoir un smartphone ou tablette dédiée connectée en Wifi sur le même réseau que votre Home center. - Un carte SIM activée ( Forfait à 2 € suffisant ) - l'application AutomateIt installée. Version mini de l'os supportée :2.2 --------------------------------------------------------------------- Principe de fonctionnement et possibilités : Grace à l'Api de notre Home Center, nous allons pouvoir la contrôler facilement au moyen de requêtes http envoyées par l'application. Cela ouvre bon nombre de possibilité comme par exemple: - Désactiver l'alarme de notre domicile - Allumer ou éteindre des lumières. -Rebooter sa Home Center à distance. - etc... Tout ce qu'il est possible de faire via l'Api Fibaro est possible ici, c'est à dire à peu prés tout ! L'envoi de ces requêtes seront "conditionnées" par la réception d'un Sms. Cas concret n° 1: Un Artisan doit effectuer des travaux dans votre domicile en votre absence mais vous ne souhaitez pas lui donner le code de l'alarme ou télécommande. Dans ce cas là , vous lui donnez simplement le numéro de téléphone, celui où est installé AutomateIT. Et vous lui dites d'envoyer un Sms à ce numéro avec par exemple comme texte : ' ouvrir portail' puis 'désactiver l'alarme'. Bien évidement, c'est à vous de choisir quel texte vous souhaitez pour exécuter la tâche. Cas concret n° 2: Vous souhaitez allumer votre chauffage à distance, mais vous vous apercevez qu'ici, au fond de l'Auvergne, vous n'avez plus d’accès à internet depuis votre smartphone, juste du réseau cellulaire: Un sms, et le tour est joué ! ----------------------------------------------------------- De plus, vous pourrez via les règles dans l'application, autoriser qu'un numéro unique ou certains de votre répertoire. Le texte à envoyer peut être ou non "sensible à la casse", ça sera à vous de choisir. Pour le principe de fonctionnement, voici une vidéo avec allumage puis extinction d'un Wallplug : . . ----------------------------------------------------------------------------------------- Paramétrage de l'application : Lancer l’application et cliquer sur " ajouter une règle" : Sélectionner votre "déclencheur" : Dans mon exemple, appuyer sur " Evénement de sms contenant tel texte" : Saisir le texte qu'il faudra saisir lors de l'envoi du sms : Ensuite, on passe à l'onglet "action". Sélectionner l'action souhaitée, ou un groupe d'action ( les groupes nécessitent la version pro de l'appli ) : Dans notre exemple, sélectionner " Action d'ouverture url" : Maintenant, saisir la requête http souhaitée: Voici quelques exemples de requêtes : Pour allumer : http://<LOGIN>:<PASS>@<IP>/api/callAction?deviceID=<ID>&name=turnOn Pour éteindre : http://<LOGIN>:<PASS>@<IP>/api/callAction?deviceID=<ID>&name=turnOff Pour appuyer sur un module virtuel : http://<LOGIN>:<PASS>@<IP>/api/callAction?deviceID=<ID>&name=pressButton&arg1=<BUTTON ID> Pour lancer une scène : http://<LOGIN>:<PASS>@<IP>/api/sceneControl?id=<SCENE ID>&action=start Pour renseigner une consigne de température sur une Danfoss : http://<LOGIN>:<PASS>@<IP>/api/callAction?deviceID=<ID>&name=setTargetLevel&arg1=<TEMP VALUE> Pour armer un capteur : http:///api/callAction?deviceID=51&&name=setArmed&arg1=0 D'autres exemples sont disponibles ici : http://tutoriels.domotique-store.fr/content/49/45/fr/api-commander-le-home-center-par-des-requ%C3%AAtes-http.html Finir en donnant un nom à votre règle dans le 3 ème et dernier onglet : ---------------------------------------------------------------------------------------- Voilà une solution simple qui vous permettra donc de lancer une action sur votre Home Center dés réception d'un SMS par l'application Avec les groupes de déclenchement et d'action dans l'application, et les conditions " ET / OU " , vous allez pouvoir créer des règles plus poussées et combiner plusieurs actions et requêtes Maintenant à vous de jouer ! Je suis dispo pour tousvos commentaires... --------------------------------------------------------------------
  20. Bonsoir, bienvenue sur le forum. ​
  21. Bonsoir, bienvenue sur le forum.
  22. Moicphil
    Philips Hue
    Tu as raison, il faut passer par l'Api du pont pour créer un utilisateur : http://www.developers.meethue.com/documentation/configuration-api#71_create_user Sinon, tu peux aussi rester avec avec le compte par défaut 'newdeveloper"
  23. Bonjour, bienvenue sur le forum.
  24. Bonjour, bienvenue sur le forum.
