1 501 -
15
héhé 4.053 > New Features: - Fibaro Dimmer 2 support - Multichannel Associations support - to use that feature reinclusion or soft reconfiguration is required - Notification Center in web interface - basic set of notifications is currently available, this feature will be developed - It is possible to choose whether the device should be added in secure mode - for devices other than door locks, sirens, roller blinds it is strongly advised to use non secure mode due to Z-Wave protocol performance - Secure update availability check via https - It is possible to interrupt the process of device reconfiguration - Reworded notification messages > New Plugins: - Planika - Bio Fireplace - New video cameras support (check on plugin list) > Resolved Issues: #0003316 Z-Wave communication breakdown after sending an empty argument #0002493 FortrezZ SSA2 siren no template #0002622 Home Center 2 is not supporting multichannel associations #0002706 Cant set parameters on Fibaro Sensor (FGMS) #0001705 POP_123665 Z-Wave UK Plug-in Switch plus Power Meter does not display measured power #0002052 MCOHOME touch panel switch #0002227 Association to Vitrum's slave button is not working #0002276 FGS-221 + WCD2 - cannot associate the second channel #0001771 Metering Report #0002432 unable to change any parameters on Home Energy Meter DSB28-ZWEU E2 #0003345 Display truncated in 4.048 Satel alarm disarming > Other changes: - Z-Wave Stability Improvements - Z-Wave Network Reconfiguration Improvement - Many other system improvements > Known issues: Using multichanel assocations requires soft reconfiguration of devices Android version of the Fibaro mobile app does not display icons for following devices properly: - NetAtmo Thermostat - NetAtmo Weather Station - Sonos Global polling interval is set to a fixed value (120s), this may cause a delay in operation of large Z-Wave networks. Inconsistencies in Satel interface. Power Mettering may not work properly for some devices Alarm Panel doesn't work in some specific configurations Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly On mobile clients devices may be visible in different categories than configured Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly
5.40 installée, la réactivité est bien meilleure en instantané!
HANSOLO a répondu à un(e) sujet de Fanou dans Modules Fibaro
Il faut faire les trous aux emplacements materialisés -
une idée de titre "il faut sauver le soldat @Steven"
Voilà ce que j'ai, je ne vois pas de "supprimer mon vote". @Lazer, mon cerceau va bien Je ne suis pas le seul, @ihexley a aussi voté en 4.5x
Topic unique Aeotec Zw096 - Smart Switch 6
HANSOLO a répondu à un(e) sujet de couillerot dans Aeon Labs / Aeotec
Prise USB en plus 3000W au lieu de 2500W -
Vous inquiétez pas ça ne m'empêche pas de dormir
Pour le freeplayer ça ne me dérange pas qu'il soit derrière le dual wan, il est dans la chambre sur la seconde télé et je l'utilise rarement. J'ai un PC en htpc dans le salon et un nas syno.
Polling global
fibre ou cable en plus de l'adsl free (que je veux garder) les deux connexions active en même temps
4.052 et pas de soucis sur mes 5 swiidinter
Autre, en attendant une hypothétique fibre chez free
ADSL et fibre ou câble
J'y pense depuis un petit moment pour quand un accès >30 Mbit/s sera dispos dans mon coin.
J'ai juste "vous avez déjàvoté á ce sondage"
Tu couple ta freebox et ta livebox? Qu'utilise tu?
Le cancer des doigts s'est propagé a mon cerveau! Ou alors c'est parce que tu es modérateur (avec des droits en plus)
Bienvenue au club, la mienne est japonaise...
Ca c'est dans les autres choses......
Tu as réservé un petit?
Il est en couple avec @Steven, ils sont occupés à définir le planning d'accès à la HC2 entres autres choses donc plus le temps d'intervenir sur le forum.
Pas eu le cancer des doigts pour lancer la maj cette fois-ci
En cours
Pfffttt! Mais d'un autre coté, c'est quoi la ligne 4.5X? (suis pas le seul à avoir le cancer des doigts )
Me suis planté dans le vote!
