labomatik
    186
Tout ce qui a été posté par labomatik
  1. labomatik
    Fibaro et Qnap
    Attention que là on parte d'un qpkg développé par un partenaire (stéphane) sans aucune interaction avec le système, d'apres ce que j'ai compris du PM pour Fibaro on parle d'une integration profonde (sans doute: caméra, systeme d'alerte, fichiers,...) christophe
  2. labomatik
    Fibaro et Qnap
    Je vais essayer d'avoir plus d'infos via le PM chez QNAP. J'espere pouvoir avoir aussi quelques beta Christophe
  3. labomatik
    Fibaro et Qnap
    Voici ce qui peut etre démontré sur le stand Qnap au cebit, c'est une connexion en local sur le nas
  4. labomatik
    Fibaro et Qnap
    Taipei, Taiwan, March 23, 2017 - QNAP® Systems, Inc. and FIBARO®, one of the fastest-growing companies in the smart home sector and producer of the Internet of Things devices, have joined forces to introduce an optimized smart home solution built on renowned QNAP NAS solutions and FIBARO systems. FIBARO’s contribution means having access to the endless possibilities offered by one of the most innovative smart home systems in the world. It provides a wireless home automation system to create smart homes by using a server and peripheral devices - motion sensors, leak sensors, shutter and lightning controllers, and beyond. As the hub is the heart of the FIBARO system to manage all of the executive devices, QNAP NAS ensures ease-of-use, robust operation, large storage potential, high reliability and security to provide the ideal management center for all the connected FIBARO system features. A setup of QNAP NAS and FIBARO software and technology will allow users to do the following: automatize lighting, heating, and security monitoring. They will also be able to manage shutters and windows as well as flooding and fire alarms, set complex scenes (programmed sequences of actions executed by home devices). They can also play music or videos stored on the NAS for home entertainment, or build an archive server for security footage. The official launch of FIBARO solutions for QNAP NAS is scheduled for 2017. Visitors will have an opportunity to preview the integrated system at QNAP's booth (Hall 2, Stand C63) in CeBIT 2017.
  5. Ahhh je viens de trouver, sous chrome rien dans la liste, sous safari, là j'ai la liste... (l'erreur de chrome:)
  6. Perso j'ai réinstallé tout le lapin, via le reset http://plug.openkarotz.org puis installation de la version 2.0 puis j'applique le firmware 2.1 et là le fameux Web Version : 210 RootFs : Unkown Mais là impossible d'installer un nouveau firmware pour corriger le rootFS comme précisé dans la doc, la liste est vide: @Massalia: une idée?
  7. But what about OpenKarotz? Will it ever speak again? We also found a workaround for this problem: We created a Python script you can use in combination with Voice RSS. Voice RSS is also a Text To Speech service, offering a free plan for a maximum of 350 request per day. On VoiceRss.org, you can create a free account. It will give you a personal API key. You will need this key together with our script to let your Karotz talk using OpenKarotz. Follow these steps: Create an account on http://www.voicerss.org/ Save your Api key. Download http://www.freerabbits.nl/downloads/karotz/tts.zip or download the source from Github. UnZIP the file. Edit it with a textfile editor and replace "your-key-here" with your Api key (line 9, don't remove the quotes) Save the file, don't forget to use Unix line-endings. Upload it to your Karotz to /www/cgi-bin and replace the original file. You can also remove tts.inc now. Test TTS using the webinterface of OpenKarotz. If it doesn't work: enter commands "dos2unix /www/cgi-bin/tts" and "chmod 755 /www/cgi-bin/tts" and try again. Although the quality is not as good as Polly, this might be a solution you can live with. We hope this will help you to let your Karotz talk again. Let us know what you think!
  8. meme chose chez moi pour la conso
  9. Juste un petit point:
  10. labomatik
    Ajouter Un Jeedom Comme Slave
    Voici les infos de Loic: Merci pour la réponse, le primaire est une HC2 sur lequel j'ai activé l'apprentissage Ajouter un contrôleur "secondaire. Y a t'il moyen d'avoir plus d'information sur ce qui pose problème. y a t'il une doc qui explique quel est le bénéfice d'un master et slave, en gros je veux personnellement avoir jeedom= slave et HC2=master mais peut etre vaut il mieux l'inverse... Donc en gros, le zwave master et slave c'est une bonne implementation sauf que tout le monde pointe vers les autres intégrateurs (c'est leur faute) en disant que c'est pas testé et supporté :-(
  11. labomatik
    j'ai ouvert un ticket sur le support ... on va bien voir. Coté Jeedom j'aime bien les intégrations plugins, code scénario mais je prefere HC2 au niveau UI et la partie Zwave
  12. labomatik
    Cmoi20, est ce que tu sais si jeedom est au courant pour le probleme "Créer un nouveau noeud primaire" car je viens d'essayer et aucun lien entre le HC2 et jeedom (ils sont à coté l'un de l'autre) christophe
  13. Bonjour à tous, j'ai la version beta 4.057 sur ma HC2, je souhaiterai ajouter un système jeedom comme esclave et garder HC2 en maitre, avez-vous une idée de comment procéder? Christophe
  14. non j'utilise le thermostat de l'aterno
  15. J'ai finalement rajoute un plug on/off sur la prise From tapatalk.
  16. je vais contacter qnap pour voir si l'api a changé. Christophe
  17. Quel est la version du QTS? christophe
  18. C'est un problème lié àopenkarotz et non au vd. J'ai appliqué ce patch et tout fonctionne http://www.touteladomotique.com/forum/viewtopic.php?f=160&t=11661&start=2127 Envoyé de mon iPhone en utilisant Tapatalk
  19. sur la faq du site: A moins de faire du reverse engineering ça me parait peut probable, le signal est crypté entre la caméra et le recepteur, le recepteur change d'adresse tous les jours et envoie les données au site de ABUS (23.23.185.237) de manière cryptée. Christophe
  20. Bonjour à tous, J'ai une question concernant le module dimmer qubino http://qubino.com/products-2/flushdimmer/ est il possible de lier ce module avec un interrupteur dimmer du type NIko http://www.niko.eu/frfr/niko/produits/variateurs/variateurs_a_encastrer/variateur_a_bouton_rotatif_300w et http://www.niko.eu/frfr/niko/article/310-01301 Si ce n'est pas possible quels sont les alternatives? (un autre module Zwave? un bouton poussoir?) Merci d'avance, Christophe
  21. labomatik
    AH excellent pour le if...
  22. labomatik
    Bon ben voilàaprès quelques essais la ligne qui pose problème , un id incorrect :-( GEA.add(id['DETECTEUR_SALON_ALARME'], 1*30,"", {{"If",{"Global", "DETECTEUR_BAS_PREMIERE_NOTIF", "0"}},{"Global", "Karotz", "Lecture calendrier"}, {"VirtualDevice", 20, 1},{"Global", "DETECTEUR_BAS_PREMIERE_NOTIF", "1"}})
  23. labomatik
    Bon voilà je suis passé à la V5 et depuis: [ERROR] 10:23:26: line 1551: attempt to concatenate local 'name' (a nil value) quelqu'un à une idée
  24. La DB est maintenant du mysql
  25. hormis un plantage tout les jours, une reconfiguration qui cache tous les élements de la satel :-) maintenant ça fonctionne bien, ça fait du bien!! :-) C
