Design
    46
    LYON
    Home Center Lite
1815 visualisations du profil
Design's Achievements
  • Week One Done
  • One Month Later
  • One Year In
Recent Badges
  1. Yesss
  2. Je lance !
  3. Pas de problème pour le moment
  4. Hello regarde dans la configuration au niveau de l’interrogation , la mienne était désactivée. je l’ai mis sur globale et hop c’est revenu
  5. C'est ok pour mon qubino smart meter un intervalle d'interrogation à paramétrer pour les fils pilote je ne sais pas, les miens étaient déjà inclus ...
  6. Idem Ok pour moi, par contre je n'ai plus la mesure instantané sur mon smartmeter qubino je vais fouiller dans les paramètres
  7. Idem en cours update
  8. Bonjour, Liste des modifications logicielles 4.550: Version 4.550 New improvements: - Implemented security fixes for backups. - Optimized and reduced amount of data processed when adding Z-Wave devices. - Optimized and reduced amount of data processed when booting the system. - Optimized communication between services to speed up the operation of the gateway. - Added geofencing events to be used in scenes. - Added possibility of setting radius around the point in localisation panel. - Added notification recommending users to edit scenes based on location to ensure their proper operation in the next version of FIBARO Home Center app. - Optimized response time of scenes setting brightness and colour of the LED ring for FIBARO Walli series. - Optimized Z-Wave locks synchronization process by reducing maximum number of pin codes. - Added possibility of assigning virtual devices to categories to be used in FIBARO Home Center app. - Added possibility of hiding the virtual device. - Added possibility of creating global variables with predefined values. - Changed the time zones display format into more user-friendly. - Added the button in General Configuration for resetting energy data. - Home Center name is automatically set to serial number if empty and may be selected in block scenes. - Added possibility of updating firmware of FIBARO Roller Shutter 2 (requires reconfiguration). - Added support for FIBARO Roller Shutter 2 v26.26. - Added support for FIBARO RGBW Controller v27.27. - Added support for overriding the heating schedule for Danfoss Link Room Sensor. - Added support for Heatit Z-TRM2fx. - Added support for Qubino Smart Meter. - Added support for Qubino 3-Phase Smart Meter. Resolved issues: - The map in location configuration is not displayed correctly and the location cannot be set by entering coordinates. - Gateway in DHCP mode does not automatically establish a connection in case of temporary network shortage. - Parameters cannot be changed for devices without templates. - Setting the decimal separator affects values after the decimal point for temperature sensors. - List of backups does not load correctly. - Specific configuration of sprinklers panel results in no connection with the gateway. - Remote support does not work after losing and restoring the connection to remote access. - FIBARO Walli devices do not properly support all actions available in scenes. - Actions set in the configuration of FIBARO Walli devices are not hidden after changing the value of responsible parameter. - The outputs state of the FIBARO Smart Implant changes automatically after rebooting the gateway. - The inputs state of the FIBARO Smart Implant is always safe after rebooting the gateway. - Leviton devices do not report the status correctly. - CoolMasterNet Universal HVAC Bridge loses configuration after rebooting the gateway. - Remote support is always enabled and does not turn off automatically after 7 days. - Connected gateways lose the connection. - Failed login attempts are counted incorrectly. - Location is not updated when setting in the wizard. - Scene code is not generated properly when setting two or more geofence events. - Devices related to the CoolAutomation plugin are not added to the device list. - Time of overriding the heating schedule for Danfoss thermostats is always set to 2 hours. - Widgets are not available in mobile app. - Users from China cannot set their location. - Other minor fixes.
  9. pour le smartmeter, il me dit que je dois refaire une nouvelle configuration, je l'ai relancé depuis l'interface, rien d'exceptionnel, j'ai juste l'aiguille de la conso qui fonctionne maintenant pour les fil pilote je vais voir apres
  10. Hello Je lance la mise a jour comme j'ai un smart Meter
  11. Bonjour, Et le problème également, en non configuré, c'est que je ne peux pas inclure le module dans une scène..... J'ai 3 anciens qubino fil pilote qui fonctionne sans soucis et là c'est la cata, c'est la catastrophe ^^ Auriez vous une idée ? sur HCL.. Merci
  12. Design
    Foscam FI9853EP
    Oui je m'en étais douté lol mais de toutes façon je n'ai toujours pas d'affichage
  13. Design
    Foscam FI9853EP
    Ok, mais c'est surtout que j'ai l'ipad dans le mur et pour madame c'est quand même plus conviviale d'avoir tout au même endroit..... Bon je pense que je ne suis pas très loin pour y arriver.......
  14. Design
    Foscam FI9853EP
    Bonsoir, Tout d'abord, merci pour vos différentes interventions. J'ai bien un utilisateur fibaro dans ma camera qui est administrateur. Dans le doute je viens de tester avec le compte admin de la camera. le port est bien renseigné. Le résultat est pratiquement le même à la différence que maintenant j'ai un refresh de l'image toutes les 3 secondes. C'est que je pense que çà interroge bien mais le flux vidéo ne remonte pas :/
  15. Design
    Foscam FI9853EP
    Oui, alors j'ai une FI8904 qui fonctionne parfaitement. Le fait que mes autres camera foscam soit HD pose le prolbème pour récupérer le flux de l'image. Ma config : HCL en version 4.130 Foscam sur le réseau en 192.168.0.XX:XXXX pour le port. Pas de problème pour récupérer le flux vidéo par une application tierce comme IpCam. Pour ma HCL, j'ai utilisé le plugins Foscam 8904, impec pour ma 8904. j'ai juste modifé le snapshot. mais pour les HD fi9853EP j'ai testé : cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=fibaro&pwd=password / NOK cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=fibaro&pwd=password / NOK snapshot.cgi?user=fibaro&pwd=password / NOK videostream.cgi?user=fibaro&pwd=password&resolution=32&rate=13 / NOK 192.168.0.XX:XXXX/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=fibaro&pwd=password / NOK http://192.168.0.XX:XXXX/cgi-bin/CGIProxy.fcgi?cmd=setSubStreamFormat&format=1&usr=fibaro&pwd=password / NOK http://192.168.0.XX:XXXX/cgi-bin/CGIProxy.fcgi?usr=fibaro&pwd=password&cmd=setSubStreamFormat&format=1 / NOK rtsp://192.168.0.XX:XXXX/videoMain / NOK rtsp://192.168.0.XX:XXXX/videoSub / NOK Voilà..... dans le plugins generic même résultat...et idem en ajoutant juste une camera.... Merci pour vos idées
