sonnyboy
43 -
Tout ce qui a été posté par sonnyboy
@pepite Thanks for putting me in the right direction again, i can use me old VD for this. I call the VD from Gea and then it works Example code From my VD that turn on the light. fibaro:call(36, "turnOn") fibaro:sleep(math.random(3000,12000)) fibaro:call(266, "turnOn") fibaro:wakeUpDeadDevice(274) -- Wake up if dead fibaro:sleep(math.random(5000,14000)) fibaro:call(274, "setValue", "99") fibaro:sleep(math.random(6000,15000)) fibaro:call(300, "turnOn")
- 12 410 réponses
@pepite, I wanted it Between each light turned on
- 12 410 réponses
Hello is there any possibility to have like this in GEA (math.random(6000,15000)) i would like to have some time between the lights when they turn on. GEA.add({"Global-", "Sun", "1.0"}, 30, "", {{"Time", "05:30", "12:50"}, {"Days", "Weekday"}, {"turnOn", LivingRoom["Bakom_Soffa"]}, {"turnOn", LivingRoom["Bakom_Tv"]}, {"turnOn", Kitchen["Window"]}})
- 12 410 réponses
@pepite You just made my mornig bright And i will have a happy wife Tank you!
- 12 410 réponses
Bonsoir Will this work tomorrow morning around 05:30 if my global Sun is less than 1? GEA.add({"Global-", "Sun", "1.0"}, 30, "", {{"Time", "05:30", "12:50"}, {"Days", "Weekdays"},{"turnOn", LivingRoom["Bakom_Soffa"]}}) GEA.add({"Global-", "Sun", "1.0"}, 30, "", {{"Time", "05:30", "12:50"}, {"Days", "Weekdays"},{"turnOn", LivingRoom["Bakom_Tv"]}}) GEA.add({"Global-", "Sun", "1.0"}, 30, "", {{"Time", "05:30", "12:50"}, {"Days", "Weekdays"},{"turnOn", Kitchen["Window"]}})
- 12 410 réponses
@Steven Thank so Much for this
- 12 410 réponses
Yes @pepite That is exactly what i want to do, is it possible? I just love GEA lets get all in it
- 12 410 réponses
EN Now i will write in En My France is not so good and when i use google translate my sentens doesent look good Is if possible to get random lighting? i post my lua that i have for this, i want diffrent lights that turns on first every night. just to foll the thieves local deviceIDs = { 248, 250, 252, 269, 45, 189 } math.randomseed(os.time()) function randomOrder(table) local new = {} for j,x in pairs(table) do new[j] = x end local res = {} while (#new > #res) do local index = math.random(1,#new) if (new[index] > -1) then res[#res+1] = new[index] new[index] = -1 end end return res end for Device,device in pairs(randomOrder(deviceIDs)) do local lightstatus=tonumber(fibaro:getValue(device, "value")); fibaro:debug(lightstatus) if (lightstatus==0) then fibaro:call(device, "turnOn") end fibaro:debug( Device .. " DeviceID: "..device) fibaro:sleep(math.random(5000,12000)) fibaro:call(20, "pressButton", "4")--Endast för VD end
- 12 410 réponses
@971jmd Merci beaucoup, maintenant je l'ai eu, c'était un peu plus dans le code, mais ça marche maintenant GEA.add(SENSORS["Wc"], -1, "", {{"Time", "22:31", "05:00"}, {"Value", Wc["Tak"], 30}})
- 12 410 réponses
Quelqu'un peut-il m'aider avec ça, ça ne marche pas. C'est pour ma lumière de nuit dans le Wc GEA.add(SENSORS["Wc"], -1, "", {{"Time", "22:31", "05:00"}, {"Value", 30}, Wc["Tak"]}})
- 12 410 réponses
L'aide que je reçois de @pepite travaillé, merci donc mutch Mais est-il une manière je peux obtenir ceci seulement à courir entre 13:00 et 18:50 GEA.add({"Global-", "Sun", "1.3"}, 30, "", {{"VirtualDevice", 193, 1}}) Edit: Je l'ai résolu moi-même cette fois GEA.add({"Global-", "Sun", "1.3"}, 30, "", {{"Time", "13:00", "18:50"}, {"VirtualDevice", 193, 1}})
- 12 410 réponses
@pepite Thanks will trie that when i got help from fibaro, got error 503 after i tried to update
- 12 410 réponses
Bonjour, je viens de commencer avec GEA et il va très bien, mais j'avoir un problème, je veux utiliser ma variable "soleil" global pour allumer et éteindre les lumières. Je veux que les lumières sont en place et fonctionne aussi longtemps que le "Sun" est plus petite île de 0,7. "Sun est récupéré toutes les 5 minutes. Cela ne fonctionne pas, vous voulez que quelqu'un me aider? pardonnez mon français GEA.add(true, 300, "", {{"Global", "Sun", ">0.7"}}, -1, "",{{"turnOn", id["Farstukvist"]}})
- 12 410 réponses
Fonctionne très bien pour moi sur W10 64 bits
- 478 réponses
- tuto hc2 et hcl
- toolkit
- (et 4 en plus)
sonnyboy a répondu à un(e) sujet de Krikroff dans Plugins Developpeur
Cela aurait été traitée avant, mais je couru avec capteur Virtual Senso àjour àla dernière version bêta, lorsque je reçus seulement 503, il n'y a pas moyen de passer cette commande sans une reprise? Ça marche si vous désinstallez le plugin avant de vous mettre àjour? Google Translate m'a aidé àécrire en français. // Sonny- 932 réponses
- Plugin
- Virtual Sensor
Qu'est-ce un plugin merveilleux. Maintenant, je peux utiliser mes périphériques 433 MHz pour de vrai nouveau Est-il possible d'obtenir mm de pluie au lieu de pouces? En Suède, nous utilisons mm de pluie- 932 réponses
- Plugin
- Virtual Sensor
